[U-Boot] [PATCH v5 2/5] mips: add support for QCA/Atheros ath79 SOCs
This patch enable work for ar933x SOC, tested on ar9331 board.
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v5: - Add independent Kconfig - Use SRAM for initial stack - Move DDR initialization into board_early_init_f - Convert DDR tap tunning code to C - Save SOC's version into arch_global_data
Changes in v4: - Use global_data to save CPU/DDR/AHB clock - Use arch_global_data to save SOC's type, revison and id
Changes in v3: - Move SoC specific header files into arch/mips/mach-ath79/include/mach - Optimize assembly code - Same code style convertion
Changes in v2: - Move all SoC specific header files into arch/mips/include/asm/arch-ath79 - Check SOC type and extract common code into arch/mips/mach-ath79
arch/mips/Kconfig | 6 + arch/mips/Makefile | 1 + arch/mips/include/asm/global_data.h | 6 + arch/mips/mach-ath79/Kconfig | 20 + arch/mips/mach-ath79/Makefile | 9 + arch/mips/mach-ath79/ar933x/Makefile | 8 + arch/mips/mach-ath79/ar933x/board.c | 42 + arch/mips/mach-ath79/ar933x/clk.c | 86 ++ arch/mips/mach-ath79/ar933x/ddr.c | 215 +++++ arch/mips/mach-ath79/ar933x/lowlevel_init.S | 286 ++++++ arch/mips/mach-ath79/cpu.c | 173 ++++ arch/mips/mach-ath79/dram.c | 17 + arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1136 +++++++++++++++++++++++ arch/mips/mach-ath79/include/mach/ath79.h | 143 +++ arch/mips/mach-ath79/include/mach/ddr.h | 14 + arch/mips/mach-ath79/reset.c | 46 + 16 files changed, 2208 insertions(+) create mode 100644 arch/mips/mach-ath79/Kconfig create mode 100644 arch/mips/mach-ath79/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/board.c create mode 100644 arch/mips/mach-ath79/ar933x/clk.c create mode 100644 arch/mips/mach-ath79/ar933x/ddr.c create mode 100644 arch/mips/mach-ath79/ar933x/lowlevel_init.S create mode 100644 arch/mips/mach-ath79/cpu.c create mode 100644 arch/mips/mach-ath79/dram.c create mode 100644 arch/mips/mach-ath79/include/mach/ar71xx_regs.h create mode 100644 arch/mips/mach-ath79/include/mach/ath79.h create mode 100644 arch/mips/mach-ath79/include/mach/ddr.h create mode 100644 arch/mips/mach-ath79/reset.c
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 388e4c0..c9c6aae 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -53,6 +53,11 @@ config TARGET_PB1X00 select SYS_MIPS_CACHE_INIT_RAM_LOAD select MIPS_TUNE_4KC
+config ARCH_ATH79 + bool "Support ath79" + select OF_CONTROL + select DM + endchoice
source "board/dbau1x00/Kconfig" @@ -60,6 +65,7 @@ source "board/imgtec/malta/Kconfig" source "board/micronas/vct/Kconfig" source "board/pb1x00/Kconfig" source "board/qemu-mips/Kconfig" +source "arch/mips/mach-ath79/Kconfig"
if MIPS
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 90cd590..93c461c 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -8,6 +8,7 @@ libs-y += arch/mips/cpu/ libs-y += arch/mips/lib/
machine-$(CONFIG_SOC_AU1X00) += au1x00 +machine-$(CONFIG_ARCH_ATH79) += ath79
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) libs-y += $(machdirs) diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index 2d9a0c9..3799e98 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -20,6 +20,12 @@ struct arch_global_data { unsigned long tbl; unsigned long lastinc; #endif +#ifdef CONFIG_ARCH_ATH79 + unsigned long id; + unsigned long soc; + unsigned long rev; + unsigned long ver; +#endif };
#include <asm-generic/global_data.h> diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig new file mode 100644 index 0000000..52766c9 --- /dev/null +++ b/arch/mips/mach-ath79/Kconfig @@ -0,0 +1,20 @@ +menu "QCA/Atheros ath79 platforms" + depends on ARCH_ATH79 + +config SYS_VENDOR + default "ath79" + +config SYS_SOC + default "ath79" + +config SOC_AR933X + bool + select SUPPORTS_BIG_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select SYS_MIPS_CACHE_INIT_RAM_LOAD + select MIPS_TUNE_24KC + help + This supports QCA/Atheros ar933x family SOCs. + +endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile new file mode 100644 index 0000000..bc0a41f --- /dev/null +++ b/arch/mips/mach-ath79/Makefile @@ -0,0 +1,9 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += reset.o +obj-y += cpu.o +obj-y += dram.o + +obj-$(CONFIG_SOC_AR933X) += ar933x/ diff --git a/arch/mips/mach-ath79/ar933x/Makefile b/arch/mips/mach-ath79/ar933x/Makefile new file mode 100644 index 0000000..27c7855 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/Makefile @@ -0,0 +1,8 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += clk.o +obj-y += board.o +obj-y += lowlevel_init.o +obj-y += ddr.o diff --git a/arch/mips/mach-ath79/ar933x/board.c b/arch/mips/mach-ath79/ar933x/board.c new file mode 100644 index 0000000..b4a76e8 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/board.c @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void uart_pin_init(void) +{ + u32 val; + + /* + * Set GPIO10 (UART_SO) as output and enable UART, + * BIT(15) in GPIO_FUNCTION_1 register must be written with 1 + */ + val = readl(KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_OE)); + val |= BIT(10); + writel(val, KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_OE)); + + val = readl(KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_FUNC)); + val |= (AR933X_GPIO_FUNC_UART_EN | BIT(15)); + writel(val, KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_FUNC)); +} + + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + uart_pin_init(); + ddr_init(); + return 0; +} +#endif diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c new file mode 100644 index 0000000..cfc4bb9 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -0,0 +1,86 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +static u32 ar933x_get_xtal(void) +{ + u32 val; + + val = readl(KSEG1ADDR(AR71XX_RESET_BASE + AR933X_RESET_REG_BOOTSTRAP)); + if (val & AR933X_BOOTSTRAP_REF_CLK_40) + return 40000000; + else + return 25000000; +} + +int get_serial_clock(void) +{ + return ar933x_get_xtal(); +} + +int get_clocks(void) +{ + u32 val, xtal, pll, div; + + xtal = ar933x_get_xtal(); + val = readl(KSEG1ADDR(AR71XX_PLL_BASE + AR933X_PLL_CPU_CONFIG_REG)); + + /* VCOOUT = XTAL * DIV_INT */ + div = (val >> AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT) + & AR933X_PLL_CPU_CONFIG_REFDIV_MASK; + pll = xtal / div; + + /* PLLOUT = VCOOUT * (1/2^OUTDIV) */ + div = (val >> AR933X_PLL_CPU_CONFIG_DIVINT_SHIFT) + & AR933X_PLL_CPU_CONFIG_DIVINT_MASK; + pll *= div; + div = (val >> AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT) + & AR933X_PLL_CPU_CONFIG_OUTDIV_MASK; + if (!div) + div = 1; + pll >>= div; + + val = readl(KSEG1ADDR(AR71XX_PLL_BASE + AR933X_PLL_CLOCK_CTRL_REG)); + + /* CPU_CLK = PLLOUT / CPU_POST_DIV */ + div = ((val >> AR933X_PLL_CLOCK_CTRL_CPU_DIV_SHIFT) + & AR933X_PLL_CLOCK_CTRL_CPU_DIV_MASK) + 1; + gd->cpu_clk = pll / div; + + /* DDR_CLK = PLLOUT / DDR_POST_DIV */ + div = ((val >> AR933X_PLL_CLOCK_CTRL_DDR_DIV_SHIFT) + & AR933X_PLL_CLOCK_CTRL_DDR_DIV_MASK) + 1; + gd->mem_clk = pll / div; + + /* AHB_CLK = PLLOUT / AHB_POST_DIV */ + div = ((val >> AR933X_PLL_CLOCK_CTRL_AHB_DIV_SHIFT) + & AR933X_PLL_CLOCK_CTRL_AHB_DIV_MASK) + 1; + gd->bus_clk = pll / div; + + return 0; +} + +ulong get_bus_freq(ulong dummy) +{ + if (!gd->bus_clk) + get_clocks(); + return gd->bus_clk; +} + +ulong get_ddr_freq(ulong dummy) +{ + if (!gd->mem_clk) + get_clocks(); + return gd->mem_clk; +} diff --git a/arch/mips/mach-ath79/ar933x/ddr.c b/arch/mips/mach-ath79/ar933x/ddr.c new file mode 100644 index 0000000..3985299 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/ddr.c @@ -0,0 +1,215 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +void ddr_init(void) +{ + void __iomem *regs = (void *)KSEG1ADDR(AR71XX_DDR_CTRL_BASE); + u32 val; + + writel(0x7fbc8cd0, regs + AR71XX_DDR_REG_CONFIG); + writel(0x9dd0e6a8, regs + AR71XX_DDR_REG_CONFIG2); + + val = readl(KSEG1ADDR(AR71XX_RESET_BASE) + + AR933X_RESET_REG_BOOTSTRAP); + if (val & AR933X_BOOTSTRAP_DDR2) { + /* Enable DDR2 */ + writel(0xA59, regs + AR933X_DDR_REG_DDR2_CONFIG); + + /* Precharge All */ + writel(0x08, regs + AR71XX_DDR_REG_CONTROL); + + /* Disable High Temperature Self-Refresh Rate */ + writel(0x00, regs + AR933X_DDR_REG_EMR2); + /* Extended Mode Register 2 Set (EMR2S) */ + writel(0x10, regs + AR71XX_DDR_REG_CONTROL); + + writel(0x00, regs + AR933X_DDR_REG_EMR3); + /* Extended Mode Register 3 Set (EMR3S) */ + writel(0x20, regs + AR71XX_DDR_REG_CONTROL); + + /* Enable DLL */ + writel(0x00, regs + AR71XX_DDR_REG_EMR); + /* Extended Mode Register Set (EMRS) */ + writel(0x02, regs + AR71XX_DDR_REG_CONTROL); + + /* Reset DLL */ + writel(0x100, regs + AR71XX_DDR_REG_MODE); + /* Mode Register Set (MRS) */ + writel(0x01, regs + AR71XX_DDR_REG_CONTROL); + + /* Precharge All */ + writel(0x08, regs + AR71XX_DDR_REG_CONTROL); + + /* Auto Refresh */ + writel(0x04, regs + AR71XX_DDR_REG_CONTROL); + writel(0x04, regs + AR71XX_DDR_REG_CONTROL); + + /* Write recovery (WR) 6 clock, CAS Latency 3, + * Burst Length 8 */ + writel(0xa33, regs + AR71XX_DDR_REG_MODE); + /* Mode Register Set (MRS) */ + writel(0x01, regs + AR71XX_DDR_REG_CONTROL); + + /* E7,E8,E9 equal to 1(Enable OCD defaults), + * Enable DLL, Reduced Drive Strength */ + writel(0x382, regs + AR71XX_DDR_REG_EMR); + /* Extended Mode Register Set (EMRS) */ + writel(0x02, regs + AR71XX_DDR_REG_CONTROL); + + /* E7,E8,E9 equal to 0(OCD exit), Enable DLL, + * Reduced Drive Strength */ + writel(0x402, regs + AR71XX_DDR_REG_EMR); + /* Extended Mode Register Set (EMRS) */ + writel(0x02, regs + AR71XX_DDR_REG_CONTROL); + + /* Refresh control. Bit 14 is enable. + * Bits<13:0> Refresh time */ + if (val & AR933X_BOOTSTRAP_REF_CLK_40) + writel(0x4270, regs + AR71XX_DDR_REG_REFRESH); + else + writel(0x4186, regs + AR71XX_DDR_REG_REFRESH); + + /* DQS 0 Tap Control */ + writel(0x08, regs + AR71XX_DDR_REG_TAP_CTRL0); + /* DQS 1 Tap Control */ + writel(0x09, regs + AR71XX_DDR_REG_TAP_CTRL1); + + /* For 16-bit DDR */ + writel(0xff, regs + AR71XX_DDR_REG_RD_CYCLE); + } else { + /* Precharge All */ + writel(0x08, regs + AR71XX_DDR_REG_CONTROL); + + /* Write Mode Word */ + writel(0x133, regs + AR71XX_DDR_REG_MODE); + /* Forces an MRS update cycle in DDR */ + writel(0x01, regs + AR71XX_DDR_REG_CONTROL); + + /* Enable DLL, High drive strength from DDR */ + writel(0x02, regs + AR71XX_DDR_REG_EMR); + /* Extended Mode Register Set (EMRS) */ + writel(0x02, regs + AR71XX_DDR_REG_CONTROL); + + /* Precharge All */ + writel(0x08, regs + AR71XX_DDR_REG_CONTROL); + + /* DLL out of reset, CAS Latency 3 */ + writel(0x33, regs + AR71XX_DDR_REG_MODE); + /* Mode Register Set (MRS) */ + writel(0x01, regs + AR71XX_DDR_REG_CONTROL); + + /* Refresh control. Bit 14 is enable. + * Bits<13:0> Refresh time */ + if (val & AR933X_BOOTSTRAP_REF_CLK_40) + writel(0x4270, regs + AR71XX_DDR_REG_REFRESH); + else + writel(0x4186, regs + AR71XX_DDR_REG_REFRESH); + + /* DQS 0 Tap Control */ + writel(0x08, regs + AR71XX_DDR_REG_TAP_CTRL0); + /* DQS 1 Tap Control */ + writel(0x09, regs + AR71XX_DDR_REG_TAP_CTRL1); + + /* For 16-bit DDR */ + writel(0xff, regs + AR71XX_DDR_REG_RD_CYCLE); + } +} + +void ddr_tap_tunning(void) +{ + void __iomem *regs = (void *)KSEG1ADDR(AR71XX_DDR_CTRL_BASE); + u32 *addr_k0, *addr_k1, *addr; + u32 tap, tap_val, upper, lower; + int i, j, dir, err, done; + + addr = (void *)KSEG0ADDR(0x2000); + for (i = 0; i < 256; i++) { + tap_val = 0; + for (j = 0; j < 8; j++) { + if (i & (1 << j)) { + if (j % 2) + tap_val |= 0xffff0000; + else + tap_val |= 0x0000ffff; + } + + if (j % 2) { + *addr++ = tap_val; + tap_val = 0; + } + } + } + + err = 0; + done = 0; + dir = 1; + + tap = readl(regs + AR71XX_DDR_REG_TAP_CTRL0); + tap_val = tap; + while (!done) { + err = 0; + writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL0); + writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL1); + for (i = 0; i < 2; i++) { + addr_k1 = (void *)KSEG1ADDR(0x2000); + addr_k0 = (void *)KSEG0ADDR(0x2000); + addr = (void *)KSEG0ADDR(0x3000); + + while (addr_k0 < addr) { + if (*addr_k1++ != *addr_k0++) { + err = 1; + break; + } + } + + if (err) + break; + } + + if (err) { + if (dir) { + dir = 0; + tap_val--; + upper = tap_val; + tap_val = tap; + } else { + tap_val++; + lower = tap_val; + done = 1; + } + } else { + if (dir) { + if (tap_val < 0x20) { + tap_val++; + } else { + dir = 0; + upper = tap_val; + tap_val = tap; + } + } else { + if (!tap_val) { + lower = tap_val; + done = 1; + } else { + tap_val--; + } + } + } + } + tap_val = (upper + lower) / 2; + writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL0); + tap_val++; + writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL1); +} diff --git a/arch/mips/mach-ath79/ar933x/lowlevel_init.S b/arch/mips/mach-ath79/ar933x/lowlevel_init.S new file mode 100644 index 0000000..9cc32bf --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/lowlevel_init.S @@ -0,0 +1,286 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <mach/ar71xx_regs.h> + +#define SET_BIT(val, bit) ((val) | (1 << (bit))) +#define SET_PLL_PD(val) SET_BIT(val, 30) +#define AHB_DIV_TO_4(val) SET_BIT(SET_BIT(val, 15), 16) +#define PLL_BYPASS(val) SET_BIT(val, 2) + +#define MK_PLL_CONF(divint, refdiv, range, outdiv) \ + (((0x3F & divint) << 10) | \ + ((0x1F & refdiv) << 16) | \ + ((0x1 & range) << 21) | \ + ((0x7 & outdiv) << 23) ) + +#define MK_CLK_CNTL(cpudiv, ddrdiv, ahbdiv) \ + (((0x3 & (cpudiv - 1)) << 5) | \ + ((0x3 & (ddrdiv - 1)) << 10) | \ + ((0x3 & (ahbdiv - 1)) << 15) ) + +/* + * PLL_CPU_CONFIG_VAL + * + * Bit30 is set (CPU_PLLPWD = 1 -> power down control for CPU PLL) + * After PLL configuration we need to clear this bit + * + * Values written into CPU PLL Configuration (CPU_PLL_CONFIG) + * + * bits 10..15 (6bit) DIV_INT (Integer part of the DIV to CPU PLL) + * => 32 (0x20) VCOOUT = XTAL * DIV_INT + * bits 16..20 (5bit) REFDIV (Reference clock divider) + * => 1 (0x1) [Must start at values 1] + * bits 21 (1bit) RANGE (VCO frequency range of the CPU PLL) + * => 0 (0x0) [Doesn't impact clock values] + * bits 23..25 (3bit) OUTDIV (Ratio between VCO and PLL output) + * => 1 (0x1) [0 is illegal!] + * PLLOUT = VCOOUT * (1/2^OUTDIV) + */ +/* DIV_INT=32 (25MHz*32/2=400MHz), REFDIV=1, RANGE=0, OUTDIV=1 */ +#define PLL_CPU_CONFIG_VAL_40M MK_PLL_CONF(20, 1, 0, 1) +/* DIV_INT=20 (40MHz*20/2=400MHz), REFDIV=1, RANGE=0, OUTDIV=1 */ +#define PLL_CPU_CONFIG_VAL_25M MK_PLL_CONF(32, 1, 0, 1) + +/* + * PLL_CLK_CONTROL_VAL + * + * In PLL_CLK_CONTROL_VAL bit 2 is set (BYPASS = 1 -> bypass PLL) + * After PLL configuration we need to clear this bit + * + * Values written into CPU Clock Control Register CLOCK_CONTROL + * + * bits 2 (1bit) BYPASS (Bypass PLL. This defaults to 1 for test. + * Software must enable the CPU PLL for normal and + * then set this bit to 0) + * bits 5..6 (2bit) CPU_POST_DIV => 0 (DEFAULT, Ratio = 1) + * CPU_CLK = PLLOUT / CPU_POST_DIV + * bits 10..11 (2bit) DDR_POST_DIV => 0 (DEFAULT, Ratio = 1) + * DDR_CLK = PLLOUT / DDR_POST_DIV + * bits 15..16 (2bit) AHB_POST_DIV => 1 (DEFAULT, Ratio = 2) + * AHB_CLK = PLLOUT / AHB_POST_DIV + * + */ +#define PLL_CLK_CONTROL_VAL MK_CLK_CNTL(1, 1, 2) + + .text + .set noreorder + +LEAF(lowlevel_init) + /* These three WLAN_RESET will avoid original issue */ + li t3, 0x03 +1: + li t0, KSEG1ADDR(AR71XX_RESET_BASE) + lw t1, AR933X_RESET_REG_RESET_MODULE(t0) + ori t1, t1, 0x0800 + sw t1, AR933X_RESET_REG_RESET_MODULE(t0) + nop + lw t1, AR933X_RESET_REG_RESET_MODULE(t0) + li t2, 0xfffff7ff + and t1, t1, t2 + sw t1, AR933X_RESET_REG_RESET_MODULE(t0) + nop + addi t3, t3, -1 + bnez t3, 1b + nop + + li t2, 0x20 +2: + beqz t2, 1b + nop + addi t2, t2, -1 + lw t5, AR933X_RESET_REG_BOOTSTRAP(t0) + andi t1, t5, 0x10 + bnez t1, 2b + nop + + li t1, 0x02110E + sw t1, AR933X_RESET_REG_BOOTSTRAP(t0) + nop + + /* RTC Force Wake */ + li t0, KSEG1ADDR(AR933X_RTC_BASE) + li t1, 0x03 + sw t1, AR933X_RTC_REG_FORCE_WAKE(t0) + nop + nop + + /* RTC Reset */ + li t1, 0x00 + sw t1, AR933X_RTC_REG_RESET(t0) + nop + nop + + li t1, 0x01 + sw t1, AR933X_RTC_REG_RESET(t0) + nop + nop + + /* Wait for RTC in on state */ +1: + lw t1, AR933X_RTC_REG_STATUS(t0) + andi t1, t1, 0x02 + beqz t1, 1b + nop + + /* Program ki/kd */ + li t0, KSEG1ADDR(AR933X_SRIF_BASE) + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, 0x19e82f01 + b 2f + nop +1: + li t1, 0x18e82f01 +2: + sw t1, AR933X_SRIF_DDR_DPLL2_REG(t0) + + /* Program phase shift */ + lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + li t2, 0xc07fffff + and t1, t1, t2 + li t2, 0x800000 # meas_at_txon + or t1, t1, t2 + sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + nop + + /* Max AHB Master wait time out ... */ + li t0, KSEG1ADDR(AR71XX_DDR_CTRL_BASE) + li t1, 0xfffff + sw t1, AR933X_DDR_REG_TIMEOUT_MAX(t0) + nop + + /* in some cases, the SoC doesn't start with higher clock on AHB */ + li t0, KSEG1ADDR(AR71XX_PLL_BASE) + li t1, AHB_DIV_TO_4(PLL_BYPASS(PLL_CLK_CONTROL_VAL)) + sw t1, AR933X_PLL_CLOCK_CTRL_REG(t0) + nop + + /* Set SETTLE_TIME in CPU PLL */ + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, 0x0352 + b 2f + nop +1: + li t1, 0x0550 +2: + sw t1, AR71XX_PLL_REG_SEC_CONFIG(t0) + nop + + /* Set nint, frac, refdiv, outdiv, range according to xtal */ +0: + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, SET_PLL_PD(PLL_CPU_CONFIG_VAL_25M) + b 2f + nop +1: + li t1, SET_PLL_PD(PLL_CPU_CONFIG_VAL_40M) +2: + sw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + nop +1: + lw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + li t2, 0x80000000 + and t1, t1, t2 + bnez t1, 1b + nop + + /* Put frac bit19:10 configuration */ + li t1, 0x1003E8 + sw t1, AR933X_PLL_DITHER_FRAC_REG(t0) + nop + + /* Clear PLL power