[U-Boot] [PATCH v2 05/15] x86: Add basic cache operations
Add functions to enable/disable the data cache.
Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Move all control register access into new include/asm/control_regs.h - Redo the cache control functions in cpu.c instead of creating new ones - Add dummy cache functions required by U-Boot
arch/x86/cpu/cpu.c | 38 +++++++++++-- arch/x86/cpu/interrupts.c | 68 +---------------------- arch/x86/include/asm/cache.h | 16 +++++ arch/x86/include/asm/control_regs.h | 105 +++++++++++++++++++++++++++++++++++ 4 files changed, 155 insertions(+), 72 deletions(-) create mode 100644 arch/x86/include/asm/control_regs.h
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index fabfbd1..315e87a 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -34,6 +34,7 @@
#include <common.h> #include <command.h> +#include <asm/control_regs.h> #include <asm/processor.h> #include <asm/processor-flags.h> #include <asm/interrupt.h> @@ -147,16 +148,27 @@ int cpu_init_r(void) __attribute__((weak, alias("x86_cpu_init_r")));
void x86_enable_caches(void) { - const u32 nw_cd_rst = ~(X86_CR0_NW | X86_CR0_CD); + unsigned long cr0;
- /* turn on the cache and disable write through */ - asm("movl %%cr0, %%eax\n" - "andl %0, %%eax\n" - "movl %%eax, %%cr0\n" - "wbinvd\n" : : "i" (nw_cd_rst) : "eax"); + cr0 = read_cr0(); + cr0 &= ~(X86_CR0_NW | X86_CR0_CD); + write_cr0(cr0); + wbinvd(); } void enable_caches(void) __attribute__((weak, alias("x86_enable_caches")));
+void x86_disable_caches(void) +{ + unsigned long cr0; + + cr0 = read_cr0(); + cr0 |= X86_CR0_NW | X86_CR0_CD; + wbinvd(); + write_cr0(cr0); + wbinvd(); +} +void disable_caches(void) __attribute__((weak, alias("x86_disable_caches"))); + int x86_init_cache(void) { enable_caches(); @@ -200,3 +212,17 @@ void __reset_cpu(ulong addr) generate_gpf(); /* start the show */ } void reset_cpu(ulong addr) __attribute__((weak, alias("__reset_cpu"))); + +int dcache_status(void) +{ + return !(read_cr0() & 0x40000000); +} + +/* Define these functions to allow ehch-hcd to function */ +void flush_dcache_range(unsigned long start, unsigned long stop) +{ +} + +void invalidate_dcache_range(unsigned long start, unsigned long stop) +{ +} diff --git a/arch/x86/cpu/interrupts.c b/arch/x86/cpu/interrupts.c index 43ec3f8..e788715 100644 --- a/arch/x86/cpu/interrupts.c +++ b/arch/x86/cpu/interrupts.c @@ -28,6 +28,8 @@ */
#include <common.h> +#include <asm/cache.h> +#include <asm/control_regs.h> #include <asm/interrupt.h> #include <asm/io.h> #include <asm/processor-flags.h> @@ -41,72 +43,6 @@ "pushl $"#x"\n" \ "jmp irq_common_entry\n"
-/* - * Volatile isn't enough to prevent the compiler from reordering the - * read/write functions for the control registers and messing everything up. - * A memory clobber would solve the problem, but would prevent reordering of - * all loads stores around it, which can hurt performance. Solution is to - * use a variable and mimic reads and writes to it to enforce serialisation - */ -static unsigned long __force_order; - -static inline unsigned long read_cr0(void) -{ - unsigned long val; - asm volatile("mov %%cr0,%0\n\t" : "=r" (val), "=m" (__force_order)); - return val; -} - -static inline unsigned long read_cr2(void) -{ - unsigned long val; - asm volatile("mov %%cr2,%0\n\t" : "=r" (val), "=m" (__force_order)); - return val; -} - -static inline unsigned long read_cr3(void) -{ - unsigned long val; - asm volatile("mov %%cr3,%0\n\t" : "=r" (val), "=m" (__force_order)); - return val; -} - -static inline unsigned long read_cr4(void) -{ - unsigned long val; - asm volatile("mov %%cr4,%0\n\t" : "=r" (val), "=m" (__force_order)); - return val; -} - -static inline unsigned long get_debugreg(int regno) -{ - unsigned long val = 0; /* Damn you, gcc! */ - - switch (regno) { - case 0: - asm("mov %%db0, %0" : "=r" (val)); - break; - case 1: - asm("mov %%db1, %0" : "=r" (val)); - break; - case 2: - asm("mov %%db2, %0" : "=r" (val)); - break; - case 3: - asm("mov %%db3, %0" : "=r" (val)); - break; - case 6: - asm("mov %%db6, %0" : "=r" (val)); - break; - case 7: - asm("mov %%db7, %0" : "=r" (val)); - break; - default: - val = 0; - } - return val; -} - void dump_regs(struct irq_regs *regs) { unsigned long cr0 = 0L, cr2 = 0L, cr3 = 0L, cr4 = 0L; diff --git a/arch/x86/include/asm/cache.h b/arch/x86/include/asm/cache.h index 87c9e0b..d4678d4 100644 --- a/arch/x86/include/asm/cache.h +++ b/arch/x86/include/asm/cache.h @@ -32,4 +32,20 @@ #define ARCH_DMA_MINALIGN 64 #endif
