[PATCH] mmc: renesas-sdhi: Add R-Car Gen4 support
Support R-Car Gen4 family. The default quirk is similar to previous generation.
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org Signed-off-by: Hai Pham hai.pham.ud@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org # Use RCAR_64 Kconfig --- drivers/mmc/renesas-sdhi.c | 1 + drivers/mmc/tmio-common.c | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 34119f949aa..280d96dbc2d 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -843,6 +843,7 @@ static const struct udevice_id renesas_sdhi_match[] = { { .compatible = "renesas,sdhi-r8a77970", .data = RENESAS_GEN3_QUIRKS }, { .compatible = "renesas,sdhi-r8a77990", .data = RENESAS_GEN3_QUIRKS }, { .compatible = "renesas,sdhi-r8a77995", .data = RENESAS_GEN3_QUIRKS }, + { .compatible = "renesas,rcar-gen4-sdhi", .data = RENESAS_GEN3_QUIRKS }, { /* sentinel */ } };
diff --git a/drivers/mmc/tmio-common.c b/drivers/mmc/tmio-common.c index d8b6a4a8821..8d7ee481d64 100644 --- a/drivers/mmc/tmio-common.c +++ b/drivers/mmc/tmio-common.c @@ -369,7 +369,7 @@ static bool tmio_sd_addr_is_dmaable(struct mmc_data *data) if (!IS_ALIGNED(addr, TMIO_SD_DMA_MINALIGN)) return false;
- if (IS_ENABLED(CONFIG_RCAR_GEN3)) { + if (IS_ENABLED(CONFIG_RCAR_64)) { if (!(data->flags & MMC_DATA_READ) && !IS_ALIGNED(addr, 128)) return false; /* Gen3 DMA has 32bit limit */