down bit in CPU PLL configuration */ + andi t1, t5, 0x01 # t5 BOOT_STRAP + bnez t1, 1f + nop + li t1, PLL_CPU_CONFIG_VAL_25M + b 2f + nop +1: + li t1, PLL_CPU_CONFIG_VAL_40M +2: + sw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + nop + + /* Wait for PLL update -> bit 31 in CPU_PLL_CONFIG should be 0 */ +1: + lw t1, AR933X_PLL_CPU_CONFIG_REG(t0) + li t2, 0x80000000 + and t1, t1, t2 + bnez t1, 1b + nop + + /* Confirm DDR PLL lock */ + li t3, 100 + li t4, 0 + +2: + addi t4, t4, 1 + bgt t4, t3, 0b + nop + + li t3, 5 +3: + /* Clear do_meas */ + li t0, KSEG1ADDR(AR933X_SRIF_BASE) + lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + li t2, 0xBFFFFFFF + and t1, t1, t2 + sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + nop + + li t2, 10 +1: + subu t2, t2, 1 + bnez t2, 1b + nop + + /* Set do_meas */ + li t2, 0x40000000 + or t1, t1, t2 + sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + nop + + /* Check meas_done */ +1: + lw t1, AR933X_SRIF_DDR_DPLL4_REG(t0) + andi t1, t1, 0x8 + beqz t1, 1b + nop + + lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0) + li t2, 0x007FFFF8 + and t1, t1, t2 + srl t1, t1, 3 + li t2, 0x4000 + bgt t1, t2, 2b + nop + addi t3, t3, -1 + bnez t3, 3b + nop + + /* clear PLL bypass (bit 2) in CPU CLOCK CONTROL register */ + li t0, KSEG1ADDR(AR71XX_PLL_BASE) + li t1, PLL_CLK_CONTROL_VAL + sw t1, AR933X_PLL_CLOCK_CTRL_REG(t0) + nop + + nop + jr ra + nop + END(lowlevel_init) diff --git a/arch/mips/mach-ath79/cpu.c b/arch/mips/mach-ath79/cpu.c new file mode 100644 index 0000000..c03480d --- /dev/null +++ b/arch/mips/mach-ath79/cpu.c @@ -0,0 +1,173 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <asm/arch/ath79.h> +#include <asm/arch/ar71xx_regs.h> + +int print_cpuinfo(void) +{ + enum ath79_soc_type soc = ATH79_SOC_UNKNOWN; + char *chip = "????"; + u32 id, major, minor; + u32 rev = 0; + u32 ver = 1; + + id = readl(KSEG1ADDR(AR71XX_RESET_BASE + AR71XX_RESET_REG_REV_ID)); + major = id & REV_ID_MAJOR_MASK; + + switch (major) { + case REV_ID_MAJOR_AR71XX: + minor = id & AR71XX_REV_ID_MINOR_MASK; + rev = id >> AR71XX_REV_ID_REVISION_SHIFT; + rev &= AR71XX_REV_ID_REVISION_MASK; + switch (minor) { + case AR71XX_REV_ID_MINOR_AR7130: + soc = ATH79_SOC_AR7130; + chip = "7130"; + break; + + case AR71XX_REV_ID_MINOR_AR7141: + soc = ATH79_SOC_AR7141; + chip = "7141"; + break; + + case AR71XX_REV_ID_MINOR_AR7161: + soc = ATH79_SOC_AR7161; + chip = "7161"; + break; + } + break; + + case REV_ID_MAJOR_AR7240: + soc = ATH79_SOC_AR7240; + chip = "7240"; + rev = id & AR71XX_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR7241: + soc = ATH79_SOC_AR7241; + chip = "7241"; + rev = id & AR71XX_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR7242: + soc = ATH79_SOC_AR7242; + chip = "7242"; + rev = id & AR71XX_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR913X: + minor = id & AR71XX_REV_ID_MINOR_MASK; + rev = id >> AR71XX_REV_ID_REVISION_SHIFT; + rev &= AR71XX_REV_ID_REVISION_MASK; + switch (minor) { + case AR913X_REV_ID_MINOR_AR9130: + soc = ATH79_SOC_AR9130; + chip = "9130"; + break; + + case AR913X_REV_ID_MINOR_AR9132: + soc = ATH79_SOC_AR9132; + chip = "9132"; + break; + } + break; + + case REV_ID_MAJOR_AR9330: + soc = ATH79_SOC_AR9330; + chip = "9330"; + rev = id & AR71XX_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR9331: + soc = ATH79_SOC_AR9331; + chip = "9331"; + rev = id & AR71XX_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR9341: + soc = ATH79_SOC_AR9341; + chip = "9341"; + rev = id & AR934X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR9342: + soc = ATH79_SOC_AR9342; + chip = "9342"; + rev = id & AR934X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_AR9344: + soc = ATH79_SOC_AR9344; + chip = "9344"; + rev = id & AR934X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_QCA9533_V2: + ver = 2; + /* drop through */ + + case REV_ID_MAJOR_QCA9533: + soc = ATH79_SOC_QCA9533; + chip = "9533"; + rev = id & QCA953X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_QCA9556: + soc = ATH79_SOC_QCA9556; + chip = "9556"; + rev = id & QCA955X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_QCA9558: + soc = ATH79_SOC_QCA9558; + chip = "9558"; + rev = id & QCA955X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_TP9343: + soc = ATH79_SOC_TP9343; + chip = "9343"; + rev = id & QCA956X_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_QCA9561: + soc = ATH79_SOC_QCA9561; + chip = "9561"; + rev = id & QCA956X_REV_ID_REVISION_MASK; + break; + } + + gd->arch.id = id; + gd->arch.soc = soc; + gd->arch.rev = rev; + gd->arch.ver = ver; + puts("SoC: "); + switch (soc) { + case ATH79_SOC_QCA9533: + case ATH79_SOC_QCA9556: + case ATH79_SOC_QCA9558: + case ATH79_SOC_QCA9561: + printf("Qualcomm Atheros QCA%s ver %u rev %u\n", chip, + ver, rev); + break; + case ATH79_SOC_TP9343: + printf("Qualcomm Atheros TP%s rev %u\n", chip, rev); + break; + case ATH79_SOC_UNKNOWN: + printf("ATH79: unknown SoC, id:0x%08x", id); + break; + default: + printf("Atheros AR%s rev %u\n", chip, rev); + } + + return 0; +} diff --git a/arch/mips/mach-ath79/dram.c b/arch/mips/mach-ath79/dram.c new file mode 100644 index 0000000..dbd56d2 --- /dev/null +++ b/arch/mips/mach-ath79/dram.c @@ -0,0 +1,17 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/sizes.h> +#include <asm/addrspace.h> +#include <mach/ddr.h> + +phys_size_t initdram(int board_type) +{ + ddr_tap_tunning(); + return get_ram_size((void *)KSEG1, SZ_256M); +} diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h new file mode 100644 index 0000000..61321e8 --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -0,0 +1,1136 @@ +/* + * Atheros AR71XX/AR724X/AR913X SoC register definitions + * + * Copyright (C) 2015 Wills Wang, wills.wang@live.com + * Copyright (C) 2010-2011 Jaiganesh Narayanan jnarayanan@atheros.com + * Copyright (C) 2008-2010 Gabor Juhos juhosg@openwrt.org + * Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_AR71XX_REGS_H +#define __ASM_MACH_AR71XX_REGS_H + +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#else +#ifndef BIT +#define BIT(nr) (1UL << (nr)) +#endif +#endif + +#define AR71XX_APB_BASE 0x18000000 +#define AR71XX_GE0_BASE 0x19000000 +#define AR71XX_GE0_SIZE 0x10000 +#define AR71XX_GE1_BASE 0x1a000000 +#define AR71XX_GE1_SIZE 0x10000 +#define AR71XX_EHCI_BASE 0x1b000000 +#define AR71XX_EHCI_SIZE 0x1000 +#define AR71XX_OHCI_BASE 0x1c000000 +#define AR71XX_OHCI_SIZE 0x1000 +#define AR71XX_SPI_BASE 0x1f000000 +#define AR71XX_SPI_SIZE 0x01000000 + +#define AR71XX_DDR_CTRL_BASE (AR71XX_APB_BASE + 0x00000000) +#define AR71XX_DDR_CTRL_SIZE 0x100 +#define AR71XX_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR71XX_UART_SIZE 0x100 +#define AR71XX_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR71XX_USB_CTRL_SIZE 0x100 +#define AR71XX_GPIO_BASE (AR71XX_APB_BASE + 0x00040000) +#define AR71XX_GPIO_SIZE 0x100 +#define AR71XX_PLL_BASE (AR71XX_APB_BASE + 0x00050000) +#define AR71XX_PLL_SIZE 0x100 +#define AR71XX_RESET_BASE (AR71XX_APB_BASE + 0x00060000) +#define AR71XX_RESET_SIZE 0x100 +#define AR71XX_MII_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR71XX_MII_SIZE 0x100 + +#define AR71XX_PCI_MEM_BASE 0x10000000 +#define AR71XX_PCI_MEM_SIZE 0x07000000 + +#define AR71XX_PCI_WIN0_OFFS 0x10000000 +#define AR71XX_PCI_WIN1_OFFS 0x11000000 +#define AR71XX_PCI_WIN2_OFFS 0x12000000 +#define AR71XX_PCI_WIN3_OFFS 0x13000000 +#define AR71XX_PCI_WIN4_OFFS 0x14000000 +#define AR71XX_PCI_WIN5_OFFS 0x15000000 +#define AR71XX_PCI_WIN6_OFFS 0x16000000 +#define AR71XX_PCI_WIN7_OFFS 0x07000000 + +#define AR71XX_PCI_CFG_BASE \ + (AR71XX_PCI_MEM_BASE + AR71XX_PCI_WIN7_OFFS + 0x10000) +#define AR71XX_PCI_CFG_SIZE 0x100 + +#define AR7240_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR7240_USB_CTRL_SIZE 0x100 +#define AR7240_OHCI_BASE 0x1b000000 +#define AR7240_OHCI_SIZE 0x1000 + +#define AR724X_PCI_MEM_BASE 0x10000000 +#define AR724X_PCI_MEM_SIZE 0x04000000 + +#define AR724X_PCI_CFG_BASE 0x14000000 +#define AR724X_PCI_CFG_SIZE 0x1000 +#define AR724X_PCI_CRP_BASE (AR71XX_APB_BASE + 0x000c0000) +#define AR724X_PCI_CRP_SIZE 0x1000 +#define AR724X_PCI_CTRL_BASE (AR71XX_APB_BASE + 0x000f0000) +#define AR724X_PCI_CTRL_SIZE 0x100 + +#define AR724X_EHCI_BASE 0x1b000000 +#define AR724X_EHCI_SIZE 0x1000 + +#define AR913X_EHCI_BASE 0x1b000000 +#define AR913X_EHCI_SIZE 0x1000 +#define AR913X_WMAC_BASE (AR71XX_APB_BASE + 0x000C0000) +#define AR913X_WMAC_SIZE 0x30000 + +#define AR933X_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR933X_UART_SIZE 0x14 +#define AR933X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR933X_GMAC_SIZE 0x04 +#define AR933X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR933X_WMAC_SIZE 0x20000 +#define AR933X_RTC_BASE (AR71XX_APB_BASE + 0x00107000) +#define AR933X_RTC_SIZE 0x1000 +#define AR933X_EHCI_BASE 0x1b000000 +#define AR933X_EHCI_SIZE 0x1000 +#define AR933X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR933X_SRIF_SIZE 0x1000 + +#define AR934X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR934X_GMAC_SIZE 0x14 +#define AR934X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR934X_WMAC_SIZE 0x20000 +#define AR934X_EHCI_BASE 0x1b000000 +#define AR934X_EHCI_SIZE 0x200 +#define AR934X_NFC_BASE 0x1b000200 +#define AR934X_NFC_SIZE 0xb8 +#define AR934X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR934X_SRIF_SIZE 0x1000 + +#define QCA953X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA953X_GMAC_SIZE 0x14 +#define QCA953X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA953X_WMAC_SIZE 0x20000 +#define QCA953X_EHCI_BASE 0x1b000000 +#define QCA953X_EHCI_SIZE 0x200 +#define QCA953X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define QCA953X_SRIF_SIZE 0x1000 + +#define QCA953X_PCI_CFG_BASE0 0x14000000 +#define QCA953X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA953X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA953X_PCI_MEM_BASE0 0x10000000 +#define QCA953X_PCI_MEM_SIZE 0x02000000 + +#define QCA955X_PCI_MEM_BASE0 0x10000000 +#define QCA955X_PCI_MEM_BASE1 0x12000000 +#define QCA955X_PCI_MEM_SIZE 0x02000000 +#define QCA955X_PCI_CFG_BASE0 0x14000000 +#define QCA955X_PCI_CFG_BASE1 0x16000000 +#define QCA955X_PCI_CFG_SIZE 0x1000 +#define QCA955X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA955X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA955X_PCI_CRP_SIZE 0x1000 +#define QCA955X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA955X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA955X_PCI_CTRL_SIZE 0x100 + +#define QCA955X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA955X_GMAC_SIZE 0x40 +#define QCA955X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA955X_WMAC_SIZE 0x20000 +#define QCA955X_EHCI0_BASE 0x1b000000 +#define QCA955X_EHCI1_BASE 0x1b400000 +#define QCA955X_EHCI_SIZE 0x1000 +#define QCA955X_NFC_BASE 0x1b800200 +#define QCA955X_NFC_SIZE 0xb8 + +#define QCA956X_PCI_MEM_BASE1 0x12000000 +#define QCA956X_PCI_MEM_SIZE 0x02000000 +#define QCA956X_PCI_CFG_BASE1 0x16000000 +#define QCA956X_PCI_CFG_SIZE 0x1000 +#define QCA956X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA956X_PCI_CRP_SIZE 0x1000 +#define QCA956X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA956X_PCI_CTRL_SIZE 0x100 + +#define QCA956X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA956X_WMAC_SIZE 0x20000 +#define QCA956X_EHCI0_BASE 0x1b000000 +#define QCA956X_EHCI1_BASE 0x1b400000 +#define QCA956X_EHCI_SIZE 0x200 +#define QCA956X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA956X_GMAC_SIZE 0x64 + +#define AR9300_OTP_BASE 0x14000 +#define AR9300_OTP_STATUS 0x15f18 +#define AR9300_OTP_STATUS_TYPE 0x7 +#define AR9300_OTP_STATUS_VALID 0x4 +#define AR9300_OTP_STATUS_ACCESS_BUSY 0x2 +#define AR9300_OTP_STATUS_SM_BUSY 0x1 +#define AR9300_OTP_READ_DATA 0x15f1c + +/* + * DDR_CTRL block + */ +#define AR71XX_DDR_REG_CONFIG 0x00 +#define AR71XX_DDR_REG_CONFIG2 0x04 +#define AR71XX_DDR_REG_MODE 0x08 +#define AR71XX_DDR_REG_EMR 0x0c +#define AR71XX_DDR_REG_CONTROL 0x10 +#define AR71XX_DDR_REG_REFRESH 0x14 +#define AR71XX_DDR_REG_RD_CYCLE 0x18 +#define AR71XX_DDR_REG_TAP_CTRL0 0x1c +#define AR71XX_DDR_REG_TAP_CTRL1 0x20 + +#define AR71XX_DDR_REG_PCI_WIN0 0x7c +#define AR71XX_DDR_REG_PCI_WIN1 0x80 +#define AR71XX_DDR_REG_PCI_WIN2 0x84 +#define AR71XX_DDR_REG_PCI_WIN3 0x88 +#define AR71XX_DDR_REG_PCI_WIN4 0x8c +#define AR71XX_DDR_REG_PCI_WIN5 0x90 +#define AR71XX_DDR_REG_PCI_WIN6 0x94 +#define AR71XX_DDR_REG_PCI_WIN7 0x98 +#define AR71XX_DDR_REG_FLUSH_GE0 0x9c +#define AR71XX_DDR_REG_FLUSH_GE1 0xa0 +#define AR71XX_DDR_REG_FLUSH_USB 0xa4 +#define AR71XX_DDR_REG_FLUSH_PCI 0xa8 + +#define AR724X_DDR_REG_FLUSH_GE0 0x7c +#define AR724X_DDR_REG_FLUSH_GE1 0x80 +#define AR724X_DDR_REG_FLUSH_USB 0x84 +#define AR724X_DDR_REG_FLUSH_PCIE 0x88 + +#define AR913X_DDR_REG_FLUSH_GE0 0x7c +#define AR913X_DDR_REG_FLUSH_GE1 0x80 +#define AR913X_DDR_REG_FLUSH_USB 0x84 +#define AR913X_DDR_REG_FLUSH_WMAC 0x88 + +#define AR933X_DDR_REG_FLUSH_GE0 0x7c +#define AR933X_DDR_REG_FLUSH_GE1 0x80 +#define AR933X_DDR_REG_FLUSH_USB 0x84 +#define AR933X_DDR_REG_FLUSH_WMAC 0x88 +#define AR933X_DDR_REG_DDR2_CONFIG 0x8c +#define AR933X_DDR_REG_EMR2 0x90 +#define AR933X_DDR_REG_EMR3 0x94 +#define AR933X_DDR_REG_BURST 0x98 +#define AR933X_DDR_REG_TIMEOUT_MAX 0x9c +#define AR933X_DDR_REG_TIMEOUT_CNT 0x9c +#define AR933X_DDR_REG_TIMEOUT_ADDR 0x9c + +#define AR934X_DDR_REG_FLUSH_GE0 0x9c +#define AR934X_DDR_REG_FLUSH_GE1 0xa0 +#define AR934X_DDR_REG_FLUSH_USB 0xa4 +#define AR934X_DDR_REG_FLUSH_PCIE 0xa8 +#define AR934X_DDR_REG_FLUSH_WMAC 0xac + +#define QCA953X_DDR_REG_FLUSH_GE0 0x9c +#define QCA953X_DDR_REG_FLUSH_GE1 0xa0 +#define QCA953X_DDR_REG_FLUSH_USB 0xa4 +#define QCA953X_DDR_REG_FLUSH_PCIE 0xa8 +#define QCA953X_DDR_REG_FLUSH_WMAC 0xac + +/* + * PLL block + */ +#define AR71XX_PLL_REG_CPU_CONFIG 0x00 +#define AR71XX_PLL_REG_SEC_CONFIG 0x04 +#define AR71XX_PLL_REG_ETH0_INT_CLOCK 0x10 +#define AR71XX_PLL_REG_ETH1_INT_CLOCK 0x14 + +#define AR71XX_PLL_DIV_SHIFT 3 +#define AR71XX_PLL_DIV_MASK 0x1f +#define AR71XX_CPU_DIV_SHIFT 16 +#define AR71XX_CPU_DIV_MASK 0x3 +#define AR71XX_DDR_DIV_SHIFT 18 +#define AR71XX_DDR_DIV_MASK 0x3 +#define AR71XX_AHB_DIV_SHIFT 20 +#define AR71XX_AHB_DIV_MASK 0x7 + +#define AR71XX_ETH0_PLL_SHIFT 17 +#define AR71XX_ETH1_PLL_SHIFT 19 + +#define AR724X_PLL_REG_CPU_CONFIG 0x00 +#define AR724X_PLL_REG_PCIE_CONFIG 0x18 + +#define AR724X_PLL_DIV_SHIFT 0 +#define AR724X_PLL_DIV_MASK 0x3ff +#define AR724X_PLL_REF_DIV_SHIFT 10 +#define AR724X_PLL_REF_DIV_MASK 0xf +#define AR724X_AHB_DIV_SHIFT 19 +#define AR724X_AHB_DIV_MASK 0x1 +#define AR724X_DDR_DIV_SHIFT 22 +#define AR724X_DDR_DIV_MASK 0x3 + +#define AR7242_PLL_REG_ETH0_INT_CLOCK 0x2c + +#define AR913X_PLL_REG_CPU_CONFIG 0x00 +#define AR913X_PLL_REG_ETH_CONFIG 0x04 +#define AR913X_PLL_REG_ETH0_INT_CLOCK 0x14 +#define AR913X_PLL_REG_ETH1_INT_CLOCK 0x18 + +#define AR913X_PLL_DIV_SHIFT 0 +#define AR913X_PLL_DIV_MASK 0x3ff +#define AR913X_DDR_DIV_SHIFT 22 +#define AR913X_DDR_DIV_MASK 0x3 +#define AR913X_AHB_DIV_SHIFT 19 +#define AR913X_AHB_DIV_MASK 0x1 + +#define AR913X_ETH0_PLL_SHIFT 20 +#define AR913X_ETH1_PLL_SHIFT 22 + +#define AR933X_PLL_CPU_CONFIG_REG 0x00 +#define AR933X_PLL_CLOCK_CTRL_REG 0x08 +#define AR933X_PLL_DITHER_FRAC_REG 0x10 + +#define AR933X_PLL_CPU_CONFIG_DIVINT_SHIFT 10 +#define AR933X_PLL_CPU_CONFIG_DIVINT_MASK 0x3f +#define AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT 16 +#define AR933X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT 23 +#define AR933X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7 + +#define AR933X_PLL_CLOCK_CTRL_BYPASS BIT(2) +#define AR933X_PLL_CLOCK_CTRL_CPU_DIV_SHIFT 5 +#define AR933X_PLL_CLOCK_CTRL_CPU_DIV_MASK 0x3 +#define AR933X_PLL_CLOCK_CTRL_DDR_DIV_SHIFT 10 +#define AR933X_PLL_CLOCK_CTRL_DDR_DIV_MASK 0x3 +#define AR933X_PLL_CLOCK_CTRL_AHB_DIV_SHIFT 15 +#define AR933X_PLL_CLOCK_CTRL_AHB_DIV_MASK 0x7 + +#define AR934X_PLL_CPU_CONFIG_REG 0x00 +#define AR934X_PLL_DDR_CONFIG_REG 0x04 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_REG 0x08 +#define AR934X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define AR934X_PLL_ETH_XMII_CONTROL_REG 0x2c + +#define AR934X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define AR934X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define AR934X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define AR934X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3 + +#define AR934X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define AR934X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define AR934X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define AR934X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define AR934X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +#define AR934X_PLL_SWITCH_CLOCK_CONTROL_MDIO_CLK_SEL BIT(6) + +#define QCA953X_PLL_CPU_CONFIG_REG 0x00 +#define QCA953X_PLL_DDR_CONFIG_REG 0x04 +#define QCA953X_PLL_CLK_CTRL_REG 0x08 +#define QCA953X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define QCA953X_PLL_ETH_XMII_CONTROL_REG 0x2c +#define QCA953X_PLL_ETH_SGMII_CONTROL_REG 0x48 + +#define QCA953X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA953X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA953X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7 + +#define QCA953X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA953X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA953X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA953X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define