[U-Boot-Users] [PATCH 03/30] common/cmd_[p-x]*: Remove obsolete references to CONFIG_COMMANDS.
Signed-off-by: Jon Loeliger jdl@freescale.com --- common/cmd_pci.c | 4 ++-- common/cmd_pcmcia.c | 7 +++---- common/cmd_portio.c | 2 +- common/cmd_reginfo.c | 6 +++--- common/cmd_reiser.c | 4 ++-- common/cmd_scsi.c | 4 ++-- common/cmd_spi.c | 2 +- common/cmd_universe.c | 4 ++-- common/cmd_usb.c | 6 +++--- common/cmd_vfd.c | 2 +- common/cmd_ximg.c | 4 ++-- 11 files changed, 22 insertions(+), 23 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 10e0691..8be6da9 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -38,7 +38,7 @@ #include <asm/io.h> #include <pci.h>
-#if (CONFIG_COMMANDS & CFG_CMD_PCI) || defined(CONFIG_CMD_PCI) +#if defined(CONFIG_CMD_PCI)
extern int cmd_get_data_size(char* arg, int default_size);
@@ -565,6 +565,6 @@ U_BOOT_CMD( " - write to CFG address\n" );
-#endif /* (CONFIG_COMMANDS & CFG_CMD_PCI) */ +#endif
#endif /* CONFIG_PCI */ diff --git a/common/cmd_pcmcia.c b/common/cmd_pcmcia.c index dfa41e0..dcd07c0 100644 --- a/common/cmd_pcmcia.c +++ b/common/cmd_pcmcia.c @@ -61,7 +61,7 @@
-#if (CONFIG_COMMANDS & CFG_CMD_PCMCIA) || defined(CONFIG_CMD_PCMCIA) +#if defined(CONFIG_CMD_PCMCIA)
extern int pcmcia_on (void); extern int pcmcia_off (void); @@ -93,14 +93,13 @@ U_BOOT_CMD( "pinit off - power off PCMCIA socket\n" );
-#endif /* CONFIG_COMMANDS & CFG_CMD_PCMCIA */ +#endif
#undef CHECK_IDE_DEVICE
-#if ((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE)) \ - && defined(CONFIG_IDE_8xx_PCCARD) +#if defined(CONFIG_CMD_IDE) && defined(CONFIG_IDE_8xx_PCCARD) #define CHECK_IDE_DEVICE #endif
diff --git a/common/cmd_portio.c b/common/cmd_portio.c index 6a07482..ad6656a 100644 --- a/common/cmd_portio.c +++ b/common/cmd_portio.c @@ -30,7 +30,7 @@ #include <common.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_PORTIO) || defined(CONFIG_CMD_PORTIO) +#if defined(CONFIG_CMD_PORTIO)
extern int cmd_get_data_size (char *arg, int default_size);
diff --git a/common/cmd_reginfo.c b/common/cmd_reginfo.c index 57de0fe..17e9cd9 100644 --- a/common/cmd_reginfo.c +++ b/common/cmd_reginfo.c @@ -33,7 +33,7 @@ #include <mpc5xxx.h> #endif
-#if (CONFIG_COMMANDS & CFG_CMD_REGINFO) || defined(CONFIG_CMD_REGINFO) +#if defined(CONFIG_CMD_REGINFO)
int do_reginfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -335,14 +335,14 @@ int do_reginfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#endif /* CONFIG_COMMANDS & CFG_CMD_REGINFO */ +#endif
#if ( defined(CONFIG_8xx) || defined(CONFIG_405GP) || \ defined(CONFIG_405EP) || defined(CONFIG_MPC5200) ) && \ - ((CONFIG_COMMANDS & CFG_CMD_REGINFO) || defined(CONFIG_CMD_REGINFO)) + defined(CONFIG_CMD_REGINFO)
U_BOOT_CMD( reginfo, 2, 1, do_reginfo, diff --git a/common/cmd_reiser.c b/common/cmd_reiser.c index f54019b..989fd57 100644 --- a/common/cmd_reiser.c +++ b/common/cmd_reiser.c @@ -28,7 +28,7 @@ */ #include <common.h>
