[PATCH v3 00/19] labgrid: Provide an integration with Labgrid
Labgrid provides access to a hardware lab in an automated way. It is possible to boot U-Boot on boards in the lab without physically touching them. It relies on relays, USB UARTs and SD muxes, among other things.
By way of background, about 4 years ago I wrong a thing called Labman[1] which allowed my lab of about 30 devices to be operated remotely, using tbot for the console and build integration. While it worked OK and I used it for many bisects, I didn't take it any further.
It turns out that there was already an existing program, called Labgrid, which I did not know about at time (thank you Tom for telling me). It is more rounded than Labman and has a number of advantages:
- does not need udev rules, mostly - has several existing users who rely on it - supports multiple machines exporting their devices
It lacks a 'lab check' feature and a few other things, but these can be remedied.
On and off over the past several weeks I have been experimenting with Labgrid. I have managed to create an initial U-Boot integration (this series) by adding various features to Labgrid[2] and the U-Boot test hooks.
I hope that this might inspire others to set up boards and run tests automatically, rather than relying on infrequent, manual test. Perhaps it may even be possible to have a number of labs available.
Included in the integration are a number of simple scripts which make it easy to connect to boards and run tests:
ub-int <target> Build and boot on a target, starting an interactive session
ub-cli <target> Build and boot on a target, ensure U-Boot starts and provide an interactive session from there
ub-smoke <target> Smoke test U-Boot to check that it boots to a prompt on a target
ub-bisect Bisect a git tree to locate a failure on a particular target
ub-pyt <target> <testspec> Run U-Boot pytests on a target
Some of these help to provide the same tbot[4] workflow which I have relied on for several years, albeit much simpler versions.
The goal here is to create some sort of script which can collect patches from the mailing list, apply them and test them on a selection of boards. I suspect that script already exists, so please let me know what you suggest.
I hope you find this interesting and take a look!
[1] https://github.com/sjg20/u-boot/tree/lab6a [2] https://github.com/labgrid-project/labgrid/pull/1411 [3] https://github.com/sjg20/uboot-test-hooks/tree/labgrid [4] https://tbot.tools/index.html
Changes in v3: - Split out most patches into two new series and update cover letter
Changes in v2: - Only disable echo if a terminal is detected - Avoid running a docker image for skipped lab tests
Simon Glass (19): test: Allow signaling that U-Boot is ready test: Use a constant for the test timeout test: Pass stderr to stdout test: Release board after tests complete test: Allow connecting to a running board test: Avoid failing skipped tests test: Create a common function to get the config test: Introduce the concept of a role test: Move the receive code into a function test: Separate out the exception handling test: Detect dead connections test: Tidy up remaining exceptions test: Introduce lab mode test: Improve handling of sending commands test: Fix mulptiplex_log typo test: Avoid double echo when starting up test: Try to shut down the lab console gracefully test: Add a section for closing the connection CI: Allow running tests on sjg lab
.gitlab-ci.yml | 153 +++++++++++++++++++++++++ test/py/conftest.py | 86 +++++++++++--- test/py/u_boot_console_base.py | 154 ++++++++++++++++++-------- test/py/u_boot_console_exec_attach.py | 31 ++++-- test/py/u_boot_spawn.py | 120 +++++++++++++++++--- test/test-main.c | 16 ++- 6 files changed, 470 insertions(+), 90 deletions(-)
When Labgrid is used, it can get U-Boot ready for running tests. It prints a message when it has done so.
Add logic to detect this message and accept it.
(no changes since v1)
test/py/u_boot_console_base.py | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index 76a550d45a1..882d04cd1e9 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -22,6 +22,7 @@ pattern_stop_autoboot_prompt = re.compile('Hit any key to stop autoboot: ') pattern_unknown_command = re.compile('Unknown command '.*' - try 'help'') pattern_error_notification = re.compile('## Error: ') pattern_error_please_reset = re.compile('### ERROR ### Please RESET the board ###') +pattern_ready_prompt = re.compile('U-Boot is ready')
PAT_ID = 0 PAT_RE = 1 @@ -196,15 +197,15 @@ class ConsoleBase(object): self.bad_pattern_ids[m - 1]) self.u_boot_version_string = self.p.after while True: - m = self.p.expect([self.prompt_compiled, + m = self.p.expect([self.prompt_compiled, pattern_ready_prompt, pattern_stop_autoboot_prompt] + self.bad_patterns) - if m == 0: + if m == 0 or m == 1: break - if m == 1: + if m == 2: self.p.send(' ') continue raise Exception('Bad pattern found on console: ' + - self.bad_pattern_ids[m - 2]) + self.bad_pattern_ids[m - 3])
except Exception as ex: self.log.error(str(ex))
Declare a constant rather than open-coding the same value twice.
test/py/u_boot_console_base.py | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index 882d04cd1e9..9cc0af66356 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -27,6 +27,9 @@ pattern_ready_prompt = re.compile('U-Boot is ready') PAT_ID = 0 PAT_RE = 1
+# Timeout before expecting the console to be ready (in milliseconds) +TIMEOUT_MS = 30000 + bad_pattern_defs = ( ('spl_signon', pattern_u_boot_spl_signon), ('main_signon', pattern_u_boot_main_signon), @@ -423,7 +426,7 @@ class ConsoleBase(object): # Reset the console timeout value as some tests may change # its default value during the execution if not self.config.gdbserver: - self.p.timeout = 30000 + self.p.timeout = TIMEOUT_MS return try: self.log.start_section('Starting U-Boot') @@ -434,7 +437,7 @@ class ConsoleBase(object): # future, possibly per-test to be optimal. This works for 'help' # on board 'seaboard'. if not self.config.gdbserver: - self.p.timeout = 30000 + self.p.timeout = TIMEOUT_MS self.p.logfile_read = self.logstream if expect_reset: loop_num = 2
Some tests may output things to stderr. Ensure that this output is not dropped, by redirecting it to stdout
test/py/u_boot_spawn.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index 97e95e07c80..81a09a9d639 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -10,6 +10,7 @@ import re import pty import signal import select +import sys import time import traceback
@@ -59,6 +60,7 @@ class Spawn: signal.signal(signal.SIGHUP, signal.SIG_DFL) if cwd: os.chdir(cwd) + sys.stderr = sys.stdout os.execvp(args[0], args) except: print('CHILD EXECEPTION:')
When a board is finished with, the lab may want to power it off, or perform some other function. Add a new script which is called when tests are complete.
test/py/u_boot_console_exec_attach.py | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/test/py/u_boot_console_exec_attach.py b/test/py/u_boot_console_exec_attach.py index 8dd8cc1230c..5f4916b7da2 100644 --- a/test/py/u_boot_console_exec_attach.py +++ b/test/py/u_boot_console_exec_attach.py @@ -70,3 +70,13 @@ class ConsoleExecAttach(ConsoleBase): raise
return s + + def close(self): + super().close() + + self.log.action('Releasing board') + args = [self.config.board_type, self.config.board_identity] + cmd = ['u-boot-test-release'] + args + runner = self.log.get_runner(cmd[0], sys.stdout) + runner.run(cmd) + runner.close()
Sometimes we know that the board is already running the right software, so provide an option to allow running of tests directly, without first resetting the board.