QCA953X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA953X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA953X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA953X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA953X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +#define QCA955X_PLL_CPU_CONFIG_REG 0x00 +#define QCA955X_PLL_DDR_CONFIG_REG 0x04 +#define QCA955X_PLL_CLK_CTRL_REG 0x08 +#define QCA955X_PLL_ETH_XMII_CONTROL_REG 0x28 +#define QCA955X_PLL_ETH_SGMII_CONTROL_REG 0x48 + +#define QCA955X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA955X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA955X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3 + +#define QCA955X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA955X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA955X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA955X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define QCA955X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA955X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA955X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA955X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA955X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +#define QCA956X_PLL_CPU_CONFIG_REG 0x00 +#define QCA956X_PLL_CPU_CONFIG1_REG 0x04 +#define QCA956X_PLL_DDR_CONFIG_REG 0x08 +#define QCA956X_PLL_DDR_CONFIG1_REG 0x0c +#define QCA956X_PLL_CLK_CTRL_REG 0x10 + +#define QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA956X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7 + +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_CPU_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_CPU_CONFIG1_NINT_MASK 0x1ff + +#define QCA956X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA956X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_DDR_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_DDR_CONFIG1_NINT_MASK 0x1ff + +#define QCA956X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA956X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA956X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_DDRPLL BIT(20) +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_CPUPLL BIT(21) +#define QCA956X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +/* + * USB_CONFIG block + */ +#define AR71XX_USB_CTRL_REG_FLADJ 0x00 +#define AR71XX_USB_CTRL_REG_CONFIG 0x04 + +/* + * RESET block + */ +#define AR71XX_RESET_REG_TIMER 0x00 +#define AR71XX_RESET_REG_TIMER_RELOAD 0x04 +#define AR71XX_RESET_REG_WDOG_CTRL 0x08 +#define AR71XX_RESET_REG_WDOG 0x0c +#define AR71XX_RESET_REG_MISC_INT_STATUS 0x10 +#define AR71XX_RESET_REG_MISC_INT_ENABLE 0x14 +#define AR71XX_RESET_REG_PCI_INT_STATUS 0x18 +#define AR71XX_RESET_REG_PCI_INT_ENABLE 0x1c +#define AR71XX_RESET_REG_GLOBAL_INT_STATUS 0x20 +#define AR71XX_RESET_REG_RESET_MODULE 0x24 +#define AR71XX_RESET_REG_PERFC_CTRL 0x2c +#define AR71XX_RESET_REG_PERFC0 0x30 +#define AR71XX_RESET_REG_PERFC1 0x34 +#define AR71XX_RESET_REG_REV_ID 0x90 + +#define AR913X_RESET_REG_GLOBAL_INT_STATUS 0x18 +#define AR913X_RESET_REG_RESET_MODULE 0x1c +#define AR913X_RESET_REG_PERF_CTRL 0x20 +#define AR913X_RESET_REG_PERFC0 0x24 +#define AR913X_RESET_REG_PERFC1 0x28 + +#define AR724X_RESET_REG_RESET_MODULE 0x1c + +#define AR933X_RESET_REG_RESET_MODULE 0x1c +#define AR933X_RESET_REG_BOOTSTRAP 0xac + +#define AR934X_RESET_REG_RESET_MODULE 0x1c +#define AR934X_RESET_REG_BOOTSTRAP 0xb0 +#define AR934X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac + +#define QCA953X_RESET_REG_RESET_MODULE 0x1c +#define QCA953X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA953X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac + +#define QCA955X_RESET_REG_RESET_MODULE 0x1c +#define QCA955X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA955X_RESET_REG_EXT_INT_STATUS 0xac + +#define QCA956X_RESET_REG_RESET_MODULE 0x1c +#define QCA956X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA956X_RESET_REG_EXT_INT_STATUS 0xac + +#define MISC_INT_MIPS_SI_TIMERINT_MASK BIT(28) +#define MISC_INT_ETHSW BIT(12) +#define MISC_INT_TIMER4 BIT(10) +#define MISC_INT_TIMER3 BIT(9) +#define MISC_INT_TIMER2 BIT(8) +#define MISC_INT_DMA BIT(7) +#define MISC_INT_OHCI BIT(6) +#define MISC_INT_PERFC BIT(5) +#define MISC_INT_WDOG BIT(4) +#define MISC_INT_UART BIT(3) +#define MISC_INT_GPIO BIT(2) +#define MISC_INT_ERROR BIT(1) +#define MISC_INT_TIMER BIT(0) + +#define AR71XX_RESET_EXTERNAL BIT(28) +#define AR71XX_RESET_FULL_CHIP BIT(24) +#define AR71XX_RESET_CPU_NMI BIT(21) +#define AR71XX_RESET_CPU_COLD BIT(20) +#define AR71XX_RESET_DMA BIT(19) +#define AR71XX_RESET_SLIC BIT(18) +#define AR71XX_RESET_STEREO BIT(17) +#define AR71XX_RESET_DDR BIT(16) +#define AR71XX_RESET_GE1_MAC BIT(13) +#define AR71XX_RESET_GE1_PHY BIT(12) +#define AR71XX_RESET_USBSUS_OVERRIDE BIT(10) +#define AR71XX_RESET_GE0_MAC BIT(9) +#define AR71XX_RESET_GE0_PHY BIT(8) +#define AR71XX_RESET_USB_OHCI_DLL BIT(6) +#define AR71XX_RESET_USB_HOST BIT(5) +#define AR71XX_RESET_USB_PHY BIT(4) +#define AR71XX_RESET_PCI_BUS BIT(1) +#define AR71XX_RESET_PCI_CORE BIT(0) + +#define AR7240_RESET_USB_HOST BIT(5) +#define AR7240_RESET_OHCI_DLL BIT(3) + +#define AR724X_RESET_GE1_MDIO BIT(23) +#define AR724X_RESET_GE0_MDIO BIT(22) +#define AR724X_RESET_PCIE_PHY_SERIAL BIT(10) +#define AR724X_RESET_PCIE_PHY BIT(7) +#define AR724X_RESET_PCIE BIT(6) +#define AR724X_RESET_USB_HOST BIT(5) +#define AR724X_RESET_USB_PHY BIT(4) +#define AR724X_RESET_USBSUS_OVERRIDE BIT(3) + +#define AR913X_RESET_AMBA2WMAC BIT(22) +#define AR913X_RESET_USBSUS_OVERRIDE BIT(10) +#define AR913X_RESET_USB_HOST BIT(5) +#define AR913X_RESET_USB_PHY BIT(4) + +#define AR933X_RESET_GE1_MDIO BIT(23) +#define AR933X_RESET_GE0_MDIO BIT(22) +#define AR933X_RESET_GE1_MAC BIT(13) +#define AR933X_RESET_WMAC BIT(11) +#define AR933X_RESET_GE0_MAC BIT(9) +#define AR933X_RESET_USB_HOST BIT(5) +#define AR933X_RESET_USB_PHY BIT(4) +#define AR933X_RESET_USBSUS_OVERRIDE BIT(3) + +#define AR934X_RESET_HOST BIT(31) +#define AR934X_RESET_SLIC BIT(30) +#define AR934X_RESET_HDMA BIT(29) +#define AR934X_RESET_EXTERNAL BIT(28) +#define AR934X_RESET_RTC BIT(27) +#define AR934X_RESET_PCIE_EP_INT BIT(26) +#define AR934X_RESET_CHKSUM_ACC BIT(25) +#define AR934X_RESET_FULL_CHIP BIT(24) +#define AR934X_RESET_GE1_MDIO BIT(23) +#define AR934X_RESET_GE0_MDIO BIT(22) +#define AR934X_RESET_CPU_NMI BIT(21) +#define AR934X_RESET_CPU_COLD BIT(20) +#define AR934X_RESET_HOST_RESET_INT BIT(19) +#define AR934X_RESET_PCIE_EP BIT(18) +#define AR934X_RESET_UART1 BIT(17) +#define AR934X_RESET_DDR BIT(16) +#define AR934X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define AR934X_RESET_NANDF BIT(14) +#define AR934X_RESET_GE1_MAC BIT(13) +#define AR934X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define AR934X_RESET_USB_PHY_ANALOG BIT(11) +#define AR934X_RESET_HOST_DMA_INT BIT(10) +#define AR934X_RESET_GE0_MAC BIT(9) +#define AR934X_RESET_ETH_SWITCH BIT(8) +#define AR934X_RESET_PCIE_PHY BIT(7) +#define AR934X_RESET_PCIE BIT(6) +#define AR934X_RESET_USB_HOST BIT(5) +#define AR934X_RESET_USB_PHY BIT(4) +#define AR934X_RESET_USBSUS_OVERRIDE BIT(3) +#define AR934X_RESET_LUT BIT(2) +#define AR934X_RESET_MBOX BIT(1) +#define AR934X_RESET_I2S BIT(0) + +#define QCA953X_RESET_USB_EXT_PWR BIT(29) +#define QCA953X_RESET_EXTERNAL BIT(28) +#define QCA953X_RESET_RTC BIT(27) +#define QCA953X_RESET_FULL_CHIP BIT(24) +#define QCA953X_RESET_GE1_MDIO BIT(23) +#define QCA953X_RESET_GE0_MDIO BIT(22) +#define QCA953X_RESET_CPU_NMI BIT(21) +#define QCA953X_RESET_CPU_COLD BIT(20) +#define QCA953X_RESET_DDR BIT(16) +#define QCA953X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA953X_RESET_GE1_MAC BIT(13) +#define QCA953X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define QCA953X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA953X_RESET_GE0_MAC BIT(9) +#define QCA953X_RESET_ETH_SWITCH BIT(8) +#define QCA953X_RESET_PCIE_PHY BIT(7) +#define QCA953X_RESET_PCIE BIT(6) +#define QCA953X_RESET_USB_HOST BIT(5) +#define QCA953X_RESET_USB_PHY BIT(4) +#define QCA953X_RESET_USBSUS_OVERRIDE BIT(3) + +#define QCA955X_RESET_HOST BIT(31) +#define QCA955X_RESET_SLIC BIT(30) +#define QCA955X_RESET_HDMA BIT(29) +#define QCA955X_RESET_EXTERNAL BIT(28) +#define QCA955X_RESET_RTC BIT(27) +#define QCA955X_RESET_PCIE_EP_INT BIT(26) +#define QCA955X_RESET_CHKSUM_ACC BIT(25) +#define QCA955X_RESET_FULL_CHIP BIT(24) +#define QCA955X_RESET_GE1_MDIO BIT(23) +#define QCA955X_RESET_GE0_MDIO BIT(22) +#define QCA955X_RESET_CPU_NMI BIT(21) +#define QCA955X_RESET_CPU_COLD BIT(20) +#define QCA955X_RESET_HOST_RESET_INT BIT(19) +#define QCA955X_RESET_PCIE_EP BIT(18) +#define QCA955X_RESET_UART1 BIT(17) +#define QCA955X_RESET_DDR BIT(16) +#define QCA955X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA955X_RESET_NANDF BIT(14) +#define QCA955X_RESET_GE1_MAC BIT(13) +#define QCA955X_RESET_SGMII_ANALOG BIT(12) +#define QCA955X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA955X_RESET_HOST_DMA_INT BIT(10) +#define QCA955X_RESET_GE0_MAC BIT(9) +#define QCA955X_RESET_SGMII BIT(8) +#define QCA955X_RESET_PCIE_PHY BIT(7) +#define QCA955X_RESET_PCIE BIT(6) +#define QCA955X_RESET_USB_HOST BIT(5) +#define QCA955X_RESET_USB_PHY BIT(4) +#define QCA955X_RESET_USBSUS_OVERRIDE BIT(3) +#define QCA955X_RESET_LUT BIT(2) +#define QCA955X_RESET_MBOX BIT(1) +#define QCA955X_RESET_I2S BIT(0) + +#define AR933X_BOOTSTRAP_MDIO_GPIO_EN BIT(18) +#define AR933X_BOOTSTRAP_DDR2 BIT(13) +#define AR933X_BOOTSTRAP_EEPBUSY BIT(4) +#define AR933X_BOOTSTRAP_REF_CLK_40 BIT(0) + +#define AR934X_BOOTSTRAP_SW_OPTION8 BIT(23) +#define AR934X_BOOTSTRAP_SW_OPTION7 BIT(22) +#define AR934X_BOOTSTRAP_SW_OPTION6 BIT(21) +#define AR934X_BOOTSTRAP_SW_OPTION5 BIT(20) +#define AR934X_BOOTSTRAP_SW_OPTION4 BIT(19) +#define AR934X_BOOTSTRAP_SW_OPTION3 BIT(18) +#define AR934X_BOOTSTRAP_SW_OPTION2 BIT(17) +#define AR934X_BOOTSTRAP_SW_OPTION1 BIT(16) +#define AR934X_BOOTSTRAP_USB_MODE_DEVICE BIT(7) +#define AR934X_BOOTSTRAP_PCIE_RC BIT(6) +#define AR934X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define AR934X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define AR934X_BOOTSTRAP_BOOT_FROM_SPI BIT(2) +#define AR934X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define AR934X_BOOTSTRAP_DDR1 BIT(0) + +#define QCA953X_BOOTSTRAP_SW_OPTION2 BIT(12) +#define QCA953X_BOOTSTRAP_SW_OPTION1 BIT(11) +#define QCA953X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define QCA953X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define QCA953X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define QCA953X_BOOTSTRAP_DDR1 BIT(0) + +#define QCA955X_BOOTSTRAP_REF_CLK_40 BIT(4) + +#define QCA956X_BOOTSTRAP_REF_CLK_40 BIT(2) + +#define AR934X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define AR934X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define AR934X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define AR934X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define AR934X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define AR934X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define AR934X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define AR934X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define AR934X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define AR934X_PCIE_WMAC_INT_WMAC_ALL \ + (AR934X_PCIE_WMAC_INT_WMAC_MISC | AR934X_PCIE_WMAC_INT_WMAC_TX | \ + AR934X_PCIE_WMAC_INT_WMAC_RXLP | AR934X_PCIE_WMAC_INT_WMAC_RXHP) + +#define AR934X_PCIE_WMAC_INT_PCIE_ALL \ + (AR934X_PCIE_WMAC_INT_PCIE_RC | AR934X_PCIE_WMAC_INT_PCIE_RC0 | \ + AR934X_PCIE_WMAC_INT_PCIE_RC1 | AR934X_PCIE_WMAC_INT_PCIE_RC2 | \ + AR934X_PCIE_WMAC_INT_PCIE_RC3) + +#define QCA953X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define QCA953X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define QCA953X_PCIE_WMAC_INT_WMAC_ALL \ + (QCA953X_PCIE_WMAC_INT_WMAC_MISC | QCA953X_PCIE_WMAC_INT_WMAC_TX | \ + QCA953X_PCIE_WMAC_INT_WMAC_RXLP | QCA953X_PCIE_WMAC_INT_WMAC_RXHP) + +#define QCA953X_PCIE_WMAC_INT_PCIE_ALL \ + (QCA953X_PCIE_WMAC_INT_PCIE_RC | QCA953X_PCIE_WMAC_INT_PCIE_RC0 | \ + QCA953X_PCIE_WMAC_INT_PCIE_RC1 | QCA953X_PCIE_WMAC_INT_PCIE_RC2 | \ + QCA953X_PCIE_WMAC_INT_PCIE_RC3) + +#define QCA955X_EXT_INT_WMAC_MISC BIT(0) +#define QCA955X_EXT_INT_WMAC_TX BIT(1) +#define QCA955X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA955X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA955X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA955X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA955X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA955X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA955X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA955X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA955X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA955X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA955X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA955X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA955X_EXT_INT_USB1 BIT(24) +#define QCA955X_EXT_INT_USB2 BIT(28) + +#define QCA955X_EXT_INT_WMAC_ALL \ + (QCA955X_EXT_INT_WMAC_MISC | QCA955X_EXT_INT_WMAC_TX | \ + QCA955X_EXT_INT_WMAC_RXLP | QCA955X_EXT_INT_WMAC_RXHP) + +#define QCA955X_EXT_INT_PCIE_RC1_ALL \ + (QCA955X_EXT_INT_PCIE_RC1 | QCA955X_EXT_INT_PCIE_RC1_INT0 | \ + QCA955X_EXT_INT_PCIE_RC1_INT1 | QCA955X_EXT_INT_PCIE_RC1_INT2 | \ + QCA955X_EXT_INT_PCIE_RC1_INT3) + +#define QCA955X_EXT_INT_PCIE_RC2_ALL \ + (QCA955X_EXT_INT_PCIE_RC2 | QCA955X_EXT_INT_PCIE_RC2_INT0 | \ + QCA955X_EXT_INT_PCIE_RC2_INT1 | QCA955X_EXT_INT_PCIE_RC2_INT2 | \ + QCA955X_EXT_INT_PCIE_RC2_INT3) + +#define QCA956X_EXT_INT_WMAC_MISC BIT(0) +#define QCA956X_EXT_INT_WMAC_TX BIT(1) +#define QCA956X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA956X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA956X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA956X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA956X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA956X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA956X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA956X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA956X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA956X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA956X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA956X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA956X_EXT_INT_USB1 BIT(24) +#define QCA956X_EXT_INT_USB2 BIT(28) + +#define QCA956X_EXT_INT_WMAC_ALL \ + (QCA956X_EXT_INT_WMAC_MISC | QCA956X_EXT_INT_WMAC_TX | \ + QCA956X_EXT_INT_WMAC_RXLP | QCA956X_EXT_INT_WMAC_RXHP) + +#define QCA956X_EXT_INT_PCIE_RC1_ALL \ + (QCA956X_EXT_INT_PCIE_RC1 | QCA956X_EXT_INT_PCIE_RC1_INT0 | \ + QCA956X_EXT_INT_PCIE_RC1_INT1 | QCA956X_EXT_INT_PCIE_RC1_INT2 | \ + QCA956X_EXT_INT_PCIE_RC1_INT3) + +#define QCA956X_EXT_INT_PCIE_RC2_ALL \ + (QCA956X_EXT_INT_PCIE_RC2 | QCA956X_EXT_INT_PCIE_RC2_INT0 | \ + QCA956X_EXT_INT_PCIE_RC2_INT1 | QCA956X_EXT_INT_PCIE_RC2_INT2 | \ + QCA956X_EXT_INT_PCIE_RC2_INT3) + +#define REV_ID_MAJOR_MASK 0xfff0 +#define REV_ID_MAJOR_AR71XX 0x00a0 +#define REV_ID_MAJOR_AR913X 0x00b0 +#define REV_ID_MAJOR_AR7240 0x00c0 +#define REV_ID_MAJOR_AR7241 0x0100 +#define REV_ID_MAJOR_AR7242 0x1100 +#define REV_ID_MAJOR_AR9330 0x0110 +#define REV_ID_MAJOR_AR9331 0x1110 +#define REV_ID_MAJOR_AR9341 0x0120 +#define REV_ID_MAJOR_AR9342 0x1120 +#define REV_ID_MAJOR_AR9344 0x2120 +#define REV_ID_MAJOR_QCA9533 0x0140 +#define REV_ID_MAJOR_QCA9533_V2 0x0160 +#define REV_ID_MAJOR_QCA9556 0x0130 +#define REV_ID_MAJOR_QCA9558 0x1130 +#define REV_ID_MAJOR_TP9343 0x0150 +#define REV_ID_MAJOR_QCA9561 0x1150 + +#define AR71XX_REV_ID_MINOR_MASK 0x3 +#define AR71XX_REV_ID_MINOR_AR7130 0x0 +#define AR71XX_REV_ID_MINOR_AR7141 0x1 +#define AR71XX_REV_ID_MINOR_AR7161 0x2 +#define AR71XX_REV_ID_REVISION_MASK 0x3 +#define AR71XX_REV_ID_REVISION_SHIFT 2 + +#define AR913X_REV_ID_MINOR_AR9130 0x0 +#define AR913X_REV_ID_MINOR_AR9132 0x1 + +#define AR934X_REV_ID_REVISION_MASK 0xf +#define QCA953X_REV_ID_REVISION_MASK 0xf +#define QCA955X_REV_ID_REVISION_MASK 0xf +#define QCA956X_REV_ID_REVISION_MASK 0xf + +/* + * RTC block + */ +#define AR933X_RTC_REG_RESET 0x40 +#define AR933X_RTC_REG_STATUS 0x44 +#define AR933X_RTC_REG_DERIVED 0x48 +#define AR933X_RTC_REG_FORCE_WAKE 0x4c +#define AR933X_RTC_REG_INT_CAUSE 0x50 +#define AR933X_RTC_REG_CAUSE_CLR 0x50 +#define AR933X_RTC_REG_INT_ENABLE 0x54 +#define AR933X_RTC_REG_INT_MASKE 0x58 + +/* + * SPI block + */ +#define AR71XX_SPI_REG_FS 0x00 /* Function Select */ +#define AR71XX_SPI_REG_CTRL 0x04 /* SPI Control */ +#define AR71XX_SPI_REG_IOC 0x08 /* SPI I/O Control */ +#define AR71XX_SPI_REG_RDS 0x0c /* Read Data Shift */ + +#define AR71XX_SPI_FS_GPIO BIT(0) /* Enable GPIO mode */ + +#define AR71XX_SPI_CTRL_RD BIT(6) /* Remap Disable */ +#define AR71XX_SPI_CTRL_DIV_MASK 0x3f + +#define AR71XX_SPI_IOC_DO BIT(0) /* Data Out pin */ +#define AR71XX_SPI_IOC_CLK BIT(8) /* CLK pin */ +#define AR71XX_SPI_IOC_CS(n) BIT(16 + (n)) +#define AR71XX_SPI_IOC_CS0 AR71XX_SPI_IOC_CS(0) +#define AR71XX_SPI_IOC_CS1 AR71XX_SPI_IOC_CS(1) +#define AR71XX_SPI_IOC_CS2 AR71XX_SPI_IOC_CS(2) +#define AR71XX_SPI_IOC_CS_ALL (AR71XX_SPI_IOC_CS0 | AR71XX_SPI_IOC_CS1 | \ + AR71XX_SPI_IOC_CS2) + +/* + * GPIO block + */ +#define AR71XX_GPIO_REG_OE 0x00 +#define AR71XX_GPIO_REG_IN 0x04 +#define AR71XX_GPIO_REG_OUT 0x08 +#define AR71XX_GPIO_REG_SET 0x0c +#define AR71XX_GPIO_REG_CLEAR 0x10 +#define AR71XX_GPIO_REG_INT_MODE 0x14 +#define AR71XX_GPIO_REG_INT_TYPE 0x18 +#define AR71XX_GPIO_REG_INT_POLARITY 0x1c +#define AR71XX_GPIO_REG_INT_PENDING 0x20 +#define AR71XX_GPIO_REG_INT_ENABLE 0x24 +#define AR71XX_GPIO_REG_FUNC 