[U-Boot] [PATCH] Makefile: use $(shell ...) for determining file_size
file_size was being calculated using back-ticks but map_size uses $(shell ...). Update the file_size calculation to use $(shell ...).
Signed-off-by: Chris Packham judge.packham@gmail.com --- The back ticks didn't work in my environment (GNU Make 3.81). Updating to use $(shell ...) makes sense from a consistency view even if the problem is my environment.
Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index ca212b5..f6a0f68 100644 --- a/Makefile +++ b/Makefile @@ -786,7 +786,7 @@ u-boot.hex u-boot.srec: u-boot FORCE OBJCOPYFLAGS_u-boot.bin := -O binary
binary_size_check: u-boot.bin System.map FORCE - @file_size=`stat -c %s u-boot.bin` ; \ + file_size=$(shell stat -c %s u-boot.bin) ; \ map_size=$(shell cat System.map | \ awk '/_image_copy_start/ {start = $$1} /_image_binary_end/ {end = $$1} END {if (start != "" && end != "") print "ibase=16; " toupper(end) " - " toupper(start)}' \ | bc); \
But you might want to look at this.
http://patchwork.ozlabs.org/patch/371936/
Yeah, Jeroen, can we get a v2 of your patch that uses $(shell ... )? Thanks!
no problem. For the record I have not seen any issues with mentioned gmake version. But using $(shell .. ) seem like a sane thing to do. v2 is on its way, running MAKEALL for arm (can we keep it?).
Chris: blackfin targets seem to rely on the same construct btw...
Regards, Jeroen
MAKEALL isn't going away for v2014.10 but please reply to Simon's RFC about it. I do have to admit that switching all of my stuff to buildman is still on my TODO list.
Hi Simon,
Thanks. I've re-submitted a version with Jeroen's change included and it seems a v2 of his patch is imminent too. Either way I'm not fussed.
But this has highlighted another issue I'm experiencing related to this code. Originally I thought it was because I was doing something a bit weird with a custom u-boot.lds but actually the problem is my u-boot is setup so that it finishes exactly at the end of a 32bit address space so _image_binary_end is just off the end of it which screws up the size calculation.
$ grep _image_binary_end u-boot.map 0x0000000100000000 _image_binary_end = .
$ grep _image_binary_end System.map 00000000 A _image_binary_end
$ make binary_size_check ... System.map shows a binary size of -4294180864 but u-boot.bin shows 786432 make: *** [binary_size_check] Error 1
I think it should be possible to change binary_size_check to use u-boot.map instead of System.map but would that be OK for all architectures?
u-boot.map is generated automatically by the compiler and more importantly can handle addresses >4GB. --- On Thu, Jul 24, 2014 at 5:14 PM, Chris Packham judge.packham@gmail.com wrote:
Hi Simon,
Something like this works for me but maybe there is a way to get nm to handle addresses >4GB.
Makefile | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index b98a80a..3ed02a4 100644 --- a/Makefile +++ b/Makefile @@ -785,14 +785,15 @@ u-boot.hex u-boot.srec: u-boot FORCE
-binary_size_check: u-boot.bin System.map FORCE +binary_size_check: u-boot.bin FORCE @file_size=$(shell wc -c u-boot.bin | awk '{print $$1}') ; \ - map_size=$(shell cat System.map | \ + map_size=$(shell cat u-boot.map | \ awk '/_image_copy_start/ {start = $$1} /_image_binary_end/ {end = $$1} END {if (start != "" && end != "") print "ibase=16; " toupper(end) " - " toupper(start)}' \ + | sed 's/0X//g' \ | bc); \ if [ "" != "$$map_size" ]; then \ if test $$map_size -ne $$file_size; then \ - echo "System.map shows a binary size of $$map_size" >&2 ; \ + echo "u-boot.map shows a binary size of $$map_size" >&2 ; \ echo " but u-boot.bin shows $$file_size" >&2 ; \ exit 1; \ fi \
Dear Chris Packham,
In message 1406179627-9496-1-git-send-email-judge.packham@gmail.com you wrote:
- map_size=$(shell cat u-boot.map | \ awk '/_image_copy_start/ {start = $$1} /_image_binary_end/ {end = $$1} END {if (start != "" && end != "") print "ibase=16; " toupper(end) " - " toupper(start)}' \
| sed 's/0X//g' \
Do we _really_ need all of this?
This looks very much like creaping featurism to me...
On Thu, Jul 24, 2014 at 10:31:14AM +0200, Wolfgang Denk wrote:
Dear Chris Packham,
| sed 's/0X//g' \
So it's a safetey check. The various linker script clean-ups we've been doing have introduced a problem from time to time and binary_check_size gives a sanity check. This just fixes a corner case in the test.
Hi Wolfgang, Tom,
Dear Chris Packham,
| sed 's/0X//g' \
Do we need it? Maybe not I'd defer that judgement to you.
My problem is binary_size_check is on by default and my particular platform (an out of tree ARM board) fails to build because of it. If there was a way of opting out I'd happily use it.
I wouldn't say this is a corner case. Certainly for the ARM target I'm building it is unusual but I know plenty of powerpc boards would hit the same problem becuase they have a jump instruction at the top of their address space.
-- Tom
Hi Chris,
On 24 July 2014 06:14, Chris Packham judge.packham@gmail.com wrote:
Hi Simon,
That's unfortunate - it's just a little check. It does protect again a breakage but we need to keep it simple. Maybe in this case we can mask with 0xffffffff and get the right answer?
participants (5)
Chris Packham
Jeroen Hofstee