This saves time when re-running a test where only the Python code is changing.
test/py/conftest.py | 3 +++ test/py/u_boot_console_base.py | 14 ++++++++++---- test/py/u_boot_console_exec_attach.py | 21 ++++++++++++--------- 3 files changed, 25 insertions(+), 13 deletions(-)
diff --git a/test/py/conftest.py b/test/py/conftest.py index fc9dd3a83f8..ca66b9d9e61 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -79,6 +79,8 @@ def pytest_addoption(parser): parser.addoption('--gdbserver', default=None, help='Run sandbox under gdbserver. The argument is the channel '+ 'over which gdbserver should communicate, e.g. localhost:1234') + parser.addoption('--no-prompt-wait', default=False, action='store_true', + help="Assume that U-Boot is ready and don't wait for a prompt")
def run_build(config, source_dir, build_dir, board_type, log): """run_build: Build U-Boot @@ -238,6 +240,7 @@ def pytest_configure(config): ubconfig.board_type = board_type ubconfig.board_identity = board_identity ubconfig.gdbserver = gdbserver + ubconfig.no_prompt_wait = config.getoption('no_prompt_wait') ubconfig.dtb = build_dir + '/arch/sandbox/dts/test.dtb'
env_vars = ( diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index 9cc0af66356..8a9c4a576dc 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -439,11 +439,17 @@ class ConsoleBase(object): if not self.config.gdbserver: self.p.timeout = TIMEOUT_MS self.p.logfile_read = self.logstream - if expect_reset: - loop_num = 2 + if self.config.no_prompt_wait: + # Send an empty command to set up the 'expect' logic. This has + # the side effect of ensuring that there was no partial command + # line entered + self.run_command(' ') else: - loop_num = 1 - self.wait_for_boot_prompt(loop_num = loop_num) + if expect_reset: + loop_num = 2 + else: + loop_num = 1 + self.wait_for_boot_prompt(loop_num = loop_num) self.at_prompt = True self.at_prompt_logevt = self.logstream.logfile.cur_evt except Exception as ex: diff --git a/test/py/u_boot_console_exec_attach.py b/test/py/u_boot_console_exec_attach.py index 5f4916b7da2..42fc15197b9 100644 --- a/test/py/u_boot_console_exec_attach.py +++ b/test/py/u_boot_console_exec_attach.py @@ -59,15 +59,18 @@ class ConsoleExecAttach(ConsoleBase): args = [self.config.board_type, self.config.board_identity] s = Spawn(['u-boot-test-console'] + args)
- try: - self.log.action('Resetting board') - cmd = ['u-boot-test-reset'] + args - runner = self.log.get_runner(cmd[0], sys.stdout) - runner.run(cmd) - runner.close() - except: - s.close() - raise + if self.config.no_prompt_wait: + self.log.action('Connecting to board without reset') + else: + try: + self.log.action('Resetting board') + cmd = ['u-boot-test-reset'] + args + runner = self.log.get_runner(cmd[0], sys.stdout) + runner.run(cmd) + runner.close() + except: + s.close() + raise
return s
When a test returns -EAGAIN this should not be considered a failure. Fix what seems to be a problem case, where the pytests see a failure when a test has merely been skipped.
test/test-main.c | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/test/test-main.c b/test/test-main.c index 3fa6f6e32ec..cda1a186390 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -448,7 +448,7 @@ static int ut_run_test(struct unit_test_state *uts, struct unit_test *test, static int ut_run_test_live_flat(struct unit_test_state *uts, struct unit_test *test) { - int runs; + int runs, ret;
if ((test->flags & UT_TESTF_OTHER_FDT) && !IS_ENABLED(CONFIG_SANDBOX)) return skip_test(uts); @@ -458,8 +458,11 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, if (CONFIG_IS_ENABLED(OF_LIVE)) { if (!(test->flags & UT_TESTF_FLAT_TREE)) { uts->of_live = true; - ut_assertok(ut_run_test(uts, test, test->name)); - runs++; + ret = ut_run_test(uts, test, test->name); + if (ret != -EAGAIN) { + ut_assertok(ret); + runs++; + } } }
@@ -483,8 +486,11 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, (!runs || ut_test_run_on_flattree(test)) && !(gd->flags & GD_FLG_FDT_CHANGED)) { uts->of_live = false; - ut_assertok(ut_run_test(uts, test, test->name)); - runs++; + ret = ut_run_test(uts, test, test->name); + if (ret != -EAGAIN) { + ut_assertok(ret); + runs++; + } }
- int runs;
int runs, ret;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
How did you trigger this case exactly?
Hi Tom,
int runs;
int runs, ret; if ((test->flags & UT_TESTF_OTHER_FDT) && !IS_ENABLED(CONFIG_SANDBOX)) return skip_test(uts);
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
I noticed this in CI, where some skipped tests were shown as failed in the log, even though they were not counted as failures in the final results.
-- Tom
On Tue, Jun 25, 2024 at 01:38:00PM +0100, Simon Glass wrote:
Hi Tom,
int runs;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
That's really really strange, do you have an example log or something around still?
Hi Tom,
Hi Tom,
int runs;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
This happens on snow, which is (maybe) the only real board that defines CONFIG_UNIT_TEST
test/py/tests/test_ut.py sssnow # ut bdinfo bdinfo_test_eth Test: bdinfo_test_eth: bdinfo.c Skipping: Console recording disabled test/test-main.c:486, ut_run_test_live_flat(): 0 == ut_run_test(uts, test, test->name): Expected 0x0 (0), got 0xfffffff5 (-11) Test bdinfo_test_eth failed 1 times Skipped: 1, Failures: 1 snow # F+u-boot-test-reset snow snow
For this particular mechanism (-EAGAIN returned by test_pre_run()) , I think a better fix would be to squash the error in ut_run_test(), as is done when -EAGAIN is returned in the body of the test. I'll update that. I cannot see any other way this could happen, but we can always deal with it later if it does.
On Wed, Jun 26, 2024 at 09:00:42AM +0100, Simon Glass wrote:
Hi Tom,
Hi Tom,
int runs;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
I think it is too, but that's also perhaps a reminder that I should be enabling it as part of my build before testing scripts. I'll go do that now and see if this problem shows up a tiny bit more widely.
Thanks for explaining, please also include the example in the commit message in v2.
Hi Tom,
Hi Tom,
int runs;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
OK, not right now then, there's missing dependencies within the test. I'll selectively enable once v2 is in tho.
Hi Tom,
On Wed, 26 Jun 2024 at 02:00, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
int runs;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
No, that doesn't work, since the failure counting happens in the caller. This patch seems to be the right fix, so I'll send it again with a better commit message.
