[U-Boot-Users] Device tree question for 85xx
Hi all, please excuse if device tree questions are off topic for this list - I already tried linuxppc-embedded2 on usenet with no luck. I've also been reading booting-without-of.txt .
I'm trying to define the 'mdio' and 'ethernet' nodes for my mpc8548e board that arrives soon, using cds for my reference. The cds reference has a Quad PHY of either a CIS8204 or a 88E1145 - swappable as a mezzanine I believe. Our board has two dual PHY's - 88E1111 and a 88E1121R . Our hardware engineer has simply defined four external interrupts:
IRQ0 : PHY 0 - TSEC 1 (P0 of the 88E1121R) IRQ1 : PHY 1 - TSEC 2 (P1 of the 88E1121R) IRQ2 : PHY 2 - TSEC 3 (88E1111) IRQ3 : PHY 3 - TSEC 4 (88E1111)
The docs say the interrupts depend on the 'type of interrupt controller' - which is on chip I believe for the 8548. Here's how cds has it in the linux-2.6.22/arch/powerpc/boot/dts/mpc8548cds.dts - Can anyone please help me understand how to define a dts for my board? I've been struggling to understand how this works - any help appreciated.
mdio@24520 { #address-cells = <1>; #size-cells = <0>; device_type = "mdio"; compatible = "gianfar"; reg = <24520 20>; phy0: ethernet-phy@0 { interrupt-parent = <&mpic>; interrupts = <35 0>; reg = <0>; device_type = "ethernet-phy"; }; phy1: ethernet-phy@1 { interrupt-parent = <&mpic>; interrupts = <35 0>; reg = <1>; device_type = "ethernet-phy"; }; phy2: ethernet-phy@2 { interrupt-parent = <&mpic>; interrupts = <35 0>; reg = <2>; device_type = "ethernet-phy"; }; phy3: ethernet-phy@3 { interrupt-parent = <&mpic>; interrupts = <35 0>; reg = <3>; device_type = "ethernet-phy"; }; }; ethernet@24000 { #address-cells = <1>; #size-cells = <0>; device_type = "network"; model = "eTSEC"; compatible = "gianfar"; reg = <24000 1000>; local-mac-address = [ 00 E0 0C 00 73 00 ]; interrupts = <d 2 e 2 12 2>; interrupt-parent = <&mpic>; phy-handle = <&phy0>; };
ethernet@25000 { #address-cells = <1>; #size-cells = <0>; device_type = "network"; model = "eTSEC"; compatible = "gianfar"; reg = <25000 1000>; local-mac-address = [ 00 E0 0C 00 73 01 ]; interrupts = <13 2 14 2 18 2>; interrupt-parent = <&mpic>; phy-handle = <&phy1>; };
/* eTSEC 3/4 are currently broken ethernet@26000 { #address-cells = <1>; #size-cells = <0>; device_type = "network"; model = "eTSEC"; compatible = "gianfar"; reg = <26000 1000>; local-mac-address = [ 00 E0 0C 00 73 02 ]; interrupts = <f 2 10 2 11 2>; interrupt-parent = <&mpic>; phy-handle = <&phy2>; }; ethernet@27000 { #address-cells = <1>; #size-cells = <0>; device_type = "network"; model = "eTSEC"; compatible = "gianfar"; reg = <27000 1000>; local-mac-address = [ 00 E0 0C 00 73 03 ]; interrupts = <15 2 16 2 17 2>; interrupt-parent = <&mpic>; phy-handle = <&phy3>; }; */
Thanks, Robert
I'm not familiar with "linuxppc-embedded2", but linuxppc-embedded@ozlabs.org is the place for this kind of thing.
External interrupts start at zero (internal interrupt numbers have 0x10 added to them), so the first cell should correspond to the external IRQ number.
The second cell encodes the level and sense information, and is documented in Documentation/powerpc/booting-without-of.txt:
0 = low to high edge sensitive type enabled 1 = active low level sensitive type enabled 2 = active high level sensitive type enabled 3 = high to low edge sensitive type enabled
-Scott
robert lazarski
Scott Wood
