[U-Boot] [PATCH v2 1/7] sunxi: gpio: Indentation fix
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/include/asm/arch-sunxi/gpio.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index f2c247d..a66e45c 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -84,7 +84,7 @@ struct sunxi_gpio_reg { #define GPIO_CFG_INDEX(pin) (((pin) & 0x1f) >> 3) #define GPIO_CFG_OFFSET(pin) ((((pin) & 0x1f) & 0x7) << 2)
-#define GPIO_DRV_INDEX(pin) (((pin) & 0x1f) >> 4) +#define GPIO_DRV_INDEX(pin) (((pin) & 0x1f) >> 4) #define GPIO_DRV_OFFSET(pin) ((((pin) & 0x1f) & 0xf) << 1)
#define GPIO_PULL_INDEX(pin) (((pin) & 0x1f) >> 4) @@ -194,7 +194,7 @@ enum sunxi_gpio_number { #define SUN8I_GPL3_R_UART_RX 2
#define SUN9I_GPN0_R_RSB_SCK 3 -#define SUN9I_GPN1_R_RSB_SDA 3 +#define SUN9I_GPN1_R_RSB_SDA 3
/* GPIO pin pull-up/down config */ #define SUNXI_GPIO_PULL_DISABLE 0
This converts the VBUS detection and enable logic to GPIO instead of separate axp functions and checks that have to be used aside usual GPIO functions.
Signed-off-by: Hans de Goede hdegoede@redhat.com Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/include/asm/arch-sunxi/gpio.h | 4 ++ drivers/gpio/sunxi_gpio.c | 6 +++ drivers/power/axp221.c | 75 ++++++++++++++++++++-------------- include/axp221.h | 14 +++---- 4 files changed, 60 insertions(+), 39 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index a66e45c..3a4b8c3 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -201,6 +201,10 @@ enum sunxi_gpio_number { #define SUNXI_GPIO_PULL_UP 1 #define SUNXI_GPIO_PULL_DOWN 2
+/* Virtual AXP0 GPIOs */ +#define SUNXI_GPIO_AXP0_VBUS_DETECT 8 +#define SUNXI_GPIO_AXP0_VBUS_ENABLE 9 + void sunxi_gpio_set_cfgbank(struct sunxi_gpio *pio, int bank_offset, u32 val); void sunxi_gpio_set_cfgpin(u32 pin, u32 val); int sunxi_gpio_get_cfgbank(struct sunxi_gpio *pio, int bank_offset); diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index 6296092..c66aa51 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -125,6 +125,12 @@ int sunxi_name_to_gpio(const char *name) #ifdef AXP_GPIO if (strncasecmp(name, "AXP0-", 5) == 0) { name += 5; + if (strcmp(name, "VBUS-DETECT") == 0) + return SUNXI_GPIO_AXP0_START + + SUNXI_GPIO_AXP0_VBUS_DETECT; + if (strcmp(name, "VBUS-ENABLE") == 0) + return SUNXI_GPIO_AXP0_START + + SUNXI_GPIO_AXP0_VBUS_ENABLE; pin = simple_strtol(name, &eptr, 10); if (!*name || *eptr) return -1; diff --git a/drivers/power/axp221.c b/drivers/power/axp221.c index c2c3988..f758a75 100644 --- a/drivers/power/axp221.c +++ b/drivers/power/axp221.c @@ -14,6 +14,7 @@ #include <errno.h> #include <asm/arch/p2wi.h> #include <asm/arch/rsb.h> +#include <asm/arch/gpio.h> #include <axp221.h>
/* @@ -385,54 +386,66 @@ int axp221_get_sid(unsigned int *sid) return 0; }
-int axp_get_vbus(void) +int axp_gpio_direction_input(unsigned int pin) { - int ret; - u8 val; - - ret = axp221_init(); - if (ret) - return ret; - - ret = pmic_bus_read(AXP221_POWER_STATUS, &val); - if (ret) - return ret; - - return (val & AXP221_POWER_STATUS_VBUS_USABLE) ? 1 : 0; + switch (pin) { + case SUNXI_GPIO_AXP0_VBUS_DETECT: + return 0; + default: + return -EINVAL; + } }
-static int axp_drivebus_setup(void) +int axp_gpio_direction_output(unsigned int pin, unsigned int val) { int ret;