On Wed, Aug 21, 2024 at 09:00:33PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
int runs;
runs++;
ut_assertok(ret);
runs++;
runs++;
ut_assertok(ret);
runs++;
} } return 0;
And I'll try and test it on Pi as with the series I posted and so UNIT_TEST compiles on there, I got what looks like the same failure.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
> When a test returns -EAGAIN this should not be considered a failure. > Fix what seems to be a problem case, where the pytests see a failure > when a test has merely been skipped. > > Signed-off-by: Simon Glass sjg@chromium.org > --- > > (no changes since v1) > > test/test-main.c | 16 +++++++++++----- > 1 file changed, 11 insertions(+), 5 deletions(-) > > diff --git a/test/test-main.c b/test/test-main.c > index 3fa6f6e32ec..cda1a186390 100644 > --- a/test/test-main.c > +++ b/test/test-main.c > @@ -448,7 +448,7 @@ static int ut_run_test(struct unit_test_state *uts, struct unit_test *test, > static int ut_run_test_live_flat(struct unit_test_state *uts, > struct unit_test *test) > { > - int runs; > + int runs, ret; > > if ((test->flags & UT_TESTF_OTHER_FDT) && !IS_ENABLED(CONFIG_SANDBOX)) > return skip_test(uts); > @@ -458,8 +458,11 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, > if (CONFIG_IS_ENABLED(OF_LIVE)) { > if (!(test->flags & UT_TESTF_FLAT_TREE)) { > uts->of_live = true; > - ut_assertok(ut_run_test(uts, test, test->name)); > - runs++; > + ret = ut_run_test(uts, test, test->name); > + if (ret != -EAGAIN) { > + ut_assertok(ret); > + runs++; > + } > } > } > > @@ -483,8 +486,11 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, > (!runs || ut_test_run_on_flattree(test)) && > !(gd->flags & GD_FLG_FDT_CHANGED)) { > uts->of_live = false; > - ut_assertok(ut_run_test(uts, test, test->name)); > - runs++; > + ret = ut_run_test(uts, test, test->name); > + if (ret != -EAGAIN) { > + ut_assertok(ret); > + runs++; > + } > } > > return 0;
OK ta.
It would be good to get the Labgrid series into -next as it fixes quite a few problems on snow for me. It will provide a better base for solving other problems.
Regards, SImon
On Thu, Aug 22, 2024 at 08:22:59AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
On Mon, 24 Jun 2024 at 19:06, Tom Rini trini@konsulko.com wrote: > > On Sun, Jun 23, 2024 at 02:32:00PM -0600, Simon Glass wrote: > > > When a test returns -EAGAIN this should not be considered a failure. > > Fix what seems to be a problem case, where the pytests see a failure > > when a test has merely been skipped. > > > > Signed-off-by: Simon Glass sjg@chromium.org > > --- > > > > (no changes since v1) > > > > test/test-main.c | 16 +++++++++++----- > > 1 file changed, 11 insertions(+), 5 deletions(-) > > > > diff --git a/test/test-main.c b/test/test-main.c > > index 3fa6f6e32ec..cda1a186390 100644 > > --- a/test/test-main.c > > +++ b/test/test-main.c > > @@ -448,7 +448,7 @@ static int ut_run_test(struct unit_test_state *uts, struct unit_test *test, > > static int ut_run_test_live_flat(struct unit_test_state *uts, > > struct unit_test *test) > > { > > - int runs; > > + int runs, ret; > > > > if ((test->flags & UT_TESTF_OTHER_FDT) && !IS_ENABLED(CONFIG_SANDBOX)) > > return skip_test(uts); > > @@ -458,8 +458,11 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, > > if (CONFIG_IS_ENABLED(OF_LIVE)) { > > if (!(test->flags & UT_TESTF_FLAT_TREE)) { > > uts->of_live = true; > > - ut_assertok(ut_run_test(uts, test, test->name)); > > - runs++; > > + ret = ut_run_test(uts, test, test->name); > > + if (ret != -EAGAIN) { > > + ut_assertok(ret); > > + runs++; > > + } > > } > > } > > > > @@ -483,8 +486,11 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, > > (!runs || ut_test_run_on_flattree(test)) && > > !(gd->flags & GD_FLG_FDT_CHANGED)) { > > uts->of_live = false; > > - ut_assertok(ut_run_test(uts, test, test->name)); > > - runs++; > > + ret = ut_run_test(uts, test, test->name); > > + if (ret != -EAGAIN) { > > + ut_assertok(ret); > > + runs++; > > + } > > } > > > > return 0; > > How did you trigger this case exactly?
OK ta.
I want to pick some of it for sure. But it also broke my lab support (before an office power cycle left it in an odd state and I need to go and confirm what's needed / not needed again to bring the boards up).
The settings are decoded in two places. Combine them into a new function, before (in a future patch) expanding the number of items.
test/py/conftest.py | 41 ++++++++++++++++++++++++++++------------- 1 file changed, 28 insertions(+), 13 deletions(-)
diff --git a/test/py/conftest.py b/test/py/conftest.py index ca66b9d9e61..6547c6922c6 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -117,14 +117,36 @@ def run_build(config, source_dir, build_dir, board_type, log): runner.close() log.status_pass('OK')
-def pytest_xdist_setupnodes(config, specs): - """Clear out any 'done' file from a previous build""" - global build_done_file - build_dir = config.getoption('build_dir') +def get_details(config): + """Obtain salient details about the board and directories to use + + Args: + config (pytest.Config): pytest configuration + + Returns: + tuple: + str: Board type (U-Boot build name) + str: Identity for the lab board + str: Build directory + str: Source directory + """ board_type = config.getoption('board_type') + board_identity = config.getoption('board_identity') + build_dir = config.getoption('build_dir') + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) + default_build_dir = source_dir + '/build-' + board_type if not build_dir: - build_dir = source_dir + '/build-' + board_type + build_dir = default_build_dir + + return board_type, board_identity, build_dir, source_dir + +def pytest_xdist_setupnodes(config, specs): + """Clear out any 'done' file from a previous build""" + global build_done_file + + build_dir = get_details(config)[2] + build_done_file = Path(build_dir) / 'build.done' if build_done_file.exists(): os.remove(build_done_file) @@ -163,17 +185,10 @@ def pytest_configure(config): global console global ubconfig
- source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) + board_type, board_identity, build_dir, source_dir = get_details(config)
- board_type = config.getoption('board_type') board_type_filename = board_type.replace('-', '_') - - board_identity = config.getoption('board_identity') board_identity_filename = board_identity.replace('-', '_') - - build_dir = config.getoption('build_dir') - if not build_dir: - build_dir = source_dir + '/build-' + board_type mkdir_p(build_dir)
result_dir = config.getoption('result_dir')
In Labgrid there is the concept of a 'role', which is similar to the U-Boot board ID in U-Boot's pytest subsystem.
The role indicates both the target and information about the U-Boot build to use. It can also provide any amount of other configuration. The information is obtained using the 'labgrid-client query' operation.
Make use of this in tests, so that only the role is required in gitlab and other situations. The board type and other things can be queried as needed.
Use a new 'u-boot-test-getrole' script to obtain the requested information.
With this it is possible to run lab tests in gitlab with just a single 'ROLE' variable for each board.