0x28 +#define AR933X_GPIO_REG_FUNC 0x30 + +#define AR934X_GPIO_REG_OUT_FUNC0 0x2c +#define AR934X_GPIO_REG_OUT_FUNC1 0x30 +#define AR934X_GPIO_REG_OUT_FUNC2 0x34 +#define AR934X_GPIO_REG_OUT_FUNC3 0x38 +#define AR934X_GPIO_REG_OUT_FUNC4 0x3c +#define AR934X_GPIO_REG_OUT_FUNC5 0x40 +#define AR934X_GPIO_REG_FUNC 0x6c + +#define QCA953X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA953X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA953X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA953X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA953X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA953X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA953X_GPIO_REG_FUNC 0x6c + +#define QCA953X_GPIO_OUT_MUX_SPI_CS1 10 +#define QCA953X_GPIO_OUT_MUX_SPI_CS2 11 +#define QCA953X_GPIO_OUT_MUX_SPI_CS0 9 +#define QCA953X_GPIO_OUT_MUX_SPI_CLK 8 +#define QCA953X_GPIO_OUT_MUX_SPI_MOSI 12 +#define QCA953X_GPIO_OUT_MUX_LED_LINK1 41 +#define QCA953X_GPIO_OUT_MUX_LED_LINK2 42 +#define QCA953X_GPIO_OUT_MUX_LED_LINK3 43 +#define QCA953X_GPIO_OUT_MUX_LED_LINK4 44 +#define QCA953X_GPIO_OUT_MUX_LED_LINK5 45 + +#define QCA955X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA955X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA955X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA955X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA955X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA955X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA955X_GPIO_REG_FUNC 0x6c + +#define QCA956X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA956X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA956X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA956X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA956X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA956X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA956X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA956X_GPIO_REG_IN_ENABLE3 0x50 +#define QCA956X_GPIO_REG_FUNC 0x6c + +#define QCA956X_GPIO_OUT_MUX_GE0_MDO 32 +#define QCA956X_GPIO_OUT_MUX_GE0_MDC 33 + +#define AR71XX_GPIO_COUNT 16 +#define AR7240_GPIO_COUNT 18 +#define AR7241_GPIO_COUNT 20 +#define AR913X_GPIO_COUNT 22 +#define AR933X_GPIO_COUNT 30 +#define AR934X_GPIO_COUNT 23 +#define QCA953X_GPIO_COUNT 18 +#define QCA955X_GPIO_COUNT 24 +#define QCA956X_GPIO_COUNT 23 + +/* + * SRIF block + */ +#define AR933X_SRIF_DDR_DPLL1_REG 0x240 +#define AR933X_SRIF_DDR_DPLL2_REG 0x244 +#define AR933X_SRIF_DDR_DPLL3_REG 0x248 +#define AR933X_SRIF_DDR_DPLL4_REG 0x24c + +#define AR934X_SRIF_CPU_DPLL1_REG 0x1c0 +#define AR934X_SRIF_CPU_DPLL2_REG 0x1c4 +#define AR934X_SRIF_CPU_DPLL3_REG 0x1c8 + +#define AR934X_SRIF_DDR_DPLL1_REG 0x240 +#define AR934X_SRIF_DDR_DPLL2_REG 0x244 +#define AR934X_SRIF_DDR_DPLL3_REG 0x248 + +#define AR934X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define AR934X_SRIF_DPLL1_REFDIV_MASK 0x1f +#define AR934X_SRIF_DPLL1_NINT_SHIFT 18 +#define AR934X_SRIF_DPLL1_NINT_MASK 0x1ff +#define AR934X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff + +#define AR934X_SRIF_DPLL2_LOCAL_PLL BIT(30) +#define AR934X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define AR934X_SRIF_DPLL2_OUTDIV_MASK 0x7 + +#define QCA953X_SRIF_CPU_DPLL1_REG 0x1c0 +#define QCA953X_SRIF_CPU_DPLL2_REG 0x1c4 +#define QCA953X_SRIF_CPU_DPLL3_REG 0x1c8 + +#define QCA953X_SRIF_DDR_DPLL1_REG 0x240 +#define QCA953X_SRIF_DDR_DPLL2_REG 0x244 +#define QCA953X_SRIF_DDR_DPLL3_REG 0x248 + +#define QCA953X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define QCA953X_SRIF_DPLL1_REFDIV_MASK 0x1f +#define QCA953X_SRIF_DPLL1_NINT_SHIFT 18 +#define QCA953X_SRIF_DPLL1_NINT_MASK 0x1ff +#define QCA953X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff + +#define QCA953X_SRIF_DPLL2_LOCAL_PLL BIT(30) +#define QCA953X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define QCA953X_SRIF_DPLL2_OUTDIV_MASK 0x7 + +#define AR71XX_GPIO_FUNC_STEREO_EN BIT(17) +#define AR71XX_GPIO_FUNC_SLIC_EN BIT(16) +#define AR71XX_GPIO_FUNC_SPI_CS2_EN BIT(13) +#define AR71XX_GPIO_FUNC_SPI_CS1_EN BIT(12) +#define AR71XX_GPIO_FUNC_UART_EN BIT(8) +#define AR71XX_GPIO_FUNC_USB_OC_EN BIT(4) +#define AR71XX_GPIO_FUNC_USB_CLK_EN BIT(0) + +#define AR724X_GPIO_FUNC_GE0_MII_CLK_EN BIT(19) +#define AR724X_GPIO_FUNC_SPI_EN BIT(18) +#define AR724X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR724X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR724X_GPIO_FUNC_CLK_OBS5_EN BIT(12) +#define AR724X_GPIO_FUNC_CLK_OBS4_EN BIT(11) +#define AR724X_GPIO_FUNC_CLK_OBS3_EN BIT(10) +#define AR724X_GPIO_FUNC_CLK_OBS2_EN BIT(9) +#define AR724X_GPIO_FUNC_CLK_OBS1_EN BIT(8) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR724X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR724X_GPIO_FUNC_UART_EN BIT(1) +#define AR724X_GPIO_FUNC_JTAG_DISABLE BIT(0) + +#define AR913X_GPIO_FUNC_WMAC_LED_EN BIT(22) +#define AR913X_GPIO_FUNC_EXP_PORT_CS_EN BIT(21) +#define AR913X_GPIO_FUNC_I2S_REFCLKEN BIT(20) +#define AR913X_GPIO_FUNC_I2S_MCKEN BIT(19) +#define AR913X_GPIO_FUNC_I2S1_EN BIT(18) +#define AR913X_GPIO_FUNC_I2S0_EN BIT(17) +#define AR913X_GPIO_FUNC_SLIC_EN BIT(16) +#define AR913X_GPIO_FUNC_UART_RTSCTS_EN BIT(9) +#define AR913X_GPIO_FUNC_UART_EN BIT(8) +#define AR913X_GPIO_FUNC_USB_CLK_EN BIT(4) + +#define AR933X_GPIO_FUNC_SPDIF2TCK BIT(31) +#define AR933X_GPIO_FUNC_SPDIF_EN BIT(30) +#define AR933X_GPIO_FUNC_I2SO_22_18_EN BIT(29) +#define AR933X_GPIO_FUNC_I2S_MCK_EN BIT(27) +#define AR933X_GPIO_FUNC_I2SO_EN BIT(26) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_DUPL BIT(25) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_COLL BIT(24) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_ACT BIT(23) +#define AR933X_GPIO_FUNC_SPI_EN BIT(18) +#define AR933X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR933X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR933X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR933X_GPIO_FUNC_UART_EN BIT(1) +#define AR933X_GPIO_FUNC_JTAG_DISABLE BIT(0) + +#define AR933X_GPIO_FUNC_XLNA_EN BIT(12) + +#define AR934X_GPIO_FUNC_CLK_OBS7_EN BIT(9) +#define AR934X_GPIO_FUNC_CLK_OBS6_EN BIT(8) +#define AR934X_GPIO_FUNC_CLK_OBS5_EN BIT(7) +#define AR934X_GPIO_FUNC_CLK_OBS4_EN BIT(6) +#define AR934X_GPIO_FUNC_CLK_OBS3_EN BIT(5) +#define AR934X_GPIO_FUNC_CLK_OBS2_EN BIT(4) +#define AR934X_GPIO_FUNC_CLK_OBS1_EN BIT(3) +#define AR934X_GPIO_FUNC_CLK_OBS0_EN BIT(2) +#define AR934X_GPIO_FUNC_JTAG_DISABLE BIT(1) + +#define AR934X_GPIO_OUT_GPIO 0 +#define AR934X_GPIO_OUT_SPI_CS1 7 +#define AR934X_GPIO_OUT_LED_LINK0 41 +#define AR934X_GPIO_OUT_LED_LINK1 42 +#define AR934X_GPIO_OUT_LED_LINK2 43 +#define AR934X_GPIO_OUT_LED_LINK3 44 +#define AR934X_GPIO_OUT_LED_LINK4 45 +#define AR934X_GPIO_OUT_EXT_LNA0 46 +#define AR934X_GPIO_OUT_EXT_LNA1 47 + +#define QCA955X_GPIO_OUT_GPIO 0 + +/* + * MII_CTRL block + */ +#define AR71XX_MII_REG_MII0_CTRL 0x00 +#define AR71XX_MII_REG_MII1_CTRL 0x04 + +#define AR71XX_MII_CTRL_IF_MASK 3 +#define AR71XX_MII_CTRL_SPEED_SHIFT 4 +#define AR71XX_MII_CTRL_SPEED_MASK 3 +#define AR71XX_MII_CTRL_SPEED_10 0 +#define AR71XX_MII_CTRL_SPEED_100 1 +#define AR71XX_MII_CTRL_SPEED_1000 2 + +#define AR71XX_MII0_CTRL_IF_GMII 0 +#define AR71XX_MII0_CTRL_IF_MII 1 +#define AR71XX_MII0_CTRL_IF_RGMII 2 +#define AR71XX_MII0_CTRL_IF_RMII 3 + +#define AR71XX_MII1_CTRL_IF_RGMII 0 +#define AR71XX_MII1_CTRL_IF_RMII 1 + +/* + * AR933X GMAC interface + */ +#define AR933X_GMAC_REG_ETH_CFG 0x00 + +#define AR933X_ETH_CFG_RGMII_GE0 BIT(0) +#define AR933X_ETH_CFG_MII_GE0 BIT(1) +#define AR933X_ETH_CFG_GMII_GE0 BIT(2) +#define AR933X_ETH_CFG_MII_GE0_MASTER BIT(3) +#define AR933X_ETH_CFG_MII_GE0_SLAVE BIT(4) +#define AR933X_ETH_CFG_MII_GE0_ERR_EN BIT(5) +#define AR933X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR933X_ETH_CFG_SW_PHY_ADDR_SWAP BIT(8) +#define AR933X_ETH_CFG_RMII_GE0 BIT(9) +#define AR933X_ETH_CFG_RMII_GE0_SPD_10 0 +#define AR933X_ETH_CFG_RMII_GE0_SPD_100 BIT(10) + +/* + * AR934X GMAC Interface + */ +#define AR934X_GMAC_REG_ETH_CFG 0x00 + +#define AR934X_ETH_CFG_RGMII_GMAC0 BIT(0) +#define AR934X_ETH_CFG_MII_GMAC0 BIT(1) +#define AR934X_ETH_CFG_GMII_GMAC0 BIT(2) +#define AR934X_ETH_CFG_MII_GMAC0_MASTER BIT(3) +#define AR934X_ETH_CFG_MII_GMAC0_SLAVE BIT(4) +#define AR934X_ETH_CFG_MII_GMAC0_ERR_EN BIT(5) +#define AR934X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define AR934X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR934X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define AR934X_ETH_CFG_RMII_GMAC0 BIT(10) +#define AR933X_ETH_CFG_MII_CNTL_SPEED BIT(11) +#define AR934X_ETH_CFG_RMII_GMAC0_MASTER BIT(12) +#define AR933X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13) +#define AR934X_ETH_CFG_RXD_DELAY BIT(14) +#define AR934X_ETH_CFG_RXD_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RXD_DELAY_SHIFT 14 +#define AR934X_ETH_CFG_RDV_DELAY BIT(16) +#define AR934X_ETH_CFG_RDV_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RDV_DELAY_SHIFT 16 + +/* + * QCA953X GMAC Interface + */ +#define QCA953X_GMAC_REG_ETH_CFG 0x00 + +#define QCA953X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define QCA953X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define QCA953X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define QCA953X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13) + +/* + * QCA955X GMAC Interface + */ + +#define QCA955X_GMAC_REG_ETH_CFG 0x00 + +#define QCA955X_ETH_CFG_RGMII_EN BIT(0) +#define QCA955X_ETH_CFG_GE0_SGMII BIT(6) + +#endif /* __ASM_AR71XX_H */ diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h new file mode 100644 index 0000000..58c8224 --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -0,0 +1,143 @@ +/* + * Atheros AR71XX/AR724X/AR913X common definitions + * + * Copyright (C) 2015 Wills Wang, wills.wang@live.com + * Copyright (C) 2008-2011 Gabor Juhos juhosg@openwrt.org + * Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_ATH79_H +#define __ASM_MACH_ATH79_H + +#include <linux/types.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum ath79_soc_type { + ATH79_SOC_UNKNOWN, + ATH79_SOC_AR7130, + ATH79_SOC_AR7141, + ATH79_SOC_AR7161, + ATH79_SOC_AR7240, + ATH79_SOC_AR7241, + ATH79_SOC_AR7242, + ATH79_SOC_AR9130, + ATH79_SOC_AR9132, + ATH79_SOC_AR9330, + ATH79_SOC_AR9331, + ATH79_SOC_AR9341, + ATH79_SOC_AR9342, + ATH79_SOC_AR9344, + ATH79_SOC_QCA9533, + ATH79_SOC_QCA9556, + ATH79_SOC_QCA9558, + ATH79_SOC_TP9343, + ATH79_SOC_QCA9561, +}; + +static inline int soc_is_ar71xx(void) +{ + return gd->arch.soc == ATH79_SOC_AR7130 || + gd->arch.soc == ATH79_SOC_AR7141 || + gd->arch.soc == ATH79_SOC_AR7161; +} + +static inline int soc_is_ar724x(void) +{ + return gd->arch.soc == ATH79_SOC_AR7240 || + gd->arch.soc == ATH79_SOC_AR7241 || + gd->arch.soc == ATH79_SOC_AR7242; +} + +static inline int soc_is_ar7240(void) +{ + return gd->arch.soc == ATH79_SOC_AR7240; +} + +static inline int soc_is_ar7241(void) +{ + return gd->arch.soc == ATH79_SOC_AR7241; +} + +static inline int soc_is_ar7242(void) +{ + return gd->arch.soc == ATH79_SOC_AR7242; +} + +static inline int soc_is_ar913x(void) +{ + return gd->arch.soc == ATH79_SOC_AR9130 || + gd->arch.soc == ATH79_SOC_AR9132; +} + +static inline int soc_is_ar933x(void) +{ + return gd->arch.soc == ATH79_SOC_AR9330 || + gd->arch.soc == ATH79_SOC_AR9331; +} + +static inline int soc_is_ar9341(void) +{ + return gd->arch.soc == ATH79_SOC_AR9341; +} + +static inline int soc_is_ar9342(void) +{ + return gd->arch.soc == ATH79_SOC_AR9342; +} + +static inline int soc_is_ar9344(void) +{ + return gd->arch.soc == ATH79_SOC_AR9344; +} + +static inline int soc_is_ar934x(void) +{ + return soc_is_ar9341() || + soc_is_ar9342() || + soc_is_ar9344(); +} + +static inline int soc_is_qca9533(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9533; +} + +static inline int soc_is_qca953x(void) +{ + return soc_is_qca9533(); +} + +static inline int soc_is_qca9556(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9556; +} + +static inline int soc_is_qca9558(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9558; +} + +static inline int soc_is_qca955x(void) +{ + return soc_is_qca9556() || soc_is_qca9558(); +} + +static inline int soc_is_tp9343(void) +{ + return gd->arch.soc == ATH79_SOC_TP9343; +} + +static inline int soc_is_qca9561(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9561; +} + +static inline int soc_is_qca956x(void) +{ + return soc_is_tp9343() || soc_is_qca9561(); +} + +#endif /* __ASM_MACH_ATH79_H */ diff --git a/arch/mips/mach-ath79/include/mach/ddr.h b/arch/mips/mach-ath79/include/mach/ddr.h new file mode 100644 index 0000000..3a6097e --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ddr.h @@ -0,0 +1,14 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_DDR_H +#define __ASM_MACH_DDR_H + +void ddr_init(void); +void ddr_tap_tunning(void); + +#endif /* __ASM_MACH_DDR_H */ diff --git a/arch/mips/mach-ath79/reset.c b/arch/mips/mach-ath79/reset.c new file mode 100644 index 0000000..c003c21 --- /dev/null +++ b/arch/mips/mach-ath79/reset.c @@ -0,0 +1,46 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <asm/arch/ath79.h> +#include <mach/ar71xx_regs.h> + +void _machine_restart(void) +{ + u32 val, reg = 0; + + if (soc_is_ar71xx()) + reg = AR71XX_RESET_REG_RESET_MODULE; + else if (soc_is_ar724x()) + reg = AR724X_RESET_REG_RESET_MODULE; + else if (soc_is_ar913x()) + reg = AR913X_RESET_REG_RESET_MODULE; + else if (soc_is_ar933x()) + reg = AR933X_RESET_REG_RESET_MODULE; + else if (soc_is_ar934x()) + reg = AR934X_RESET_REG_RESET_MODULE; + else if (soc_is_qca953x()) + reg = QCA953X_RESET_REG_RESET_MODULE; + else if (soc_is_qca955x()) + reg = QCA955X_RESET_REG_RESET_MODULE; + else if (soc_is_qca956x()) + reg = QCA956X_RESET_REG_RESET_MODULE; + else + puts("Reset register not defined for this SOC\n"); + + if (reg) { + val = readl(KSEG1ADDR(AR71XX_RESET_BASE + reg)); + val |= AR71XX_RESET_FULL_CHIP; + writel(val, KSEG1ADDR(AR71XX_RESET_BASE + reg)); + } + + while (1) + /* NOP */; +}
Am 29.12.2015 um 12:17 schrieb Wills Wang:
This patch enable work for ar933x SOC, tested on ar9331 board.
Signed-off-by: Wills Wang wills.wang@live.com
Changes in v5:
- Add independent Kconfig
- Use SRAM for initial stack
- Move DDR initialization into board_early_init_f
- Convert DDR tap tunning code to C
- Save SOC's version into arch_global_data
Changes in v4:
- Use global_data to save CPU/DDR/AHB clock
- Use arch_global_data to save SOC's type, revison and id
Changes in v3:
- Move SoC specific header files into arch/mips/mach-ath79/include/mach
- Optimize assembly code
- Same code style convertion
Changes in v2:
- Move all SoC specific header files into arch/mips/include/asm/arch-ath79
- Check SOC type and extract common code into arch/mips/mach-ath79
arch/mips/Kconfig | 6 + arch/mips/Makefile | 1 + arch/mips/include/asm/global_data.h | 6 + arch/mips/mach-ath79/Kconfig | 20 + arch/mips/mach-ath79/Makefile | 9 + arch/mips/mach-ath79/ar933x/Makefile | 8 + arch/mips/mach-ath79/ar933x/board.c | 42 + arch/mips/mach-ath79/ar933x/clk.c | 86 ++ arch/mips/mach-ath79/ar933x/ddr.c | 215 +++++ arch/mips/mach-ath79/ar933x/lowlevel_init.S | 286 ++++++ arch/mips/mach-ath79/cpu.c | 173 ++++ arch/mips/mach-ath79/dram.c | 17 + arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1136 +++++++++++++++++++++++ arch/mips/mach-ath79/include/mach/ath79.h | 143 +++ arch/mips/mach-ath79/include/mach/ddr.h | 14 + arch/mips/mach-ath79/reset.c | 46 + 16 files changed, 2208 insertions(+) create mode 100644 arch/mips/mach-ath79/Kconfig create mode 100644 arch/mips/mach-ath79/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/board.c create mode 100644 arch/mips/mach-ath79/ar933x/clk.c create mode 100644 arch/mips/mach-ath79/ar933x/ddr.c create mode 100644 arch/mips/mach-ath79/ar933x/lowlevel_init.S create mode 100644 arch/mips/mach-ath79/cpu.c create mode 100644 arch/mips/mach-ath79/dram.c create mode 100644 arch/mips/mach-ath79/include/mach/ar71xx_regs.h create mode 100644 arch/mips/mach-ath79/include/mach/ath79.h create mode 100644 arch/mips/mach-ath79/include/mach/ddr.h create mode 100644 arch/mips/mach-ath79/reset.c
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 388e4c0..c9c6aae 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -53,6 +53,11 @@ config TARGET_PB1X00 select SYS_MIPS_CACHE_INIT_RAM_LOAD select MIPS_TUNE_4KC
+config ARCH_ATH79
- bool "Support ath79"
- select OF_CONTROL
- select DM
endchoice
source "board/dbau1x00/Kconfig" @@ -60,6 +65,7 @@ source "board/imgtec/malta/Kconfig" source "board/micronas/vct/Kconfig" source "board/pb1x00/Kconfig" source "board/qemu-mips/Kconfig" +source "arch/mips/mach-ath79/Kconfig"
if MIPS
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 90cd590..93c461c 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -8,6 +8,7 @@ libs-y += arch/mips/cpu/ libs-y += arch/mips/lib/
machine-$(CONFIG_SOC_AU1X00) += au1x00 +machine-$(CONFIG_ARCH_ATH79) += ath79
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) libs-y += $(machdirs) diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index 2d9a0c9..3799e98 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -20,6 +20,12 @@ struct arch_global_data { unsigned long tbl; unsigned long lastinc; #endif +#ifdef CONFIG_ARCH_ATH79
- unsigned long id;
- unsigned long soc;
- unsigned long rev;
- unsigned long ver;
do you really need this at this location? global_data is only intended for variables needed before and after relocation and should be kept as small as possible. You can always read SoC info values directly from the hardware registers if you need them. There is no value in caching those infos in global_data.