- ret = axp221_init(); - if (ret) - return ret; + switch (pin) { + case SUNXI_GPIO_AXP0_VBUS_ENABLE: + ret = axp221_clrbits(AXP221_MISC_CTRL, + AXP221_MISC_CTRL_N_VBUSEN_FUNC); + if (ret) + return ret;
- /* Set N_VBUSEN pin to output / DRIVEBUS function */ - return axp221_clrbits(AXP221_MISC_CTRL, AXP221_MISC_CTRL_N_VBUSEN_FUNC); + return axp_gpio_set_value(pin, val); + default: + return -EINVAL; + } }
-int axp_drivebus_enable(void) +int axp_gpio_get_value(unsigned int pin) { int ret; + u8 val;
- ret = axp_drivebus_setup(); - if (ret) - return ret; + switch (pin) { + case SUNXI_GPIO_AXP0_VBUS_DETECT: + ret = pmic_bus_read(AXP221_POWER_STATUS, &val); + if (ret) + return ret;
- /* Set DRIVEBUS high */ - return axp221_setbits(AXP221_VBUS_IPSOUT, AXP221_VBUS_IPSOUT_DRIVEBUS); + return !!(val & AXP221_POWER_STATUS_VBUS_USABLE); + default: + return -EINVAL; + } }
-int axp_drivebus_disable(void) +int axp_gpio_set_value(unsigned int pin, unsigned int val) { int ret;
- ret = axp_drivebus_setup(); - if (ret) - return ret; + switch (pin) { + case SUNXI_GPIO_AXP0_VBUS_ENABLE: + if (val) + ret = axp221_setbits(AXP221_VBUS_IPSOUT, + AXP221_VBUS_IPSOUT_DRIVEBUS); + else + ret = axp221_clrbits(AXP221_VBUS_IPSOUT, + AXP221_VBUS_IPSOUT_DRIVEBUS);
- /* Set DRIVEBUS low */ - return axp221_clrbits(AXP221_VBUS_IPSOUT, AXP221_VBUS_IPSOUT_DRIVEBUS); + if (ret) + return ret; + } + + return 0; } diff --git a/include/axp221.h b/include/axp221.h index be6058e..0aac04d 100644 --- a/include/axp221.h +++ b/include/axp221.h @@ -62,11 +62,7 @@ /* Page 1 addresses */ #define AXP221_SID 0x20
-/* We support vbus detection */ -#define AXP_VBUS_DETECT - -/* We support drivebus control */ -#define AXP_DRIVEBUS +#define AXP_GPIO
int axp221_set_dcdc1(unsigned int mvolt); int axp221_set_dcdc2(unsigned int mvolt); @@ -83,6 +79,8 @@ int axp221_set_aldo3(unsigned int mvolt); int axp221_set_eldo(int eldo_num, unsigned int mvolt); int axp221_init(void); int axp221_get_sid(unsigned int *sid); -int axp_get_vbus(void); -int axp_drivebus_enable(void); -int axp_drivebus_disable(void); + +int axp_gpio_direction_input(unsigned int pin); +int axp_gpio_direction_output(unsigned int pin, unsigned int val); +int axp_gpio_get_value(unsigned int pin); +int axp_gpio_set_value(unsigned int pin, unsigned int val);
VBUS detection and enable is now be used with virtual AXP GPIOs, so all the USB code has to use GPIO in every case and let sunxi_gpio do the heavy lifting.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/sunxi/usbc.c | 17 --------------- configs/Ippo_q8h_v1_2_defconfig | 4 ++-- configs/Ippo_q8h_v5_defconfig | 4 ++-- drivers/usb/musb-new/sunxi.c | 48 ++++++++++++++++------------------------- 4 files changed, 23 insertions(+), 50 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/usbc.c b/arch/arm/cpu/armv7/sunxi/usbc.c index 14de9f9..4d8a9a1 100644 --- a/arch/arm/cpu/armv7/sunxi/usbc.c +++ b/arch/arm/cpu/armv7/sunxi/usbc.c @@ -80,12 +80,6 @@ static struct sunxi_usbc_hcd {
static int enabled_hcd_count;
-static bool use_axp_drivebus(int index) -{ - return index == 0 && - strcmp(CONFIG_USB0_VBUS_PIN, "axp_drivebus") == 0; -} - void *sunxi_usbc_get_io_base(int index) { switch (index) { @@ -102,9 +96,6 @@ void *sunxi_usbc_get_io_base(int index)
