[U-Boot] Please pull u-boot-ti/master
The following changes since commit e2b1fb98dab08f18e456fd8d846440fe81567785: Sandeep Paulraj (1): Merge branch 'master' of git://git.denx.de/u-boot-arm
git://git.denx.de/u-boot-ti.git master
Ben Gardiner (1): da850evm: fix NAND WSTROBE and TA timings
board/davinci/da8xxevm/da850evm.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
Hi Sandeep,
Actually commit e2b1fb98dab08f18e456fd8d846440fe81567785 is a merge commit of the u-boot-arm/master branch into yours, whereas the pull request should have been based on the u-boot-arm/master branch itself, commit 2fa8ca98c37d5b1bb0328b19ddb7e9d162cd9683 (seems you have done a merge of u-boot-arm/master into u-boot-ti rather than a rebase of u-boot-ti onto u-boot-arm).
However, seeing as there is only one commit in the request, I'll simply cherry-pick it on top of my master and consider it as:
Applied, thanks.
Prafulla : take note that u-boot-arm/master has moved; if you have not already prepared your pull request, please rebase it, sorry for the inconvenience.
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Saturday, May 07, 2011 3:43 PM To: s-paulraj@ti.com Cc: u-boot@lists.denx.de; Prafulla Wadaskar Subject: Re: Please pull u-boot-ti/master
Hi Sandeep,
Applied, thanks.
Hi Albert Thanks, I will do it. Regards.. Prafulla . .
Amicalement,
Albert.
Albert ARIBAUD
Prafulla Wadaskar
s-paulraj@ti.com