+static inline void wbinvd(void) +{ + asm volatile ("wbinvd" : : : "memory"); +} + +static inline void invd(void) +{ + asm volatile("invd" : : : "memory"); +} + +/* Enable caches and write buffer */ +void enable_caches(void); + +/* Disable caches and write buffer */ +void disable_caches(void); + #endif /* __X86_CACHE_H__ */ diff --git a/arch/x86/include/asm/control_regs.h b/arch/x86/include/asm/control_regs.h new file mode 100644 index 0000000..aa8be30 --- /dev/null +++ b/arch/x86/include/asm/control_regs.h @@ -0,0 +1,105 @@ +/* + * Copyright (c) 2012 The Chromium OS Authors. + * + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * + * Portions of this file are derived from the Linux kernel source + * Copyright (C) 1991, 1992 Linus Torvalds + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __X86_CONTROL_REGS_H +#define __X86_CONTROL_REGS_H + +/* + * The memory clobber prevents the GCC from reordering the read/write order + * of CR0 +*/ +static inline unsigned long read_cr0(void) +{ + unsigned long val; + + asm volatile ("movl %%cr0, %0" : "=r" (val) : : "memory"); + return val; +} + +static inline void write_cr0(unsigned long val) +{ + asm volatile ("movl %0, %%cr0" : : "r" (val) : "memory"); +} + +static inline unsigned long read_cr2(void) +{ + unsigned long val; + + asm volatile("mov %%cr2,%0\n\t" : "=r" (val) : : "memory"); + return val; +} + +static inline unsigned long read_cr3(void) +{ + unsigned long val; + + asm volatile("mov %%cr3,%0\n\t" : "=r" (val) : : "memory"); + return val; +} + +static inline unsigned long read_cr4(void) +{ + unsigned long val; + + asm volatile("mov %%cr4,%0\n\t" : "=r" (val) : : "memory"); + return val; +} + +static inline unsigned long get_debugreg(int regno) +{ + unsigned long val = 0; /* Damn you, gcc! */ + + switch (regno) { + case 0: + asm("mov %%db0, %0" : "=r" (val)); + break; + case 1: + asm("mov %%db1, %0" : "=r" (val)); + break; + case 2: + asm("mov %%db2, %0" : "=r" (val)); + break; + case 3: + asm("mov %%db3, %0" : "=r" (val)); + break; + case 6: + asm("mov %%db6, %0" : "=r" (val)); + break; + case 7: + asm("mov %%db7, %0" : "=r" (val)); + break; + default: + val = 0; + } + return val; +} + +#endif
Imported from Linux 3.1 with a few modifications to suit U-Boot
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Bring in Graeme's Linux in place so we cover all bases
arch/x86/include/asm/msr-index.h | 447 ++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/msr.h | 216 ++++++++++++++++++ arch/x86/include/asm/mtrr.h | 203 +++++++++++++++++ 3 files changed, 866 insertions(+), 0 deletions(-) create mode 100644 arch/x86/include/asm/msr-index.h create mode 100644 arch/x86/include/asm/msr.h create mode 100644 arch/x86/include/asm/mtrr.h
diff --git a/arch/x86/include/asm/msr-index.h b/arch/x86/include/asm/msr-index.h new file mode 100644 index 0000000..2d4a20a --- /dev/null +++ b/arch/x86/include/asm/msr-index.h @@ -0,0 +1,447 @@ +#ifndef _ASM_X86_MSR_INDEX_H +#define _ASM_X86_MSR_INDEX_H + +/* CPU model specific register (MSR) numbers */ + +/* x86-64 specific MSRs */ +#define MSR_EFER 0xc0000080 /* extended feature register */ +#define MSR_STAR 0xc0000081 /* legacy mode SYSCALL target */ +#define MSR_LSTAR 0xc0000082 /* long mode SYSCALL target */ +#define MSR_CSTAR 0xc0000083 /* compat mode SYSCALL target */ +#define MSR_SYSCALL_MASK 0xc0000084 /* EFLAGS mask for syscall */ +#define MSR_FS_BASE 0xc0000100 /* 64bit FS base */ +#define MSR_GS_BASE 0xc0000101 /* 64bit GS base */ +#define MSR_KERNEL_GS_BASE 0xc0000102 /* SwapGS GS shadow */ +#define MSR_TSC_AUX 0xc0000103 /* Auxiliary TSC */ + +/* EFER bits: */ +#define _EFER_SCE 0 /* SYSCALL/SYSRET */ +#define _EFER_LME 8 /* Long mode enable */ +#define _EFER_LMA 10 /* Long mode active (read-only) */ +#define _EFER_NX 11 /* No execute enable */ +#define _EFER_SVME 12 /* Enable virtualization */ +#define _EFER_LMSLE 13 /* Long Mode Segment Limit Enable */ +#define _EFER_FFXSR 14 /* Enable Fast FXSAVE/FXRSTOR */ + +#define EFER_SCE (1<<_EFER_SCE) +#define EFER_LME (1<<_EFER_LME) +#define EFER_LMA (1<<_EFER_LMA) +#define EFER_NX (1<<_EFER_NX) +#define EFER_SVME (1<<_EFER_SVME) +#define EFER_LMSLE (1<<_EFER_LMSLE) +#define EFER_FFXSR (1<<_EFER_FFXSR) + +/* Intel MSRs. Some also available on other CPUs */ +#define MSR_IA32_PERFCTR0 0x000000c1 +#define MSR_IA32_PERFCTR1 0x000000c2 +#define MSR_FSB_FREQ 0x000000cd + +#define MSR_NHM_SNB_PKG_CST_CFG_CTL 0x000000e2 +#define NHM_C3_AUTO_DEMOTE (1UL << 25) +#define NHM_C1_AUTO_DEMOTE (1UL << 26) +#define ATM_LNC_C6_AUTO_DEMOTE (1UL << 25) + +#define MSR_MTRRcap 0x000000fe +#define MSR_IA32_BBL_CR_CTL 0x00000119 +#define MSR_IA32_BBL_CR_CTL3 0x0000011e + +#define MSR_IA32_SYSENTER_CS 0x00000174 +#define MSR_IA32_SYSENTER_ESP 0x00000175 +#define MSR_IA32_SYSENTER_EIP 0x00000176 + +#define MSR_IA32_MCG_CAP 0x00000179 +#define MSR_IA32_MCG_STATUS 0x0000017a +#define MSR_IA32_MCG_CTL 0x0000017b + +#define MSR_OFFCORE_RSP_0 0x000001a6 +#define