static int get_vbus_gpio(int index) { - if (use_axp_drivebus(index)) - return -1; - switch (index) { case 0: return sunxi_name_to_gpio(CONFIG_USB0_VBUS_PIN); case 1: return sunxi_name_to_gpio(CONFIG_USB1_VBUS_PIN); @@ -251,10 +242,6 @@ void sunxi_usbc_vbus_enable(int index) { struct sunxi_usbc_hcd *sunxi_usbc = &sunxi_usbc_hcd[index];
-#ifdef AXP_DRIVEBUS - if (use_axp_drivebus(index)) - axp_drivebus_enable(); -#endif if (sunxi_usbc->gpio_vbus != -1) gpio_direction_output(sunxi_usbc->gpio_vbus, 1); } @@ -263,10 +250,6 @@ void sunxi_usbc_vbus_disable(int index) { struct sunxi_usbc_hcd *sunxi_usbc = &sunxi_usbc_hcd[index];
-#ifdef AXP_DRIVEBUS - if (use_axp_drivebus(index)) - axp_drivebus_disable(); -#endif if (sunxi_usbc->gpio_vbus != -1) gpio_direction_output(sunxi_usbc->gpio_vbus, 0); } diff --git a/configs/Ippo_q8h_v1_2_defconfig b/configs/Ippo_q8h_v1_2_defconfig index 0c88edd..e003b4c 100644 --- a/configs/Ippo_q8h_v1_2_defconfig +++ b/configs/Ippo_q8h_v1_2_defconfig @@ -2,8 +2,8 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_FDTFILE="sun8i-a23-ippo-q8h-v1.2.dtb" CONFIG_USB_MUSB_SUNXI=y -CONFIG_USB0_VBUS_PIN="axp_drivebus" -CONFIG_USB0_VBUS_DET="axp_vbus_detect" +CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:167,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" diff --git a/configs/Ippo_q8h_v5_defconfig b/configs/Ippo_q8h_v5_defconfig index 16ba03b..87d898e 100644 --- a/configs/Ippo_q8h_v5_defconfig +++ b/configs/Ippo_q8h_v5_defconfig @@ -2,8 +2,8 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_FDTFILE="sun8i-a23-ippo-q8h-v5.dtb" CONFIG_USB_MUSB_SUNXI=y -CONFIG_USB0_VBUS_PIN="axp_drivebus" -CONFIG_USB0_VBUS_DET="axp_vbus_detect" +CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:168,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_POWER="PH7" diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 90aaec6..8049944 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -238,38 +238,28 @@ static int sunxi_musb_init(struct musb *musb) if (is_host_enabled(musb)) { int vbus_det = sunxi_name_to_gpio(CONFIG_USB0_VBUS_DET);
-#ifdef AXP_VBUS_DETECT - if (!strcmp(CONFIG_USB0_VBUS_DET, "axp_vbus_detect")) { - err = axp_get_vbus(); - if (err < 0) - return err; - } else { -#endif - if (vbus_det == -1) { - eprintf("Error invalid Vusb-det pin\n"); - return -EINVAL; - } - - err = gpio_request(vbus_det, "vbus0_det"); - if (err) - return err; - - err = gpio_direction_input(vbus_det); - if (err) { - gpio_free(vbus_det); - return err; - } - - err = gpio_get_value(vbus_det); - if (err < 0) { - gpio_free(vbus_det); - return -EIO; - } + if (vbus_det == -1) { + eprintf("Error invalid Vusb-det pin\n"); + return -EINVAL; + } + + err = gpio_request(vbus_det, "vbus0_det"); + if (err) + return err;
+ err = gpio_direction_input(vbus_det); + if (err) { gpio_free(vbus_det); -#ifdef AXP_VBUS_DETECT + return err; } -#endif + + err = gpio_get_value(vbus_det); + if (err < 0) { + gpio_free(vbus_det); + return -EIO; + } + + gpio_free(vbus_det);
if (err) { eprintf("Error: A charger is plugged into the OTG\n");