test/py/conftest.py | 31 +++++++++++++++++++++++++++---- 1 file changed, 27 insertions(+), 4 deletions(-)
diff --git a/test/py/conftest.py b/test/py/conftest.py index 6547c6922c6..5de8d7b0e23 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -23,6 +23,7 @@ from pathlib import Path import pytest import re from _pytest.runner import runtestprotocol +import subprocess import sys
# Globals: The HTML log file, and the connection to the U-Boot console. @@ -79,6 +80,7 @@ def pytest_addoption(parser): parser.addoption('--gdbserver', default=None, help='Run sandbox under gdbserver. The argument is the channel '+ 'over which gdbserver should communicate, e.g. localhost:1234') + parser.addoption('--role', help='U-Boot board role (for Labgrid)') parser.addoption('--no-prompt-wait', default=False, action='store_true', help="Assume that U-Boot is ready and don't wait for a prompt")
@@ -130,12 +132,33 @@ def get_details(config): str: Build directory str: Source directory """ - board_type = config.getoption('board_type') - board_identity = config.getoption('board_identity') + role = config.getoption('role') build_dir = config.getoption('build_dir') + if role: + board_identity = role + cmd = ['u-boot-test-getrole', role, '--configure'] + env = os.environ.copy() + if build_dir: + env['U_BOOT_BUILD_DIR'] = build_dir + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', + env=env) + if proc.returncode: + raise ValueError(proc.stderr) + print('conftest: lab:', proc.stdout) + vals = {} + for line in proc.stdout.splitlines(): + item, value = line.split(' ', maxsplit=1) + k = item.split(':')[-1] + vals[k] = value + print('conftest: lab info:', vals) + board_type, default_build_dir, source_dir = (vals['board'], + vals['build_dir'], vals['source_dir']) + else: + board_type = config.getoption('board_type') + board_identity = config.getoption('board_identity')
- source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) - default_build_dir = source_dir + '/build-' + board_type + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) + default_build_dir = source_dir + '/build-' + board_type if not build_dir: build_dir = default_build_dir
- parser.addoption('--role', help='U-Boot board role (for Labgrid)') parser.addoption('--no-prompt-wait', default=False, action='store_true', help="Assume that U-Boot is ready and don't wait for a prompt")
- role = config.getoption('role') build_dir = config.getoption('build_dir')
- if role:
if build_dir:
env=env)
if proc.returncode:
vals = {}
vals[k] = value
- else:
if not build_dir: build_dir = default_build_dirdefault_build_dir = source_dir + '/build-' + board_type
I'm a little confused here. Why can't we construct "role" from board_type+board_identity and then we have the board conf.${board_type}_${board_identity} file set whatever needs setting to be "labgrid" ?
Hi Tom,
- if role:
if build_dir:
env=env)
if proc.returncode:
vals = {}
vals[k] = value
- else:
The role is equivalent to the board identity, not the combination of the U-Boot board type and the board identity. I went this way to avoid having to type long and complicated roles when connecting to boards. It is similar to how things work today, except that the board type is implied by the 'role'.
For boards which have multiple identities (e.g. can support two different board types), Labgrid handles acquiring and releasing the shares resources, to avoid any problems.
On Tue, Jun 25, 2024 at 01:38:08PM +0100, Simon Glass wrote:
Hi Tom,
- if role:
if build_dir:
env=env)
if proc.returncode:
vals = {}
vals[k] = value
- else:
I guess I have two sets of questions. First, if it's basically the board identity why can't we just use that as the role name, in your setup?
But second, I'm not sure why we need this. The labgrid support we worked up here (but, sigh, it's not really clean enough to post) has: $ cat bin/lootbox/conf.rpi_4_na console_impl=labgrid reset_impl=labgrid flash_impl=labgrid.rpi_4 flash_writer=labgrid.rpi_4
For example and: $ cat bin/writer.labgrid.rpi_4 set -e
build=${U_BOOT_BUILD_DIR}
$LG_CLIENT write-files -T ${build}/u-boot.bin kernel8.img
So I don't know what the "role" part you have is for. And yes, there end up being multiple writer.labgrid.FOO scripts because for TI K3 platforms (such as beagleplay) we have: $ cat bin/writer.labgrid.ti-k3 set -e build=${U_BOOT_BUILD_DIR}
if [ -z "${tispl}" -o -z "${uboot}" -o -z "${tiboot3}" ]; then echo "Must configure tispl, uboot, tiboot3 and optionally sysfw" echo "per the board documentation." exit 1 fi echo "Writing build at ${build}" $LG_CLIENT write-files -T ${build}/${tispl} tispl.bin $LG_CLIENT write-files -T ${build}/${uboot} u-boot.img $LG_CLIENT write-files -T ${build/_a??/_r5}/${tiboot3} tiboot3.bin echo "Done writing build"
In all cases we first build U-Boot and then pass the build directory to test.py, in something like: export LG_PLACE=rpi4 ./test/py/test.py -ra --bd rpi_4 --build-dir .../build-rpi4 \ --results-dir .../results-rpi4 --persistent-data-dir .../pd-rpi4 \ --exitfirst
The only U-Boot side changes I needed to make were for counting the SPL banner instances, and that was regardless of framework (a particularly fun platform will show it 3 times).
Hi Tom,
Hi Tom,
- if role:
if build_dir:
env=env)
if proc.returncode:
vals = {}
vals[k] = value
- else:
Yes, that's what I am doing. If you look in console.labgrid you can see that it is passing U_BOOT_BOARD_IDENTITY as the -r argument.
Yes it is possible to build U-Boot separately. Of course that involved various blobs and so on, so every board is different. The approach I have taken here is to have Labgrid call buildman to build what is needed, with the blobs defined in the environment.
You can use the -B flag to use a pre-built U-Boot, with the scripts I've included.
On Wed, Jun 26, 2024 at 09:00:33AM +0100, Simon Glass wrote:
Hi Tom,
Hi Tom,
- if role:
if build_dir:
env=env)
if proc.returncode:
vals = {}
vals[k] = value
- else:
Then why do we need this?
OK. I personally think pre-built (or outside of buildman built) U-Boot will be an important case, since everything needs more options enabled to test more features, but on real hardware. For example, CONFIG_UNIT_TEST should be on for everyone, in testing, once the build issues are resolved. And I need to add CONFIG_FIT to some platforms so that I can then use the kernel test. And some platforms I end up enabling CONFIG_CMD_BOOTEFI_HELLO on (but others disabling CONFIG_CMD_BOOTEFI_SELFTEST as that fails and that's just A Thing).
Hi Tom,
Hi Tom,
Hi Tom,
- if role:
if build_dir:
env=env)
if proc.returncode:
vals = {}
vals[k] = value
- else:
We need to pass a role to Labgrid, since it determines the board identity to use. It also (indirectly) determines the U-Boot build to use, since each board identity / role is a particular board with a particular build.
For example: role / identify = samus - uses 'samus' board with build chromebook_samus role / identify = samus_tpl - uses 'samus' board with build chromebook_samus_tpl
Basically, as I understand it, the 'role' is the thing we want.
Labgrid environment:
samus: resources: RemotePlace: name: samus ... UBootProviderDriver: board: chromebook_samus binman_indir: /vid/software/devel/samus/bin
samus_tpl: resources: RemotePlace: name: samus UBootProviderDriver: board: chromebook_samus_tpl binman_indir: /vid/software/devel/samus/bin
Yes that all sounds good. I have figured out how to add QEMU into this Labgrid integration, but I cannot Debian to boot all the way to a prompt with -nographic unless I pass something special on the Linux commandline. So for now I parked that.
