[U-Boot] [PATCH] board: sama5d4ek: fix DD2 configuration
Fix the DDR2 configuration to make SPL work.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
arch/arm/mach-at91/include/mach/atmel_mpddrc.h | 7 ++++++- board/atmel/sama5d4ek/sama5d4ek.c | 16 +++++++++++++++- 2 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/atmel_mpddrc.h b/arch/arm/mach-at91/include/mach/atmel_mpddrc.h index f6bcecda38..803501f5cf 100644 --- a/arch/arm/mach-at91/include/mach/atmel_mpddrc.h +++ b/arch/arm/mach-at91/include/mach/atmel_mpddrc.h @@ -186,9 +186,14 @@ int ddr3_init(const unsigned int base, #define ATMEL_MPDDRC_IO_CALIBR_DDR3_RZQ_73 0x6 #define ATMEL_MPDDRC_IO_CALIBR_DDR3_RZQ_110 0x7
-#define ATMEL_MPDDRC_IO_CALIBR_TZQIO 0x7f +#define ATMEL_MPDDRC_IO_CALIBR_TZQIO (0x7f << 8) #define ATMEL_MPDDRC_IO_CALIBR_TZQIO_(x) (((x) & 0x7f) << 8)
+#define ATMEL_MPDDRC_IO_CALIBR_CALCODEP (0xf << 16) +#define ATMEL_MPDDRC_IO_CALIBR_CALCODEP_(x) (((x) & 0xf) << 16) +#define ATMEL_MPDDRC_IO_CALIBR_CALCODEN (0xf << 20) +#define ATMEL_MPDDRC_IO_CALIBR_CALCODEN_(x) (((x) & 0xf) << 20) + #define ATMEL_MPDDRC_IO_CALIBR_EN_CALIB (0x1 << 4)
/* Bit field in Read Data Path Register */ diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index d1b5ff5797..8eec0e88a5 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -349,7 +349,6 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) ATMEL_MPDDRC_CR_NR_ROW_14 | ATMEL_MPDDRC_CR_CAS_DDR_CAS3 | ATMEL_MPDDRC_CR_NB_8BANKS | - ATMEL_MPDDRC_CR_NDQS_DISABLED | ATMEL_MPDDRC_CR_DECOD_INTERLEAVED | ATMEL_MPDDRC_CR_UNAL_SUPPORTED);
@@ -379,6 +378,8 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) void mem_init(void) { struct atmel_mpddrc_config ddr2; + const struct atmel_mpddr *mpddr = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; + u32 tmp;
ddr2_conf(&ddr2);
@@ -386,6 +387,19 @@ void mem_init(void) at91_periph_clk_enable(ATMEL_ID_MPDDRC); at91_system_clk_enable(AT91_PMC_DDR);
+ tmp = ATMEL_MPDDRC_RD_DATA_PATH_SHIFT_ONE_CYCLE; + writel(tmp, &mpddr->rd_data_path); + + tmp = readl(&mpddr->io_calibr); + tmp = (tmp & ~(ATMEL_MPDDRC_IO_CALIBR_RDIV | + ATMEL_MPDDRC_IO_CALIBR_TZQIO | + ATMEL_MPDDRC_IO_CALIBR_CALCODEP | + ATMEL_MPDDRC_IO_CALIBR_CALCODEN)) | + ATMEL_MPDDRC_IO_CALIBR_DDR2_RZQ_52 | + ATMEL_MPDDRC_IO_CALIBR_TZQIO_(8) | + ATMEL_MPDDRC_IO_CALIBR_EN_CALIB; + writel(tmp, &mpddr->io_calibr); + /* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddr2); }
Applied to u-boot-dm/next, thanks!
sjg@google.com
Wenyou Yang