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- drivers/power/axp209.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/power/axp209.c b/drivers/power/axp209.c index 4565398..e1cbba9 100644 --- a/drivers/power/axp209.c +++ b/drivers/power/axp209.c @@ -7,6 +7,7 @@
#include <common.h> #include <i2c.h> +#include <asm/arch/gpio.h> #include <axp209.h>
enum axp209_reg { @@ -31,6 +32,7 @@ enum axp209_reg { };
#define AXP209_POWER_STATUS_ON_BY_DC (1 << 0) +#define AXP209_POWER_STATUS_VBUS_USABLE (1 << 4)
#define AXP209_IRQ5_PEK_UP (1 << 6) #define AXP209_IRQ5_PEK_DOWN (1 << 5) @@ -205,6 +207,9 @@ static u8 axp209_get_gpio_ctrl_reg(unsigned int pin)
int axp_gpio_direction_input(unsigned int pin) { + if (pin == SUNXI_GPIO_AXP0_VBUS_DETECT) + return 0; + u8 reg = axp209_get_gpio_ctrl_reg(pin); /* GPIO3 is "special" */ u8 val = (pin == 3) ? AXP209_GPIO3_INPUT : AXP209_GPIO_INPUT; @@ -232,7 +237,10 @@ int axp_gpio_get_value(unsigned int pin) u8 val, mask; int rc;
- if (pin == 3) { + if (pin == SUNXI_GPIO_AXP0_VBUS_DETECT) { + rc = axp209_read(AXP209_POWER_STATUS, &val); + mask = AXP209_POWER_STATUS_VBUS_USABLE; + } else if (pin == 3) { rc = axp209_read(AXP209_GPIO3_CTRL, &val); mask = 1; } else {
VBUS detection could be needed not only by the musb code (to prevent host mode), but also by e.g. gadget drivers to start only when a cable is connected.
In addition, this allows more flexibility in vbus detection, as it could easily be extended to other USBC indexes. Eventually, this would help making musb support independent from a hardcoded USB controller index (0).
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/sunxi/usbc.c | 47 +++++++++++++++++++++++++++++++--- arch/arm/include/asm/arch-sunxi/usbc.h | 1 + board/sunxi/Kconfig | 1 - drivers/usb/musb-new/sunxi.c | 35 +++++-------------------- 4 files changed, 50 insertions(+), 34 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/usbc.c b/arch/arm/cpu/armv7/sunxi/usbc.c index 4d8a9a1..d2c6f23 100644 --- a/arch/arm/cpu/armv7/sunxi/usbc.c +++ b/arch/arm/cpu/armv7/sunxi/usbc.c @@ -41,6 +41,7 @@ static struct sunxi_usbc_hcd { int usb_rst_mask; int ahb_clk_mask; int gpio_vbus; + int gpio_vbus_det; int irq; int id; } sunxi_usbc_hcd[] = { @@ -104,6 +105,14 @@ static int get_vbus_gpio(int index) return -1; }
+static int get_vbus_detect_gpio(int index) +{ + switch (index) { + case 0: return sunxi_name_to_gpio(CONFIG_USB0_VBUS_DET); + } + return -1; +} + static void usb_phy_write(struct sunxi_usbc_hcd *sunxi_usbc, int addr, int data, int len) { @@ -176,22 +185,31 @@ static void sunxi_usb_passby(struct sunxi_usbc_hcd *sunxi_usbc, int enable) int sunxi_usbc_request_resources(int index) { struct sunxi_usbc_hcd *sunxi_usbc = &sunxi_usbc_hcd[index]; + int ret = 0;
sunxi_usbc->gpio_vbus = get_vbus_gpio(index); if (sunxi_usbc->gpio_vbus != -1) - return gpio_request(sunxi_usbc->gpio_vbus, "usbc_vbus"); + ret |= gpio_request(sunxi_usbc->gpio_vbus, "usbc_vbus"); + + sunxi_usbc->gpio_vbus_det = get_vbus_detect_gpio(index); + if (sunxi_usbc->gpio_vbus_det != -1) + ret |= gpio_request(sunxi_usbc->gpio_vbus_det, "usbc_vbus_det");
- return 0; + return ret; }
int sunxi_usbc_free_resources(int index) { struct sunxi_usbc_hcd *sunxi_usbc = &sunxi_usbc_hcd[index]; + int ret = 0;