MSR_OFFCORE_RSP_1 0x000001a7 + +#define MSR_IA32_PEBS_ENABLE 0x000003f1 +#define MSR_IA32_DS_AREA 0x00000600 +#define MSR_IA32_PERF_CAPABILITIES 0x00000345 + +#define MSR_MTRRfix64K_00000 0x00000250 +#define MSR_MTRRfix16K_80000 0x00000258 +#define MSR_MTRRfix16K_A0000 0x00000259 +#define MSR_MTRRfix4K_C0000 0x00000268 +#define MSR_MTRRfix4K_C8000 0x00000269 +#define MSR_MTRRfix4K_D0000 0x0000026a +#define MSR_MTRRfix4K_D8000 0x0000026b +#define MSR_MTRRfix4K_E0000 0x0000026c +#define MSR_MTRRfix4K_E8000 0x0000026d +#define MSR_MTRRfix4K_F0000 0x0000026e +#define MSR_MTRRfix4K_F8000 0x0000026f +#define MSR_MTRRdefType 0x000002ff + +#define MSR_IA32_CR_PAT 0x00000277 + +#define MSR_IA32_DEBUGCTLMSR 0x000001d9 +#define MSR_IA32_LASTBRANCHFROMIP 0x000001db +#define MSR_IA32_LASTBRANCHTOIP 0x000001dc +#define MSR_IA32_LASTINTFROMIP 0x000001dd +#define MSR_IA32_LASTINTTOIP 0x000001de + +/* DEBUGCTLMSR bits (others vary by model): */ +#define DEBUGCTLMSR_LBR (1UL << 0) +#define DEBUGCTLMSR_BTF (1UL << 1) +#define DEBUGCTLMSR_TR (1UL << 6) +#define DEBUGCTLMSR_BTS (1UL << 7) +#define DEBUGCTLMSR_BTINT (1UL << 8) +#define DEBUGCTLMSR_BTS_OFF_OS (1UL << 9) +#define DEBUGCTLMSR_BTS_OFF_USR (1UL << 10) +#define DEBUGCTLMSR_FREEZE_LBRS_ON_PMI (1UL << 11) + +#define MSR_IA32_MC0_CTL 0x00000400 +#define MSR_IA32_MC0_STATUS 0x00000401 +#define MSR_IA32_MC0_ADDR 0x00000402 +#define MSR_IA32_MC0_MISC 0x00000403 + +#define MSR_AMD64_MC0_MASK 0xc0010044 + +#define MSR_IA32_MCx_CTL(x) (MSR_IA32_MC0_CTL + 4*(x)) +#define MSR_IA32_MCx_STATUS(x) (MSR_IA32_MC0_STATUS + 4*(x)) +#define MSR_IA32_MCx_ADDR(x) (MSR_IA32_MC0_ADDR + 4*(x)) +#define MSR_IA32_MCx_MISC(x) (MSR_IA32_MC0_MISC + 4*(x)) + +#define MSR_AMD64_MCx_MASK(x) (MSR_AMD64_MC0_MASK + (x)) + +/* These are consecutive and not in the normal 4er MCE bank block */ +#define MSR_IA32_MC0_CTL2 0x00000280 +#define MSR_IA32_MCx_CTL2(x) (MSR_IA32_MC0_CTL2 + (x)) + +#define MSR_P6_PERFCTR0 0x000000c1 +#define MSR_P6_PERFCTR1 0x000000c2 +#define MSR_P6_EVNTSEL0 0x00000186 +#define MSR_P6_EVNTSEL1 0x00000187 + +/* AMD64 MSRs. Not complete. See the architecture manual for a more + complete list. */ + +#define MSR_AMD64_PATCH_LEVEL 0x0000008b +#define MSR_AMD64_NB_CFG 0xc001001f +#define MSR_AMD64_PATCH_LOADER 0xc0010020 +#define MSR_AMD64_OSVW_ID_LENGTH 0xc0010140 +#define MSR_AMD64_OSVW_STATUS 0xc0010141 +#define MSR_AMD64_DC_CFG 0xc0011022 +#define MSR_AMD64_IBSFETCHCTL 0xc0011030 +#define MSR_AMD64_IBSFETCHLINAD 0xc0011031 +#define MSR_AMD64_IBSFETCHPHYSAD 0xc0011032 +#define MSR_AMD64_IBSOPCTL 0xc0011033 +#define MSR_AMD64_IBSOPRIP 0xc0011034 +#define MSR_AMD64_IBSOPDATA 0xc0011035 +#define MSR_AMD64_IBSOPDATA2 0xc0011036 +#define MSR_AMD64_IBSOPDATA3 0xc0011037 +#define MSR_AMD64_IBSDCLINAD 0xc0011038 +#define MSR_AMD64_IBSDCPHYSAD 0xc0011039 +#define MSR_AMD64_IBSCTL 0xc001103a +#define MSR_AMD64_IBSBRTARGET 0xc001103b + +/* Fam 15h MSRs */ +#define MSR_F15H_PERF_CTL 0xc0010200 +#define MSR_F15H_PERF_CTR 0xc0010201 + +/* Fam 10h MSRs */ +#define MSR_FAM10H_MMIO_CONF_BASE 0xc0010058 +#define FAM10H_MMIO_CONF_ENABLE (1<<0) +#define FAM10H_MMIO_CONF_BUSRANGE_MASK 0xf +#define FAM10H_MMIO_CONF_BUSRANGE_SHIFT 2 +#define FAM10H_MMIO_CONF_BASE_MASK 0xfffffffULL +#define FAM10H_MMIO_CONF_BASE_SHIFT 20 +#define MSR_FAM10H_NODE_ID 0xc001100c + +/* K8 MSRs */ +#define MSR_K8_TOP_MEM1 0xc001001a +#define MSR_K8_TOP_MEM2 0xc001001d +#define MSR_K8_SYSCFG 0xc0010010 +#define MSR_K8_INT_PENDING_MSG 0xc0010055 +/* C1E active bits in int pending message */ +#define K8_INTP_C1E_ACTIVE_MASK 0x18000000 +#define MSR_K8_TSEG_ADDR 0xc0010112 +#define K8_MTRRFIXRANGE_DRAM_ENABLE 0x00040000 /* MtrrFixDramEn bit */ +#define K8_MTRRFIXRANGE_DRAM_MODIFY 0x00080000 /* MtrrFixDramModEn bit */ +#define K8_MTRR_RDMEM_WRMEM_MASK 0x18181818 /* Mask: RdMem|WrMem */ + +/* K7 MSRs */ +#define MSR_K7_EVNTSEL0 0xc0010000 +#define MSR_K7_PERFCTR0 0xc0010004 +#define MSR_K7_EVNTSEL1 0xc0010001 +#define MSR_K7_PERFCTR1 0xc0010005 +#define MSR_K7_EVNTSEL2 0xc0010002 +#define MSR_K7_PERFCTR2 0xc0010006 +#define MSR_K7_EVNTSEL3 0xc0010003 +#define MSR_K7_PERFCTR3 0xc0010007 +#define MSR_K7_CLK_CTL 0xc001001b +#define MSR_K7_HWCR 0xc0010015 +#define MSR_K7_FID_VID_CTL 0xc0010041 +#define MSR_K7_FID_VID_STATUS 0xc0010042 + +/* K6 MSRs */ +#define MSR_K6_WHCR 0xc0000082 +#define MSR_K6_UWCCR 0xc0000085 +#define MSR_K6_EPMR 0xc0000086 +#define MSR_K6_PSOR 0xc0000087 +#define MSR_K6_PFIR 0xc0000088 + +/* Centaur-Hauls/IDT defined MSRs. */ +#define MSR_IDT_FCR1 0x00000107 +#define MSR_IDT_FCR2 0x00000108 +#define MSR_IDT_FCR3 0x00000109 +#define MSR_IDT_FCR4 0x0000010a + +#define MSR_IDT_MCR0 0x00000110 +#define MSR_IDT_MCR1 0x00000111 +#define MSR_IDT_MCR2 0x00000112 +#define MSR_IDT_MCR3 0x00000113 +#define MSR_IDT_MCR4 0x00000114 +#define MSR_IDT_MCR5 0x00000115 +#define MSR_IDT_MCR6 0x00000116 +#define MSR_IDT_MCR7 0x00000117 +#define MSR_IDT_MCR_CTRL 0x00000120 + +/* VIA Cyrix defined MSRs*/ +#define MSR_VIA_FCR 0x00001107 +#define MSR_VIA_LONGHAUL 0x0000110a +#define MSR_VIA_RNG 0x0000110b +#define MSR_VIA_BCR2 0x00001147 + +/* Transmeta defined MSRs */ +#define MSR_TMTA_LONGRUN_CTRL 0x80868010 +#define MSR_TMTA_LONGRUN_FLAGS 0x80868011 +#define MSR_TMTA_LRTI_READOUT 0x80868018 +#define MSR_TMTA_LRTI_VOLT_MHZ 0x8086801a + +/* Intel defined MSRs. */ +#define MSR_IA32_P5_MC_ADDR 0x00000000 +#define MSR_IA32_P5_MC_TYPE 0x00000001 +#define MSR_IA32_TSC 0x00000010 +#define MSR_IA32_PLATFORM_ID 0x00000017 +#define MSR_IA32_EBL_CR_POWERON 0x0000002a +#define MSR_EBC_FREQUENCY_ID 0x0000002c +#define MSR_IA32_FEATURE_CONTROL 0x0000003a + +#define FEATURE_CONTROL_LOCKED (1<<0) +#define FEATURE_CONTROL_VMXON_ENABLED_INSIDE_SMX (1<<1) +#define FEATURE_CONTROL_VMXON_ENABLED_OUTSIDE_SMX (1<<2) + +#define MSR_IA32_APICBASE 0x0000001b +#define MSR_IA32_APICBASE_BSP (1<<8) +#define MSR_IA32_APICBASE_ENABLE (1<<11) +#define MSR_IA32_APICBASE_BASE (0xfffff<<12) + +#define MSR_IA32_UCODE_WRITE 0x00000079 +#define MSR_IA32_UCODE_REV 0x0000008b + +#define MSR_IA32_PERF_STATUS 0x00000198 +#define MSR_IA32_PERF_CTL 0x00000199 + +#define MSR_IA32_MPERF 0x000000e7 +#define MSR_IA32_APERF 0x000000e8 + +#define MSR_IA32_THERM_CONTROL 0x0000019a +#define MSR_IA32_THERM_INTERRUPT 0x0000019b + +#define THERM_INT_HIGH_ENABLE (1 << 0) +#define THERM_INT_LOW_ENABLE (1 << 1) +#define THERM_INT_PLN_ENABLE (1 << 24) + +#define MSR_IA32_THERM_STATUS 0x0000019c + +#define THERM_STATUS_PROCHOT (1 << 0) +#define THERM_STATUS_POWER_LIMIT (1 << 10) + +#define MSR_THERM2_CTL 0x0000019d + +#define MSR_THERM2_CTL_TM_SELECT (1ULL << 16) + +#define MSR_IA32_MISC_ENABLE 0x000001a0 + +#define MSR_IA32_TEMPERATURE_TARGET 0x000001a2 + +#define MSR_IA32_ENERGY_PERF_BIAS 0x000001b0 + +#define MSR_IA32_PACKAGE_THERM_STATUS 0x000001b1 + +#define PACKAGE_THERM_STATUS_PROCHOT (1 << 0) +#define PACKAGE_THERM_STATUS_POWER_LIMIT (1 << 10) + +#define MSR_IA32_PACKAGE_THERM_INTERRUPT 0x000001b2 + +#define PACKAGE_THERM_INT_HIGH_ENABLE (1 << 0) +#define PACKAGE_THERM_INT_LOW_ENABLE (1 << 1) +#define PACKAGE_THERM_INT_PLN_ENABLE (1 << 24) + +/* Thermal Thresholds Support */ +#define THERM_INT_THRESHOLD0_ENABLE (1 << 15) +#define THERM_SHIFT_THRESHOLD0 8 +#define THERM_MASK_THRESHOLD0 (0x7f << THERM_SHIFT_THRESHOLD0) +#define THERM_INT_THRESHOLD1_ENABLE (1 << 23) +#define THERM_SHIFT_THRESHOLD1 16 +#define THERM_MASK_THRESHOLD1 (0x7f << THERM_SHIFT_THRESHOLD1) +#define THERM_STATUS_THRESHOLD0 (1 << 6) +#define THERM_LOG_THRESHOLD0 (1 << 7) +#define THERM_STATUS_THRESHOLD1 (1 << 8) +#define THERM_LOG_THRESHOLD1 (1 << 9) + +/* MISC_ENABLE bits: architectural */ +#define MSR_IA32_MISC_ENABLE_FAST_STRING (1ULL << 0) +#define MSR_IA32_MISC_ENABLE_TCC (1ULL << 1) +#define MSR_IA32_MISC_ENABLE_EMON (1ULL << 7) +#define MSR_IA32_MISC_ENABLE_BTS_UNAVAIL (1ULL << 11) +#define MSR_IA32_MISC_ENABLE_PEBS_UNAVAIL (1ULL << 12) +#define MSR_IA32_MISC_ENABLE_ENHANCED_SPEEDSTEP (1ULL << 16) +#define MSR_IA32_MISC_ENABLE_MWAIT (1ULL << 18) +#define MSR_IA32_MISC_ENABLE_LIMIT_CPUID (1ULL << 22) +#define MSR_IA32_MISC_ENABLE_XTPR_DISABLE (1ULL << 23) +#define MSR_IA32_MISC_ENABLE_XD_DISABLE (1ULL << 34) + +/* MISC_ENABLE bits: model-specific, meaning may vary from core to core */ +#define MSR_IA32_MISC_ENABLE_X87_COMPAT (1ULL << 2) +#define MSR_IA32_MISC_ENABLE_TM1 (1ULL << 3) +#define MSR_IA32_MISC_ENABLE_SPLIT_LOCK_DISABLE (1ULL << 4) +#define MSR_IA32_MISC_ENABLE_L3CACHE_DISABLE (1ULL << 6) +#define MSR_IA32_MISC_ENABLE_SUPPRESS_LOCK (1ULL << 8) +#define MSR_IA32_MISC_ENABLE_PREFETCH_DISABLE (1ULL << 9) +#define MSR_IA32_MISC_ENABLE_FERR (1ULL << 10) +#define MSR_IA32_MISC_ENABLE_FERR_MULTIPLEX (1ULL << 10) +#define MSR_IA32_MISC_ENABLE_TM2 (1ULL << 13) +#define MSR_IA32_MISC_ENABLE_ADJ_PREF_DISABLE (1ULL << 19) +#define MSR_IA32_MISC_ENABLE_SPEEDSTEP_LOCK (1ULL << 20) +#define MSR_IA32_MISC_ENABLE_L1D_CONTEXT (1ULL << 24) +#define MSR_IA32_MISC_ENABLE_DCU_PREF_DISABLE (1ULL << 37) +#define MSR_IA32_MISC_ENABLE_TURBO_DISABLE (1ULL << 38) +#define MSR_IA32_MISC_ENABLE_IP_PREF_DISABLE (1ULL << 39) + +/* P4/Xeon+ specific */ +#define MSR_IA32_MCG_EAX 0x00000180 +#define MSR_IA32_MCG_EBX 0x00000181 +#define MSR_IA32_MCG_ECX 0x00000182 +#define MSR_IA32_MCG_EDX 0x00000183 +#define MSR_IA32_MCG_ESI 0x00000184 +#define MSR_IA32_MCG_EDI 0x00000185 +#define MSR_IA32_MCG_EBP 0x00000186 +#define MSR_IA32_MCG_ESP 0x00000187 +#define MSR_IA32_MCG_EFLAGS 0x00000188 +#define MSR_IA32_MCG_EIP 0x00000189 +#define MSR_IA32_MCG_RESERVED 0x0000018a + +/* Pentium IV performance counter MSRs */ +#define MSR_P4_BPU_PERFCTR0 0x00000300 +#define MSR_P4_BPU_PERFCTR1 0x00000301 +#define MSR_P4_BPU_PERFCTR2 0x00000302 +#define MSR_P4_BPU_PERFCTR3 0x00000303 +#define MSR_P4_MS_PERFCTR0 0x00000304 +#define MSR_P4_MS_PERFCTR1 0x00000305 +#define MSR_P4_MS_PERFCTR2 0x00000306 +#define MSR_P4_MS_PERFCTR3 0x00000307 +#define MSR_P4_FLAME_PERFCTR0 0x00000308 +#define MSR_P4_FLAME_PERFCTR1 0x00000309 +#define MSR_P4_FLAME_PERFCTR2 0x0000030a +#define MSR_P4_FLAME_PERFCTR3 0x0000030b +#define MSR_P4_IQ_PERFCTR0 0x0000030c +#define MSR_P4_IQ_PERFCTR1 0x0000030d +#define MSR_P4_IQ_PERFCTR2 0x0000030e +#define MSR_P4_IQ_PERFCTR3 0x0000030f +#define MSR_P4_IQ_PERFCTR4 0x00000310 +#define MSR_P4_IQ_PERFCTR5 0x00000311 +#define MSR_P4_BPU_CCCR0 0x00000360 +#define MSR_P4_BPU_CCCR1 0x00000361 +#define MSR_P4_BPU_CCCR2 0x00000362 +#define MSR_P4_BPU_CCCR3 0x00000363 +#define MSR_P4_MS_CCCR0 0x00000364 +#define MSR_P4_MS_CCCR1 0x00000365 +#define MSR_P4_MS_CCCR2 0x00000366 +#define MSR_P4_MS_CCCR3 0x00000367 +#define MSR_P4_FLAME_CCCR0 0x00000368 +#define MSR_P4_FLAME_CCCR1 0x00000369 +#define MSR_P4_FLAME_CCCR2 0x0000036a +#define MSR_P4_FLAME_CCCR3 0x0000036b +#define MSR_P4_IQ_CCCR0 0x0000036c +#define MSR_P4_IQ_CCCR1 0x0000036d +#define MSR_P4_IQ_CCCR2 0x0000036e +#define MSR_P4_IQ_CCCR3 0x0000036f +#define MSR_P4_IQ_CCCR4 0x00000370 +#define MSR_P4_IQ_CCCR5 0x00000371 +#define MSR_P4_ALF_ESCR0 0x000003ca +#define MSR_P4_ALF_ESCR1 0x000003cb +#define MSR_P4_BPU_ESCR0 0x000003b2 +#define MSR_P4_BPU_ESCR1 0x000003b3 +#define MSR_P4_BSU_ESCR0 0x000003a0 +#define MSR_P4_BSU_ESCR1 0x000003a1 +#define MSR_P4_CRU_ESCR0 0x000003b8 +#define MSR_P4_CRU_ESCR1 0x000003b9 +#define MSR_P4_CRU_ESCR2 0x000003cc +#define MSR_P4_CRU_ESCR3 0x000003cd +#define MSR_P4_CRU_ESCR4 0x000003e0 +#define MSR_P4_CRU_ESCR5 0x000003e1 +#define MSR_P4_DAC_ESCR0 0x000003a8 +#define MSR_P4_DAC_ESCR1 0x000003a9 +#define MSR_P4_FIRM_ESCR0 0x000003a4 +#define MSR_P4_FIRM_ESCR1 0x000003a5 +#define MSR_P4_FLAME_ESCR0 0x000003a6 +#define MSR_P4_FLAME_ESCR1 0x000003a7 +#define MSR_P4_FSB_ESCR0 0x000003a2 +#define MSR_P4_FSB_ESCR1 0x000003a3 +#define MSR_P4_IQ_ESCR0 0x000003ba +#define MSR_P4_IQ_ESCR1 0x000003bb +#define MSR_P4_IS_ESCR0 0x000003b4 +#define MSR_P4_IS_ESCR1 0x000003b5 +#define MSR_P4_ITLB_ESCR0 0x000003b6 +#define MSR_P4_ITLB_ESCR1 0x000003b7 +#define MSR_P4_IX_ESCR0 0x000003c8 +#define MSR_P4_IX_ESCR1 0x000003c9 +#define MSR_P4_MOB_ESCR0 0x000003aa +#define MSR_P4_MOB_ESCR1 0x000003ab +#define MSR_P4_MS_ESCR0 0x000003c0 +#define MSR_P4_MS_ESCR1 0x000003c1 +#define MSR_P4_PMH_ESCR0 0x000003ac +#define MSR_P4_PMH_ESCR1 0x000003ad +#define MSR_P4_RAT_ESCR0 0x000003bc +#define MSR_P4_RAT_ESCR1 0x000003bd +#define MSR_P4_SAAT_ESCR0 0x000003ae +#define MSR_P4_SAAT_ESCR1 0x000003af +#define MSR_P4_SSU_ESCR0 0x000003be +#define MSR_P4_SSU_ESCR1 0x000003bf /* guess: not in manual */ + +#define MSR_P4_TBPU_ESCR0 0x000003c2 +#define MSR_P4_TBPU_ESCR1 0x000003c3 +#define MSR_P4_TC_ESCR0 0x000003c4 +#define MSR_P4_TC_ESCR1 0x000003c5 +#define MSR_P4_U2L_ESCR0 0x000003b0 +#define MSR_P4_U2L_ESCR1 0x000003b1 + +#define MSR_P4_PEBS_MATRIX_VERT 0x000003f2 + +/* Intel Core-based CPU performance counters */ +#define MSR_CORE_PERF_FIXED_CTR0 0x00000309 +#define MSR_CORE_PERF_FIXED_CTR1 0x0000030a +#define MSR_CORE_PERF_FIXED_CTR2 0x0000030b +#define MSR_CORE_PERF_FIXED_CTR_CTRL 0x0000038d +#define MSR_CORE_PERF_GLOBAL_STATUS 0x0000038e +#define MSR_CORE_PERF_GLOBAL_CTRL 0x0000038f +#define MSR_CORE_PERF_GLOBAL_OVF_CTRL 0x00000390 + +/* Geode defined MSRs */ +#define MSR_GEODE_BUSCONT_CONF0 0x00001900 + +/* Intel VT MSRs */ +#define MSR_IA32_VMX_BASIC 0x00000480 +#define MSR_IA32_VMX_PINBASED_CTLS 0x00000481 +#define MSR_IA32_VMX_PROCBASED_CTLS 0x00000482 +#define MSR_IA32_VMX_EXIT_CTLS 0x00000483 +#define MSR_IA32_VMX_ENTRY_CTLS 0x00000484 +#define MSR_IA32_VMX_MISC 0x00000485 +#define MSR_IA32_VMX_CR0_FIXED0 0x00000486 +#define MSR_IA32_VMX_CR0_FIXED1 0x00000487 +#define MSR_IA32_VMX_CR4_FIXED0 0x00000488 +#define MSR_IA32_VMX_CR4_FIXED1 0x00000489 +#define MSR_IA32_VMX_VMCS_ENUM 0x0000048a +#define MSR_IA32_VMX_PROCBASED_CTLS2 0x0000048b +#define MSR_IA32_VMX_EPT_VPID_CAP 0x0000048c + +/* AMD-V MSRs */ + +#define MSR_VM_CR 0xc0010114 +#define MSR_VM_IGNNE 0xc0010115 +#define MSR_VM_HSAVE_PA 0xc0010117 + +#endif /* _ASM_X86_MSR_INDEX_H */ diff --git a/arch/x86/include/asm/msr.h b/arch/x86/include/asm/msr.h new file mode 100644 index 0000000..1865c64 --- /dev/null +++ b/arch/x86/include/asm/msr.h @@ -0,0 +1,216 @@ +#ifndef _ASM_X86_MSR_H +#define _ASM_X86_MSR_H + +#include <asm/msr-index.h> + +#ifndef __ASSEMBLY__ + +#include <linux/types.h> +#include <linux/ioctl.h> + +#define X86_IOC_RDMSR_REGS _IOWR('c', 0xA0, __u32[8]) +#define X86_IOC_WRMSR_REGS _IOWR('c', 0xA1, __u32[8]) + +#ifdef __KERNEL__ + +#include <asm/errno.h> + +struct msr { + union { + struct { + u32 l; + u32 h; + }; + u64 q; + }; +}; + +struct msr_info { + u32 msr_no; + struct msr reg; + struct msr *msrs; + int err; +}; + +struct msr_regs_info { + u32 *regs; + int err; +}; + +static inline unsigned long long native_read_tscp(unsigned int *aux) +{ + unsigned long low, high; + asm volatile(".byte 0x0f,0x01,0xf9" + : "=a" (low), "=d" (high), "=c" (*aux)); + return low | ((u64)high << 32); +} + +/* + * both i386 and x86_64 returns 64-bit value in edx:eax, but gcc's "A" + * constraint has different meanings. For i386, "A" means exactly + * edx:eax, while for x86_64 it doesn't mean rdx:rax or edx:eax. Instead, + * it means rax *or* rdx. + */ +#ifdef CONFIG_X86_64 +#define DECLARE_ARGS(val, low, high) unsigned low, high +#define EAX_EDX_VAL(val, low, high) ((low) | ((u64)(high) << 32)) +#define EAX_EDX_ARGS(val, low, high) "a" (low), "d" (high) +#define EAX_EDX_RET(val, low, high) "=a" (low), "=d" (high) +#else +#define DECLARE_ARGS(val, low, high) unsigned long long val +#define EAX_EDX_VAL(val, low, high) (val) +#define EAX_EDX_ARGS(val, low, high) "A" (val) +#define EAX_EDX_RET(val, low, high) "=A" (val) +#endif + +static inline unsigned long long native_read_msr(unsigned int msr) +{ + DECLARE_ARGS(val, low, high); + + asm volatile("rdmsr" : EAX_EDX_RET(val, low, high) : "c" (msr)); + return EAX_EDX_VAL(val, low, high); +} + +static inline void native_write_msr(unsigned int msr, + unsigned low, unsigned high) +{ + asm volatile("wrmsr" : : "c" (msr), "a"(low), "d" (high) : "memory"); +} + +extern unsigned long long native_read_tsc(void); + +extern int native_rdmsr_safe_regs(u32 regs[8]); +extern int native_wrmsr_safe_regs(u32 regs[8]); + +static inline unsigned long long native_read_pmc(int counter) +{ + DECLARE_ARGS(val, low, high); + + asm volatile("rdpmc" : EAX_EDX_RET(val, low, high) : "c" (counter)); + return EAX_EDX_VAL(val, low, high); +} + +#ifdef CONFIG_PARAVIRT +#include <asm/paravirt.h> +#else +#include <errno.h> +/* + * Access to machine-specific registers (available on 586 and better only) + * Note: the rd* operations modify the parameters directly (without using + * pointer indirection), this allows gcc to optimize better + */ + +#define rdmsr(msr, val1, val2) \ +do { \ + u64 __val = native_read_msr((msr)); \ + (void)((val1) = (u32)__val); \ + (void)((val2) = (u32)(__val >> 32)); \ +} while (0) + +static inline void wrmsr(unsigned msr, unsigned low, unsigned high) +{ + native_write_msr(msr, low, high); +} + +#define rdmsrl(msr, val) \ + ((val) = native_read_msr((msr))) + +#define wrmsrl(msr, val) \ + native_write_msr((msr), (u32)((u64)(val)), (u32)((u64)(val) >> 32)) + +/* rdmsr with exception handling */ +#define rdmsr_safe(msr, p1, p2) \ +({ \ + int __err; \ + u64 __val = native_read_msr_safe((msr), &__err); \ + (*p1) = (u32)__val; \ + (*p2) = (u32)(__val >> 32); \ + __err; \ +}) + +static inline int rdmsrl_amd_safe(unsigned msr, unsigned long long *p) +{ + u32 gprs[8] = { 0 }; + int err; + + gprs[1] = msr; + gprs[7] = 0x9c5a203a; + + err = native_rdmsr_safe_regs(gprs); + + *p = gprs[0] | ((u64)gprs[2] << 32); + + return err; +} + +static inline int wrmsrl_amd_safe(unsigned msr, unsigned long long val) +{ + u32 gprs[8] = { 0 }; + + gprs[0] = (u32)val; + gprs[1] = msr; + gprs[2] = val >> 32; + gprs[7] = 0x9c5a203a; + + return native_wrmsr_safe_regs(gprs); +} + +static inline int rdmsr_safe_regs(u32 regs[8]) +{ + return native_rdmsr_safe_regs(regs); +} + +static inline int wrmsr_safe_regs(u32 regs[8]) +{ + return native_wrmsr_safe_regs(regs); +} + +#define rdtscl(low) \ + ((low) = (u32)__native_read_tsc()) + +#define rdtscll(val) \ + ((val) = __native_read_tsc()) + +#define rdpmc(counter, low, high) \ +do { \ + u64 _l = native_read_pmc((counter)); \ + (low) = (u32)_l; \ + (high) = (u32)(_l >> 32); \ +} while (0) + +#define rdtscp(low, high, aux) \ +do { \ + unsigned long long _val = native_read_tscp(&(aux)); \ + (low) = (u32)_val; \ + (high) = (u32)(_val >> 32); \ +} while (0) + +#define rdtscpll(val, aux) (val) = native_read_tscp(&(aux)) + +#endif /* !CONFIG_PARAVIRT */ + + +#define checking_wrmsrl(msr, val) wrmsr_safe((msr), (u32)(val), \ + (u32)((val) >> 32)) + +#define write_tsc(val1, val2) wrmsr(MSR_IA32_TSC, (val1), (val2)) + +#define write_rdtscp_aux(val) wrmsr(MSR_TSC_AUX, (val), 0) + +struct msr *msrs_alloc(void); +void msrs_free(struct msr *msrs); + +#ifdef CONFIG_SMP +int rdmsr_on_cpu(unsigned int cpu, u32 msr_no, u32 *l, u32 *h); +int wrmsr_on_cpu(unsigned int cpu, u32 msr_no, u32 