On Thu, Jun 27, 2024 at 09:37:18AM +0100, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
> In Labgrid there is the concept of a 'role', which is similar to the > U-Boot board ID in U-Boot's pytest subsystem. > > The role indicates both the target and information about the U-Boot > build to use. It can also provide any amount of other configuration. > The information is obtained using the 'labgrid-client query' operation. > > Make use of this in tests, so that only the role is required in gitlab > and other situations. The board type and other things can be queried > as needed. > > Use a new 'u-boot-test-getrole' script to obtain the requested > information. > > With this it is possible to run lab tests in gitlab with just a single > 'ROLE' variable for each board. > > Signed-off-by: Simon Glass sjg@chromium.org > --- > > (no changes since v1) > > test/py/conftest.py | 31 +++++++++++++++++++++++++++---- > 1 file changed, 27 insertions(+), 4 deletions(-) > > diff --git a/test/py/conftest.py b/test/py/conftest.py > index 6547c6922c6..5de8d7b0e23 100644 > --- a/test/py/conftest.py > +++ b/test/py/conftest.py > @@ -23,6 +23,7 @@ from pathlib import Path > import pytest > import re > from _pytest.runner import runtestprotocol > +import subprocess > import sys > > # Globals: The HTML log file, and the connection to the U-Boot console. > @@ -79,6 +80,7 @@ def pytest_addoption(parser): > parser.addoption('--gdbserver', default=None, > help='Run sandbox under gdbserver. The argument is the channel '+ > 'over which gdbserver should communicate, e.g. localhost:1234') > + parser.addoption('--role', help='U-Boot board role (for Labgrid)') > parser.addoption('--no-prompt-wait', default=False, action='store_true', > help="Assume that U-Boot is ready and don't wait for a prompt") > > @@ -130,12 +132,33 @@ def get_details(config): > str: Build directory > str: Source directory > """ > - board_type = config.getoption('board_type') > - board_identity = config.getoption('board_identity') > + role = config.getoption('role') > build_dir = config.getoption('build_dir') > + if role: > + board_identity = role > + cmd = ['u-boot-test-getrole', role, '--configure'] > + env = os.environ.copy() > + if build_dir: > + env['U_BOOT_BUILD_DIR'] = build_dir > + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', > + env=env) > + if proc.returncode: > + raise ValueError(proc.stderr) > + print('conftest: lab:', proc.stdout) > + vals = {} > + for line in proc.stdout.splitlines(): > + item, value = line.split(' ', maxsplit=1) > + k = item.split(':')[-1] > + vals[k] = value > + print('conftest: lab info:', vals) > + board_type, default_build_dir, source_dir = (vals['board'], > + vals['build_dir'], vals['source_dir']) > + else: > + board_type = config.getoption('board_type') > + board_identity = config.getoption('board_identity') > > - source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > - default_build_dir = source_dir + '/build-' + board_type > + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > + default_build_dir = source_dir + '/build-' + board_type > if not build_dir: > build_dir = default_build_dir
Oh, I get where you're coming from now at least. But this still sounds like a detail to put in to the conf.${board}_${board_type} file and not a thing to set here?
Yes, or using one physical Pi 4 to test rpi_4_defconfig and rpi_arm64_defconfig (and if labgrid supported a way to remove files from the FAT partition, rpi_4_32b_defconfig).
I guess the problem here is that from my point of view, this can live in the u-boot-test-hooks/bin/<host>/conf.<machine> file since we're never going to worry about building U-Boot (even if blobs aren't a problem, we want to enable more features to test more things on HW) but from your point of view, buildman must provide test.py with the correct build so we need to know things prior.
Putting QEMU in to labgrid too could be interesting, yes. But I lost how it's related? To be clear, today we can test boot a Linux kernel on hardware. Somewhere on my TODO list is cycling over what kernel images to grab and shove in to the docker container so that our existing QEMU tests can do that too, for some platforms at least.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
On Mon, 24 Jun 2024 at 19:13, Tom Rini trini@konsulko.com wrote: > > On Sun, Jun 23, 2024 at 02:32:02PM -0600, Simon Glass wrote: > > > In Labgrid there is the concept of a 'role', which is similar to the > > U-Boot board ID in U-Boot's pytest subsystem. > > > > The role indicates both the target and information about the U-Boot > > build to use. It can also provide any amount of other configuration. > > The information is obtained using the 'labgrid-client query' operation. > > > > Make use of this in tests, so that only the role is required in gitlab > > and other situations. The board type and other things can be queried > > as needed. > > > > Use a new 'u-boot-test-getrole' script to obtain the requested > > information. > > > > With this it is possible to run lab tests in gitlab with just a single > > 'ROLE' variable for each board. > > > > Signed-off-by: Simon Glass sjg@chromium.org > > --- > > > > (no changes since v1) > > > > test/py/conftest.py | 31 +++++++++++++++++++++++++++---- > > 1 file changed, 27 insertions(+), 4 deletions(-) > > > > diff --git a/test/py/conftest.py b/test/py/conftest.py > > index 6547c6922c6..5de8d7b0e23 100644 > > --- a/test/py/conftest.py > > +++ b/test/py/conftest.py > > @@ -23,6 +23,7 @@ from pathlib import Path > > import pytest > > import re > > from _pytest.runner import runtestprotocol > > +import subprocess > > import sys > > > > # Globals: The HTML log file, and the connection to the U-Boot console. > > @@ -79,6 +80,7 @@ def pytest_addoption(parser): > > parser.addoption('--gdbserver', default=None, > > help='Run sandbox under gdbserver. The argument is the channel '+ > > 'over which gdbserver should communicate, e.g. localhost:1234') > > + parser.addoption('--role', help='U-Boot board role (for Labgrid)') > > parser.addoption('--no-prompt-wait', default=False, action='store_true', > > help="Assume that U-Boot is ready and don't wait for a prompt") > > > > @@ -130,12 +132,33 @@ def get_details(config): > > str: Build directory > > str: Source directory > > """ > > - board_type = config.getoption('board_type') > > - board_identity = config.getoption('board_identity') > > + role = config.getoption('role') > > build_dir = config.getoption('build_dir') > > + if role: > > + board_identity = role > > + cmd = ['u-boot-test-getrole', role, '--configure'] > > + env = os.environ.copy() > > + if build_dir: > > + env['U_BOOT_BUILD_DIR'] = build_dir > > + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', > > + env=env) > > + if proc.returncode: > > + raise ValueError(proc.stderr) > > + print('conftest: lab:', proc.stdout) > > + vals = {} > > + for line in proc.stdout.splitlines(): > > + item, value = line.split(' ', maxsplit=1) > > + k = item.split(':')[-1] > > + vals[k] = value > > + print('conftest: lab info:', vals) > > + board_type, default_build_dir, source_dir = (vals['board'], > > + vals['build_dir'], vals['source_dir']) > > + else: > > + board_type = config.getoption('board_type') > > + board_identity = config.getoption('board_identity') > > > > - source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > - default_build_dir = source_dir + '/build-' + board_type > > + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > + default_build_dir = source_dir + '/build-' + board_type > > if not build_dir: > > build_dir = default_build_dir > > I'm a little confused here. Why can't we construct "role" from > board_type+board_identity and then we have the board > conf.${board_type}_${board_identity} file set whatever needs setting to > be "labgrid" ?
There are no such files with the Labgrid integration so far. They are not needed.
Yes, that would be a nice addition.
Well, either you already have a build to test, iwc it is fine, or if you don't you can pass --build to force a build, or rely on Labgrid to initiate the build.
But in your case, the build must be done before running test.py since it needs the .config file.
It's just a nice way of allowing 'ub-int qemu-x86' and getting to a U-Boot prompt. Yes there are other ways to do it, and in fact it works today if you set up your conf files for the machine you are on.