if (sunxi_usbc->gpio_vbus != -1) - return gpio_free(sunxi_usbc->gpio_vbus); + ret |= gpio_free(sunxi_usbc->gpio_vbus);
- return 0; + if (sunxi_usbc->gpio_vbus_det != -1) + ret |= gpio_free(sunxi_usbc->gpio_vbus_det); + + return ret; }
void sunxi_usbc_enable(int index) @@ -253,3 +271,24 @@ void sunxi_usbc_vbus_disable(int index) if (sunxi_usbc->gpio_vbus != -1) gpio_direction_output(sunxi_usbc->gpio_vbus, 0); } + +int sunxi_usbc_vbus_detect(int index) +{ + struct sunxi_usbc_hcd *sunxi_usbc = &sunxi_usbc_hcd[index]; + int err; + + if (sunxi_usbc->gpio_vbus_det == -1) { + eprintf("Error: invalid vbus detection pin\n"); + return -1; + } + + err = gpio_direction_input(sunxi_usbc->gpio_vbus_det); + if (err) + return err; + + err = gpio_get_value(sunxi_usbc->gpio_vbus_det); + if (err < 0) + return err; + + return err; +} diff --git a/arch/arm/include/asm/arch-sunxi/usbc.h b/arch/arm/include/asm/arch-sunxi/usbc.h index cb538cd..67281ec 100644 --- a/arch/arm/include/asm/arch-sunxi/usbc.h +++ b/arch/arm/include/asm/arch-sunxi/usbc.h @@ -20,3 +20,4 @@ void sunxi_usbc_enable(int index); void sunxi_usbc_disable(int index); void sunxi_usbc_vbus_enable(int index); void sunxi_usbc_vbus_disable(int index); +int sunxi_usbc_vbus_detect(int index); diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 9d0eb91..5639321 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -225,7 +225,6 @@ config USB0_VBUS_PIN
config USB0_VBUS_DET string "Vbus detect pin for usb0 (otg)" - depends on USB_MUSB_SUNXI default "" ---help--- Set the Vbus detect pin for usb0 (otg). This takes a string in the diff --git a/drivers/usb/musb-new/sunxi.c b/drivers/usb/musb-new/sunxi.c index 8049944..c9a6a16 100644 --- a/drivers/usb/musb-new/sunxi.c +++ b/drivers/usb/musb-new/sunxi.c @@ -235,42 +235,19 @@ static int sunxi_musb_init(struct musb *musb)
pr_debug("%s():\n", __func__);
- if (is_host_enabled(musb)) { - int vbus_det = sunxi_name_to_gpio(CONFIG_USB0_VBUS_DET); - - if (vbus_det == -1) { - eprintf("Error invalid Vusb-det pin\n"); - return -EINVAL; - } - - err = gpio_request(vbus_det, "vbus0_det"); - if (err) - return err; - - err = gpio_direction_input(vbus_det); - if (err) { - gpio_free(vbus_det); - return err; - } - - err = gpio_get_value(vbus_det); - if (err < 0) { - gpio_free(vbus_det); - return -EIO; - } - - gpio_free(vbus_det); + err = sunxi_usbc_request_resources(0); + if (err) + return err;
+ if (is_host_enabled(musb)) { + err = sunxi_usbc_vbus_detect(0); if (err) { eprintf("Error: A charger is plugged into the OTG\n"); + sunxi_usbc_free_resources(0); return -EIO; } }
- err = sunxi_usbc_request_resources(0); - if (err) - return err; - musb->isr = sunxi_musb_interrupt; sunxi_usbc_enable(0);
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/board.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index e1891d1..becdc8b 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -241,6 +241,13 @@ static struct musb_hdrc_platform_data musb_plat = { }; #endif
+#ifdef CONFIG_USB_GADGET +int g_dnl_board_usb_cable_connected(void) +{ + return sunxi_usbc_vbus_detect(0); +} +#endif + #ifdef CONFIG_MISC_INIT_R int misc_init_r(void) {
