[U-Boot] [PATCH] Convert CONFIG_MXC_GPIO to Kconfig
This converts the following to Kconfig: CONFIG_MXC_GPIO
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/Kconfig | 5 +++++ configs/apf27_defconfig | 1 + configs/flea3_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/mx31ads_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + drivers/gpio/Kconfig | 5 +++++ include/configs/advantech_dms-ba16.h | 1 - include/configs/apalis_imx6.h | 1 - include/configs/apf27.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/flea3.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/imx31_phycore.h | 2 -- include/configs/m53evk.h | 2 -- include/configs/mx25pdk.h | 1 - include/configs/mx31ads.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx35pdk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53ard.h | 2 -- include/configs/mx53cx9020.h | 1 - include/configs/mx53evk.h | 2 -- include/configs/mx53loco.h | 1 - include/configs/mx53ppd.h | 1 - include/configs/mx53smd.h | 2 -- include/configs/mx6_common.h | 1 - include/configs/mx6ullevk.h | 2 -- include/configs/mx7_common.h | 1 - include/configs/ts4800.h | 1 - include/configs/usbarmory.h | 1 - include/configs/woodburn_common.h | 3 --- include/configs/zmx25.h | 1 - scripts/config_whitelist.txt | 1 - 39 files changed, 18 insertions(+), 37 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b730bcb..d2305d5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -663,11 +663,13 @@ config ARCH_MESON config ARCH_MX25 bool "NXP MX25" select CPU_ARM926EJS + imply MXC_GPIO
config ARCH_MX7ULP bool "NXP MX7ULP" select CPU_V7 select ROM_UNIFIED_SECTIONS + imply MXC_GPIO
config ARCH_MX7 bool "Freescale MX7" @@ -677,6 +679,7 @@ config ARCH_MX7 select SYS_FSL_SEC_LE select BOARD_EARLY_INIT_F select ARCH_MISC_INIT + imply MXC_GPIO
config ARCH_MX6 bool "Freescale MX6" @@ -685,6 +688,7 @@ config ARCH_MX6 select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE select SYS_THUMB_BUILD if SPL + imply MXC_GPIO
if ARCH_MX6 config SPL_LDSCRIPT @@ -695,6 +699,7 @@ config ARCH_MX5 bool "Freescale MX5" select CPU_V7 select BOARD_EARLY_INIT_F + imply MXC_GPIO
config ARCH_QEMU bool "QEMU Virtual Platform" diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index f09c5a8..9f16994 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand.0:1M(u-boot)ro,512K(env),512K(env2),512K(firmware),512K(dtb),5M(kernel),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_MXC_GPIO=y CONFIG_MMC_MXC=y CONFIG_NAND=y CONFIG_NAND_MXC=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 9f9d8ee..069f442 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=mxc_nand,nor0=physmap-flash.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64m(app1),10m(app2),-(spool);physmap-flash.0:512k(u-boot),64k(env1),64k(env2),3776k(kernel1),3776k(kernel2)" CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NAND=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index 5defae8..e80791b 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.0:128k(uboot)ro,1536k(kernel),-(root)" CONFIG_ENV_IS_IN_EEPROM=y +CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y diff --git a/configs/mx31ads_defconfig b/configs/mx31ads_defconfig index da71670..af81275 100644 --- a/configs/mx31ads_defconfig +++ b/configs/mx31ads_defconfig @@ -7,5 +7,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index ea6daf2..e4e955c 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_MXC_GPIO=y # CONFIG_MMC is not set CONFIG_NAND=y CONFIG_NAND_MXC=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 61d2013..e550d40 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -23,6 +23,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:1m(boot),5m(linux),96m(root),8m(cfg), CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MXC_GPIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_NAND=y CONFIG_NAND_MXC=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 4d50d4e..da2b659 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -24,6 +24,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand:50m(root1),32m(rootfb),64m(pcache),64 CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MXC_GPIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_NAND=y CONFIG_NAND_MXC=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 4fe5f2f..281019d 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -35,6 +35,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y +CONFIG_MXC_GPIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_NAND=y CONFIG_NAND_MXC=y diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index b121979..34d4409 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -108,6 +108,11 @@ config MSM_GPIO - APQ8016 - MSM8916
+config MXC_GPIO + bool "Freescale/NXP MXC UART driver" + help + Support GPIO controllers on various i.MX platforms + config OMAP_GPIO bool "TI OMAP GPIO driver" depends on ARCH_OMAP2PLUS diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 1c2dee7..c70b655 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -33,7 +33,6 @@ #define CONFIG_REVISION_TAG #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
-#define CONFIG_MXC_GPIO #define CONFIG_MXC_UART
#define CONFIG_MXC_OCOTP diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 18218c1..7b4e679 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -101,7 +101,6 @@ #define CONFIG_DFU_MMC
/* Miscellaneous commands */ -#define CONFIG_MXC_GPIO
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 24afc84..9579717 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -172,7 +172,6 @@ /* * GPIO */ -#define CONFIG_MXC_GPIO
/* * NOR diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 823034f..12124f3 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -89,7 +89,6 @@ #define CONFIG_DFU_MMC
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 1f26ef4..bcbc380 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -65,7 +65,6 @@ #endif
/* GPIO */ -#define CONFIG_MXC_GPIO