l, u32 h); +void rdmsr_on_cpus(const struct cpumask *mask, u32 msr_no, struct msr *msrs); +void wrmsr_on_cpus(const struct cpumask *mask, u32 msr_no, struct msr *msrs); +int rdmsr_safe_on_cpu(unsigned int cpu, u32 msr_no, u32 *l, u32 *h); +int wrmsr_safe_on_cpu(unsigned int cpu, u32 msr_no, u32 l, u32 h); +int rdmsr_safe_regs_on_cpu(unsigned int cpu, u32 regs[8]); +int wrmsr_safe_regs_on_cpu(unsigned int cpu, u32 regs[8]); + +#endif /* CONFIG_SMP */ +#endif /* __KERNEL__ */ +#endif /* __ASSEMBLY__ */ +#endif /* _ASM_X86_MSR_H */ diff --git a/arch/x86/include/asm/mtrr.h b/arch/x86/include/asm/mtrr.h new file mode 100644 index 0000000..b75203c --- /dev/null +++ b/arch/x86/include/asm/mtrr.h @@ -0,0 +1,203 @@ +/* Generic MTRR (Memory Type Range Register) ioctls. + + Copyright (C) 1997-1999 Richard Gooch + + This library is free software; you can redistribute it and/or + modify it under the terms of the GNU Library General Public + License as published by the Free Software Foundation; either + version 2 of the License, or (at your option) any later version. + + This library is distributed in the hope that it will be useful, + but WITHOUT ANY WARRANTY; without even the implied warranty of + MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + Library General Public License for more details. + + You should have received a copy of the GNU Library General Public + License along with this library; if not, write to the Free + Software Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + + Richard Gooch may be reached by email at rgooch@atnf.csiro.au + The postal address is: + Richard Gooch, c/o ATNF, P. O. Box 76, Epping, N.S.W., 2121, Australia. +*/ +#ifndef _ASM_X86_MTRR_H +#define _ASM_X86_MTRR_H + +#define MTRRphysBase_MSR(reg) (0x200 + 2 * (reg)) +#define MTRRphysMask_MSR(reg) (0x200 + 2 * (reg) + 1) + +#ifndef __ASSEMBLY__ + +#include <linux/types.h> +#include <linux/ioctl.h> +#include <errno.h> + +#define MTRR_IOCTL_BASE 'M' + +struct mtrr_sentry { + unsigned long base; /* Base address */ + unsigned int size; /* Size of region */ + unsigned int type; /* Type of region */ +}; + +/* + * Warning: this structure has a different order from i386 + * on x86-64. The 32bit emulation code takes care of that. + * But you need to use this for 64bit, otherwise your X server + * will break. + */ + +#ifdef __i386__ +struct mtrr_gentry { + unsigned int regnum; /* Register number */ + unsigned long base; /* Base address */ + unsigned int size; /* Size of region */ + unsigned int type; /* Type of region */ +}; + +#else /* __i386__ */ + +struct mtrr_gentry { + unsigned long base; /* Base address */ + unsigned int size; /* Size of region */ + unsigned int regnum; /* Register number */ + unsigned int type; /* Type of region */ +}; +#endif /* !__i386__ */ + +struct mtrr_var_range { + __u32 base_lo; + __u32 base_hi; + __u32 mask_lo; + __u32 mask_hi; +}; + +/* + * In the Intel processor's MTRR interface, the MTRR type is always held in + * an 8 bit field: + */ +typedef __u8 mtrr_type; + +#define MTRR_NUM_FIXED_RANGES 88 +#define MTRR_MAX_VAR_RANGES 256 + +struct mtrr_state_type { + struct mtrr_var_range var_ranges[MTRR_MAX_VAR_RANGES]; + mtrr_type fixed_ranges[MTRR_NUM_FIXED_RANGES]; + unsigned char enabled; + unsigned char have_fixed; + mtrr_type def_type; +}; + +/* These are the various ioctls */ +#define MTRRIOC_ADD_ENTRY _IOW(MTRR_IOCTL_BASE, 0, struct mtrr_sentry) +#define MTRRIOC_SET_ENTRY _IOW(MTRR_IOCTL_BASE, 1, struct mtrr_sentry) +#define MTRRIOC_DEL_ENTRY _IOW(MTRR_IOCTL_BASE, 2, struct mtrr_sentry) +#define MTRRIOC_GET_ENTRY _IOWR(MTRR_IOCTL_BASE, 3, struct mtrr_gentry) +#define MTRRIOC_KILL_ENTRY _IOW(MTRR_IOCTL_BASE, 4, struct mtrr_sentry) +#define MTRRIOC_ADD_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 5, struct mtrr_sentry) +#define MTRRIOC_SET_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 6, struct mtrr_sentry) +#define MTRRIOC_DEL_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 7, struct mtrr_sentry) +#define MTRRIOC_GET_PAGE_ENTRY _IOWR(MTRR_IOCTL_BASE, 8, struct mtrr_gentry) +#define MTRRIOC_KILL_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 9, struct mtrr_sentry) + +/* These are the region types */ +#define MTRR_TYPE_UNCACHABLE 0 +#define MTRR_TYPE_WRCOMB 1 +/*#define MTRR_TYPE_ 2*/ +/*#define MTRR_TYPE_ 3*/ +#define MTRR_TYPE_WRTHROUGH 4 +#define MTRR_TYPE_WRPROT 5 +#define MTRR_TYPE_WRBACK 6 +#define MTRR_NUM_TYPES 7 + +#ifdef __KERNEL__ + +/* The following functions are for use by other drivers */ +# ifdef CONFIG_MTRR +extern u8 mtrr_type_lookup(u64 addr, u64 end); +extern void mtrr_save_fixed_ranges(void *); +extern void mtrr_save_state(void); +extern int mtrr_add(unsigned long base, unsigned long size, + unsigned