#include <asm-generic/global_data.h> diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig new file mode 100644 index 0000000..52766c9 --- /dev/null +++ b/arch/mips/mach-ath79/Kconfig @@ -0,0 +1,20 @@ +menu "QCA/Atheros ath79 platforms"
- depends on ARCH_ATH79
+config SYS_VENDOR
- default "ath79"
+config SYS_SOC
- default "ath79"
+config SOC_AR933X
- bool
- select SUPPORTS_BIG_ENDIAN
- select SUPPORTS_CPU_MIPS32_R1
- select SUPPORTS_CPU_MIPS32_R2
- select SYS_MIPS_CACHE_INIT_RAM_LOAD
- select MIPS_TUNE_24KC
- help
This supports QCA/Atheros ar933x family SOCs.
+endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile new file mode 100644 index 0000000..bc0a41f --- /dev/null +++ b/arch/mips/mach-ath79/Makefile @@ -0,0 +1,9 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-y += reset.o +obj-y += cpu.o +obj-y += dram.o
+obj-$(CONFIG_SOC_AR933X) += ar933x/ diff --git a/arch/mips/mach-ath79/ar933x/Makefile b/arch/mips/mach-ath79/ar933x/Makefile new file mode 100644 index 0000000..27c7855 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/Makefile @@ -0,0 +1,8 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-y += clk.o +obj-y += board.o +obj-y += lowlevel_init.o +obj-y += ddr.o diff --git a/arch/mips/mach-ath79/ar933x/board.c b/arch/mips/mach-ath79/ar933x/board.c new file mode 100644 index 0000000..b4a76e8 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/board.c @@ -0,0 +1,42 @@ +/*
- (C) Copyright 2015
- Wills Wang, wills.wang@live.com
+#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ddr.h>
+static void uart_pin_init(void) +{
- u32 val;
* Set GPIO10 (UART_SO) as output and enable UART,
* BIT(15) in GPIO_FUNCTION_1 register must be written with 1
- val = readl(KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_OE));
- val |= BIT(10);
- writel(val, KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_OE));
- val = readl(KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_FUNC));
- val |= (AR933X_GPIO_FUNC_UART_EN | BIT(15));
- writel(val, KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_FUNC));
+#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{
- uart_pin_init();
- ddr_init();
+} +#endif
the content of this file should be moved to your board directory. As Marek already mentioned, PIN setup is board-specific. Probably not all AR933x based boards need to setup that UART pin.
diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c new file mode 100644 index 0000000..cfc4bb9 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -0,0 +1,86 @@ +/*
+static u32 ar933x_get_xtal(void) +{
- u32 val;
- val = readl(KSEG1ADDR(AR71XX_RESET_BASE + AR933X_RESET_REG_BOOTSTRAP));
now that you have implemented map_phymem(), you should always use it.
const void __iomem *regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, MAP_NOCACHE); ... val = readl(regs + AR933X_RESET_REG_BOOTSTRAP);
I'm going to sync asm/io.h and others with the kernel. Thus your current code would not compile without warnings any more. Please fix all locations in your code.
Apart from this you read the bootstrap settings in several places. You could create something like <mach/reset.h> and add a function like this
static inline u32 ar933x_get_bootstrap(void) { const void __iomem *regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, MAP_NOCACHE);
return readl(regs + AR933X_RESET_REG_BOOTSTRAP); }
- if (val & AR933X_BOOTSTRAP_REF_CLK_40)
return 40000000;
- else
return 25000000;
+int get_serial_clock(void) +{
- return ar933x_get_xtal();
+int get_clocks(void) +{
- u32 val, xtal, pll, div;
- xtal = ar933x_get_xtal();
- val = readl(KSEG1ADDR(AR71XX_PLL_BASE + AR933X_PLL_CPU_CONFIG_REG));
readl(regs + ...) as mentioned above
- /* VCOOUT = XTAL * DIV_INT */
- div = (val >> AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT)
& AR933X_PLL_CPU_CONFIG_REFDIV_MASK;
- pll = xtal / div;
- /* PLLOUT = VCOOUT * (1/2^OUTDIV) */
- div = (val >> AR933X_PLL_CPU_CONFIG_DIVINT_SHIFT)
& AR933X_PLL_CPU_CONFIG_DIVINT_MASK;
- pll *= div;
- div = (val >> AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT)
& AR933X_PLL_CPU_CONFIG_OUTDIV_MASK;
- if (!div)
div = 1;
- pll >>= div;
- val = readl(KSEG1ADDR(AR71XX_PLL_BASE + AR933X_PLL_CLOCK_CTRL_REG));
- /* CPU_CLK = PLLOUT / CPU_POST_DIV */
- div = ((val >> AR933X_PLL_CLOCK_CTRL_CPU_DIV_SHIFT)
& AR933X_PLL_CLOCK_CTRL_CPU_DIV_MASK) + 1;
- gd->cpu_clk = pll / div;
- /* DDR_CLK = PLLOUT / DDR_POST_DIV */
- div = ((val >> AR933X_PLL_CLOCK_CTRL_DDR_DIV_SHIFT)
& AR933X_PLL_CLOCK_CTRL_DDR_DIV_MASK) + 1;
- gd->mem_clk = pll / div;
- /* AHB_CLK = PLLOUT / AHB_POST_DIV */
- div = ((val >> AR933X_PLL_CLOCK_CTRL_AHB_DIV_SHIFT)
& AR933X_PLL_CLOCK_CTRL_AHB_DIV_MASK) + 1;
- gd->bus_clk = pll / div;
+ulong get_bus_freq(ulong dummy) +{
- if (!gd->bus_clk)
get_clocks();
- return gd->bus_clk;
+ulong get_ddr_freq(ulong dummy) +{
- if (!gd->mem_clk)
get_clocks();
- return gd->mem_clk;
+} diff --git a/arch/mips/mach-ath79/ar933x/ddr.c b/arch/mips/mach-ath79/ar933x/ddr.c new file mode 100644 index 0000000..3985299 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/ddr.c @@ -0,0 +1,215 @@ +/*
+void ddr_init(void) +{
- void __iomem *regs = (void *)KSEG1ADDR(AR71XX_DDR_CTRL_BASE);
map_physmem()
- u32 val;
- writel(0x7fbc8cd0, regs + AR71XX_DDR_REG_CONFIG);
- writel(0x9dd0e6a8, regs + AR71XX_DDR_REG_CONFIG2);
do not use magic values. These should be defined somewhere with descriptive names.
- val = readl(KSEG1ADDR(AR71XX_RESET_BASE) +
use the suggested ar933x_get_bootstrap() function
- if (val & AR933X_BOOTSTRAP_DDR2) {
/* Enable DDR2 */
writel(0xA59, regs + AR933X_DDR_REG_DDR2_CONFIG);
/* Precharge All */
writel(0x08, regs + AR71XX_DDR_REG_CONTROL);
/* Disable High Temperature Self-Refresh Rate */
writel(0x00, regs + AR933X_DDR_REG_EMR2);
/* Extended Mode Register 2 Set (EMR2S) */
writel(0x10, regs + AR71XX_DDR_REG_CONTROL);
writel(0x00, regs + AR933X_DDR_REG_EMR3);
/* Extended Mode Register 3 Set (EMR3S) */
writel(0x20, regs + AR71XX_DDR_REG_CONTROL);
/* Enable DLL */
writel(0x00, regs + AR71XX_DDR_REG_EMR);
/* Extended Mode Register Set (EMRS) */
writel(0x02, regs + AR71XX_DDR_REG_CONTROL);
/* Reset DLL */
writel(0x100, regs + AR71XX_DDR_REG_MODE);
/* Mode Register Set (MRS) */
writel(0x01, regs + AR71XX_DDR_REG_CONTROL);
/* Precharge All */
/* Auto Refresh */
writel(0x04, regs + AR71XX_DDR_REG_CONTROL);
/* Write recovery (WR) 6 clock, CAS Latency 3,
* Burst Length 8 */
writel(0xa33, regs + AR71XX_DDR_REG_MODE);
/* E7,E8,E9 equal to 1(Enable OCD defaults),
* Enable DLL, Reduced Drive Strength */
writel(0x382, regs + AR71XX_DDR_REG_EMR);
/* E7,E8,E9 equal to 0(OCD exit), Enable DLL,
* Reduced Drive Strength */
writel(0x402, regs + AR71XX_DDR_REG_EMR);
/* Refresh control. Bit 14 is enable.
* Bits<13:0> Refresh time */
writel(0x4270, regs + AR71XX_DDR_REG_REFRESH);
else
writel(0x4186, regs + AR71XX_DDR_REG_REFRESH);
/* DQS 0 Tap Control */
writel(0x08, regs + AR71XX_DDR_REG_TAP_CTRL0);
/* DQS 1 Tap Control */
writel(0x09, regs + AR71XX_DDR_REG_TAP_CTRL1);
/* For 16-bit DDR */
writel(0xff, regs + AR71XX_DDR_REG_RD_CYCLE);
- } else {
/* Precharge All */
/* Write Mode Word */
writel(0x133, regs + AR71XX_DDR_REG_MODE);
/* Forces an MRS update cycle in DDR */
/* Enable DLL, High drive strength from DDR */
writel(0x02, regs + AR71XX_DDR_REG_EMR);
/* Precharge All */
/* DLL out of reset, CAS Latency 3 */
writel(0x33, regs + AR71XX_DDR_REG_MODE);
else
do you mean ddr_tap_tuning() ?
map_physmem()
- u32 *addr_k0, *addr_k1, *addr;
- u32 tap, tap_val, upper, lower;
- int i, j, dir, err, done;
- addr = (void *)KSEG0ADDR(0x2000);
- for (i = 0; i < 256; i++) {
tap_val = 0;
for (j = 0; j < 8; j++) {
if (i & (1 << j)) {
if (j % 2)
tap_val |= 0xffff0000;
else
tap_val |= 0x0000ffff;
if (j % 2) {
*addr++ = tap_val;
tap_val = 0;
- err = 0;
- done = 0;
- dir = 1;
- tap = readl(regs + AR71XX_DDR_REG_TAP_CTRL0);
- tap_val = tap;
- while (!done) {
err = 0;
writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL0);
writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL1);
for (i = 0; i < 2; i++) {
addr_k1 = (void *)KSEG1ADDR(0x2000);
addr_k0 = (void *)KSEG0ADDR(0x2000);
addr = (void *)KSEG0ADDR(0x3000);
while (addr_k0 < addr) {
if (*addr_k1++ != *addr_k0++) {
err = 1;
break;
if (err)
break;
if (err) {
if (dir) {
dir = 0;
tap_val--;
upper = tap_val;
tap_val = tap;
} else {
tap_val++;
lower = tap_val;
done = 1;
} else {
if (dir) {
if (tap_val < 0x20) {
tap_val++;
} else {
dir = 0;
upper = tap_val;
tap_val = tap;
} else {
if (!tap_val) {
lower = tap_val;
done = 1;
} else {
tap_val--;
- tap_val = (upper + lower) / 2;
- writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL0);
- tap_val++;
- writel(tap_val, regs + AR71XX_DDR_REG_TAP_CTRL1);
+} diff --git a/arch/mips/mach-ath79/ar933x/lowlevel_init.S b/arch/mips/mach-ath79/ar933x/lowlevel_init.S new file mode 100644 index 0000000..9cc32bf --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/lowlevel_init.S @@ -0,0 +1,286 @@ +/*
+#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <mach/ar71xx_regs.h>
+#define SET_BIT(val, bit) ((val) | (1 << (bit))) +#define SET_PLL_PD(val) SET_BIT(val, 30) +#define AHB_DIV_TO_4(val) SET_BIT(SET_BIT(val, 15), 16) +#define PLL_BYPASS(val) SET_BIT(val, 2)
+#define MK_PLL_CONF(divint, refdiv, range, outdiv) \
(((0x3F & divint) << 10) | \
((0x1F & refdiv) << 16) | \
((0x1 & range) << 21) | \
((0x7 & outdiv) << 23) )
+#define MK_CLK_CNTL(cpudiv, ddrdiv, ahbdiv) \
- (((0x3 & (cpudiv - 1)) << 5) | \
- ((0x3 & (ddrdiv - 1)) << 10) | \
- ((0x3 & (ahbdiv - 1)) << 15) )
- PLL_CPU_CONFIG_VAL
- Bit30 is set (CPU_PLLPWD = 1 -> power down control for CPU PLL)
- After PLL configuration we need to clear this bit
- Values written into CPU PLL Configuration (CPU_PLL_CONFIG)
- bits 10..15 (6bit) DIV_INT (Integer part of the DIV to CPU PLL)
=> 32 (0x20) VCOOUT = XTAL * DIV_INT
- bits 16..20 (5bit) REFDIV (Reference clock divider)
=> 1 (0x1) [Must start at values 1]
- bits 21 (1bit) RANGE (VCO frequency range of the CPU PLL)
=> 0 (0x0) [Doesn't impact clock values]
- bits 23..25 (3bit) OUTDIV (Ratio between VCO and PLL output)
=> 1 (0x1) [0 is illegal!]
+/* DIV_INT=32 (25MHz*32/2=400MHz), REFDIV=1, RANGE=0, OUTDIV=1 */ +#define PLL_CPU_CONFIG_VAL_40M MK_PLL_CONF(20, 1, 0, 1) +/* DIV_INT=20 (40MHz*20/2=400MHz), REFDIV=1, RANGE=0, OUTDIV=1 */ +#define PLL_CPU_CONFIG_VAL_25M MK_PLL_CONF(32, 1, 0, 1)
- PLL_CLK_CONTROL_VAL
- In PLL_CLK_CONTROL_VAL bit 2 is set (BYPASS = 1 -> bypass PLL)
- Values written into CPU Clock Control Register CLOCK_CONTROL
- bits 2 (1bit) BYPASS (Bypass PLL. This defaults to 1 for test.
Software must enable the CPU PLL for normal and
then set this bit to 0)
- bits 5..6 (2bit) CPU_POST_DIV => 0 (DEFAULT, Ratio = 1)
- bits 10..11 (2bit) DDR_POST_DIV => 0 (DEFAULT, Ratio = 1)
- bits 15..16 (2bit) AHB_POST_DIV => 1 (DEFAULT, Ratio = 2)
+#define PLL_CLK_CONTROL_VAL MK_CLK_CNTL(1, 1, 2)
- .text
- .set noreorder
+LEAF(lowlevel_init)
- /* These three WLAN_RESET will avoid original issue */
- li t3, 0x03
+1:
- li t0, KSEG1ADDR(AR71XX_RESET_BASE)
- lw t1, AR933X_RESET_REG_RESET_MODULE(t0)
- ori t1, t1, 0x0800
- sw t1, AR933X_RESET_REG_RESET_MODULE(t0)
- nop
- li t2, 0xfffff7ff
- and t1, t1, t2
- nop
- addi t3, t3, -1
- bnez t3, 1b
- nop
- li t2, 0x20
+2:
- beqz t2, 1b
- nop
- addi t2, t2, -1
- lw t5, AR933X_RESET_REG_BOOTSTRAP(t0)
- andi t1, t5, 0x10
- bnez t1, 2b
- nop
- li t1, 0x02110E
- sw t1, AR933X_RESET_REG_BOOTSTRAP(t0)
- nop
- /* RTC Force Wake */
- li t0, KSEG1ADDR(AR933X_RTC_BASE)
- li t1, 0x03
- sw t1, AR933X_RTC_REG_FORCE_WAKE(t0)
- nop
- nop
- /* RTC Reset */
- li t1, 0x00
- sw t1, AR933X_RTC_REG_RESET(t0)
- nop
- nop
- li t1, 0x01
- nop
- nop
- /* Wait for RTC in on state */
+1:
- lw t1, AR933X_RTC_REG_STATUS(t0)
- andi t1, t1, 0x02
- beqz t1, 1b
- nop
- /* Program ki/kd */
- li t0, KSEG1ADDR(AR933X_SRIF_BASE)
- andi t1, t5, 0x01 # t5 BOOT_STRAP
- bnez t1, 1f
- nop
- li t1, 0x19e82f01
- b 2f
- nop
+1:
- li t1, 0x18e82f01
+2:
- sw t1, AR933X_SRIF_DDR_DPLL2_REG(t0)
- /* Program phase shift */
- lw t1, AR933X_SRIF_DDR_DPLL3_REG(t0)
- li t2, 0xc07fffff
- and t1, t1, t2
- li t2, 0x800000 # meas_at_txon
- or t1, t1, t2
- sw t1, AR933X_SRIF_DDR_DPLL3_REG(t0)
- nop
- /* Max AHB Master wait time out ... */
- li t0, KSEG1ADDR(AR71XX_DDR_CTRL_BASE)
- li t1, 0xfffff
- sw t1, AR933X_DDR_REG_TIMEOUT_MAX(t0)
- nop
- /* in some cases, the SoC doesn't start with higher clock on AHB */
- li t0, KSEG1ADDR(AR71XX_PLL_BASE)
- li t1, AHB_DIV_TO_4(PLL_BYPASS(PLL_CLK_CONTROL_VAL))
- sw t1, AR933X_PLL_CLOCK_CTRL_REG(t0)
- nop
- /* Set SETTLE_TIME in CPU PLL */
- bnez t1, 1f
- nop
- li t1, 0x0352
- b 2f
- nop
+1:
- li t1, 0x0550
+2:
- sw t1, AR71XX_PLL_REG_SEC_CONFIG(t0)
- nop
- /* Set nint, frac, refdiv, outdiv, range according to xtal */
+0:
- bnez t1, 1f
- nop
- li t1, SET_PLL_PD(PLL_CPU_CONFIG_VAL_25M)
- b 2f
- nop
+1:
- li t1, SET_PLL_PD(PLL_CPU_CONFIG_VAL_40M)
+2:
- sw t1, AR933X_PLL_CPU_CONFIG_REG(t0)
- nop
+1:
- lw t1, AR933X_PLL_CPU_CONFIG_REG(t0)
- li t2, 0x80000000
- and t1, t1, t2
- bnez t1, 1b
- nop
- /* Put frac bit19:10 configuration */
- li t1, 0x1003E8
- sw t1, AR933X_PLL_DITHER_FRAC_REG(t0)
- nop
- /* Clear PLL power down bit in CPU PLL configuration */
- bnez t1, 1f
- nop
- li t1, PLL_CPU_CONFIG_VAL_25M
- b 2f
- nop
+1:
- li t1, PLL_CPU_CONFIG_VAL_40M
+2:
- nop
- /* Wait for PLL update -> bit 31 in CPU_PLL_CONFIG should be 0 */
+1:
- li t2, 0x80000000
- and t1, t1, t2
- bnez t1, 1b
- nop
- /* Confirm DDR PLL lock */
- li t3, 100
- li t4, 0
+2:
- addi t4, t4, 1
- bgt t4, t3, 0b
- nop
- li t3, 5
+3:
- /* Clear do_meas */
- li t2, 0xBFFFFFFF
- and t1, t1, t2
- nop
- li t2, 10
+1:
- subu t2, t2, 1
- bnez t2, 1b
- nop
- /* Set do_meas */
- li t2, 0x40000000
- or t1, t1, t2
- nop
- /* Check meas_done */
+1:
- lw t1, AR933X_SRIF_DDR_DPLL4_REG(t0)
- andi t1, t1, 0x8
- beqz t1, 1b
- nop
- li t2, 0x007FFFF8
- and t1, t1, t2
- srl t1, t1, 3
- li t2, 0x4000
- bgt t1, t2, 2b
- nop
- addi t3, t3, -1
- bnez t3, 3b
- nop
- /* clear PLL bypass (bit 2) in CPU CLOCK CONTROL register */
- li t1, PLL_CLK_CONTROL_VAL
- nop
- nop
- jr ra
- nop
- END(lowlevel_init)
diff --git a/arch/mips/mach-ath79/cpu.c b/arch/mips/mach-ath79/cpu.c new file mode 100644 index 0000000..c03480d --- /dev/null +++ b/arch/mips/mach-ath79/cpu.c @@ -0,0 +1,173 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <asm/arch/ath79.h> +#include <asm/arch/ar71xx_regs.h>
+int print_cpuinfo(void) +{
- enum ath79_soc_type soc = ATH79_SOC_UNKNOWN;
- char *chip = "????";
const char *chip
- u32 id, major, minor;
- u32 rev = 0;
- u32 ver = 1;
- id = readl(KSEG1ADDR(AR71XX_RESET_BASE + AR71XX_RESET_REG_REV_ID));
- major = id & REV_ID_MAJOR_MASK;
- switch (major) {
- case REV_ID_MAJOR_AR71XX:
minor = id & AR71XX_REV_ID_MINOR_MASK;
rev = id >> AR71XX_REV_ID_REVISION_SHIFT;
rev &= AR71XX_REV_ID_REVISION_MASK;
switch (minor) {
case AR71XX_REV_ID_MINOR_AR7130:
soc = ATH79_SOC_AR7130;
chip = "7130";
break;
case AR71XX_REV_ID_MINOR_AR7141:
soc = ATH79_SOC_AR7141;
chip = "7141";
break;
case AR71XX_REV_ID_MINOR_AR7161:
soc = ATH79_SOC_AR7161;
chip = "7161";
break;
break;
- case REV_ID_MAJOR_AR7240:
soc = ATH79_SOC_AR7240;
chip = "7240";
rev = id & AR71XX_REV_ID_REVISION_MASK;
break;
- case REV_ID_MAJOR_AR7241:
soc = ATH79_SOC_AR7241;
chip = "7241";
break;
- case REV_ID_MAJOR_AR7242:
soc = ATH79_SOC_AR7242;
chip = "7242";
break;
- case REV_ID_MAJOR_AR913X:
switch (minor) {
case AR913X_REV_ID_MINOR_AR9130:
soc = ATH79_SOC_AR9130;
chip = "9130";
break;
case AR913X_REV_ID_MINOR_AR9132:
soc = ATH79_SOC_AR9132;
chip = "9132";
break;
break;
- case REV_ID_MAJOR_AR9330:
soc = ATH79_SOC_AR9330;
chip = "9330";
break;
- case REV_ID_MAJOR_AR9331:
soc = ATH79_SOC_AR9331;
chip = "9331";
break;
- case REV_ID_MAJOR_AR9341:
soc = ATH79_SOC_AR9341;
chip = "9341";
rev = id & AR934X_REV_ID_REVISION_MASK;
break;
- case REV_ID_MAJOR_AR9342:
soc = ATH79_SOC_AR9342;
chip = "9342";
break;
- case REV_ID_MAJOR_AR9344:
soc = ATH79_SOC_AR9344;
chip = "9344";
break;
- case REV_ID_MAJOR_QCA9533_V2:
ver = 2;
/* drop through */
- case REV_ID_MAJOR_QCA9533:
soc = ATH79_SOC_QCA9533;
chip = "9533";
rev = id & QCA953X_REV_ID_REVISION_MASK;
break;
- case REV_ID_MAJOR_QCA9556:
soc = ATH79_SOC_QCA9556;
chip = "9556";
rev = id & QCA955X_REV_ID_REVISION_MASK;
break;
- case REV_ID_MAJOR_QCA9558:
soc = ATH79_SOC_QCA9558;
chip = "9558";
break;
- case REV_ID_MAJOR_TP9343:
soc = ATH79_SOC_TP9343;
chip = "9343";
rev = id & QCA956X_REV_ID_REVISION_MASK;
break;
- case REV_ID_MAJOR_QCA9561:
soc = ATH79_SOC_QCA9561;
chip = "9561";
break;
- gd->arch.id = id;
- gd->arch.soc = soc;
- gd->arch.rev = rev;
- gd->arch.ver = ver;
again, no need to cache those values
- puts("SoC: ");
- switch (soc) {
- case ATH79_SOC_QCA9533:
- case ATH79_SOC_QCA9556:
- case ATH79_SOC_QCA9558:
- case ATH79_SOC_QCA9561:
printf("Qualcomm Atheros QCA%s ver %u rev %u\n", chip,
ver, rev);
break;
- case ATH79_SOC_TP9343:
printf("Qualcomm Atheros TP%s rev %u\n", chip, rev);
break;
- case ATH79_SOC_UNKNOWN:
printf("ATH79: unknown SoC, id:0x%08x", id);
break;
- default:
printf("Atheros AR%s rev %u\n", chip, rev);
+} diff --git a/arch/mips/mach-ath79/dram.c b/arch/mips/mach-ath79/dram.c new file mode 100644 index 0000000..dbd56d2 --- /dev/null +++ b/arch/mips/mach-ath79/dram.c @@ -0,0 +1,17 @@ +/*
+#include <common.h> +#include <linux/sizes.h> +#include <asm/addrspace.h> +#include <mach/ddr.h>
+phys_size_t initdram(int board_type) +{
- ddr_tap_tunning();
- return get_ram_size((void *)KSEG1, SZ_256M);
is that information available in memory controller registers?
+} diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h new file mode 100644 index 0000000..61321e8 --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -0,0 +1,1136 @@ +/*
- Atheros AR71XX/AR724X/AR913X SoC register definitions
- Copyright (C) 2015 Wills Wang, wills.wang@live.com
- Copyright (C) 2010-2011 Jaiganesh Narayanan jnarayanan@atheros.com
- Copyright (C) 2008-2010 Gabor Juhos juhosg@openwrt.org
- Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org
+#ifndef __ASM_MACH_AR71XX_REGS_H +#define __ASM_MACH_AR71XX_REGS_H
+#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#else +#ifndef BIT +#define BIT(nr) (1UL << (nr)) +#endif +#endif
+#define AR71XX_APB_BASE 0x18000000 +#define AR71XX_GE0_BASE 0x19000000 +#define AR71XX_GE0_SIZE 0x10000 +#define AR71XX_GE1_BASE 0x1a000000 +#define AR71XX_GE1_SIZE 0x10000 +#define AR71XX_EHCI_BASE 0x1b000000 +#define AR71XX_EHCI_SIZE 0x1000 +#define AR71XX_OHCI_BASE 0x1c000000 +#define AR71XX_OHCI_SIZE 0x1000 +#define AR71XX_SPI_BASE 0x1f000000 +#define AR71XX_SPI_SIZE 0x01000000
+#define AR71XX_DDR_CTRL_BASE (AR71XX_APB_BASE + 0x00000000) +#define AR71XX_DDR_CTRL_SIZE 0x100 +#define AR71XX_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR71XX_UART_SIZE 0x100 +#define AR71XX_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR71XX_USB_CTRL_SIZE 0x100 +#define AR71XX_GPIO_BASE (AR71XX_APB_BASE + 0x00040000) +#define AR71XX_GPIO_SIZE 0x100 +#define AR71XX_PLL_BASE (AR71XX_APB_BASE + 0x00050000) +#define AR71XX_PLL_SIZE 0x100 +#define AR71XX_RESET_BASE (AR71XX_APB_BASE + 0x00060000) +#define AR71XX_RESET_SIZE 0x100 +#define AR71XX_MII_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR71XX_MII_SIZE 0x100
+#define AR71XX_PCI_MEM_BASE 0x10000000 +#define AR71XX_PCI_MEM_SIZE 0x07000000
+#define AR71XX_PCI_WIN0_OFFS 0x10000000 +#define AR71XX_PCI_WIN1_OFFS 0x11000000 +#define AR71XX_PCI_WIN2_OFFS 0x12000000 +#define AR71XX_PCI_WIN3_OFFS 0x13000000 +#define AR71XX_PCI_WIN4_OFFS 0x14000000 +#define AR71XX_PCI_WIN5_OFFS 0x15000000 +#define AR71XX_PCI_WIN6_OFFS 0x16000000 +#define AR71XX_PCI_WIN7_OFFS 0x07000000
+#define AR71XX_PCI_CFG_BASE \
- (AR71XX_PCI_MEM_BASE + AR71XX_PCI_WIN7_OFFS + 0x10000)
+#define AR71XX_PCI_CFG_SIZE 0x100
+#define AR7240_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR7240_USB_CTRL_SIZE 0x100 +#define AR7240_OHCI_BASE 0x1b000000 +#define AR7240_OHCI_SIZE 0x1000
+#define AR724X_PCI_MEM_BASE 0x10000000 +#define AR724X_PCI_MEM_SIZE 0x04000000
+#define AR724X_PCI_CFG_BASE 0x14000000 +#define AR724X_PCI_CFG_SIZE 0x1000 +#define AR724X_PCI_CRP_BASE (AR71XX_APB_BASE + 0x000c0000) +#define AR724X_PCI_CRP_SIZE 0x1000 +#define AR724X_PCI_CTRL_BASE (AR71XX_APB_BASE + 0x000f0000) +#define AR724X_PCI_CTRL_SIZE 0x100
+#define AR724X_EHCI_BASE 0x1b000000 +#define AR724X_EHCI_SIZE 0x1000
+#define AR913X_EHCI_BASE 0x1b000000 +#define AR913X_EHCI_SIZE 0x1000 +#define AR913X_WMAC_BASE (AR71XX_APB_BASE + 0x000C0000) +#define AR913X_WMAC_SIZE 0x30000
+#define AR933X_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR933X_UART_SIZE 0x14 +#define AR933X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR933X_GMAC_SIZE 0x04 +#define AR933X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR933X_WMAC_SIZE 0x20000 +#define AR933X_RTC_BASE (AR71XX_APB_BASE + 0x00107000) +#define AR933X_RTC_SIZE 0x1000 +#define AR933X_EHCI_BASE 0x1b000000 +#define AR933X_EHCI_SIZE 0x1000 +#define AR933X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR933X_SRIF_SIZE 0x1000
+#define AR934X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR934X_GMAC_SIZE 0x14 +#define AR934X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR934X_WMAC_SIZE 0x20000 +#define AR934X_EHCI_BASE 0x1b000000 +#define AR934X_EHCI_SIZE 0x200 +#define AR934X_NFC_BASE 0x1b000200 +#define AR934X_NFC_SIZE 0xb8 +#define AR934X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR934X_SRIF_SIZE 0x1000
+#define QCA953X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA953X_GMAC_SIZE 0x14 +#define QCA953X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA953X_WMAC_SIZE 0x20000 +#define QCA953X_EHCI_BASE 0x1b000000 +#define QCA953X_EHCI_SIZE 0x200 +#define QCA953X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define QCA953X_SRIF_SIZE 0x1000
+#define QCA953X_PCI_CFG_BASE0 0x14000000 +#define QCA953X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA953X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA953X_PCI_MEM_BASE0 0x10000000 +#define QCA953X_PCI_MEM_SIZE 0x02000000
+#define QCA955X_PCI_MEM_BASE0 0x10000000 +#define QCA955X_PCI_MEM_BASE1 0x12000000 +#define QCA955X_PCI_MEM_SIZE 0x02000000 +#define QCA955X_PCI_CFG_BASE0 0x14000000 +#define QCA955X_PCI_CFG_BASE1 0x16000000 +#define QCA955X_PCI_CFG_SIZE 0x1000 +#define QCA955X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA955X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA955X_PCI_CRP_SIZE 0x1000 +#define QCA955X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA955X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA955X_PCI_CTRL_SIZE 0x100
+#define QCA955X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA955X_GMAC_SIZE 0x40 +#define QCA955X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA955X_WMAC_SIZE 0x20000 +#define QCA955X_EHCI0_BASE 0x1b000000 +#define QCA955X_EHCI1_BASE 0x1b400000 +#define QCA955X_EHCI_SIZE 0x1000 +#define QCA955X_NFC_BASE 0x1b800200 +#define QCA955X_NFC_SIZE 0xb8
+#define QCA956X_PCI_MEM_BASE1 0x12000000 +#define QCA956X_PCI_MEM_SIZE 0x02000000 +#define QCA956X_PCI_CFG_BASE1 0x16000000 +#define QCA956X_PCI_CFG_SIZE 0x1000 +#define QCA956X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA956X_PCI_CRP_SIZE 0x1000 +#define QCA956X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA956X_PCI_CTRL_SIZE 0x100
+#define QCA956X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA956X_WMAC_SIZE 0x20000 +#define QCA956X_EHCI0_BASE 0x1b000000 +#define QCA956X_EHCI1_BASE 0x1b400000 +#define QCA956X_EHCI_SIZE 0x200 +#define QCA956X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA956X_GMAC_SIZE 0x64
+#define AR9300_OTP_BASE 0x14000 +#define AR9300_OTP_STATUS 0x15f18 +#define AR9300_OTP_STATUS_TYPE 0x7 +#define AR9300_OTP_STATUS_VALID 0x4 +#define AR9300_OTP_STATUS_ACCESS_BUSY 0x2 +#define AR9300_OTP_STATUS_SM_BUSY 0x1 +#define AR9300_OTP_READ_DATA 0x15f1c
- DDR_CTRL block
+#define AR71XX_DDR_REG_CONFIG 0x00 +#define AR71XX_DDR_REG_CONFIG2 0x04 +#define AR71XX_DDR_REG_MODE 0x08 +#define AR71XX_DDR_REG_EMR 0x0c +#define AR71XX_DDR_REG_CONTROL 0x10 +#define AR71XX_DDR_REG_REFRESH 0x14 +#define AR71XX_DDR_REG_RD_CYCLE 0x18 +#define AR71XX_DDR_REG_TAP_CTRL0 0x1c +#define AR71XX_DDR_REG_TAP_CTRL1 0x20
+#define AR71XX_DDR_REG_PCI_WIN0 0x7c +#define AR71XX_DDR_REG_PCI_WIN1 0x80 +#define AR71XX_DDR_REG_PCI_WIN2 0x84 +#define AR71XX_DDR_REG_PCI_WIN3 0x88 +#define AR71XX_DDR_REG_PCI_WIN4 0x8c +#define AR71XX_DDR_REG_PCI_WIN5 0x90 +#define AR71XX_DDR_REG_PCI_WIN6 0x94 +#define AR71XX_DDR_REG_PCI_WIN7 0x98 +#define AR71XX_DDR_REG_FLUSH_GE0 0x9c +#define AR71XX_DDR_REG_FLUSH_GE1 0xa0 +#define AR71XX_DDR_REG_FLUSH_USB 0xa4 +#define AR71XX_DDR_REG_FLUSH_PCI 0xa8
+#define AR724X_DDR_REG_FLUSH_GE0 0x7c +#define AR724X_DDR_REG_FLUSH_GE1 0x80 +#define AR724X_DDR_REG_FLUSH_USB 0x84 +#define AR724X_DDR_REG_FLUSH_PCIE 0x88
+#define AR913X_DDR_REG_FLUSH_GE0 0x7c +#define AR913X_DDR_REG_FLUSH_GE1 0x80 +#define AR913X_DDR_REG_FLUSH_USB 0x84 +#define AR913X_DDR_REG_FLUSH_WMAC 0x88
+#define AR933X_DDR_REG_FLUSH_GE0 0x7c +#define AR933X_DDR_REG_FLUSH_GE1 0x80 +#define AR933X_DDR_REG_FLUSH_USB 0x84 +#define AR933X_DDR_REG_FLUSH_WMAC 0x88 +#define AR933X_DDR_REG_DDR2_CONFIG 0x8c +#define AR933X_DDR_REG_EMR2 0x90 +#define AR933X_DDR_REG_EMR3 0x94 +#define AR933X_DDR_REG_BURST 0x98 +#define AR933X_DDR_REG_TIMEOUT_MAX 0x9c +#define AR933X_DDR_REG_TIMEOUT_CNT 0x9c +#define AR933X_DDR_REG_TIMEOUT_ADDR 0x9c
+#define AR934X_DDR_REG_FLUSH_GE0 0x9c +#define AR934X_DDR_REG_FLUSH_GE1 0xa0 +#define AR934X_DDR_REG_FLUSH_USB 0xa4 +#define AR934X_DDR_REG_FLUSH_PCIE 0xa8 +#define AR934X_DDR_REG_FLUSH_WMAC 0xac
+#define QCA953X_DDR_REG_FLUSH_GE0 0x9c +#define QCA953X_DDR_REG_FLUSH_GE1 0xa0 +#define QCA953X_DDR_REG_FLUSH_USB 0xa4 +#define QCA953X_DDR_REG_FLUSH_PCIE 0xa8 +#define QCA953X_DDR_REG_FLUSH_WMAC 0xac
- PLL block
+#define AR71XX_PLL_REG_CPU_CONFIG 0x00 +#define AR71XX_PLL_REG_SEC_CONFIG 0x04 +#define AR71XX_PLL_REG_ETH0_INT_CLOCK 0x10 +#define AR71XX_PLL_REG_ETH1_INT_CLOCK 0x14
+#define AR71XX_PLL_DIV_SHIFT 3 +#define AR71XX_PLL_DIV_MASK 0x1f +#define AR71XX_CPU_DIV_SHIFT 16 +#define AR71XX_CPU_DIV_MASK 0x3 +#define AR71XX_DDR_DIV_SHIFT 18 +#define AR71XX_DDR_DIV_MASK 0x3 +#define AR71XX_AHB_DIV_SHIFT 20 +#define AR71XX_AHB_DIV_MASK 0x7
+#define AR71XX_ETH0_PLL_SHIFT 17 +#define AR71XX_ETH1_PLL_SHIFT 19
+#define AR724X_PLL_REG_CPU_CONFIG 0x00 +#define AR724X_PLL_REG_PCIE_CONFIG 0x18
+#define AR724X_PLL_DIV_SHIFT 0 +#define AR724X_PLL_DIV_MASK 0x3ff +#define AR724X_PLL_REF_DIV_SHIFT 10 +#define AR724X_PLL_REF_DIV_MASK 0xf +#define AR724X_AHB_DIV_SHIFT 19 +#define AR724X_AHB_DIV_MASK 0x1 +#define AR724X_DDR_DIV_SHIFT 22 +#define AR724X_DDR_DIV_MASK 0x3
+#define AR7242_PLL_REG_ETH0_INT_CLOCK 0x2c
+#define AR913X_PLL_REG_CPU_CONFIG 0x00 +#define AR913X_PLL_REG_ETH_CONFIG 0x04 +#define AR913X_PLL_REG_ETH0_INT_CLOCK 0x14 +#define AR913X_PLL_REG_ETH1_INT_CLOCK 0x18
+#define AR913X_PLL_DIV_SHIFT 0 +#define AR913X_PLL_DIV_MASK 0x3ff +#define AR913X_DDR_DIV_SHIFT 22 +#define AR913X_DDR_DIV_MASK 0x3 +#define AR913X_AHB_DIV_SHIFT 19 +#define AR913X_AHB_DIV_MASK 0x1
+#define AR913X_ETH0_PLL_SHIFT 20 +#define AR913X_ETH1_PLL_SHIFT 22
+#define AR933X_PLL_CPU_CONFIG_REG 0x00 +#define AR933X_PLL_CLOCK_CTRL_REG 0x08 +#define AR933X_PLL_DITHER_FRAC_REG 0x10
+#define AR933X_PLL_CPU_CONFIG_DIVINT_SHIFT 10 +#define AR933X_PLL_CPU_CONFIG_DIVINT_MASK 0x3f +#define AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT 16 +#define AR933X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT 23 +#define AR933X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7
+#define AR933X_PLL_CLOCK_CTRL_BYPASS BIT(2) +#define AR933X_PLL_CLOCK_CTRL_CPU_DIV_SHIFT 5 +#define AR933X_PLL_CLOCK_CTRL_CPU_DIV_MASK 0x3 +#define AR933X_PLL_CLOCK_CTRL_DDR_DIV_SHIFT 10 +#define AR933X_PLL_CLOCK_CTRL_DDR_DIV_MASK 0x3 +#define AR933X_PLL_CLOCK_CTRL_AHB_DIV_SHIFT 15 +#define AR933X_PLL_CLOCK_CTRL_AHB_DIV_MASK 0x7
+#define AR934X_PLL_CPU_CONFIG_REG 0x00 +#define AR934X_PLL_DDR_CONFIG_REG 0x04 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_REG 0x08 +#define AR934X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define AR934X_PLL_ETH_XMII_CONTROL_REG 0x2c
+#define AR934X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define AR934X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define AR934X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define AR934X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3
+#define AR934X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define AR934X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define AR934X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define AR934X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define AR934X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define AR934X_PLL_CPU_DDR_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define AR934X_PLL_CPU_DDR_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
+#define AR934X_PLL_SWITCH_CLOCK_CONTROL_MDIO_CLK_SEL BIT(6)
+#define QCA953X_PLL_CPU_CONFIG_REG 0x00 +#define QCA953X_PLL_DDR_CONFIG_REG 0x04 +#define QCA953X_PLL_CLK_CTRL_REG 0x08 +#define QCA953X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define QCA953X_PLL_ETH_XMII_CONTROL_REG 0x2c +#define QCA953X_PLL_ETH_SGMII_CONTROL_REG 0x48
+#define QCA953X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA953X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA953X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7
+#define QCA953X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA953X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA953X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA953X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define QCA953X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA953X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA953X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA953X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA953X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
+#define QCA955X_PLL_CPU_CONFIG_REG 0x00 +#define QCA955X_PLL_DDR_CONFIG_REG 0x04 +#define QCA955X_PLL_CLK_CTRL_REG 0x08 +#define QCA955X_PLL_ETH_XMII_CONTROL_REG 0x28 +#define QCA955X_PLL_ETH_SGMII_CONTROL_REG 0x48
+#define QCA955X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA955X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA955X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3
+#define QCA955X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA955X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA955X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA955X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define QCA955X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA955X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA955X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA955X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA955X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
+#define QCA956X_PLL_CPU_CONFIG_REG 0x00 +#define QCA956X_PLL_CPU_CONFIG1_REG 0x04 +#define QCA956X_PLL_DDR_CONFIG_REG 0x08 +#define QCA956X_PLL_DDR_CONFIG1_REG 0x0c +#define QCA956X_PLL_CLK_CTRL_REG 0x10
+#define QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA956X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7
+#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_CPU_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_CPU_CONFIG1_NINT_MASK 0x1ff
+#define QCA956X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA956X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_DDR_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_DDR_CONFIG1_NINT_MASK 0x1ff
+#define QCA956X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA956X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA956X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_DDRPLL BIT(20) +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_CPUPLL BIT(21) +#define QCA956X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
- USB_CONFIG block
+#define AR71XX_USB_CTRL_REG_FLADJ 0x00 +#define AR71XX_USB_CTRL_REG_CONFIG 0x04
- RESET block
+#define AR71XX_RESET_REG_TIMER 0x00 +#define AR71XX_RESET_REG_TIMER_RELOAD 0x04 +#define AR71XX_RESET_REG_WDOG_CTRL 0x08 +#define AR71XX_RESET_REG_WDOG 0x0c +#define AR71XX_RESET_REG_MISC_INT_STATUS 0x10 +#define AR71XX_RESET_REG_MISC_INT_ENABLE 0x14 +#define AR71XX_RESET_REG_PCI_INT_STATUS 0x18 +#define AR71XX_RESET_REG_PCI_INT_ENABLE 0x1c +#define AR71XX_RESET_REG_GLOBAL_INT_STATUS 0x20 +#define AR71XX_RESET_REG_RESET_MODULE 0x24 +#define AR71XX_RESET_REG_PERFC_CTRL 0x2c +#define AR71XX_RESET_REG_PERFC0 0x30 +#define AR71XX_RESET_REG_PERFC1 0x34 +#define AR71XX_RESET_REG_REV_ID 0x90
+#define AR913X_RESET_REG_GLOBAL_INT_STATUS 0x18 +#define AR913X_RESET_REG_RESET_MODULE 0x1c +#define AR913X_RESET_REG_PERF_CTRL 0x20 +#define AR913X_RESET_REG_PERFC0 0x24 +#define AR913X_RESET_REG_PERFC1 0x28
+#define AR724X_RESET_REG_RESET_MODULE 0x1c
+#define AR933X_RESET_REG_RESET_MODULE 0x1c +#define AR933X_RESET_REG_BOOTSTRAP 0xac
+#define AR934X_RESET_REG_RESET_MODULE 0x1c +#define AR934X_RESET_REG_BOOTSTRAP 0xb0 +#define AR934X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac
+#define QCA953X_RESET_REG_RESET_MODULE 0x1c +#define QCA953X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA953X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac
+#define QCA955X_RESET_REG_RESET_MODULE 0x1c +#define QCA955X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA955X_RESET_REG_EXT_INT_STATUS 0xac