On Sat, Jul 13, 2024 at 04:13:55PM +0100, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Tue, Jun 25, 2024 at 01:38:08PM +0100, Simon Glass wrote: > Hi Tom, > > On Mon, 24 Jun 2024 at 19:13, Tom Rini trini@konsulko.com wrote: > > > > On Sun, Jun 23, 2024 at 02:32:02PM -0600, Simon Glass wrote: > > > > > In Labgrid there is the concept of a 'role', which is similar to the > > > U-Boot board ID in U-Boot's pytest subsystem. > > > > > > The role indicates both the target and information about the U-Boot > > > build to use. It can also provide any amount of other configuration. > > > The information is obtained using the 'labgrid-client query' operation. > > > > > > Make use of this in tests, so that only the role is required in gitlab > > > and other situations. The board type and other things can be queried > > > as needed. > > > > > > Use a new 'u-boot-test-getrole' script to obtain the requested > > > information. > > > > > > With this it is possible to run lab tests in gitlab with just a single > > > 'ROLE' variable for each board. > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > --- > > > > > > (no changes since v1) > > > > > > test/py/conftest.py | 31 +++++++++++++++++++++++++++---- > > > 1 file changed, 27 insertions(+), 4 deletions(-) > > > > > > diff --git a/test/py/conftest.py b/test/py/conftest.py > > > index 6547c6922c6..5de8d7b0e23 100644 > > > --- a/test/py/conftest.py > > > +++ b/test/py/conftest.py > > > @@ -23,6 +23,7 @@ from pathlib import Path > > > import pytest > > > import re > > > from _pytest.runner import runtestprotocol > > > +import subprocess > > > import sys > > > > > > # Globals: The HTML log file, and the connection to the U-Boot console. > > > @@ -79,6 +80,7 @@ def pytest_addoption(parser): > > > parser.addoption('--gdbserver', default=None, > > > help='Run sandbox under gdbserver. The argument is the channel '+ > > > 'over which gdbserver should communicate, e.g. localhost:1234') > > > + parser.addoption('--role', help='U-Boot board role (for Labgrid)') > > > parser.addoption('--no-prompt-wait', default=False, action='store_true', > > > help="Assume that U-Boot is ready and don't wait for a prompt") > > > > > > @@ -130,12 +132,33 @@ def get_details(config): > > > str: Build directory > > > str: Source directory > > > """ > > > - board_type = config.getoption('board_type') > > > - board_identity = config.getoption('board_identity') > > > + role = config.getoption('role') > > > build_dir = config.getoption('build_dir') > > > + if role: > > > + board_identity = role > > > + cmd = ['u-boot-test-getrole', role, '--configure'] > > > + env = os.environ.copy() > > > + if build_dir: > > > + env['U_BOOT_BUILD_DIR'] = build_dir > > > + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', > > > + env=env) > > > + if proc.returncode: > > > + raise ValueError(proc.stderr) > > > + print('conftest: lab:', proc.stdout) > > > + vals = {} > > > + for line in proc.stdout.splitlines(): > > > + item, value = line.split(' ', maxsplit=1) > > > + k = item.split(':')[-1] > > > + vals[k] = value > > > + print('conftest: lab info:', vals) > > > + board_type, default_build_dir, source_dir = (vals['board'], > > > + vals['build_dir'], vals['source_dir']) > > > + else: > > > + board_type = config.getoption('board_type') > > > + board_identity = config.getoption('board_identity') > > > > > > - source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > - default_build_dir = source_dir + '/build-' + board_type > > > + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > + default_build_dir = source_dir + '/build-' + board_type > > > if not build_dir: > > > build_dir = default_build_dir > > > > I'm a little confused here. Why can't we construct "role" from > > board_type+board_identity and then we have the board > > conf.${board_type}_${board_identity} file set whatever needs setting to > > be "labgrid" ? > > The role is equivalent to the board identity, not the combination of > the U-Boot board type and the board identity. I went this way to avoid > having to type long and complicated roles when connecting to boards. > It is similar to how things work today, except that the board type is > implied by the 'role'. > > For boards which have multiple identities (e.g. can support two > different board types), Labgrid handles acquiring and releasing the > shares resources, to avoid any problems.
They're needed in my case since I do not (cannot) use buildman to then kick off the tests.
[snip]
No, neither buildman nor labgrid can initiate a functional build. Have you integrated the beagleplay in to your lab? That I believe demonstrates one of the problems (you need to build both am62x_beagleplay_a53 and am62x_beagleplay_r5 and write files from both, to test a given rev on the platform).
Yes, I build first and pass test.py the build directory.
Yes, I've locally included qemu hosts as needed. I guess this was just as an aside? Because yes, it would be good to run the net_boot tests on more platforms, automatically, including/especially QEMU.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
On Tue, 25 Jun 2024 at 15:27, Tom Rini trini@konsulko.com wrote: > > On Tue, Jun 25, 2024 at 01:38:08PM +0100, Simon Glass wrote: > > Hi Tom, > > > > On Mon, 24 Jun 2024 at 19:13, Tom Rini trini@konsulko.com wrote: > > > > > > On Sun, Jun 23, 2024 at 02:32:02PM -0600, Simon Glass wrote: > > > > > > > In Labgrid there is the concept of a 'role', which is similar to the > > > > U-Boot board ID in U-Boot's pytest subsystem. > > > > > > > > The role indicates both the target and information about the U-Boot > > > > build to use. It can also provide any amount of other configuration. > > > > The information is obtained using the 'labgrid-client query' operation. > > > > > > > > Make use of this in tests, so that only the role is required in gitlab > > > > and other situations. The board type and other things can be queried > > > > as needed. > > > > > > > > Use a new 'u-boot-test-getrole' script to obtain the requested > > > > information. > > > > > > > > With this it is possible to run lab tests in gitlab with just a single > > > > 'ROLE' variable for each board. > > > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > --- > > > > > > > > (no changes since v1) > > > > > > > > test/py/conftest.py | 31 +++++++++++++++++++++++++++---- > > > > 1 file changed, 27 insertions(+), 4 deletions(-) > > > > > > > > diff --git a/test/py/conftest.py b/test/py/conftest.py > > > > index 6547c6922c6..5de8d7b0e23 100644 > > > > --- a/test/py/conftest.py > > > > +++ b/test/py/conftest.py > > > > @@ -23,6 +23,7 @@ from pathlib import Path > > > > import pytest > > > > import re > > > > from _pytest.runner import runtestprotocol > > > > +import subprocess > > > > import sys > > > > > > > > # Globals: The HTML log file, and the connection to the U-Boot console. > > > > @@ -79,6 +80,7 @@ def pytest_addoption(parser): > > > > parser.addoption('--gdbserver', default=None, > > > > help='Run sandbox under gdbserver. The argument is the channel '+ > > > > 'over which gdbserver should communicate, e.g. localhost:1234') > > > > + parser.addoption('--role', help='U-Boot board role (for Labgrid)') > > > > parser.addoption('--no-prompt-wait', default=False, action='store_true', > > > > help="Assume that U-Boot is ready and don't wait for a prompt") > > > > > > > > @@ -130,12 +132,33 @@ def get_details(config): > > > > str: Build directory > > > > str: Source directory > > > > """ > > > > - board_type = config.getoption('board_type') > > > > - board_identity = config.getoption('board_identity') > > > > + role = config.getoption('role') > > > > build_dir = config.getoption('build_dir') > > > > + if role: > > > > + board_identity = role > > > > + cmd = ['u-boot-test-getrole', role, '--configure'] > > > > + env = os.environ.copy() > > > > + if build_dir: > > > > + env['U_BOOT_BUILD_DIR'] = build_dir > > > > + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', > > > > + env=env) > > > > + if proc.returncode: > > > > + raise ValueError(proc.stderr) > > > > + print('conftest: lab:', proc.stdout) > > > > + vals = {} > > > > + for line in proc.stdout.splitlines(): > > > > + item, value = line.split(' ', maxsplit=1) > > > > + k = item.split(':')[-1] > > > > + vals[k] = value > > > > + print('conftest: lab info:', vals) > > > > + board_type, default_build_dir, source_dir = (vals['board'], > > > > + vals['build_dir'], vals['source_dir']) > > > > + else: > > > > + board_type = config.getoption('board_type') > > > > + board_identity = config.getoption('board_identity') > > > > > > > > - source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > > - default_build_dir = source_dir + '/build-' + board_type > > > > + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > > + default_build_dir = source_dir + '/build-' + board_type > > > > if not build_dir: > > > > build_dir = default_build_dir > > > > > > I'm a little confused here. Why can't we construct "role" from > > > board_type+board_identity and then we have the board > > > conf.${board_type}_${board_identity} file set whatever needs setting to > > > be "labgrid" ? > > > > The role is equivalent to the board identity, not the combination of > > the U-Boot board type and the board identity. I went this way to avoid > > having to type long and complicated roles when connecting to boards. > > It is similar to how things work today, except that the board type is > > implied by the 'role'. > > > > For boards which have multiple identities (e.g. can support two > > different board types), Labgrid handles acquiring and releasing the > > shares resources, to avoid any problems. > > I guess I have two sets of questions. First, if it's basically the > board identity why can't we just use that as the role name, in your > setup?
