[U-Boot] [PATCH] scripts/Makefile* Add SPDX-License-Identifier tag
A general best practice for SPDX is that Makefiles should have an identifier, add these as everything else is currently covered.
Signed-off-by: Tom Rini trini@konsulko.com --- scripts/Makefile.autoconf | 3 +++ scripts/Makefile.build | 3 +++ scripts/Makefile.clean | 3 +++ scripts/Makefile.extrawarn | 3 +++ scripts/Makefile.host | 3 +++ scripts/Makefile.lib | 3 +++ scripts/Makefile.uncmd_spl | 2 ++ 7 files changed, 20 insertions(+)
diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index d668982..01a739d 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -6,6 +6,9 @@ # When our migration to Kconfig is done # (= When we move all CONFIGs from header files to Kconfig) # this makefile can be deleted. +# +# SPDX-License-Identifier: GPL-2.0 +#
__all: include/autoconf.mk include/autoconf.mk.dep
diff --git a/scripts/Makefile.build b/scripts/Makefile.build index de818ae..06e5c20 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -1,6 +1,9 @@ # ========================================================================== # Building # ========================================================================== +# +# SPDX-License-Identifier: GPL-2.0 +#
# Modified for U-Boot prefix := tpl diff --git a/scripts/Makefile.clean b/scripts/Makefile.clean index 4853631..b69533d 100644 --- a/scripts/Makefile.clean +++ b/scripts/Makefile.clean @@ -1,6 +1,9 @@ # ========================================================================== # Cleaning up # ========================================================================== +# +# SPDX-License-Identifier: GPL-2.0 +#
src := $(obj)
diff --git a/scripts/Makefile.extrawarn b/scripts/Makefile.extrawarn index 0ec0d24..6547e57 100644 --- a/scripts/Makefile.extrawarn +++ b/scripts/Makefile.extrawarn @@ -9,6 +9,9 @@ # $(call cc-option, -W...) handles gcc -W.. options which # are not supported by all versions of the compiler # ========================================================================== +# +# SPDX-License-Identifier: GPL-2.0 +#
ifeq ("$(origin W)", "command line") export KBUILD_ENABLE_EXTRA_GCC_CHECKS := $(W) diff --git a/scripts/Makefile.host b/scripts/Makefile.host index 133edfa..bff8b5b 100644 --- a/scripts/Makefile.host +++ b/scripts/Makefile.host @@ -19,6 +19,9 @@ # qconf-objs := menu.o # Will compile qconf as a C++ program, and menu as a C program. # They are linked as C++ code to the executable qconf +# +# SPDX-License-Identifier: GPL-2.0 +#
__hostprogs := $(sort $(hostprogs-y) $(hostprogs-m))
diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index ed30bf5..1644f8c 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -1,3 +1,6 @@ +# +# SPDX-License-Identifier: GPL-2.0 +# # Backward compatibility asflags-y += $(EXTRA_AFLAGS) ccflags-y += $(EXTRA_CFLAGS) diff --git a/scripts/Makefile.uncmd_spl b/scripts/Makefile.uncmd_spl index 4003546..15d0836 100644 --- a/scripts/Makefile.uncmd_spl +++ b/scripts/Makefile.uncmd_spl @@ -1,5 +1,7 @@ # Makefile version of include/config_uncmd_spl.h # +# SPDX-License-Identifier: GPL-2.0+ +# # TODO: Invent a better way
ifdef CONFIG_SPL_BUILD