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/flea3.h b/include/configs/flea3.h index e4d5f91..370d088 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_SPD_BUS_NUM 2 /* I2C3 */ #define CONFIG_SYS_MXC_I2C3_SLAVE 0xfe #define CONFIG_MXC_SPI -#define CONFIG_MXC_GPIO
/* * UART (console) diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 694aa8a..8321cc8 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -44,7 +44,6 @@ #define CONFIG_REVISION_TAG #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M)
#define CONFIG_MXC_OCOTP diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 9596f0b..684831d 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -134,7 +134,6 @@ /* * GPIO */ -#define CONFIG_MXC_GPIO
/* * U-Boot general configuration diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index c2d4160..751dfbc 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -147,8 +147,6 @@
/* EET platform additions */ #ifdef CONFIG_TARGET_IMX31_PHYCORE_EET -#define CONFIG_MXC_GPIO - #define CONFIG_HARD_SPI #define CONFIG_MXC_SPI
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 50379c7..10d3117 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -8,8 +8,6 @@ #ifndef __M53EVK_CONFIG_H__ #define __M53EVK_CONFIG_H__
-#define CONFIG_MXC_GPIO - #include <asm/arch/imx-regs.h>
#define CONFIG_REVISION_TAG diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index f82c4cc..8661d0f 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -12,7 +12,6 @@ /* High Level Configuration Options */
#define CONFIG_SYS_TEXT_BASE 0x81200000 -#define CONFIG_MXC_GPIO #define CONFIG_SYS_FSL_CLK
#define CONFIG_SYS_TIMER_RATE 32768 diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 18ee355..246e0cb 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -38,7 +38,6 @@ #define CONFIG_MXC_SPI 1 #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) -#define CONFIG_MXC_GPIO
/* PMIC Controller */ #define CONFIG_POWER diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 3259e82..6df3a98 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -46,7 +46,6 @@
#define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_MXC_GPIO
#define CONFIG_HARD_SPI #define CONFIG_MXC_SPI diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 6a334cb..df455bf 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_MXC_SPI -#define CONFIG_MXC_GPIO
/* * PMIC Configs diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 3ecb92c..8c32737 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -36,7 +36,6 @@
/* * SPI Configs diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 985109e..523f507 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -23,8 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_MXC_GPIO - #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR_AXI #define CONFIG_MXC_NAND_REGS_BASE NFC_BASE_ADDR_AXI diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index ccb1a4a..1929c68 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -24,7 +24,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
-#define CONFIG_MXC_GPIO #define CONFIG_REVISION_TAG
#define CONFIG_MXC_UART_BASE UART2_BASE diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index 1bddb37..e199175 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -23,8 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_MXC_GPIO - #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 323aa3d..e2490ce 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -23,7 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
#define CONFIG_MXC_UART diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index 92dd845..05c3d52 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -29,7 +29,6 @@
#define CONFIG_MISC_INIT_R #define CONFIG_BOARD_LATE_INIT -#define CONFIG_MXC_GPIO #define CONFIG_REVISION_TAG
#define CONFIG_MXC_UART diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 216a0d5..399b523 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -23,8 +23,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index ddc645c..4076238 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -70,7 +70,6 @@ #define CONFIG_SYS_MAXARGS 32
/* MMC */ #define CONFIG_BOUNCE_BUFFER diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 6a48742..2142913 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -27,8 +27,6 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (16 * SZ_1M)
diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 1785040..e454f80 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -46,7 +46,6 @@ #endif
/* UART */ #define CONFIG_MXC_UART diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index ebfbb66..5b8bac8 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -43,7 +43,6 @@
/* * SPI Configs diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 4bebc59..3eacf2a 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -12,7 +12,6 @@ #define __CONFIG_H
#define CONFIG_SYS_FSL_CLK -#define CONFIG_MXC_GPIO
diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 7ab60fd..5b94a3f 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -44,7 +44,6 @@ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_SPD_BUS_NUM 0 #define CONFIG_MXC_SPI -#define CONFIG_MXC_GPIO
/* PMIC Controller */ #define CONFIG_POWER @@ -76,8 +75,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_DNS
-#define CONFIG_MXC_GPIO - #define CONFIG_NET_RETRY_COUNT 100
diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index f9783a2..7025c3f 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -40,7 +40,6 @@ /* * GPIO */ -#define CONFIG_MXC_GPIO
/* * Serial diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index bc097db..9e103dc 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1425,7 +1425,6 @@ CONFIG_MX6DQ_LPDDR2 CONFIG_MX6SX_SABRESD_REVA CONFIG_MX6UL_14X14_EVK_EMMC_REWORK CONFIG_MXC_EPDC -CONFIG_MXC_GPIO CONFIG_MXC_GPT_HCLK CONFIG_MXC_MCI_REGS_BASE CONFIG_MXC_NAND_HWECC
Adam Ford