OK...is your environment upstream so I can compare with mine?
[snip]
Actually I was about to do that. Will get back to it in a few weeks. Labgrid can initiate two builds and copy files from both.
> But second, I'm not sure why we need this. The labgrid support we worked > up here (but, sigh, it's not really clean enough to post) has: > $ cat bin/lootbox/conf.rpi_4_na > console_impl=labgrid > reset_impl=labgrid > flash_impl=labgrid.rpi_4 > flash_writer=labgrid.rpi_4 > > For example and: > $ cat bin/writer.labgrid.rpi_4 > set -e > > build=${U_BOOT_BUILD_DIR} > > $LG_CLIENT write-files -T ${build}/u-boot.bin kernel8.img > > So I don't know what the "role" part you have is for. And yes, there end > up being multiple writer.labgrid.FOO scripts because for TI K3 platforms > (such as beagleplay) we have: > $ cat bin/writer.labgrid.ti-k3 > set -e > build=${U_BOOT_BUILD_DIR} > > if [ -z "${tispl}" -o -z "${uboot}" -o -z "${tiboot3}" ]; then > echo "Must configure tispl, uboot, tiboot3 and optionally sysfw" > echo "per the board documentation." > exit 1 > fi > echo "Writing build at ${build}" > $LG_CLIENT write-files -T ${build}/${tispl} tispl.bin > $LG_CLIENT write-files -T ${build}/${uboot} u-boot.img > $LG_CLIENT write-files -T ${build/_a??/_r5}/${tiboot3} tiboot3.bin > echo "Done writing build" > > In all cases we first build U-Boot and then pass the build directory to > test.py, in something like: > export LG_PLACE=rpi4 > ./test/py/test.py -ra --bd rpi_4 --build-dir .../build-rpi4 \ > --results-dir .../results-rpi4 --persistent-data-dir .../pd-rpi4 \ > --exitfirst > > The only U-Boot side changes I needed to make were for counting the SPL > banner instances, and that was regardless of framework (a particularly > fun platform will show it 3 times).
Indeed.
Regards, SImon
On Mon, Jul 15, 2024 at 08:11:28AM +0100, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
On Wed, Jun 26, 2024 at 09:00:33AM +0100, Simon Glass wrote: > Hi Tom, > > On Tue, 25 Jun 2024 at 15:27, Tom Rini trini@konsulko.com wrote: > > > > On Tue, Jun 25, 2024 at 01:38:08PM +0100, Simon Glass wrote: > > > Hi Tom, > > > > > > On Mon, 24 Jun 2024 at 19:13, Tom Rini trini@konsulko.com wrote: > > > > > > > > On Sun, Jun 23, 2024 at 02:32:02PM -0600, Simon Glass wrote: > > > > > > > > > In Labgrid there is the concept of a 'role', which is similar to the > > > > > U-Boot board ID in U-Boot's pytest subsystem. > > > > > > > > > > The role indicates both the target and information about the U-Boot > > > > > build to use. It can also provide any amount of other configuration. > > > > > The information is obtained using the 'labgrid-client query' operation. > > > > > > > > > > Make use of this in tests, so that only the role is required in gitlab > > > > > and other situations. The board type and other things can be queried > > > > > as needed. > > > > > > > > > > Use a new 'u-boot-test-getrole' script to obtain the requested > > > > > information. > > > > > > > > > > With this it is possible to run lab tests in gitlab with just a single > > > > > 'ROLE' variable for each board. > > > > > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > > --- > > > > > > > > > > (no changes since v1) > > > > > > > > > > test/py/conftest.py | 31 +++++++++++++++++++++++++++---- > > > > > 1 file changed, 27 insertions(+), 4 deletions(-) > > > > > > > > > > diff --git a/test/py/conftest.py b/test/py/conftest.py > > > > > index 6547c6922c6..5de8d7b0e23 100644 > > > > > --- a/test/py/conftest.py > > > > > +++ b/test/py/conftest.py > > > > > @@ -23,6 +23,7 @@ from pathlib import Path > > > > > import pytest > > > > > import re > > > > > from _pytest.runner import runtestprotocol > > > > > +import subprocess > > > > > import sys > > > > > > > > > > # Globals: The HTML log file, and the connection to the U-Boot console. > > > > > @@ -79,6 +80,7 @@ def pytest_addoption(parser): > > > > > parser.addoption('--gdbserver', default=None, > > > > > help='Run sandbox under gdbserver. The argument is the channel '+ > > > > > 'over which gdbserver should communicate, e.g. localhost:1234') > > > > > + parser.addoption('--role', help='U-Boot board role (for Labgrid)') > > > > > parser.addoption('--no-prompt-wait', default=False, action='store_true', > > > > > help="Assume that U-Boot is ready and don't wait for a prompt") > > > > > > > > > > @@ -130,12 +132,33 @@ def get_details(config): > > > > > str: Build directory > > > > > str: Source directory > > > > > """ > > > > > - board_type = config.getoption('board_type') > > > > > - board_identity = config.getoption('board_identity') > > > > > + role = config.getoption('role') > > > > > build_dir = config.getoption('build_dir') > > > > > + if role: > > > > > + board_identity = role > > > > > + cmd = ['u-boot-test-getrole', role, '--configure'] > > > > > + env = os.environ.copy() > > > > > + if build_dir: > > > > > + env['U_BOOT_BUILD_DIR'] = build_dir > > > > > + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', > > > > > + env=env) > > > > > + if proc.returncode: > > > > > + raise ValueError(proc.stderr) > > > > > + print('conftest: lab:', proc.stdout) > > > > > + vals = {} > > > > > + for line in proc.stdout.splitlines(): > > > > > + item, value = line.split(' ', maxsplit=1) > > > > > + k = item.split(':')[-1] > > > > > + vals[k] = value > > > > > + print('conftest: lab info:', vals) > > > > > + board_type, default_build_dir, source_dir = (vals['board'], > > > > > + vals['build_dir'], vals['source_dir']) > > > > > + else: > > > > > + board_type = config.getoption('board_type') > > > > > + board_identity = config.getoption('board_identity') > > > > > > > > > > - source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > > > - default_build_dir = source_dir + '/build-' + board_type > > > > > + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > > > + default_build_dir = source_dir + '/build-' + board_type > > > > > if not build_dir: > > > > > build_dir = default_build_dir > > > > > > > > I'm a little confused here. Why can't we construct "role" from > > > > board_type+board_identity and then we have the board > > > > conf.${board_type}_${board_identity} file set whatever needs setting to > > > > be "labgrid" ? > > > > > > The role is equivalent to the board identity, not the combination of > > > the U-Boot board type and the board identity. I went this way to avoid > > > having to type long and complicated roles when connecting to boards. > > > It is similar to how things work today, except that the board type is > > > implied by the 'role'. > > > > > > For boards which have multiple identities (e.g. can support two > > > different board types), Labgrid handles acquiring and releasing the > > > shares resources, to avoid any problems. > > > > I guess I have two sets of questions. First, if it's basically the > > board identity why can't we just use that as the role name, in your > > setup? > > Yes, that's what I am doing. If you look in console.labgrid you can > see that it is passing U_BOOT_BOARD_IDENTITY as the -r argument.
