[PATCH V3 0/3] doc: falcon: riscv: Falcon Mode boot on RISC-V
Changes in v3: - Change by suggestions in falcon.rst - Move the board-related code to arch-specific code, its the issue when enabling LOAD_FIT_OPENSBI_OS_BOOT - Add SPL_PAYLOAD_ARGS_ADDR to defconfig. This is the address that SPL copies into defconfig.
Randolph (3): doc: falcon: riscv: Falcon Mode boot on RISC-V spl: riscv: falcon: move fdt blob to specified address configs: andes: add the fdt blob address for SPL copy to
board/AndesTech/ae350/ae350.c | 25 ---- common/spl/Kconfig | 2 +- common/spl/spl_opensbi.c | 16 +++ configs/ae350_rv32_falcon_defconfig | 1 + configs/ae350_rv32_falcon_xip_defconfig | 1 + configs/ae350_rv64_falcon_defconfig | 1 + configs/ae350_rv64_falcon_xip_defconfig | 1 + doc/develop/falcon.rst | 171 ++++++++++++++++++++++++ 8 files changed, 192 insertions(+), 26 deletions(-)
Add documentation to introduce the Falcon Mode on RISC-V. In this mode, the boot sequence is SPL -> OpenSBI -> Linux kernel.
Signed-off-by: Randolph randolph@andestech.com --- doc/develop/falcon.rst | 171 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 171 insertions(+)
diff --git a/doc/develop/falcon.rst b/doc/develop/falcon.rst index 2f25fc8532..65644d1c57 100644 --- a/doc/develop/falcon.rst +++ b/doc/develop/falcon.rst @@ -256,3 +256,174 @@ the following command: Falcon Mode was presented at the RMLL 2012. Slides are available at:
http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf + +Falcon Mode Boot on RISC-V +-------------------------- + +Introduction +~~~~~~~~~~~~ + +In the RISC-V environment, OpenSBI is required to enable a supervisor mode +binary to execute certain privileged operations. The typical boot sequence on +RISC-V is SPL -> OpenSBI -> U-Boot -> Linux kernel. SPL will load and start +the OpenSBI initializations, then OpenSBI will bring up the next image, U-Boot +proper. The OpenSBI binary must be prepared in advance of the U-Boot build +process and it will be packed together with U-Boot into a file called +u-boot.itb. + +The Falcon Mode on RISC-V platforms is a distinct boot sequence. Borrowing +ideas from the U-Boot Falcon Mode on ARM, it skips the U-Boot proper phase +in the normal boot process and allows OpenSBI to load and start the Linux +kernel. Its boot sequence is SPL -> OpenSBI -> Linux kernel. The OpenSBI +binary and Linux kernel binary must be prepared prior to the U-Boot build +process and they will be packed together as a FIT image named linux.itb in +this process. + +CONFIG_SPL_LOAD_FIT_OPENSBI_OS_BOOT enables the Falcon Mode boot on RISC-V. +This configuration setting tells OpenSBI that Linux kernel is its next OS +image and makes it load and start the kernel afterwards. + +Note that the Falcon Mode boot bypasses a lot of initializations by U-Boot. +If the Linux kernel expects hardware initializations by U-Boot, make sure to +port the relevant code to the SPL build process. + +Configuration +~~~~~~~~~~~~~ + +CONFIG_SPL_LOAD_FIT_ADDRESS + Specifies the address to load u-boot.itb in a normal boot. When the Falcon + Mode boot is enabled, it specifies the load address of linux.itb. + +CONFIG_SYS_TEXT_BASE + Specifies the address of the text section for a u-boot proper in a normal + boot. When the Falcon Mode boot is enabled, it specifies the text section + address for the Linux kernel image. + +CONFIG_SPL_PAYLOAD_ARGS_ADDR + The