+#define QCA956X_RESET_REG_RESET_MODULE 0x1c +#define QCA956X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA956X_RESET_REG_EXT_INT_STATUS 0xac
+#define MISC_INT_MIPS_SI_TIMERINT_MASK BIT(28) +#define MISC_INT_ETHSW BIT(12) +#define MISC_INT_TIMER4 BIT(10) +#define MISC_INT_TIMER3 BIT(9) +#define MISC_INT_TIMER2 BIT(8) +#define MISC_INT_DMA BIT(7) +#define MISC_INT_OHCI BIT(6) +#define MISC_INT_PERFC BIT(5) +#define MISC_INT_WDOG BIT(4) +#define MISC_INT_UART BIT(3) +#define MISC_INT_GPIO BIT(2) +#define MISC_INT_ERROR BIT(1) +#define MISC_INT_TIMER BIT(0)
+#define AR71XX_RESET_EXTERNAL BIT(28) +#define AR71XX_RESET_FULL_CHIP BIT(24) +#define AR71XX_RESET_CPU_NMI BIT(21) +#define AR71XX_RESET_CPU_COLD BIT(20) +#define AR71XX_RESET_DMA BIT(19) +#define AR71XX_RESET_SLIC BIT(18) +#define AR71XX_RESET_STEREO BIT(17) +#define AR71XX_RESET_DDR BIT(16) +#define AR71XX_RESET_GE1_MAC BIT(13) +#define AR71XX_RESET_GE1_PHY BIT(12) +#define AR71XX_RESET_USBSUS_OVERRIDE BIT(10) +#define AR71XX_RESET_GE0_MAC BIT(9) +#define AR71XX_RESET_GE0_PHY BIT(8) +#define AR71XX_RESET_USB_OHCI_DLL BIT(6) +#define AR71XX_RESET_USB_HOST BIT(5) +#define AR71XX_RESET_USB_PHY BIT(4) +#define AR71XX_RESET_PCI_BUS BIT(1) +#define AR71XX_RESET_PCI_CORE BIT(0)
+#define AR7240_RESET_USB_HOST BIT(5) +#define AR7240_RESET_OHCI_DLL BIT(3)
+#define AR724X_RESET_GE1_MDIO BIT(23) +#define AR724X_RESET_GE0_MDIO BIT(22) +#define AR724X_RESET_PCIE_PHY_SERIAL BIT(10) +#define AR724X_RESET_PCIE_PHY BIT(7) +#define AR724X_RESET_PCIE BIT(6) +#define AR724X_RESET_USB_HOST BIT(5) +#define AR724X_RESET_USB_PHY BIT(4) +#define AR724X_RESET_USBSUS_OVERRIDE BIT(3)
+#define AR913X_RESET_AMBA2WMAC BIT(22) +#define AR913X_RESET_USBSUS_OVERRIDE BIT(10) +#define AR913X_RESET_USB_HOST BIT(5) +#define AR913X_RESET_USB_PHY BIT(4)
+#define AR933X_RESET_GE1_MDIO BIT(23) +#define AR933X_RESET_GE0_MDIO BIT(22) +#define AR933X_RESET_GE1_MAC BIT(13) +#define AR933X_RESET_WMAC BIT(11) +#define AR933X_RESET_GE0_MAC BIT(9) +#define AR933X_RESET_USB_HOST BIT(5) +#define AR933X_RESET_USB_PHY BIT(4) +#define AR933X_RESET_USBSUS_OVERRIDE BIT(3)
+#define AR934X_RESET_HOST BIT(31) +#define AR934X_RESET_SLIC BIT(30) +#define AR934X_RESET_HDMA BIT(29) +#define AR934X_RESET_EXTERNAL BIT(28) +#define AR934X_RESET_RTC BIT(27) +#define AR934X_RESET_PCIE_EP_INT BIT(26) +#define AR934X_RESET_CHKSUM_ACC BIT(25) +#define AR934X_RESET_FULL_CHIP BIT(24) +#define AR934X_RESET_GE1_MDIO BIT(23) +#define AR934X_RESET_GE0_MDIO BIT(22) +#define AR934X_RESET_CPU_NMI BIT(21) +#define AR934X_RESET_CPU_COLD BIT(20) +#define AR934X_RESET_HOST_RESET_INT BIT(19) +#define AR934X_RESET_PCIE_EP BIT(18) +#define AR934X_RESET_UART1 BIT(17) +#define AR934X_RESET_DDR BIT(16) +#define AR934X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define AR934X_RESET_NANDF BIT(14) +#define AR934X_RESET_GE1_MAC BIT(13) +#define AR934X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define AR934X_RESET_USB_PHY_ANALOG BIT(11) +#define AR934X_RESET_HOST_DMA_INT BIT(10) +#define AR934X_RESET_GE0_MAC BIT(9) +#define AR934X_RESET_ETH_SWITCH BIT(8) +#define AR934X_RESET_PCIE_PHY BIT(7) +#define AR934X_RESET_PCIE BIT(6) +#define AR934X_RESET_USB_HOST BIT(5) +#define AR934X_RESET_USB_PHY BIT(4) +#define AR934X_RESET_USBSUS_OVERRIDE BIT(3) +#define AR934X_RESET_LUT BIT(2) +#define AR934X_RESET_MBOX BIT(1) +#define AR934X_RESET_I2S BIT(0)
+#define QCA953X_RESET_USB_EXT_PWR BIT(29) +#define QCA953X_RESET_EXTERNAL BIT(28) +#define QCA953X_RESET_RTC BIT(27) +#define QCA953X_RESET_FULL_CHIP BIT(24) +#define QCA953X_RESET_GE1_MDIO BIT(23) +#define QCA953X_RESET_GE0_MDIO BIT(22) +#define QCA953X_RESET_CPU_NMI BIT(21) +#define QCA953X_RESET_CPU_COLD BIT(20) +#define QCA953X_RESET_DDR BIT(16) +#define QCA953X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA953X_RESET_GE1_MAC BIT(13) +#define QCA953X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define QCA953X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA953X_RESET_GE0_MAC BIT(9) +#define QCA953X_RESET_ETH_SWITCH BIT(8) +#define QCA953X_RESET_PCIE_PHY BIT(7) +#define QCA953X_RESET_PCIE BIT(6) +#define QCA953X_RESET_USB_HOST BIT(5) +#define QCA953X_RESET_USB_PHY BIT(4) +#define QCA953X_RESET_USBSUS_OVERRIDE BIT(3)
+#define QCA955X_RESET_HOST BIT(31) +#define QCA955X_RESET_SLIC BIT(30) +#define QCA955X_RESET_HDMA BIT(29) +#define QCA955X_RESET_EXTERNAL BIT(28) +#define QCA955X_RESET_RTC BIT(27) +#define QCA955X_RESET_PCIE_EP_INT BIT(26) +#define QCA955X_RESET_CHKSUM_ACC BIT(25) +#define QCA955X_RESET_FULL_CHIP BIT(24) +#define QCA955X_RESET_GE1_MDIO BIT(23) +#define QCA955X_RESET_GE0_MDIO BIT(22) +#define QCA955X_RESET_CPU_NMI BIT(21) +#define QCA955X_RESET_CPU_COLD BIT(20) +#define QCA955X_RESET_HOST_RESET_INT BIT(19) +#define QCA955X_RESET_PCIE_EP BIT(18) +#define QCA955X_RESET_UART1 BIT(17) +#define QCA955X_RESET_DDR BIT(16) +#define QCA955X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA955X_RESET_NANDF BIT(14) +#define QCA955X_RESET_GE1_MAC BIT(13) +#define QCA955X_RESET_SGMII_ANALOG BIT(12) +#define QCA955X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA955X_RESET_HOST_DMA_INT BIT(10) +#define QCA955X_RESET_GE0_MAC BIT(9) +#define QCA955X_RESET_SGMII BIT(8) +#define QCA955X_RESET_PCIE_PHY BIT(7) +#define QCA955X_RESET_PCIE BIT(6) +#define QCA955X_RESET_USB_HOST BIT(5) +#define QCA955X_RESET_USB_PHY BIT(4) +#define QCA955X_RESET_USBSUS_OVERRIDE BIT(3) +#define QCA955X_RESET_LUT BIT(2) +#define QCA955X_RESET_MBOX BIT(1) +#define QCA955X_RESET_I2S BIT(0)
+#define AR933X_BOOTSTRAP_MDIO_GPIO_EN BIT(18) +#define AR933X_BOOTSTRAP_DDR2 BIT(13) +#define AR933X_BOOTSTRAP_EEPBUSY BIT(4) +#define AR933X_BOOTSTRAP_REF_CLK_40 BIT(0)
+#define AR934X_BOOTSTRAP_SW_OPTION8 BIT(23) +#define AR934X_BOOTSTRAP_SW_OPTION7 BIT(22) +#define AR934X_BOOTSTRAP_SW_OPTION6 BIT(21) +#define AR934X_BOOTSTRAP_SW_OPTION5 BIT(20) +#define AR934X_BOOTSTRAP_SW_OPTION4 BIT(19) +#define AR934X_BOOTSTRAP_SW_OPTION3 BIT(18) +#define AR934X_BOOTSTRAP_SW_OPTION2 BIT(17) +#define AR934X_BOOTSTRAP_SW_OPTION1 BIT(16) +#define AR934X_BOOTSTRAP_USB_MODE_DEVICE BIT(7) +#define AR934X_BOOTSTRAP_PCIE_RC BIT(6) +#define AR934X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define AR934X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define AR934X_BOOTSTRAP_BOOT_FROM_SPI BIT(2) +#define AR934X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define AR934X_BOOTSTRAP_DDR1 BIT(0)
+#define QCA953X_BOOTSTRAP_SW_OPTION2 BIT(12) +#define QCA953X_BOOTSTRAP_SW_OPTION1 BIT(11) +#define QCA953X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define QCA953X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define QCA953X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define QCA953X_BOOTSTRAP_DDR1 BIT(0)
+#define QCA955X_BOOTSTRAP_REF_CLK_40 BIT(4)
+#define QCA956X_BOOTSTRAP_REF_CLK_40 BIT(2)
+#define AR934X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define AR934X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define AR934X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define AR934X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define AR934X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define AR934X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define AR934X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define AR934X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define AR934X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define AR934X_PCIE_WMAC_INT_WMAC_ALL \
- (AR934X_PCIE_WMAC_INT_WMAC_MISC | AR934X_PCIE_WMAC_INT_WMAC_TX | \
AR934X_PCIE_WMAC_INT_WMAC_RXLP | AR934X_PCIE_WMAC_INT_WMAC_RXHP)
+#define AR934X_PCIE_WMAC_INT_PCIE_ALL \
- (AR934X_PCIE_WMAC_INT_PCIE_RC | AR934X_PCIE_WMAC_INT_PCIE_RC0 | \
AR934X_PCIE_WMAC_INT_PCIE_RC1 | AR934X_PCIE_WMAC_INT_PCIE_RC2 | \
AR934X_PCIE_WMAC_INT_PCIE_RC3)
+#define QCA953X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define QCA953X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define QCA953X_PCIE_WMAC_INT_WMAC_ALL \
- (QCA953X_PCIE_WMAC_INT_WMAC_MISC | QCA953X_PCIE_WMAC_INT_WMAC_TX | \
QCA953X_PCIE_WMAC_INT_WMAC_RXLP | QCA953X_PCIE_WMAC_INT_WMAC_RXHP)
+#define QCA953X_PCIE_WMAC_INT_PCIE_ALL \
- (QCA953X_PCIE_WMAC_INT_PCIE_RC | QCA953X_PCIE_WMAC_INT_PCIE_RC0 | \
QCA953X_PCIE_WMAC_INT_PCIE_RC1 | QCA953X_PCIE_WMAC_INT_PCIE_RC2 | \
QCA953X_PCIE_WMAC_INT_PCIE_RC3)
+#define QCA955X_EXT_INT_WMAC_MISC BIT(0) +#define QCA955X_EXT_INT_WMAC_TX BIT(1) +#define QCA955X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA955X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA955X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA955X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA955X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA955X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA955X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA955X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA955X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA955X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA955X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA955X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA955X_EXT_INT_USB1 BIT(24) +#define QCA955X_EXT_INT_USB2 BIT(28)
+#define QCA955X_EXT_INT_WMAC_ALL \
- (QCA955X_EXT_INT_WMAC_MISC | QCA955X_EXT_INT_WMAC_TX | \
QCA955X_EXT_INT_WMAC_RXLP | QCA955X_EXT_INT_WMAC_RXHP)
+#define QCA955X_EXT_INT_PCIE_RC1_ALL \
- (QCA955X_EXT_INT_PCIE_RC1 | QCA955X_EXT_INT_PCIE_RC1_INT0 | \
QCA955X_EXT_INT_PCIE_RC1_INT1 | QCA955X_EXT_INT_PCIE_RC1_INT2 | \
QCA955X_EXT_INT_PCIE_RC1_INT3)
+#define QCA955X_EXT_INT_PCIE_RC2_ALL \
- (QCA955X_EXT_INT_PCIE_RC2 | QCA955X_EXT_INT_PCIE_RC2_INT0 | \
QCA955X_EXT_INT_PCIE_RC2_INT1 | QCA955X_EXT_INT_PCIE_RC2_INT2 | \
QCA955X_EXT_INT_PCIE_RC2_INT3)
+#define QCA956X_EXT_INT_WMAC_MISC BIT(0) +#define QCA956X_EXT_INT_WMAC_TX BIT(1) +#define QCA956X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA956X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA956X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA956X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA956X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA956X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA956X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA956X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA956X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA956X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA956X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA956X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA956X_EXT_INT_USB1 BIT(24) +#define QCA956X_EXT_INT_USB2 BIT(28)
+#define QCA956X_EXT_INT_WMAC_ALL \
- (QCA956X_EXT_INT_WMAC_MISC | QCA956X_EXT_INT_WMAC_TX | \
QCA956X_EXT_INT_WMAC_RXLP | QCA956X_EXT_INT_WMAC_RXHP)
+#define QCA956X_EXT_INT_PCIE_RC1_ALL \
- (QCA956X_EXT_INT_PCIE_RC1 | QCA956X_EXT_INT_PCIE_RC1_INT0 | \
QCA956X_EXT_INT_PCIE_RC1_INT1 | QCA956X_EXT_INT_PCIE_RC1_INT2 | \
QCA956X_EXT_INT_PCIE_RC1_INT3)
+#define QCA956X_EXT_INT_PCIE_RC2_ALL \
- (QCA956X_EXT_INT_PCIE_RC2 | QCA956X_EXT_INT_PCIE_RC2_INT0 | \
QCA956X_EXT_INT_PCIE_RC2_INT1 | QCA956X_EXT_INT_PCIE_RC2_INT2 | \
QCA956X_EXT_INT_PCIE_RC2_INT3)
+#define REV_ID_MAJOR_MASK 0xfff0 +#define REV_ID_MAJOR_AR71XX 0x00a0 +#define REV_ID_MAJOR_AR913X 0x00b0 +#define REV_ID_MAJOR_AR7240 0x00c0 +#define REV_ID_MAJOR_AR7241 0x0100 +#define REV_ID_MAJOR_AR7242 0x1100 +#define REV_ID_MAJOR_AR9330 0x0110 +#define REV_ID_MAJOR_AR9331 0x1110 +#define REV_ID_MAJOR_AR9341 0x0120 +#define REV_ID_MAJOR_AR9342 0x1120 +#define REV_ID_MAJOR_AR9344 0x2120 +#define REV_ID_MAJOR_QCA9533 0x0140 +#define REV_ID_MAJOR_QCA9533_V2 0x0160 +#define REV_ID_MAJOR_QCA9556 0x0130 +#define REV_ID_MAJOR_QCA9558 0x1130 +#define REV_ID_MAJOR_TP9343 0x0150 +#define REV_ID_MAJOR_QCA9561 0x1150
+#define AR71XX_REV_ID_MINOR_MASK 0x3 +#define AR71XX_REV_ID_MINOR_AR7130 0x0 +#define AR71XX_REV_ID_MINOR_AR7141 0x1 +#define AR71XX_REV_ID_MINOR_AR7161 0x2 +#define AR71XX_REV_ID_REVISION_MASK 0x3 +#define AR71XX_REV_ID_REVISION_SHIFT 2
+#define AR913X_REV_ID_MINOR_AR9130 0x0 +#define AR913X_REV_ID_MINOR_AR9132 0x1
+#define AR934X_REV_ID_REVISION_MASK 0xf +#define QCA953X_REV_ID_REVISION_MASK 0xf +#define QCA955X_REV_ID_REVISION_MASK 0xf +#define QCA956X_REV_ID_REVISION_MASK 0xf
- RTC block
+#define AR933X_RTC_REG_RESET 0x40 +#define AR933X_RTC_REG_STATUS 0x44 +#define AR933X_RTC_REG_DERIVED 0x48 +#define AR933X_RTC_REG_FORCE_WAKE 0x4c +#define AR933X_RTC_REG_INT_CAUSE 0x50 +#define AR933X_RTC_REG_CAUSE_CLR 0x50 +#define AR933X_RTC_REG_INT_ENABLE 0x54 +#define AR933X_RTC_REG_INT_MASKE 0x58
- SPI block
+#define AR71XX_SPI_REG_FS 0x00 /* Function Select */ +#define AR71XX_SPI_REG_CTRL 0x04 /* SPI Control */ +#define AR71XX_SPI_REG_IOC 0x08 /* SPI I/O Control */ +#define AR71XX_SPI_REG_RDS 0x0c /* Read Data Shift */
+#define AR71XX_SPI_FS_GPIO BIT(0) /* Enable GPIO mode */
+#define AR71XX_SPI_CTRL_RD BIT(6) /* Remap Disable */ +#define AR71XX_SPI_CTRL_DIV_MASK 0x3f
+#define AR71XX_SPI_IOC_DO BIT(0) /* Data Out pin */ +#define AR71XX_SPI_IOC_CLK BIT(8) /* CLK pin */ +#define AR71XX_SPI_IOC_CS(n) BIT(16 + (n)) +#define AR71XX_SPI_IOC_CS0 AR71XX_SPI_IOC_CS(0) +#define AR71XX_SPI_IOC_CS1 AR71XX_SPI_IOC_CS(1) +#define AR71XX_SPI_IOC_CS2 AR71XX_SPI_IOC_CS(2) +#define AR71XX_SPI_IOC_CS_ALL (AR71XX_SPI_IOC_CS0 | AR71XX_SPI_IOC_CS1 | \
AR71XX_SPI_IOC_CS2)
- GPIO block
+#define AR71XX_GPIO_REG_OE 0x00 +#define AR71XX_GPIO_REG_IN 0x04 +#define AR71XX_GPIO_REG_OUT 0x08 +#define AR71XX_GPIO_REG_SET 0x0c +#define AR71XX_GPIO_REG_CLEAR 0x10 +#define AR71XX_GPIO_REG_INT_MODE 0x14 +#define AR71XX_GPIO_REG_INT_TYPE 0x18 +#define AR71XX_GPIO_REG_INT_POLARITY 0x1c +#define AR71XX_GPIO_REG_INT_PENDING 0x20 +#define AR71XX_GPIO_REG_INT_ENABLE 0x24 +#define AR71XX_GPIO_REG_FUNC 0x28 +#define AR933X_GPIO_REG_FUNC 0x30
+#define AR934X_GPIO_REG_OUT_FUNC0 0x2c +#define AR934X_GPIO_REG_OUT_FUNC1 0x30 +#define AR934X_GPIO_REG_OUT_FUNC2 0x34 +#define AR934X_GPIO_REG_OUT_FUNC3 0x38 +#define AR934X_GPIO_REG_OUT_FUNC4 0x3c +#define AR934X_GPIO_REG_OUT_FUNC5 0x40 +#define AR934X_GPIO_REG_FUNC 0x6c
+#define QCA953X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA953X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA953X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA953X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA953X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA953X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA953X_GPIO_REG_FUNC 0x6c
+#define QCA953X_GPIO_OUT_MUX_SPI_CS1 10 +#define QCA953X_GPIO_OUT_MUX_SPI_CS2 11 +#define QCA953X_GPIO_OUT_MUX_SPI_CS0 9 +#define QCA953X_GPIO_OUT_MUX_SPI_CLK 8 +#define QCA953X_GPIO_OUT_MUX_SPI_MOSI 12 +#define QCA953X_GPIO_OUT_MUX_LED_LINK1 41 +#define QCA953X_GPIO_OUT_MUX_LED_LINK2 42 +#define QCA953X_GPIO_OUT_MUX_LED_LINK3 43 +#define QCA953X_GPIO_OUT_MUX_LED_LINK4 44 +#define QCA953X_GPIO_OUT_MUX_LED_LINK5 45
+#define QCA955X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA955X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA955X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA955X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA955X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA955X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA955X_GPIO_REG_FUNC 0x6c
+#define QCA956X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA956X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA956X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA956X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA956X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA956X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA956X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA956X_GPIO_REG_IN_ENABLE3 0x50 +#define QCA956X_GPIO_REG_FUNC 0x6c
+#define QCA956X_GPIO_OUT_MUX_GE0_MDO 32 +#define QCA956X_GPIO_OUT_MUX_GE0_MDC 33
+#define AR71XX_GPIO_COUNT 16 +#define AR7240_GPIO_COUNT 18 +#define AR7241_GPIO_COUNT 20 +#define AR913X_GPIO_COUNT 22 +#define AR933X_GPIO_COUNT 30 +#define AR934X_GPIO_COUNT 23 +#define QCA953X_GPIO_COUNT 18 +#define QCA955X_GPIO_COUNT 24 +#define QCA956X_GPIO_COUNT 23
