[PATCH] mmc: dw_mmc: reset controller after data error
Per dw_mmc databook, it's recommended to reset the host controller if some data-related error occurred. Implement a reset mechanism.
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com Co-developed-by: Jason Zhu jason.zhu@rock-chips.com Signed-off-by: Jason Zhu jason.zhu@rock-chips.com [eugen.hristev@collabora.com: modified a bit the variables initialization] Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- drivers/mmc/dw_mmc.c | 20 +++++++++++++++++++- 1 file changed, 19 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 5085a3b491da..7c302ee614f4 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -138,7 +138,7 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data) { struct mmc *mmc = host->mmc; int ret = 0; - u32 timeout, mask, size, i, len = 0; + u32 timeout, reset_timeout = 100, status, ctrl, mask, size, i, len = 0; u32 *buf = NULL; ulong start = get_timer(0); u32 fifo_depth = (((host->fifoth_val & RX_WMARK_MASK) >> @@ -159,6 +159,24 @@ static int dwmci_data_transfer(struct dwmci_host *host, struct mmc_data *data) /* Error during data transfer. */ if (mask & (DWMCI_DATA_ERR | DWMCI_DATA_TOUT)) { debug("%s: DATA ERROR!\n", __func__); + + dwmci_wait_reset(host, DWMCI_RESET_ALL); + dwmci_writel(host, DWMCI_CMD, DWMCI_CMD_PRV_DAT_WAIT | + DWMCI_CMD_UPD_CLK | DWMCI_CMD_START); + + do { + status = dwmci_readl(host, DWMCI_CMD); + if (!reset_timeout) + break; + udelay(100); + } while (status & DWMCI_CMD_START); + + if (!host->fifo_mode) { + ctrl = dwmci_readl(host, DWMCI_BMOD); + ctrl |= DWMCI_BMOD_IDMAC_RESET; + dwmci_writel(host, DWMCI_BMOD, ctrl); + } + ret = -EINVAL; break; }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- u32 timeout, reset_timeout = 100, status, ctrl, mask, size, i, len = 0; u32 *buf = NULL; ulong start = get_timer(0); u32 fifo_depth = (((host->fifoth_val & RX_WMARK_MASK) >>
do {
if (!reset_timeout)
break;
udelay(100);
}ret = -EINVAL; break;
Hi Eugen,
do {
if (!reset_timeout)
It does not look like reset_timeout is modified and this has potential to get stuck in an endless loop.
Regards, Jonas
break;
udelay(100);
Eugen Hristev
Jonas Karlman
Kever Yang