address in the RAM to which the FDT blob is to be moved by the SPL. + SPL places the FDT blob right after the kernel. As the kernel does not + include the BSS section in its size calculation, SPL ends up placing + the FDT blob within the BSS section of the kernel. This may cause the + FDT blob to be cleared during kernel BSS initialization. To avoid the + issue, be sure to move the FDT blob out of the kernel first. + +CONFIG_SPL_LOAD_FIT_OPENSBI_OS_BOOT + Activates the Falcon Mode boot on RISC-V. + +Function that a board must implement +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +Initially, SPL places the FDT blob right after the kernel. As the kernel does +not include the BSS section in its size calculation, SPL ends up placing the +FDT blob within the BSS section of the kernel. This may cause the FDT blob to +be cleared during kernel BSS initialization. To avoid the issue, be sure to +move the FDT blob out of the kernel first. + +void spl_perform_fixups(struct spl_image_info *spl_image) + required, necessary action to move the FDT blob out of the Linux kernel BSS + section + +Example for Andes AE350 Board +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +A FDT blob is required to boot the Linux kernel from the SPL. Andes AE350 +platforms generally come with a builtin dtb. If you want to load a custom DTB, +follow the steps below: + +1. Load the custom DTB to SDRAM:: + + => fatload mmc 0:1 0x20000000 user_custom.dtb + +2. Set the SPI speed:: + + => sf probe 0:0 50000000 0 + +3. Erase sectors from the SPI Flash:: + + => sf erase 0xf0000 0x10000 + +4. Write the FDT blob to the erased sectors of the Flash:: + + => sf write 0x20000000 0xf0000 0x10000 + +Console Log of AE350 Falcon Mode Boot +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +:: + + U-Boot SPL 2023.01-00031-g777ecdea66 (Oct 31 2023 - 18:41:36 +0800) + Trying to boot from RAM + + OpenSBI v1.2-51-g7304e42 + ____ _____ ____ _____ + / __ \ / ____| _ _ _| + | | | |_ __ ___ _ __ | (___ | |_) || | + | | | | '_ \ / _ \ '_ \ ___ | _ < | | + | |__| | |_) | __/ | | |____) | |_) || |_ + ____/| .__/ ___|_| |_|_____/|____/_____| + | | + |_| + + Platform Name : andestech,ax25 + Platform Features : medeleg + Platform HART Count : 1 + Platform IPI Device : andes_plicsw + Platform Timer Device : andes_plmt @ 60000000Hz + Platform Console Device : uart8250 + Platform HSM Device : andes_smu + Platform PMU Device : andes_pmu + Platform Reboot Device : atcwdt200 + Platform Shutdown Device : --- + Firmware Base : 0x0 + Firmware Size : 196 KB + Runtime SBI Version : 1.0 + + Domain0 Name : root + Domain0 Boot HART : 0 + Domain0 HARTs : 0* + Domain0 Region00 : 0x0000000000000000-0x000000000003ffff () + Domain0 Region01 : 0x00000000e6000000-0x00000000e60fffff (I,R) + Domain0 Region02 : 0x00000000e6400000-0x00000000e67fffff (I) + Domain0 Region03 : 0x0000000000000000-0xffffffffffffffff (R,W,X) + Domain0 Next Address : 0x0000000001800000 + Domain0 Next Arg1 : 0x0000000001700000 + Domain0 Next Mode : S-mode + Domain0 SysReset : yes + + Boot HART ID : 0 + Boot HART Domain : root + Boot HART Priv Version : v1.11 + Boot HART Base ISA : rv64imafdcx + Boot HART ISA Extensions : none + Boot HART PMP Count : 8 + Boot HART PMP Granularity : 4 + Boot HART PMP Address Bits: 31 + Boot HART MHPM Count : 4 + Boot HART MHPM Bits : 64 + Boot HART MIDELEG : 0x0000000000000222 + Boot