[PATCH 1/5] ARM: uniphier: rename include guard of include/configs/uniphier.h
Make the include guard match to the file name.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
include/configs/uniphier.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index d0841a7d55f9..1b942cf657db 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -7,8 +7,8 @@
/* U-Boot - Common settings for UniPhier Family */
-#ifndef __CONFIG_UNIPHIER_COMMON_H__ -#define __CONFIG_UNIPHIER_COMMON_H__ +#ifndef __CONFIG_UNIPHIER_H__ +#define __CONFIG_UNIPHIER_H__
#ifndef CONFIG_SPL_BUILD #include <config_distro_bootcmd.h> @@ -213,4 +213,4 @@
#define CONFIG_SPL_PAD_TO 0x20000
-#endif /* __CONFIG_UNIPHIER_COMMON_H__ */ +#endif /* __CONFIG_UNIPHIER_H__ */
This function is unused since commit 862274913f8f ("bus: uniphier-system-bus: move hardware init from board files").
arch/arm/mach-uniphier/Makefile | 1 - arch/arm/mach-uniphier/init.h | 1 - arch/arm/mach-uniphier/pinctrl-glue.c | 30 --------------------------- 3 files changed, 32 deletions(-) delete mode 100644 arch/arm/mach-uniphier/pinctrl-glue.c
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index 38b6d904f466..d333b7091d4b 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -20,7 +20,6 @@ obj-y += reset.o endif
obj-$(CONFIG_MICRO_SUPPORT_CARD) += micro-support-card.o -obj-y += pinctrl-glue.o obj-$(CONFIG_MMC) += mmc-first-dev.o obj-y += fdt-fixup.o
diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index dd978c020804..535c06343d81 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -73,7 +73,6 @@ void uniphier_pxs3_clk_init(void); unsigned int uniphier_boot_device_raw(void); int uniphier_have_internal_stm(void); int uniphier_boot_from_backend(void); -int uniphier_pin_init(const char *pinconfig_name);
#ifdef CONFIG_ARM64 void uniphier_mem_map_init(unsigned long dram_base, unsigned long dram_size); diff --git a/arch/arm/mach-uniphier/pinctrl-glue.c b/arch/arm/mach-uniphier/pinctrl-glue.c deleted file mode 100644 index 2e0726469595..000000000000 --- a/arch/arm/mach-uniphier/pinctrl-glue.c +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2016 Socionext Inc. - * Author: Masahiro Yamada yamada.masahiro@socionext.com - */ - -#include <linux/errno.h> -#include <dm.h> -#include <dm/pinctrl.h> - -#include "init.h" - -int uniphier_pin_init(const char *pinconfig_name) -{ - struct udevice *pctldev, *config; - int ret; - - ret = uclass_first_device(UCLASS_PINCTRL, &pctldev); - if (ret) - return ret; - - device_foreach_child(config, pctldev) { - if (strcmp(config->name, pinconfig_name)) - continue; - - return pinctrl_generic_set_state(pctldev, config); - } - - return -ENODEV; -}
<nand.h> is unneeded since commit 9248a78f40d6 ("ARM: UniPhier: remove Denali NAND controller fixup code").
<linux/io.h> is uneeded since commit 1320fa2e55d2 ("ARM: uniphier: remove workaround for the NAND write protect").
arch/arm/mach-uniphier/board_late_init.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index b800e8b8c6be..8c5e5bb58f65 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -9,9 +9,7 @@ #include <init.h> #include <spl.h> #include <linux/libfdt.h> -#include <nand.h> #include <stdio.h> -#include <linux/io.h> #include <linux/printk.h>
#include "init.h" @@ -53,6 +51,7 @@ fail:
static void uniphier_set_env_addr(const char *env, const char *offset_env) { + DECLARE_GLOBAL_DATA_PTR; unsigned long offset = 0; const char *str; char *end;
drivers/serial/serial_uniphier.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/serial_uniphier.c b/drivers/serial/serial_uniphier.c index 4004cb8d48a4..a098028ca001 100644 --- a/drivers/serial/serial_uniphier.c +++ b/drivers/serial/serial_uniphier.c @@ -137,7 +137,7 @@ static int uniphier_serial_probe(struct udevice *dev)
priv->uartclk = clk_data->clk_rate;
- /* flush the trasmitter empty before changing hw setting */ + /* flush the trasmitter before changing hw setting */ while (!(readl(priv->membase + UNIPHIER_UART_LSR) & UART_LSR_TEMT)) ;
Define register fields as macros, and use FIELD_GET().
arch/arm/mach-uniphier/sg-regs.h | 5 +++++ arch/arm/mach-uniphier/soc-info.c | 21 ++++++++++----------- 2 files changed, 15 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-uniphier/sg-regs.h b/arch/arm/mach-uniphier/sg-regs.h index f47d10194987..a0fa51a8b7be 100644 --- a/arch/arm/mach-uniphier/sg-regs.h +++ b/arch/arm/mach-uniphier/sg-regs.h @@ -10,6 +10,8 @@ #ifndef UNIPHIER_SG_REGS_H #define UNIPHIER_SG_REGS_H
+#include <linux/bitops.h> + #ifndef __ASSEMBLY__ #include <linux/compiler.h> #ifdef CONFIG_ARCH_UNIPHIER_V8_MULTI @@ -24,6 +26,9 @@ extern void __iomem *sg_base;
/* Revision */ #define SG_REVISION 0x0000 +#define SG_REVISION_TYPE_MASK GENMASK(23, 16) +#define SG_REVISION_MODEL_MASK GENMASK(10, 8) +#define SG_REVISION_REV_MASK GENMASK(4, 0)
/* Memory Configuration */ #define SG_MEMCONF 0x0400 diff --git a/arch/arm/mach-uniphier/soc-info.c b/arch/arm/mach-uniphier/soc-info.c index f021a8cab330..b0221016d1ef 100644 --- a/arch/arm/mach-uniphier/soc-info.c +++ b/arch/arm/mach-uniphier/soc-info.c @@ -4,31 +4,30 @@ * Author: Masahiro Yamada yamada.masahiro@socionext.com */
+#include <linux/bitfield.h> #include <linux/io.h> #include <linux/types.h>
#include "sg-regs.h" #include "soc-info.h"
-static unsigned int __uniphier_get_revision_field(unsigned int mask, - unsigned int shift) -{ - u32 revision = readl(sg_base + SG_REVISION); - - return (revision >> shift) & mask; -} - unsigned int uniphier_get_soc_id(void) { - return __uniphier_get_revision_field(0xff, 16); + u32 rev = readl(sg_base + SG_REVISION); + + return FIELD_GET(SG_REVISION_TYPE_MASK, rev); }
unsigned int uniphier_get_soc_model(void) { - return __uniphier_get_revision_field(0x7, 8); + u32 rev = readl(sg_base + SG_REVISION); + + return FIELD_GET(SG_REVISION_MODEL_MASK, rev); }
unsigned int uniphier_get_soc_revision(void) { - return __uniphier_get_revision_field(0x1f, 0); + u32 rev = readl(sg_base + SG_REVISION); + + return FIELD_GET(SG_REVISION_REV_MASK, rev); }
Masahiro Yamada
