[U-Boot] [PATCH V2 1/3] imx: mx7dsabresd: move mmc_get_env_devno to soc code
Move mmc_get_env_devno to soc.c and rename to mmc_get_env_dev to match the one in common/env_mmc.c. Introduce a weak function board_mmc_get_env_dev. Different boards can implement this according to sdhc controller which is used by the board.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de ---
V2: Use CONFIG_ENV_IS_IN_MMC to wrap soc code. Since mmc_get_env_dev already upstreamed by this commit: " commit e92029c0f4e88ae3e738d83b25ef2d3c178ea082 Author: Clemens Gruber clemens.gruber@pqgruber.com Date: Wed Jan 20 15:43:37 2016 +0100
env_mmc: support overriding mmc dev from board code " I discard the V1 2/4 patch in my patch set.
This patch set depends on https://patchwork.ozlabs.org/patch/573336/
arch/arm/cpu/armv7/mx7/soc.c | 21 +++++++++++++++++++++ board/freescale/mx7dsabresd/mx7dsabresd.c | 20 +++++--------------- 2 files changed, 26 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c index ede7d53..ba6cfb9 100644 --- a/arch/arm/cpu/armv7/mx7/soc.c +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -388,6 +388,27 @@ enum boot_device get_boot_device(void) return boot_dev; }
+#ifdef CONFIG_ENV_IS_IN_MMC +__weak int board_mmc_get_env_dev(int devno) +{ + return CONFIG_SYS_MMC_ENV_DEV; +} + +int mmc_get_env_dev(void) +{ + struct bootrom_sw_info **p = + (struct bootrom_sw_info **)ROM_SW_INFO_ADDR; + int devno = (*p)->boot_dev_instance; + u8 boot_type = (*p)->boot_dev_type; + + /* If not boot from sd/mmc, use default value */ + if ((boot_type != BOOT_TYPE_SD) && (boot_type != BOOT_TYPE_MMC)) + return CONFIG_SYS_MMC_ENV_DEV; + + return board_mmc_get_env_dev(devno); +} +#endif + void s_init(void) { #if !defined CONFIG_SPL_BUILD diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index bbcc5bb..20e56f2 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -328,22 +328,12 @@ static struct fsl_esdhc_cfg usdhc_cfg[3] = { {USDHC3_BASE_ADDR}, };
-static int mmc_get_env_devno(void) +int board_mmc_get_env_dev(int devno) { - struct bootrom_sw_info **p = - (struct bootrom_sw_info **)ROM_SW_INFO_ADDR; + if (devno == 2) + devno--;
- u8 boot_type = (*p)->boot_dev_type; - u8 dev_no = (*p)->boot_dev_instance; - - /* If not boot from sd/mmc, use default value */ - if ((boot_type != BOOT_TYPE_SD) && (boot_type != BOOT_TYPE_MMC)) - return CONFIG_SYS_MMC_ENV_DEV; - - if (dev_no == 2) - dev_no--; - - return dev_no; + return devno; }
static int mmc_map_to_kernel_blk(int dev_no) @@ -432,7 +422,7 @@ static void mmc_late_init(void) { char cmd[32]; char mmcblk[32]; - u32 dev_no = mmc_get_env_devno(); + u32 dev_no = mmc_get_env_dev();
if (!check_mmc_autodetect()) return;
Implement mmc_get_env_dev, devno can be got from smbr1 of SRC. Introduce a weak function board_mmc_get_env_dev, different boards can implement it according to different sdhc controllers that used by the board.
V2: Use CONFIG_ENV_IS_IN_MMC to wrap code
arch/arm/cpu/armv7/mx6/soc.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index ab0ccb0..80a4828 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -349,6 +349,38 @@ int arch_cpu_init(void) return 0; }
+#ifdef CONFIG_ENV_IS_IN_MMC +__weak int board_mmc_get_env_dev(int devno) +{ + return CONFIG_SYS_MMC_ENV_DEV; +} + +int mmc_get_env_dev(void) +{ + struct src *src_regs = (struct src *)SRC_BASE_ADDR; + u32 soc_sbmr = readl(&src_regs->sbmr1); + u32 bootsel; + int devno; + + /* + * Refer to + * "i.MX 6Dual/6Quad Applications Processor Reference Manual" + * Chapter "8.5.3.1 Expansion Device eFUSE Configuration" + * i.MX6SL/SX/UL has same layout. + */ + bootsel = (soc_sbmr & 0x000000FF) >> 6; + + /* If not boot from sd/mmc, use default value */ + if (bootsel != 1) + return CONFIG_SYS_MMC_ENV_DEV; + + /* BOOT_CFG2[3] and BOOT_CFG2[4] */ + devno = (soc_sbmr & 0x00001800) >> 11; + + return board_mmc_get_env_dev(devno); +} +#endif + int board_postclk_init(void) { set_ldo_voltage(LDO_SOC, 1175); /* Set VDDSOC to 1.175V */
Implement board_mmc_get_env_dev for the boards.
Following is examples: SD1/SD2/SD3: return devno; SD2/SD3: return devno - 1; SD2/SD4: if (devno == 2), return dev - 2; return dev - 1;
V2: no change
board/freescale/mx6qarm2/mx6qarm2.c | 5 +++++ board/freescale/mx6sabresd/mx6sabresd.c | 5 +++++ board/freescale/mx6slevk/mx6slevk.c | 5 +++++ board/freescale/mx6sxsabresd/mx6sxsabresd.c | 5 +++++ 4 files changed, 20 insertions(+)
diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index 98ccdb7..5aae721 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -110,6 +110,11 @@ struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC4_BASE_ADDR}, };
+int board_mmc_get_env_dev(int devno) +{ + return devno - 2; +} + int board_mmc_getcd(struct mmc *mmc) { struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index d20953d..4af0e3e 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -235,6 +235,11 @@ struct fsl_esdhc_cfg usdhc_cfg[3] = { #define USDHC2_CD_GPIO IMX_GPIO_NR(2, 2) #define USDHC3_CD_GPIO IMX_GPIO_NR(2, 0)
+int board_mmc_get_env_dev(int devno) +{ + return devno - 1; +} + int board_mmc_getcd(struct mmc *mmc) { struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 5eab4b5..295b781 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -170,6 +170,11 @@ static struct fsl_esdhc_cfg usdhc_cfg[3] = { {USDHC3_BASE_ADDR, 0, 4}, };
+int board_mmc_get_env_dev(int devno) +{ + return devno; +} + int board_mmc_getcd(struct mmc *mmc) { struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 56dc020..0c664b5 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -313,6 +313,11 @@ static struct fsl_esdhc_cfg usdhc_cfg[3] = { #define USDHC3_PWR_GPIO IMX_GPIO_NR(2, 11) #define USDHC4_CD_GPIO IMX_GPIO_NR(6, 21)
Peng Fan
