[U-Boot] [PATCH] powerpc/85xx: Fix USB protocol definitions for P1020RDB
From: Ramneek Mehresh ramneek.mehresh@freescale.com
USB protocol macros (CONFIG_USB_EHCI ...) to be included only when CONFIG_HAS_FSL_DR_USB is defined for a board. Presence of USB DR controller should be declared along with the underlying protocol used in the controller
Signed-off-by: Ramneek Mehresh ramneek.mehresh@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/configs/P1_P2_RDB.h | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/include/configs/P1_P2_RDB.h b/include/configs/P1_P2_RDB.h index 3ffdb1a..043515d 100644 --- a/include/configs/P1_P2_RDB.h +++ b/include/configs/P1_P2_RDB.h @@ -581,6 +581,9 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif #endif
+#define CONFIG_HAS_FSL_DR_USB + +#if defined(CONFIG_HAS_FSL_DR_USB) #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI @@ -588,7 +591,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE -#define CONFIG_HAS_FSL_DR_USB +#endif #endif
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI)
applied to 85xx next
- k
Kumar Gala
