[U-Boot] [PATCH 1/3] tools: dumpimage: Provide more feedback on internal errors
The dumpimage utility errors out in a number of places without providing sufficient feedback to allow the user to easily determine what has gone wrong. Add additional error messages to make the cause of the failure more obvious.
Signed-off-by: Andrew F. Davis afd@ti.com --- tools/dumpimage.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/tools/dumpimage.c b/tools/dumpimage.c index ee3d41dda4..d5f893daf1 100644 --- a/tools/dumpimage.c +++ b/tools/dumpimage.c @@ -35,14 +35,23 @@ static int dumpimage_extract_subimage(struct image_type_params *tparams, if (tparams->verify_header) { retval = tparams->verify_header((unsigned char *)ptr, sbuf->st_size, ¶ms); - if (retval != 0) + if (retval != 0) { + fprintf(stderr, "%s: failed to verify header of %s\n", + params.cmdname, tparams->name); return -1; + } + /* * Extract the file from the image * if verify is successful */ if (tparams->extract_subimage) { retval = tparams->extract_subimage(ptr, ¶ms); + if (retval != 0) { + fprintf(stderr, "%s: extract_subimage failed for %s\n", + params.cmdname, tparams->name); + return -3; + } } else { fprintf(stderr, "%s: extract_subimage undefined for %s\n", @@ -175,6 +184,9 @@ int main(int argc, char **argv) * image type. Returns the error code if not matched */ retval = dumpimage_extract_subimage(tparams, ptr, &sbuf); + if (retval) + fprintf(stderr, "%s: Can't extract subimage from %s\n", + params.cmdname, params.imagefile); } else { /* * Print the image information for matched image type
This is very similar to fit_image_get_data but has the benefit of working on FIT images with external data unlike fit_image_get_data. This is useful for extracting sub-images from type of FIT image as this would previously just silently fail. Add an error message also so if this still fails it is easier to find out why.
Signed-off-by: Andrew F. Davis afd@ti.com --- tools/fit_image.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 5aca634b5e..0e4c2271ce 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -738,9 +738,14 @@ static int fit_image_extract( { const void *file_data; size_t file_size = 0; + int ret;
- /* get the "data" property of component at offset "image_noffset" */ - fit_image_get_data(fit, image_noffset, &file_data, &file_size); + /* get the data address and size of component at offset "image_noffset" */ + ret = fit_image_get_data_and_size(fit, image_noffset, &file_data, &file_size); + if (ret) { + fprintf(stderr, "Could not get component information\n"); + return ret; + }
/* save the "file_data" into the file specified by "file_name" */ return imagetool_save_subimage(file_name, (ulong) file_data, file_size);
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
This has the same result but some compilers will warn about this fall-through if there are statements as part of the label block.
Signed-off-by: Andrew F. Davis afd@ti.com --- tools/dumpimage.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/tools/dumpimage.c b/tools/dumpimage.c index d5f893daf1..e5481435a7 100644 --- a/tools/dumpimage.c +++ b/tools/dumpimage.c @@ -104,7 +104,6 @@ int main(int argc, char **argv) printf("dumpimage version %s\n", PLAIN_VERSION); exit(EXIT_SUCCESS); case 'h': - usage(); default: usage(); break;
ping
if (retval != 0)
if (retval != 0) {
- Extract the file from the image
- if verify is successful
if (retval != 0) {
return -3;
} else { fprintf(stderr, "%s: extract_subimage undefined for %s\n",}
if (retval)
} else { /*params.cmdname, params.imagefile);
- Print the image information for matched image type
ping
ping #2
if (retval != 0)
if (retval != 0) {
if (retval != 0) {
return -3;
if (retval)
if (retval != 0)
if (retval != 0) {
if (retval != 0) {
return -3;
if (retval)
Andrew F. Davis
Lokesh Vutla
