[U-Boot] Please pull u-boot-rockchip
Hi Tom,
This includes support for two SoCs that have been in the works for a while: rk3188 from Heiko Stübner and and SPL for rk3399 from Kever Yang. For the former there are a few more patches to come but I'll apply them in a few days once I've had time to test. In addition this includes rk3328 also from Kever which is based on the rk3399 work. I've decided to bring this in also as the impact is minimal.
There are a few bugs in mainline affecting rockchip which I'd like to fix for the release also. But I want to take a bit more time to really understand the problem before applying anything. Hopefully I will have those early next week. I'm sending this pull request now as I feel uncomfortable having so many pending patches.
The following changes since commit b24cf8540a85a9bf97975aadd6a7542f166c78a3:
video: mxsfb: Fix reset hang when videomode variable is not present (2017-02-22 21:47:59 +0100)
git://git.denx.de/u-boot-rockchip.git
for you to fetch changes up to 984fe3b08c8fcc61253965c88f882411ad8c78ec:
rockchip: rk3288: add defconfig for evb-rk3328 (2017-02-23 09:17:59 -0700)
---------------------------------------------------------------- Eddie Cai (1): rockchip: tinker: configs: use correct mmc instance as boot target device
Heiko Stübner (18): dm: allow limiting pre-reloc markings to spl or tpl rockchip: clk: rk3288: limit gpll and cpll init to SPL build rockchip: rk3288: sdram: use constants in ddrconf table rockchip: rk3288: sdram: style fixes from rk3188 sdram review rockchip: Move bootrom helper compilation to a hidden option rockchip: Move bootrom-related declarations to a header rockchip: mkimage: Allow encoding of loader code in spl images rockchip: mkimage: Add support rk3188 serial rockchip: serial: Adapt rockchip of-platdata driver for rk3188 rockchip: rk3188: Add header files for PMU and GRF rockchip: rk3188: Add pinctrl driver rockchip: rk3188: Add sysreset driver rockchip: rk3188: Add rk3066/rk3188 clock bindings rockchip: rk3188: Add clock driver rockchip: rk3188: Add core devicetree files rockchip: rk3188: Add core support rockchip: rk3188: Add sdram driver rockchip: rk3188: Add main, spl and tpl boards
Jacob Chen (1): rockchip: firefly: configs: remove config_spl_of_platdata
Kever Yang (16): rockchip: arm64: rk3399: move grf register definitions to grf_rk3399.h rockchip: clk: rk3399: update driver for spl rockchip: sdhci: rk3399: update driver to support of-platdata rockchip: pinctrl: rk3399: add the of-platdata support rockchip: arm64: rk3399: syscon addition for rk3399 rockchip: arm64: rk3399: add ddr controller driver rockchip: dts: rk3399: update for spl require driver rockchip: arm64: rk3399: add SPL support rockchip: config: rk3399: enable SPL config for evb-rk3399 rockchip: rk3328: add device tree file rockchip: rk3328: add soc basic support rockchip: rk3328: add clock driver rockchip: rk3328: add pinctrl driver rockchip: rk3328: add sysreset driver rockchip: rk3328: add evb-rk3328 support rockchip: rk3288: add defconfig for evb-rk3328
