[PATCH] dm: fix mis-word in SPL_DM description
Replace logically correct word in the description.
Fixes: 91a91ff804d ("dm: Add Kconfig options for driver model SPL support") Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
drivers/core/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 8eb0070d222..007dc6a1de3 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -18,7 +18,7 @@ config SPL_DM consider using CONFIG_SPL_SYS_MALLOC_SIMPLE. In that case you must provide CONFIG_SPL_SYS_MALLOC_F_LEN to set the size. In most cases driver model will only allocate a few uclasses - and devices in SPL, so 1KB should be enable. See + and devices in SPL, so 1KB should be enough. See CONFIG_SPL_SYS_MALLOC_F_LEN for more details on how to enable it.
config TPL_DM
On Wed, 13 Jul 2022 at 10:42, Oleksandr Suvorov oleksandr.suvorov@foundries.io wrote:
Applied to u-boot-dm, thanks!
Oleksandr Suvorov