HART MEDELEG : 0x000000000000b109 + [ 0.000000] Linux version 6.1.47-09019-g0584b09ad862-dirty + [ 0.000000] OF: fdt: Ignoring memory range 0x0 - 0x1800000 + [ 0.000000] Machine model: andestech,ax25 + [ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '') + [ 0.000000] printk: bootconsole [sbi0] enabled + [ 0.000000] Disabled 4-level and 5-level paging + [ 0.000000] efi: UEFI not found. + [ 0.000000] Zone ranges: + [ 0.000000] DMA32 [mem 0x0000000001800000-0x000000003fffffff] + [ 0.000000] Normal empty + [ 0.000000] Movable zone start for each node + [ 0.000000] Early memory node ranges + [ 0.000000] node 0: [mem 0x0000000001800000-0x000000003fffffff] + [ 0.000000] Initmem setup node 0 [mem 0x0000000001800000-0x000000003fffffff] + [ 0.000000] SBI specification v1.0 detected + [ 0.000000] SBI implementation ID=0x1 Version=0x10002 + [ 0.000000] SBI TIME extension detected + [ 0.000000] SBI IPI extension detected + [ 0.000000] SBI RFENCE extension detected + [ 0.000000] SBI SRST extension detected + [ 0.000000] SBI HSM extension detected + [ 0.000000] riscv: base ISA extensions acim + [ 0.000000] riscv: ELF capabilities acim + [ 0.000000] percpu: Embedded 18 pages/cpu s35000 r8192 d30536 u73728 + [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 252500
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
In Falcon Boot mode, the fdt blob should be move to the RAM from kernel BSS section. To avoid being cleared by BSS initialisation. SPL_PAYLOAD_ARGS_ADDR is the address where SPL copies.
Signed-off-by: Randolph randolph@andestech.com --- board/AndesTech/ae350/ae350.c | 25 ------------------------- common/spl/Kconfig | 2 +- common/spl/spl_opensbi.c | 16 ++++++++++++++++ 3 files changed, 17 insertions(+), 26 deletions(-)
diff --git a/board/AndesTech/ae350/ae350.c b/board/AndesTech/ae350/ae350.c index 772c6bf1ee..36375d9def 100644 --- a/board/AndesTech/ae350/ae350.c +++ b/board/AndesTech/ae350/ae350.c @@ -19,8 +19,6 @@ #include <fdtdec.h> #include <dm.h> #include <spl.h> -#include <mapmem.h> -#include <hang.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -28,29 +26,6 @@ DECLARE_GLOBAL_DATA_PTR; * Miscellaneous platform dependent initializations */
-#if CONFIG_IS_ENABLED(LOAD_FIT) || CONFIG_IS_ENABLED(LOAD_FIT_FULL) -#define ANDES_SPL_FDT_ADDR (CONFIG_TEXT_BASE - 0x100000) -void spl_perform_fixups(struct spl_image_info *spl_image) -{ - /* - * Originally, u-boot-spl will place DTB directly after the kernel, - * but the size of the kernel did not include the BSS section, which - * means u-boot-spl will place the DTB in the kernel BSS section - * causing the DTB to be cleared by kernel BSS initializtion. - * Moving DTB in front of the kernel can avoid the error. - */ - if (ANDES_SPL_FDT_ADDR < 0) { - printf("%s: CONFIG_TEXT_BASE needs to be larger than 0x100000\n", - __func__); - hang(); - } - - memcpy((void *)ANDES_SPL_FDT_ADDR, spl_image->fdt_addr, - fdt_totalsize(spl_image->fdt_addr)); - spl_image->fdt_addr = map_sysmem(ANDES_SPL_FDT_ADDR, 0); -} -#endif - int board_init(void) { gd->bd->bi_boot_params = PHYS_SDRAM_0 + 0x400; diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 25cd18afda..db279a588a 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1081,7 +1081,7 @@ config SPL_OS_BOOT
