[U-Boot] [PATCH v3 1/5] sunxi: R40: add gigabit ethernet clocks
Add clock control entries for the gigabit interface of the Allwinner R40/V40 CPU
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index d35aa479f7..3ea473c302 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -61,7 +61,11 @@ struct sunxi_ccm_reg { u32 reserved11; u32 sata_clk_cfg; /* 0xc8 SATA clock control (R40 only) */ u32 usb_clk_cfg; /* 0xcc USB clock control */ - u32 gmac_clk_cfg; /* 0xd0 GMAC clock control */ +#ifdef CONFIG_MACH_SUN8I_R40 + u32 cir0_clk_cfg; /* 0xd0 CIR0 clock control (R40 only) */ +#else + u32 gmac_clk_cfg; /* 0xd0 GMAC clock control (not for R40) */ +#endif u32 reserved12[7]; u32 mdfs_clk_cfg; /* 0xf0 MDFS clock control */ u32 dram_clk_cfg; /* 0xf4 DRAM configuration clock control */ @@ -104,7 +108,11 @@ struct sunxi_ccm_reg { u32 mtc_clk_cfg; /* 0x158 MTC module clock */ u32 mbus0_clk_cfg; /* 0x15c MBUS0 module clock */ u32 mbus1_clk_cfg; /* 0x160 MBUS1 module clock */ +#ifdef CONFIG_MACH_SUN8I_R40 + u32 gmac_clk_cfg; /* 0x164 GMAC clock control (R40 only) */ +#else u32 reserved16; +#endif u32 mipi_dsi_clk_cfg; /* 0x168 MIPI DSI clock control */ u32 mipi_csi_clk_cfg; /* 0x16c MIPI CSI clock control */ u32 reserved17[4];
Add support for the GMAC found in the Allwinner R40/V40 SoC.
The R40 GMAC interface is not controlled by the syscon register but has a separate configuration register in the CCU. The clock gate and reset bits are in a different register compared to the other SoCs supported by this driver. The diver uses the -gmac suffix for the R40 because the R40 also has a different 100 MBit MAC (EMAC).
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- drivers/net/sun8i_emac.c | 69 +++++++++++++++++++++++++++++++++--------------- 1 file changed, 47 insertions(+), 22 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index b6e5dafe83..83844a1d40 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -68,6 +68,8 @@
#if defined(CONFIG_MACH_SUNXI_H3_H5) #define SUN8I_GPD8_GMAC 2 +#elif defined(CONFIG_MACH_SUN8I_R40) +#define SUN8I_GPD8_GMAC 5 #else #define SUN8I_GPD8_GMAC 4 #endif @@ -99,6 +101,7 @@ DECLARE_GLOBAL_DATA_PTR; enum emac_variant { A83T_EMAC = 1, H3_EMAC, + R40_GMAC, A64_EMAC, };
@@ -279,6 +282,9 @@ static int sun8i_emac_set_syscon(struct emac_eth_dev *priv) int ret; u32 reg;
+ if (priv->variant == R40_GMAC) + return 0; + reg = readl(priv->sysctl_reg + 0x30);
if (priv->variant == H3_EMAC) { @@ -630,11 +636,25 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) } #endif
+#ifdef CONFIG_MACH_SUN8I_R40 + /* Set clock gating for emac */ + setbits_le32(&ccm->ahb_reset1_cfg, BIT(AHB_RESET_OFFSET_GMAC)); + + /* De-assert EMAC */ + setbits_le32(&ccm->ahb_gate1, BIT(AHB_GATE_OFFSET_GMAC)); + + /* Select RGMII for R40 */ + setbits_le32(&ccm->gmac_clk_cfg, CCM_GMAC_CTRL_TX_CLK_SRC_INT_RGMII | + CCM_GMAC_CTRL_GPIT_RGMII); + setbits_le32(&ccm->gmac_clk_cfg, + CCM_GMAC_CTRL_TX_CLK_DELAY(CONFIG_GMAC_TX_DELAY)); +#else /* Set clock gating for emac */ setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC));
/* De-assert EMAC */ setbits_le32(&ccm->ahb_reset0_cfg, BIT(AHB_RESET_OFFSET_GMAC)); +#endif }
#if defined(CONFIG_DM_GPIO) @@ -801,22 +821,33 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) return -EINVAL; }
- offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); - if (offset < 0) { - debug("%s: cannot find syscon node\n", __func__); - return -EINVAL; - } - reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); - if (!reg) { - debug("%s: cannot find reg property in syscon node\n", - __func__); + priv->variant = dev_get_driver_data(dev); + + if (!priv->variant) { + printf("%s: Missing variant '%s'\n", __func__, + (char *)priv->variant); return -EINVAL; } - priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, - offset, reg); - if (priv->sysctl_reg == FDT_ADDR_T_NONE) { - debug("%s: Cannot find syscon base address\n", __func__); - return -EINVAL; + + if (priv->variant != R40_GMAC) { + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); + if (offset < 0) { + debug("%s: cannot find syscon node\n", __func__); + return -EINVAL; + } + reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); + if (!reg) { + debug("%s: cannot find reg property in syscon node\n", + __func__); + return -EINVAL; + } + priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, + offset, reg); + if (priv->sysctl_reg == FDT_ADDR_T_NONE) { + debug("%s: Cannot find syscon base address\n", + __func__); + return -EINVAL; + } }
pdata->phy_interface = -1; @@ -841,14 +872,6 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) return -EINVAL; }
- priv->variant = dev_get_driver_data(dev); - - if (!priv->variant) { - printf("%s: Missing variant '%s'\n", __func__, - (char *)priv->variant); - return -EINVAL; - } - if (priv->variant == H3_EMAC) { int parent = fdt_parent_offset(gd->fdt_blob, offset);
@@ -885,6 +908,8 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev)
static const struct udevice_id sun8i_emac_eth_ids[] = { {.compatible = "allwinner,sun8i-h3-emac", .data = (uintptr_t)H3_EMAC }, + {.compatible = "allwinner,sun8i-r40-gmac", + .data = (uintptr_t)R40_GMAC }, {.compatible = "allwinner,sun50i-a64-emac", .data = (uintptr_t)A64_EMAC }, {.compatible = "allwinner,sun8i-a83t-emac",
On Mon, Apr 23, 2018 at 8:27 PM, Lothar Felten lothar.felten@gmail.com wrote:
Can be done through driver_data?
