[U-Boot] tools: board config CONFIG_SYS_BOOTM_LEN is being ignored
8 Mar
2019
8 Mar
'19
10:22 a.m.
i noticed that CONFIG_SYS_BOOTM_LEN, set in board config, and used in common/bootm.c is ignored when compiling the tools like mkimage and fit_check_sign. Instead the default value of 8MB is used and fit_check_sign may fail with "Loading Kernel Image ... Image too large: increase CONFIG_SYS_BOOTM_LEN". Still the U-Boot binary built with the increased CONFIG_SYS_BOOTM_LEN works without any problem.
I'm unsure how and where to fix it in a proper way. The Makefile system ist not quite easy to understand and the CONFIG_* options are spread over various files during build time. It may be possible to move this option to Kconfig.
Regards, Philipp
2252
Philipp Puschmann