-#if (CONFIG_COMMANDS & CFG_CMD_REISER) || defined(CONFIG_CMD_REISER) +#if defined(CONFIG_CMD_REISER) #include <config.h> #include <command.h> #include <image.h> @@ -240,4 +240,4 @@ U_BOOT_CMD( " to address 'addr' from dos filesystem\n" );
-#endif /* CONFIG_COMMANDS & CFG_CMD_REISER */ +#endif diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index ac3d81c..f563931 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -34,7 +34,7 @@ #include <image.h> #include <pci.h>
-#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) +#if defined(CONFIG_CMD_SCSI)
#ifdef CONFIG_SCSI_SYM53C8XX #define SCSI_VEND_ID 0x1000 @@ -609,4 +609,4 @@ U_BOOT_CMD( "loadAddr dev:part\n" );
-#endif /* #if (CONFIG_COMMANDS & CFG_CMD_SCSI) */ +#endif diff --git a/common/cmd_spi.c b/common/cmd_spi.c index 5874222..d446fe5 100644 --- a/common/cmd_spi.c +++ b/common/cmd_spi.c @@ -29,7 +29,7 @@ #include <command.h> #include <spi.h>
-#if (CONFIG_COMMANDS & CFG_CMD_SPI) || defined(CONFIG_CMD_SPI) +#if defined(CONFIG_CMD_SPI)
/*----------------------------------------------------------------------- * Definitions diff --git a/common/cmd_universe.c b/common/cmd_universe.c index cc55dc9..8bf0b1f 100644 --- a/common/cmd_universe.c +++ b/common/cmd_universe.c @@ -28,7 +28,7 @@
#include <universe.h>
-#if (CONFIG_COMMANDS & CFG_CMD_UNIVERSE) || defined(CONFIG_CMD_UNIVERSE) +#if defined(CONFIG_CMD_UNIVERSE)
#define PCI_VENDOR PCI_VENDOR_ID_TUNDRA #define PCI_DEVICE PCI_DEVICE_ID_TUNDRA_CA91C042 @@ -387,4 +387,4 @@ U_BOOT_CMD( " 03 -> D32 Data Width\n" );
-#endif /* (CONFIG_COMMANDS & CFG_CMD_UNIVERSE) */ +#endif diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 529938f..45e07f1 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -30,7 +30,7 @@ #include <asm/byteorder.h> #include <part.h>
-#if (CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB) +#if defined(CONFIG_CMD_USB)
#include <usb.h>
@@ -609,10 +609,10 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
-#endif /* (CONFIG_COMMANDS & CFG_CMD_USB) */ +#endif
#ifdef CONFIG_USB_STORAGE U_BOOT_CMD( diff --git a/common/cmd_vfd.c b/common/cmd_vfd.c index fffb39c..6fc0624 100644 --- a/common/cmd_vfd.c +++ b/common/cmd_vfd.c @@ -35,7 +35,7 @@ #include <common.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_VFD) || defined(CONFIG_CMD_VFD) +#if defined(CONFIG_CMD_VFD)
#include <vfd_logo.h> #define VFD_TEST_LOGO_BMPNR 0 diff --git a/common/cmd_ximg.c b/common/cmd_ximg.c index e490243..52e0614 100644 --- a/common/cmd_ximg.c +++ b/common/cmd_ximg.c @@ -24,7 +24,7 @@ * MA 02111-1307 USA */
-#if (CONFIG_COMMANDS & CFG_CMD_XIMG) || defined(CONFIG_CMD_XIMG) +#if defined(CONFIG_CMD_XIMG)
/* * Multi Image extract @@ -141,4 +141,4 @@ U_BOOT_CMD(imxtract, 4, 1, do_imgextract, "addr part [dest]\n" " - extract <part> from image at <addr> and copy to <dest>\n");
-#endif /* CONFIG_COMMANDS & CFG_CMD_XIMG */ +#endif
Jon Loeliger