R40_GMAC, A64_EMAC,
reg = readl(priv->sysctl_reg + 0x30); if (priv->variant == H3_EMAC) {
+#else
Can be done through driver_data variant?
Jagan.
On Mon, Apr 23, 2018 at 9:57 AM, Lothar Felten lothar.felten@gmail.com wrote:
diver -> driver
R40_GMAC,
It probably make sense to not insert this in the list... please put it at the end.
A64_EMAC,
This should check variant instead of using a CPP guard.
+#endif }
if (offset < 0) {
return -EINVAL;
if (!reg) {
__func__);
This makes no sense. The if statement above verified that the value was 0. You shouldn't cast that to a char * and try to print NULL.
return -EINVAL; }
offset, reg);
return -EINVAL;
if (offset < 0) {
return -EINVAL;
if (!reg) {
__func__);
return -EINVAL;
offset, reg);
__func__);
return -EINVAL;
} } pdata->phy_interface = -1;
Ah, you are just moving this from here... Please add a patch before this one that fixes this.
return -EINVAL;
-- 2.14.1
Add gpio mux settings for the Allwinner R40/V40 CPU. The gigabit ethernet interface can only be routed to a fixed set of pins.
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- arch/arm/dts/sun8i-r40.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index 48ec2e855a..ee22f6eb3a 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -126,6 +126,15 @@ #interrupt-cells = <3>; #gpio-cells = <3>;
+ gmac_pins_rgmii: gmac_rgmii { + pins = "PA0", "PA1", "PA2", + "PA3", "PA4", "PA5", "PA6", + "PA7", "PA8", "PA10", + "PA11", "PA12", "PA13", + "PA15", "PA16"; + function = "gmac"; + }; + i2c0_pins: i2c0_pins { pins = "PB0", "PB1"; function = "i2c0";
Add a device tree node for the Allwinner R40/V40 GMAC gigabit ethernet interface. The R40 SoC does not use the syscon register for GMAC settings.
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- arch/arm/dts/sun8i-r40.dtsi | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index ee22f6eb3a..b46fcbb0b9 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -168,6 +168,27 @@ #size-cells = <0>; };
+ gmac: ethernet@01c50000 { + compatible = "allwinner,sun8i-r40-gmac"; + reg = <0x01c50000 0x2000>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&osc24M>, <&osc24M>; + clock-names = "stmmaceth", "allwinner_gmac_tx"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii>; + phy-mode = "rgmii"; + status = "disabled"; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + }; + gic: interrupt-controller@1c81000 { compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; reg = <0x01c81000 0x1000>,
#size-cells = <0>;
phy-mode = "rgmii";
If that's going to be overwritten in the DTS, maybe we should just drop it from the DTSI.
The rest of the serie looks good to me, however, it is a best practice to have a changelog either in the cover letter (if you have one) or in the patches themselves so that reviewer know what changed between the two versions.
Thanks! Maxime
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Enable the gigabit ethernet for the Bananapi M2 Ultra board. Tested on BananaPi M2 Berry (R40), custom board (V40)
Signed-off-by: Lothar Felten lothar.felten@gmail.com --- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 14 ++++++++++++++ configs/Bananapi_M2_Ultra_defconfig | 3 +++ 2 files changed, 17 insertions(+)
diff --git a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts index ab471ab0bf..25f2112fbf 100644 --- a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts +++ b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts @@ -67,3 +67,17 @@ pinctrl-0 = <&uart0_pb_pins>; status = "okay"; }; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_rgmii>; + status = "okay"; + phy-handle = <&rgmii_phy>; +}; + +&mdio { + rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 37cc2df5dc..b550dc052d 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -17,3 +17,6 @@ CONFIG_AXP_DLDO4_VOLT=2500 CONFIG_AXP_ELDO3_VOLT=1200 CONFIG_SCSI=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_SUN8I_EMAC=y +CONFIG_RGMII=y +CONFIG_MACPWR="PA17"
You dropped Maxime's Acks when you sent the v3. You need to include any acks or reviews you already got in the new version unless the patch is substantially different.
You should use tools/patman/patman and indicate any changes using the "Series-changes: n" tags.
+#else
+#else u32 reserved16; +#endif u32 mipi_dsi_clk_cfg; /* 0x168 MIPI DSI clock control */ u32 mipi_csi_clk_cfg; /* 0x16c MIPI CSI clock control */ u32 reserved17[4]; -- 2.14.1
Jagan Teki
Joe Hershberger
Lothar Felten
Maxime Ripard