int type, bool increment); +extern int mtrr_add_page(unsigned long base, unsigned long size, + unsigned int type, bool increment); +extern int mtrr_del(int reg, unsigned long base, unsigned long size); +extern int mtrr_del_page(int reg, unsigned long base, unsigned long size); +extern void mtrr_centaur_report_mcr(int mcr, u32 lo, u32 hi); +extern void mtrr_ap_init(void); +extern void mtrr_bp_init(void); +extern void set_mtrr_aps_delayed_init(void); +extern void mtrr_aps_init(void); +extern void mtrr_bp_restore(void); +extern int mtrr_trim_uncached_memory(unsigned long end_pfn); +extern int amd_special_default_mtrr(void); +# else +static inline u8 mtrr_type_lookup(u64 addr, u64 end) +{ + /* + * Return no-MTRRs: + */ + return 0xff; +} +#define mtrr_save_fixed_ranges(arg) do {} while (0) +#define mtrr_save_state() do {} while (0) +static inline int mtrr_del(int reg, unsigned long base, unsigned long size) +{ + return -ENODEV; +} +static inline int mtrr_del_page(int reg, unsigned long base, unsigned long size) +{ + return -ENODEV; +} +static inline int mtrr_trim_uncached_memory(unsigned long end_pfn) +{ + return 0; +} +static inline void mtrr_centaur_report_mcr(int mcr, u32 lo, u32 hi) +{ +} + +#define mtrr_ap_init() do {} while (0) +#define mtrr_bp_init() do {} while (0) +#define set_mtrr_aps_delayed_init() do {} while (0) +#define mtrr_aps_init() do {} while (0) +#define mtrr_bp_restore() do {} while (0) +# endif + +#ifdef CONFIG_COMPAT +#include <linux/compat.h> + +struct mtrr_sentry32 { + compat_ulong_t base; /* Base address */ + compat_uint_t size; /* Size of region */ + compat_uint_t type; /* Type of region */ +}; + +struct mtrr_gentry32 { + compat_ulong_t regnum; /* Register number */ + compat_uint_t base; /* Base address */ + compat_uint_t size; /* Size of region */ + compat_uint_t type; /* Type of region */ +}; + +#define MTRR_IOCTL_BASE 'M' + +#define MTRRIOC32_ADD_ENTRY _IOW(MTRR_IOCTL_BASE, 0, struct mtrr_sentry32) +#define MTRRIOC32_SET_ENTRY _IOW(MTRR_IOCTL_BASE, 1, struct mtrr_sentry32) +#define MTRRIOC32_DEL_ENTRY _IOW(MTRR_IOCTL_BASE, 2, struct mtrr_sentry32) +#define MTRRIOC32_GET_ENTRY _IOWR(MTRR_IOCTL_BASE, 3, struct mtrr_gentry32) +#define MTRRIOC32_KILL_ENTRY _IOW(MTRR_IOCTL_BASE, 4, struct mtrr_sentry32) +#define MTRRIOC32_ADD_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 5, struct mtrr_sentry32) +#define MTRRIOC32_SET_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 6, struct mtrr_sentry32) +#define MTRRIOC32_DEL_PAGE_ENTRY _IOW(MTRR_IOCTL_BASE, 7, struct mtrr_sentry32) +#define MTRRIOC32_GET_PAGE_ENTRY _IOWR(MTRR_IOCTL_BASE, 8, struct mtrr_gentry32) +#define MTRRIOC32_KILL_PAGE_ENTRY \ + _IOW(MTRR_IOCTL_BASE, 9, struct mtrr_sentry32) +#endif /* CONFIG_COMPAT */ + +#endif /* __KERNEL__ */ + +#endif /* __ASSEMBLY__ */ + +#endif /* _ASM_X86_MTRR_H */
This cleans up the rom caching optimization implemented in coreboot (and needed throughout U-Boot runtime).
Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Use en/disable_caches() instead of en/disable_cache() - Use functions from Graeme's msr patch
arch/x86/cpu/coreboot/coreboot.c | 18 ++++++++++++++++++ 1 files changed, 18 insertions(+), 0 deletions(-)
diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index b942a3e..f262800 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -26,6 +26,8 @@ #include <asm/u-boot-x86.h> #include <flash.h> #include <netdev.h> +#include <asm/msr.h> +#include <asm/cache.h> #include <asm/arch-coreboot/tables.h> #include <asm/arch-coreboot/sysinfo.h> #include <asm/arch/timestamp.h> @@ -89,3 +91,19 @@ int board_eth_init(bd_t *bis) void setup_pcat_compatibility() { } + +#define MTRRphysBase_MSR(reg) (0x200 + 2 * (reg)) +#define MTRRphysMask_MSR(reg) (0x200 + 2 * (reg) + 1) + +int board_final_cleanup(void) +{ + /* Un-cache the ROM so the kernel has one + * more MTRR available. + */ + disable_caches(); + wrmsrl(MTRRphysBase_MSR(7), 0); + wrmsrl(MTRRphysMask_MSR(7), 0); + enable_caches(); + + return 0; +}
Enable this option to support booting a zImage.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Enable CONFIG_ZBOOT_32 to make CONFIG_CMD_BOOT work correctly
include/configs/coreboot.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index fcfa7ed..e45ecad 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -39,6 +39,7 @@ #define CONFIG_LAST_STAGE_INIT #define CONFIG_X86_NO_RESET_VECTOR #define CONFIG_SYS_VSNPRINTF +#define CONFIG_ZBOOT_32
/*----------------------------------------------------------------------- * Watchdog Configuration @@ -175,6 +176,8 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2
+#define CONFIG_CMD_ZBOOT + #define CONFIG_BOOTDELAY 2 #define CONFIG_BOOTARGS "root=/dev/mtdblock0 console=ttyS0,9600"