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/sunxi/MAINTAINERS | 5 +++++ configs/Ainol_AW1_defconfig | 16 ++++++++++++++++ 2 files changed, 21 insertions(+) create mode 100644 configs/Ainol_AW1_defconfig
diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index ef3c937..e486458 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -50,6 +50,11 @@ S: Maintained F: board/sunxi/dram_a20_olinuxino_l2.c F: configs/A20-OLinuXino-Lime2_defconfig
+AINOL AW1 BOARD +M: Paul Kocialkowski contact@paulk.fr +S: Maintained +F: configs/Ainol_AW1_defconfig + AMPE A76 BOARD M: Paul Kocialkowski contact@paulk.fr S: Maintained diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig new file mode 100644 index 0000000..1c3b942 --- /dev/null +++ b/configs/Ainol_AW1_defconfig @@ -0,0 +1,16 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" +CONFIG_FDTFILE="sun7i-a20-ainol-aw1.dtb" +CONFIG_USB_MUSB_SUNXI=y +CONFIG_USB0_VBUS_PIN="PB9" +CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" +CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:40000,le:87,ri:112,up:38,lo:141,hs:1,vs:1,sync:3,vmode:0" +CONFIG_VIDEO_LCD_POWER="PH8" +CONFIG_VIDEO_LCD_BL_EN="PH7" +CONFIG_VIDEO_LCD_BL_PWM="PB2" +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=432 +CONFIG_DRAM_ZQ=123 +CONFIG_DRAM_EMR1=4
On Mon, Mar 23, 2015 at 1:07 AM, Paul Kocialkowski contact@paulk.fr wrote:
Maybe a slight description of the board/device?
ChenYu
+CONFIG_DRAM_EMR1=4
1.9.1
Yes please, note no need to send a new version if you reply with a short description I can add that while merging these.
This version of the patch-set looks good, so I plan to merge it as is (assuming tests on the a23 tablet I've turn out ok).
Not sure yet when exactly I will get around to merging this, that should happen sometime during this week.
Regards,
Hans
ChenYu
- AMPE A76 BOARD M: Paul Kocialkowski contact@paulk.fr S: Maintained
+CONFIG_DRAM_EMR1=4
1.9.1
Never mind I've just merged this in my local tree, adding a short description myself based on (and pointing to): http://linux-sunxi.org/Ainol_AW1
I'll push this to next once tested.
Regards,
Hans
ChenYu
+CONFIG_DRAM_EMR1=4
1.9.1
Okay, I'm back home just now. For the record, I don't write device descriptions because that information is is available on the linux-sunxi wiki. Although, I understand it is only informative here, I also don't want to be adding any kind of marketing stuff to the commit message.
Thanks! All those commits have been build-tested with MAKEALL -s sunxi.
Regards,
Hans
ChenYu
+CONFIG_DRAM_EMR1=4
1.9.1
Thanks for the patches, I had to make this fixup (squashed) to fix vbus detect to work on axp221:
-------------------------- drivers/gpio/sunxi_gpio.c -------------------------- index 6296092..670af0c 100644 @@ -21,6 +21,9 @@ #ifdef CONFIG_AXP209_POWER #include <axp209.h> #endif +#ifdef CONFIG_AXP221_POWER +#include <axp221.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
Other then that + adding a small blurb with some info on the Ainol AW1 board this set has been merged as is.
The entire set has been queued up in u-boot-sunxi/next for upstream merging.
Regards,
Hans
Oh you're right, I forgot that one!
Thanks a lot!
Regards,
Hans
Chen-Yu Tsai
Hans de Goede
Paul Kocialkowski
