[U-Boot-Users] u-boot size and boot issue
Hello list,
I have mips board (au1550) and I'm having issues booting the board on its own when the u-boot size gets larger than 256k. It will boot fine when it's connected to BDI.
What am I doing wrong? I've been trying to figure out where I need to make a change to support u-boot with larger size since as long as the size if smaller than 256k, it works just fine.
Any suggestion will be greatly appreciated.
Thank you so much for your help.
mitsy wrote:
Hello list,
Hi Mitsy,
Disclaimer: I am not a MIPS expert so I may be all wet...
My first guess is that you've allocated 256Kbytes worth of flash (2 blocks at 128K each? 4 blocks at 64K each?) and so, when your image is more than 256K, you spill out of the allocated blocks and have a damaged image. It may be as simple as erasing and programming more than 256K. After erasing your u-boot image, what is at the 256K mark? Hopefully all 0xFFs (erased).
Another possibility is if you put your environment variables in a fixed location at the 256K mark, when your image exceeds 256K, the first time you do an env save command you will damage your image. This shouldn't happen, but...
Best regards, gvb
Jerry Van Baren
mitsy