- SRIF block
+#define AR933X_SRIF_DDR_DPLL1_REG 0x240 +#define AR933X_SRIF_DDR_DPLL2_REG 0x244 +#define AR933X_SRIF_DDR_DPLL3_REG 0x248 +#define AR933X_SRIF_DDR_DPLL4_REG 0x24c
+#define AR934X_SRIF_CPU_DPLL1_REG 0x1c0 +#define AR934X_SRIF_CPU_DPLL2_REG 0x1c4 +#define AR934X_SRIF_CPU_DPLL3_REG 0x1c8
+#define AR934X_SRIF_DDR_DPLL1_REG 0x240 +#define AR934X_SRIF_DDR_DPLL2_REG 0x244 +#define AR934X_SRIF_DDR_DPLL3_REG 0x248
+#define AR934X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define AR934X_SRIF_DPLL1_REFDIV_MASK 0x1f +#define AR934X_SRIF_DPLL1_NINT_SHIFT 18 +#define AR934X_SRIF_DPLL1_NINT_MASK 0x1ff +#define AR934X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff
+#define AR934X_SRIF_DPLL2_LOCAL_PLL BIT(30) +#define AR934X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define AR934X_SRIF_DPLL2_OUTDIV_MASK 0x7
+#define QCA953X_SRIF_CPU_DPLL1_REG 0x1c0 +#define QCA953X_SRIF_CPU_DPLL2_REG 0x1c4 +#define QCA953X_SRIF_CPU_DPLL3_REG 0x1c8
+#define QCA953X_SRIF_DDR_DPLL1_REG 0x240 +#define QCA953X_SRIF_DDR_DPLL2_REG 0x244 +#define QCA953X_SRIF_DDR_DPLL3_REG 0x248
+#define QCA953X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define QCA953X_SRIF_DPLL1_REFDIV_MASK 0x1f +#define QCA953X_SRIF_DPLL1_NINT_SHIFT 18 +#define QCA953X_SRIF_DPLL1_NINT_MASK 0x1ff +#define QCA953X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff
+#define QCA953X_SRIF_DPLL2_LOCAL_PLL BIT(30) +#define QCA953X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define QCA953X_SRIF_DPLL2_OUTDIV_MASK 0x7
+#define AR71XX_GPIO_FUNC_STEREO_EN BIT(17) +#define AR71XX_GPIO_FUNC_SLIC_EN BIT(16) +#define AR71XX_GPIO_FUNC_SPI_CS2_EN BIT(13) +#define AR71XX_GPIO_FUNC_SPI_CS1_EN BIT(12) +#define AR71XX_GPIO_FUNC_UART_EN BIT(8) +#define AR71XX_GPIO_FUNC_USB_OC_EN BIT(4) +#define AR71XX_GPIO_FUNC_USB_CLK_EN BIT(0)
+#define AR724X_GPIO_FUNC_GE0_MII_CLK_EN BIT(19) +#define AR724X_GPIO_FUNC_SPI_EN BIT(18) +#define AR724X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR724X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR724X_GPIO_FUNC_CLK_OBS5_EN BIT(12) +#define AR724X_GPIO_FUNC_CLK_OBS4_EN BIT(11) +#define AR724X_GPIO_FUNC_CLK_OBS3_EN BIT(10) +#define AR724X_GPIO_FUNC_CLK_OBS2_EN BIT(9) +#define AR724X_GPIO_FUNC_CLK_OBS1_EN BIT(8) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR724X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR724X_GPIO_FUNC_UART_EN BIT(1) +#define AR724X_GPIO_FUNC_JTAG_DISABLE BIT(0)
+#define AR913X_GPIO_FUNC_WMAC_LED_EN BIT(22) +#define AR913X_GPIO_FUNC_EXP_PORT_CS_EN BIT(21) +#define AR913X_GPIO_FUNC_I2S_REFCLKEN BIT(20) +#define AR913X_GPIO_FUNC_I2S_MCKEN BIT(19) +#define AR913X_GPIO_FUNC_I2S1_EN BIT(18) +#define AR913X_GPIO_FUNC_I2S0_EN BIT(17) +#define AR913X_GPIO_FUNC_SLIC_EN BIT(16) +#define AR913X_GPIO_FUNC_UART_RTSCTS_EN BIT(9) +#define AR913X_GPIO_FUNC_UART_EN BIT(8) +#define AR913X_GPIO_FUNC_USB_CLK_EN BIT(4)
+#define AR933X_GPIO_FUNC_SPDIF2TCK BIT(31) +#define AR933X_GPIO_FUNC_SPDIF_EN BIT(30) +#define AR933X_GPIO_FUNC_I2SO_22_18_EN BIT(29) +#define AR933X_GPIO_FUNC_I2S_MCK_EN BIT(27) +#define AR933X_GPIO_FUNC_I2SO_EN BIT(26) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_DUPL BIT(25) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_COLL BIT(24) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_ACT BIT(23) +#define AR933X_GPIO_FUNC_SPI_EN BIT(18) +#define AR933X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR933X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR933X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR933X_GPIO_FUNC_UART_EN BIT(1) +#define AR933X_GPIO_FUNC_JTAG_DISABLE BIT(0)
+#define AR933X_GPIO_FUNC_XLNA_EN BIT(12)
+#define AR934X_GPIO_FUNC_CLK_OBS7_EN BIT(9) +#define AR934X_GPIO_FUNC_CLK_OBS6_EN BIT(8) +#define AR934X_GPIO_FUNC_CLK_OBS5_EN BIT(7) +#define AR934X_GPIO_FUNC_CLK_OBS4_EN BIT(6) +#define AR934X_GPIO_FUNC_CLK_OBS3_EN BIT(5) +#define AR934X_GPIO_FUNC_CLK_OBS2_EN BIT(4) +#define AR934X_GPIO_FUNC_CLK_OBS1_EN BIT(3) +#define AR934X_GPIO_FUNC_CLK_OBS0_EN BIT(2) +#define AR934X_GPIO_FUNC_JTAG_DISABLE BIT(1)
+#define AR934X_GPIO_OUT_GPIO 0 +#define AR934X_GPIO_OUT_SPI_CS1 7 +#define AR934X_GPIO_OUT_LED_LINK0 41 +#define AR934X_GPIO_OUT_LED_LINK1 42 +#define AR934X_GPIO_OUT_LED_LINK2 43 +#define AR934X_GPIO_OUT_LED_LINK3 44 +#define AR934X_GPIO_OUT_LED_LINK4 45 +#define AR934X_GPIO_OUT_EXT_LNA0 46 +#define AR934X_GPIO_OUT_EXT_LNA1 47
+#define QCA955X_GPIO_OUT_GPIO 0
- MII_CTRL block
+#define AR71XX_MII_REG_MII0_CTRL 0x00 +#define AR71XX_MII_REG_MII1_CTRL 0x04
+#define AR71XX_MII_CTRL_IF_MASK 3 +#define AR71XX_MII_CTRL_SPEED_SHIFT 4 +#define AR71XX_MII_CTRL_SPEED_MASK 3 +#define AR71XX_MII_CTRL_SPEED_10 0 +#define AR71XX_MII_CTRL_SPEED_100 1 +#define AR71XX_MII_CTRL_SPEED_1000 2
+#define AR71XX_MII0_CTRL_IF_GMII 0 +#define AR71XX_MII0_CTRL_IF_MII 1 +#define AR71XX_MII0_CTRL_IF_RGMII 2 +#define AR71XX_MII0_CTRL_IF_RMII 3
+#define AR71XX_MII1_CTRL_IF_RGMII 0 +#define AR71XX_MII1_CTRL_IF_RMII 1
- AR933X GMAC interface
+#define AR933X_GMAC_REG_ETH_CFG 0x00
+#define AR933X_ETH_CFG_RGMII_GE0 BIT(0) +#define AR933X_ETH_CFG_MII_GE0 BIT(1) +#define AR933X_ETH_CFG_GMII_GE0 BIT(2) +#define AR933X_ETH_CFG_MII_GE0_MASTER BIT(3) +#define AR933X_ETH_CFG_MII_GE0_SLAVE BIT(4) +#define AR933X_ETH_CFG_MII_GE0_ERR_EN BIT(5) +#define AR933X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR933X_ETH_CFG_SW_PHY_ADDR_SWAP BIT(8) +#define AR933X_ETH_CFG_RMII_GE0 BIT(9) +#define AR933X_ETH_CFG_RMII_GE0_SPD_10 0 +#define AR933X_ETH_CFG_RMII_GE0_SPD_100 BIT(10)
- AR934X GMAC Interface
+#define AR934X_GMAC_REG_ETH_CFG 0x00
+#define AR934X_ETH_CFG_RGMII_GMAC0 BIT(0) +#define AR934X_ETH_CFG_MII_GMAC0 BIT(1) +#define AR934X_ETH_CFG_GMII_GMAC0 BIT(2) +#define AR934X_ETH_CFG_MII_GMAC0_MASTER BIT(3) +#define AR934X_ETH_CFG_MII_GMAC0_SLAVE BIT(4) +#define AR934X_ETH_CFG_MII_GMAC0_ERR_EN BIT(5) +#define AR934X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define AR934X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR934X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define AR934X_ETH_CFG_RMII_GMAC0 BIT(10) +#define AR933X_ETH_CFG_MII_CNTL_SPEED BIT(11) +#define AR934X_ETH_CFG_RMII_GMAC0_MASTER BIT(12) +#define AR933X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13) +#define AR934X_ETH_CFG_RXD_DELAY BIT(14) +#define AR934X_ETH_CFG_RXD_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RXD_DELAY_SHIFT 14 +#define AR934X_ETH_CFG_RDV_DELAY BIT(16) +#define AR934X_ETH_CFG_RDV_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RDV_DELAY_SHIFT 16
- QCA953X GMAC Interface
+#define QCA953X_GMAC_REG_ETH_CFG 0x00
+#define QCA953X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define QCA953X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define QCA953X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define QCA953X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13)
- QCA955X GMAC Interface
+#define QCA955X_GMAC_REG_ETH_CFG 0x00
+#define QCA955X_ETH_CFG_RGMII_EN BIT(0) +#define QCA955X_ETH_CFG_GE0_SGMII BIT(6)
+#endif /* __ASM_AR71XX_H */ diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h new file mode 100644 index 0000000..58c8224 --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -0,0 +1,143 @@ +/*
- Atheros AR71XX/AR724X/AR913X common definitions
- Copyright (C) 2008-2011 Gabor Juhos juhosg@openwrt.org
+#ifndef __ASM_MACH_ATH79_H +#define __ASM_MACH_ATH79_H
+#include <linux/types.h>
+DECLARE_GLOBAL_DATA_PTR;
+enum ath79_soc_type {
- ATH79_SOC_UNKNOWN,
- ATH79_SOC_AR7130,
- ATH79_SOC_AR7141,
- ATH79_SOC_AR7161,
- ATH79_SOC_AR7240,
- ATH79_SOC_AR7241,
- ATH79_SOC_AR7242,
- ATH79_SOC_AR9130,
- ATH79_SOC_AR9132,
- ATH79_SOC_AR9330,
- ATH79_SOC_AR9331,
- ATH79_SOC_AR9341,
- ATH79_SOC_AR9342,
- ATH79_SOC_AR9344,
- ATH79_SOC_QCA9533,
- ATH79_SOC_QCA9556,
- ATH79_SOC_QCA9558,
- ATH79_SOC_TP9343,
- ATH79_SOC_QCA9561,
+static inline int soc_is_ar71xx(void) +{
- return gd->arch.soc == ATH79_SOC_AR7130 ||
gd->arch.soc == ATH79_SOC_AR7141 ||
gd->arch.soc == ATH79_SOC_AR7161;
+static inline int soc_is_ar724x(void) +{
- return gd->arch.soc == ATH79_SOC_AR7240 ||
gd->arch.soc == ATH79_SOC_AR7241 ||
gd->arch.soc == ATH79_SOC_AR7242;
+static inline int soc_is_ar7240(void) +{
- return gd->arch.soc == ATH79_SOC_AR7240;
+static inline int soc_is_ar7241(void) +{
- return gd->arch.soc == ATH79_SOC_AR7241;
+static inline int soc_is_ar7242(void) +{
- return gd->arch.soc == ATH79_SOC_AR7242;
+static inline int soc_is_ar913x(void) +{
- return gd->arch.soc == ATH79_SOC_AR9130 ||
gd->arch.soc == ATH79_SOC_AR9132;
+static inline int soc_is_ar933x(void) +{
- return gd->arch.soc == ATH79_SOC_AR9330 ||
gd->arch.soc == ATH79_SOC_AR9331;
+static inline int soc_is_ar9341(void) +{
- return gd->arch.soc == ATH79_SOC_AR9341;
+static inline int soc_is_ar9342(void) +{
- return gd->arch.soc == ATH79_SOC_AR9342;
+static inline int soc_is_ar9344(void) +{
- return gd->arch.soc == ATH79_SOC_AR9344;
+static inline int soc_is_ar934x(void) +{
- return soc_is_ar9341() ||
soc_is_ar9342() ||
soc_is_ar9344();
+static inline int soc_is_qca9533(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9533;
+static inline int soc_is_qca953x(void) +{
- return soc_is_qca9533();
+static inline int soc_is_qca9556(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9556;
+static inline int soc_is_qca9558(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9558;
+static inline int soc_is_qca955x(void) +{
- return soc_is_qca9556() || soc_is_qca9558();
+static inline int soc_is_tp9343(void) +{
- return gd->arch.soc == ATH79_SOC_TP9343;
+static inline int soc_is_qca9561(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9561;
+static inline int soc_is_qca956x(void) +{
- return soc_is_tp9343() || soc_is_qca9561();
+#endif /* __ASM_MACH_ATH79_H */ diff --git a/arch/mips/mach-ath79/include/mach/ddr.h b/arch/mips/mach-ath79/include/mach/ddr.h new file mode 100644 index 0000000..3a6097e --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ddr.h @@ -0,0 +1,14 @@ +/*
- (C) Copyright 2015
- Wills Wang, wills.wang@live.com
+#ifndef __ASM_MACH_DDR_H +#define __ASM_MACH_DDR_H
+void ddr_init(void); +void ddr_tap_tunning(void);
+#endif /* __ASM_MACH_DDR_H */ diff --git a/arch/mips/mach-ath79/reset.c b/arch/mips/mach-ath79/reset.c new file mode 100644 index 0000000..c003c21 --- /dev/null +++ b/arch/mips/mach-ath79/reset.c @@ -0,0 +1,46 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <asm/arch/ath79.h> +#include <mach/ar71xx_regs.h>
+void _machine_restart(void) +{
- u32 val, reg = 0;
- if (soc_is_ar71xx())
reg = AR71XX_RESET_REG_RESET_MODULE;
- else if (soc_is_ar724x())
reg = AR724X_RESET_REG_RESET_MODULE;
- else if (soc_is_ar913x())
reg = AR913X_RESET_REG_RESET_MODULE;
- else if (soc_is_ar933x())
reg = AR933X_RESET_REG_RESET_MODULE;
- else if (soc_is_ar934x())
reg = AR934X_RESET_REG_RESET_MODULE;
- else if (soc_is_qca953x())
reg = QCA953X_RESET_REG_RESET_MODULE;
- else if (soc_is_qca955x())
reg = QCA955X_RESET_REG_RESET_MODULE;
- else if (soc_is_qca956x())
reg = QCA956X_RESET_REG_RESET_MODULE;
- else
puts("Reset register not defined for this SOC\n");
- if (reg) {
val = readl(KSEG1ADDR(AR71XX_RESET_BASE + reg));
val |= AR71XX_RESET_FULL_CHIP;
writel(val, KSEG1ADDR(AR71XX_RESET_BASE + reg));
- while (1)
/* NOP */;
On 12/30/2015 03:09 AM, Daniel Schwierzeck wrote:
diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index 2d9a0c9..3799e98 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -20,6 +20,12 @@ struct arch_global_data { unsigned long tbl; unsigned long lastinc; #endif +#ifdef CONFIG_ARCH_ATH79
- unsigned long id;
- unsigned long soc;
- unsigned long rev;
- unsigned long ver;
+#endif do you really need this at this location? global_data is only intended for variables needed before and after relocation and should be kept as small as possible. You can always read SoC info values directly from the hardware registers if you need them. There is no value in caching those infos in global_data.
Yes, these values ware write in function "print_cpuinfo", then u-boot run at ROM space, have no writable memory. Their can't be acquired directly by read register, need code to make judgments.
diff --git a/arch/mips/mach-ath79/ar933x/board.c b/arch/mips/mach-ath79/ar933x/board.c new file mode 100644 index 0000000..b4a76e8 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/board.c @@ -0,0 +1,42 @@ +/*
+#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ddr.h>
+static void uart_pin_init(void) +{
- u32 val;
* Set GPIO10 (UART_SO) as output and enable UART,
* BIT(15) in GPIO_FUNCTION_1 register must be written with 1
- val = readl(KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_OE));
- val |= BIT(10);
- writel(val, KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_OE));
- val = readl(KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_FUNC));
- val |= (AR933X_GPIO_FUNC_UART_EN | BIT(15));
- writel(val, KSEG1ADDR(AR71XX_GPIO_BASE + AR71XX_GPIO_REG_FUNC));
+#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{
- uart_pin_init();
- ddr_init();
+} +#endif the content of this file should be moved to your board directory. As Marek already mentioned, PIN setup is board-specific. Probably not all AR933x based boards need to setup that UART pin.
For ar933x, all board need to call ddr_init, or board don't boot up. ar933x have only one UART, we can't see any printout if uart_pin_init is missed.
diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c new file mode 100644 index 0000000..cfc4bb9 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -0,0 +1,86 @@ +/*
+static u32 ar933x_get_xtal(void) +{
- u32 val;
- val = readl(KSEG1ADDR(AR71XX_RESET_BASE + AR933X_RESET_REG_BOOTSTRAP));
now that you have implemented map_phymem(), you should always use it.
const void __iomem *regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, MAP_NOCACHE); ... val = readl(regs + AR933X_RESET_REG_BOOTSTRAP);
I'm going to sync asm/io.h and others with the kernel. Thus your current code would not compile without warnings any more. Please fix all locations in your code.
Apart from this you read the bootstrap settings in several places. You could create something like <mach/reset.h> and add a function like this
static inline u32 ar933x_get_bootstrap(void) { const void __iomem *regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, MAP_NOCACHE);
return readl(regs + AR933X_RESET_REG_BOOTSTRAP);
Ok.
- if (val & AR933X_BOOTSTRAP_REF_CLK_40)
return 40000000;
- else
return 25000000;
+int get_serial_clock(void) +{
- return ar933x_get_xtal();
+int get_clocks(void) +{
- u32 val, xtal, pll, div;
- xtal = ar933x_get_xtal();
- val = readl(KSEG1ADDR(AR71XX_PLL_BASE + AR933X_PLL_CPU_CONFIG_REG));
readl(regs + ...) as mentioned above
Ok.
- /* VCOOUT = XTAL * DIV_INT */
- div = (val >> AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT)
& AR933X_PLL_CPU_CONFIG_REFDIV_MASK;
- pll = xtal / div;
- /* PLLOUT = VCOOUT * (1/2^OUTDIV) */
- div = (val >> AR933X_PLL_CPU_CONFIG_DIVINT_SHIFT)
& AR933X_PLL_CPU_CONFIG_DIVINT_MASK;
- pll *= div;
- div = (val >> AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT)
& AR933X_PLL_CPU_CONFIG_OUTDIV_MASK;
- if (!div)
div = 1;
- pll >>= div;
- val = readl(KSEG1ADDR(AR71XX_PLL_BASE + AR933X_PLL_CLOCK_CTRL_REG));
Ok.
diff --git a/arch/mips/mach-ath79/ar933x/ddr.c b/arch/mips/mach-ath79/ar933x/ddr.c new file mode 100644 index 0000000..3985299 --- /dev/null +++ b/arch/mips/mach-ath79/ar933x/ddr.c @@ -0,0 +1,215 @@ +/*
+void ddr_init(void) +{
- void __iomem *regs = (void *)KSEG1ADDR(AR71XX_DDR_CTRL_BASE);
map_physmem()
Ok.
- u32 val;
- writel(0x7fbc8cd0, regs + AR71XX_DDR_REG_CONFIG);
- writel(0x9dd0e6a8, regs + AR71XX_DDR_REG_CONFIG2);
do not use magic values. These should be defined somewhere with descriptive names.
Ok.
- val = readl(KSEG1ADDR(AR71XX_RESET_BASE) +
use the suggested ar933x_get_bootstrap() function
Ok.
+void ddr_tap_tunning(void) do you mean ddr_tap_tuning() ?
Ok.
map_physmem()
Ok.
const char *chip
Ok.
No.
Daniel Schwierzeck
Wills Wang