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3188.dtsi | 601 ++++++++++++++ arch/arm/dts/rk3328-evb.dts | 45 + arch/arm/dts/rk3328.dtsi | 1477 +++++++++++++++++++++++++++++++++ arch/arm/dts/rk3399-evb.dts | 2 + arch/arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi | 1536 +++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3399.dtsi | 44 + arch/arm/dts/rk3xxx.dtsi | 417 ++++++++++ arch/arm/include/asm/arch-rockchip/bootrom.h | 22 + arch/arm/include/asm/arch-rockchip/clock.h | 9 + arch/arm/include/asm/arch-rockchip/cru_rk3188.h | 191 +++++ arch/arm/include/asm/arch-rockchip/cru_rk3328.h | 70 ++ arch/arm/include/asm/arch-rockchip/cru_rk3399.h | 5 + arch/arm/include/asm/arch-rockchip/ddr_rk3188.h | 25 + arch/arm/include/asm/arch-rockchip/ddr_rk3288.h | 8 + arch/arm/include/asm/arch-rockchip/grf_rk3188.h | 589 ++++++++++++++ arch/arm/include/asm/arch-rockchip/grf_rk3328.h | 134 +++ arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 118 +++ arch/arm/include/asm/arch-rockchip/pmu_rk3188.h | 36 + arch/arm/include/asm/arch-rockchip/sdram_rk3399.h | 119 +++ arch/arm/mach-rockchip/Kconfig | 34 + arch/arm/mach-rockchip/Makefile | 16 +- arch/arm/mach-rockchip/rk3036-board-spl.c | 3 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 218 +++++ arch/arm/mach-rockchip/rk3188-board-tpl.c | 86 ++ arch/arm/mach-rockchip/rk3188-board.c | 71 ++ arch/arm/mach-rockchip/rk3188/Kconfig | 24 + arch/arm/mach-rockchip/rk3188/Makefile | 11 + arch/arm/mach-rockchip/rk3188/clk_rk3188.c | 33 + arch/arm/mach-rockchip/rk3188/sdram_rk3188.c | 995 +++++++++++++++++++++++ arch/arm/mach-rockchip/rk3188/syscon_rk3188.c | 55 ++ arch/arm/mach-rockchip/rk3288-board-spl.c | 3 +- arch/arm/mach-rockchip/rk3288/sdram_rk3288.c | 59 +- arch/arm/mach-rockchip/rk3328/Kconfig | 23 + arch/arm/mach-rockchip/rk3328/Makefile | 9 + arch/arm/mach-rockchip/rk3328/clk_rk3328.c | 31 + arch/arm/mach-rockchip/rk3328/rk3328.c | 39 + arch/arm/mach-rockchip/rk3328/syscon_rk3328.c | 20 + arch/arm/mach-rockchip/rk3399-board-spl.c | 158 ++++ arch/arm/mach-rockchip/rk3399/Makefile | 1 + arch/arm/mach-rockchip/rk3399/clk_rk3399.c | 21 + arch/arm/mach-rockchip/rk3399/rk3399.c | 1 + arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 1321 ++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 40 + board/rockchip/evb_rk3328/Kconfig | 15 + board/rockchip/evb_rk3328/MAINTAINERS | 6 + board/rockchip/evb_rk3328/Makefile | 7 + board/rockchip/evb_rk3328/README | 70 ++ board/rockchip/evb_rk3328/evb-rk3328.c | 40 + configs/evb-rk3328_defconfig | 36 + configs/evb-rk3399_defconfig | 19 +- configs/firefly-rk3288_defconfig | 1 - doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt | 42 + doc/driver-model/README.txt | 4 + drivers/clk/at91/pmc.c | 3 +- drivers/clk/rockchip/Makefile | 2 + drivers/clk/rockchip/clk_rk3188.c | 527 ++++++++++++ drivers/clk/rockchip/clk_rk3288.c | 2 + drivers/clk/rockchip/clk_rk3328.c | 581 +++++++++++++ drivers/clk/rockchip/clk_rk3399.c | 91 ++- drivers/core/root.c | 2 +- drivers/core/util.c | 25 + drivers/mmc/rockchip_sdhci.c | 17 +- drivers/pinctrl/Kconfig | 18 + drivers/pinctrl/pinctrl-uclass.c | 3 +- drivers/pinctrl/rockchip/Makefile | 2 + drivers/pinctrl/rockchip/pinctrl_rk3188.c | 611 ++++++++++++++ drivers/pinctrl/rockchip/pinctrl_rk3328.c | 419 ++++++++++ drivers/pinctrl/rockchip/pinctrl_rk3399.c | 111 +-- drivers/serial/serial_rockchip.c | 19 +- drivers/sysreset/Makefile | 2 + drivers/sysreset/sysreset_rk3188.c | 47 ++ drivers/sysreset/sysreset_rk3328.c | 45 + include/configs/evb_rk3328.h | 26 + include/configs/rk3188_common.h | 121 +++ include/configs/rk3328_common.h | 65 ++ include/configs/rk3399_common.h | 11 + include/configs/tinker_rk3288.h | 2 +- include/dm/util.h | 26 + include/dt-bindings/clock/rk3066a-cru.h | 32 + include/dt-bindings/clock/rk3188-cru-common.h | 256 ++++++ include/dt-bindings/clock/rk3188-cru.h | 48 ++ include/dt-bindings/clock/rk3328-cru.h | 394 +++++++++ include/dt-bindings/clock/rk3399-cru.h | 16 +- include/dt-bindings/pinctrl/rockchip.h | 2 + scripts/Makefile.spl | 7 +- tools/dtoc/dtoc.py | 2 + tools/rkcommon.c | 34 +- tools/rkcommon.h | 22 + tools/rkimage.c | 3 + tools/rksd.c | 4 + tools/rkspi.c | 4 + 92 files changed, 12395 insertions(+), 168 deletions(-) create mode 100644 arch/arm/dts/rk3188.dtsi create mode 100644 arch/arm/dts/rk3328-evb.dts create mode 100644 arch/arm/dts/rk3328.dtsi create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-4GB-1600.dtsi create mode 100644 arch/arm/dts/rk3xxx.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/bootrom.h create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3328.h create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3328.h create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3188.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rk3399.h create mode 100644 arch/arm/mach-rockchip/rk3188-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk3188-board.c create mode 100644 arch/arm/mach-rockchip/rk3188/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3188/Makefile create mode 100644 arch/arm/mach-rockchip/rk3188/clk_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/sdram_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3188/syscon_rk3188.c create mode 100644 arch/arm/mach-rockchip/rk3328/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3328/Makefile create mode 100644 arch/arm/mach-rockchip/rk3328/clk_rk3328.c create mode 100644 arch/arm/mach-rockchip/rk3328/rk3328.c create mode 100644 arch/arm/mach-rockchip/rk3328/syscon_rk3328.c create mode 100644 arch/arm/mach-rockchip/rk3399-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3399/sdram_rk3399.c create mode 100644 board/rockchip/evb_rk3328/Kconfig create mode 100644 board/rockchip/evb_rk3328/MAINTAINERS create mode 100644 board/rockchip/evb_rk3328/Makefile create mode 100644 board/rockchip/evb_rk3328/README create mode 100644 board/rockchip/evb_rk3328/evb-rk3328.c create mode 100644 configs/evb-rk3328_defconfig create mode 100644 doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt create mode 100644 drivers/clk/rockchip/clk_rk3188.c create mode 100644 drivers/clk/rockchip/clk_rk3328.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3188.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3328.c create mode 100644 drivers/sysreset/sysreset_rk3188.c create mode 100644 drivers/sysreset/sysreset_rk3328.c create mode 100644 include/configs/evb_rk3328.h create mode 100644 include/configs/rk3188_common.h create mode 100644 include/configs/rk3328_common.h create mode 100644 include/dt-bindings/clock/rk3066a-cru.h create mode 100644 include/dt-bindings/clock/rk3188-cru-common.h create mode 100644 include/dt-bindings/clock/rk3188-cru.h create mode 100644 include/dt-bindings/clock/rk3328-cru.h
On Thu, Feb 23, 2017 at 09:42:57AM -0700, Simon Glass wrote:
Hi Tom,
I'm sorry, this is too big, too late. Having watched Linus' talk at ELC, I'm feeling better about being stricter about the merge window. It took them a long time, and I'd like for us to get it done in less time :) Thanks!
Hi Tom,
Hi Tom,
Yes, understood, plus even now there are still some missing patches :-( I'll use the time to get the rest of the patches tested and applied, and we can deal with it in the next release.