config SPL_PAYLOAD_ARGS_ADDR hex "Address in memory to load 'args' file for Falcon Mode to" - depends on SPL_OS_BOOT + depends on SPL_OS_BOOT || SPL_LOAD_FIT_OPENSBI_OS_BOOT default 0x88000000 if ARCH_OMAP2PLUS help Address in memory where the 'args' file, typically a device tree diff --git a/common/spl/spl_opensbi.c b/common/spl/spl_opensbi.c index 9801d38c0b..0a8ee9a7fc 100644 --- a/common/spl/spl_opensbi.c +++ b/common/spl/spl_opensbi.c @@ -16,6 +16,7 @@ #include <opensbi.h> #include <linux/libfdt.h> #include <linux/printk.h> +#include <mapmem.h>
@@ -57,6 +58,21 @@ void __noreturn spl_invoke_opensbi(struct spl_image_info *spl_image) hang(); }
+ /* + * Originally, u-boot-spl will place DTB directly after the kernel, + * but the size of the kernel did not include the BSS section, which + * means u-boot-spl will place the DTB in the kernel BSS section + * causing the DTB to be cleared by kernel BSS initializtion. + * Moving DTB in front of the kernel can avoid the error. + */ + if (CONFIG_IS_ENABLED(LOAD_FIT_OPENSBI_OS_BOOT)) { + memcpy((void *)CONFIG_SPL_PAYLOAD_ARGS_ADDR, + spl_image->fdt_addr, + fdt_totalsize(spl_image->fdt_addr)); + spl_image->fdt_addr = + map_sysmem(CONFIG_SPL_PAYLOAD_ARGS_ADDR, 0); + } + /* * Find next os image in /fit-images * The next os image default is u-boot proper, once enable
Add the address where the FDT blob should be moved.
Signed-off-by: Randolph randolph@andestech.com --- configs/ae350_rv32_falcon_defconfig | 1 + configs/ae350_rv32_falcon_xip_defconfig | 1 + configs/ae350_rv64_falcon_defconfig | 1 + configs/ae350_rv64_falcon_xip_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/ae350_rv32_falcon_defconfig b/configs/ae350_rv32_falcon_defconfig index 3f2993e371..c0837322bb 100644 --- a/configs/ae350_rv32_falcon_defconfig +++ b/configs/ae350_rv32_falcon_defconfig @@ -14,6 +14,7 @@ CONFIG_TARGET_ANDES_AE350=y CONFIG_RISCV_SMODE=y # CONFIG_AVAILABLE_HARTS is not set CONFIG_SPL_LOAD_FIT_OPENSBI_OS_BOOT=y +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x01700000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 diff --git a/configs/ae350_rv32_falcon_xip_defconfig b/configs/ae350_rv32_falcon_xip_defconfig index e4f4c7807c..d401e4963b 100644 --- a/configs/ae350_rv32_falcon_xip_defconfig +++ b/configs/ae350_rv32_falcon_xip_defconfig @@ -15,6 +15,7 @@ CONFIG_TARGET_ANDES_AE350=y CONFIG_RISCV_SMODE=y CONFIG_SPL_XIP=y CONFIG_SPL_LOAD_FIT_OPENSBI_OS_BOOT=y +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x01700000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 diff --git a/configs/ae350_rv64_falcon_defconfig b/configs/ae350_rv64_falcon_defconfig index 4fb83d8240..b4ae5f9848 100644 --- a/configs/ae350_rv64_falcon_defconfig +++ b/configs/ae350_rv64_falcon_defconfig @@ -14,6 +14,7 @@ CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y # CONFIG_AVAILABLE_HARTS is not set CONFIG_SPL_LOAD_FIT_OPENSBI_OS_BOOT=y +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x01700000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 diff --git a/configs/ae350_rv64_falcon_xip_defconfig b/configs/ae350_rv64_falcon_xip_defconfig index 45464260ee..c7c8324d30 100644 --- a/configs/ae350_rv64_falcon_xip_defconfig +++ b/configs/ae350_rv64_falcon_xip_defconfig @@ -15,6 +15,7 @@ CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y CONFIG_SPL_XIP=y CONFIG_SPL_LOAD_FIT_OPENSBI_OS_BOOT=y +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x01700000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000
Leo Liang
Randolph