The engineer here that was working on it is unfortunately leaving shortly and I forget if he got everything labgrid related posted. The other half of the environment is that none of my tests treat the hooks repository any different than before. And note that when I say cannot above I mean that because: 1) All of the TI platforms that require an Cortex-R and Cortex-A builds. You can (nominally) stick with only upgrading one part at a time, and so just test an even smaller subset on the R core, and once that passes, test the subset of tests that run on HW on the A core. 2) Enable further options. I enable CMD_BOOTMENU, CMD_LOG globally, CMD_TFTPPUT and FIT+FIT_SIGNATURE globally and BOOTSTAGE (+ stash) on Pi, and I'm going to cover TI K3 platforms next (since they too can easily share a stash addr).
The latter could be solved if buildman had some native config-fragment support and we didn't have the #include games we have today. No, I don't have a good idea on solving that either, only noting that today I use scripts/kconfig/merge_config.sh to combine defconfig + the above.
[snip]
I'm very interested in what this all looks like once that works too.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
On Wed, 26 Jun 2024 at 15:29, Tom Rini trini@konsulko.com wrote: > > On Wed, Jun 26, 2024 at 09:00:33AM +0100, Simon Glass wrote: > > Hi Tom, > > > > On Tue, 25 Jun 2024 at 15:27, Tom Rini trini@konsulko.com wrote: > > > > > > On Tue, Jun 25, 2024 at 01:38:08PM +0100, Simon Glass wrote: > > > > Hi Tom, > > > > > > > > On Mon, 24 Jun 2024 at 19:13, Tom Rini trini@konsulko.com wrote: > > > > > > > > > > On Sun, Jun 23, 2024 at 02:32:02PM -0600, Simon Glass wrote: > > > > > > > > > > > In Labgrid there is the concept of a 'role', which is similar to the > > > > > > U-Boot board ID in U-Boot's pytest subsystem. > > > > > > > > > > > > The role indicates both the target and information about the U-Boot > > > > > > build to use. It can also provide any amount of other configuration. > > > > > > The information is obtained using the 'labgrid-client query' operation. > > > > > > > > > > > > Make use of this in tests, so that only the role is required in gitlab > > > > > > and other situations. The board type and other things can be queried > > > > > > as needed. > > > > > > > > > > > > Use a new 'u-boot-test-getrole' script to obtain the requested > > > > > > information. > > > > > > > > > > > > With this it is possible to run lab tests in gitlab with just a single > > > > > > 'ROLE' variable for each board. > > > > > > > > > > > > Signed-off-by: Simon Glass sjg@chromium.org > > > > > > --- > > > > > > > > > > > > (no changes since v1) > > > > > > > > > > > > test/py/conftest.py | 31 +++++++++++++++++++++++++++---- > > > > > > 1 file changed, 27 insertions(+), 4 deletions(-) > > > > > > > > > > > > diff --git a/test/py/conftest.py b/test/py/conftest.py > > > > > > index 6547c6922c6..5de8d7b0e23 100644 > > > > > > --- a/test/py/conftest.py > > > > > > +++ b/test/py/conftest.py > > > > > > @@ -23,6 +23,7 @@ from pathlib import Path > > > > > > import pytest > > > > > > import re > > > > > > from _pytest.runner import runtestprotocol > > > > > > +import subprocess > > > > > > import sys > > > > > > > > > > > > # Globals: The HTML log file, and the connection to the U-Boot console. > > > > > > @@ -79,6 +80,7 @@ def pytest_addoption(parser): > > > > > > parser.addoption('--gdbserver', default=None, > > > > > > help='Run sandbox under gdbserver. The argument is the channel '+ > > > > > > 'over which gdbserver should communicate, e.g. localhost:1234') > > > > > > + parser.addoption('--role', help='U-Boot board role (for Labgrid)') > > > > > > parser.addoption('--no-prompt-wait', default=False, action='store_true', > > > > > > help="Assume that U-Boot is ready and don't wait for a prompt") > > > > > > > > > > > > @@ -130,12 +132,33 @@ def get_details(config): > > > > > > str: Build directory > > > > > > str: Source directory > > > > > > """ > > > > > > - board_type = config.getoption('board_type') > > > > > > - board_identity = config.getoption('board_identity') > > > > > > + role = config.getoption('role') > > > > > > build_dir = config.getoption('build_dir') > > > > > > + if role: > > > > > > + board_identity = role > > > > > > + cmd = ['u-boot-test-getrole', role, '--configure'] > > > > > > + env = os.environ.copy() > > > > > > + if build_dir: > > > > > > + env['U_BOOT_BUILD_DIR'] = build_dir > > > > > > + proc = subprocess.run(cmd, capture_output=True, encoding='utf-8', > > > > > > + env=env) > > > > > > + if proc.returncode: > > > > > > + raise ValueError(proc.stderr) > > > > > > + print('conftest: lab:', proc.stdout) > > > > > > + vals = {} > > > > > > + for line in proc.stdout.splitlines(): > > > > > > + item, value = line.split(' ', maxsplit=1) > > > > > > + k = item.split(':')[-1] > > > > > > + vals[k] = value > > > > > > + print('conftest: lab info:', vals) > > > > > > + board_type, default_build_dir, source_dir = (vals['board'], > > > > > > + vals['build_dir'], vals['source_dir']) > > > > > > + else: > > > > > > + board_type = config.getoption('board_type') > > > > > > + board_identity = config.getoption('board_identity') > > > > > > > > > > > > - source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > > > > - default_build_dir = source_dir + '/build-' + board_type > > > > > > + source_dir = os.path.dirname(os.path.dirname(TEST_PY_DIR)) > > > > > > + default_build_dir = source_dir + '/build-' + board_type > > > > > > if not build_dir: > > > > > > build_dir = default_build_dir > > > > > > > > > > I'm a little confused here. Why can't we construct "role" from > > > > > board_type+board_identity and then we have the board > > > > > conf.${board_type}_${board_identity} file set whatever needs setting to > > > > > be "labgrid" ? > > > > > > > > The role is equivalent to the board identity, not the combination of > > > > the U-Boot board type and the board identity. I went this way to avoid > > > > having to type long and complicated roles when connecting to boards. > > > > It is similar to how things work today, except that the board type is > > > > implied by the 'role'. > > > > > > > > For boards which have multiple identities (e.g. can support two > > > > different board types), Labgrid handles acquiring and releasing the > > > > shares resources, to avoid any problems. > > > > > > I guess I have two sets of questions. First, if it's basically the > > > board identity why can't we just use that as the role name, in your > > > setup? > > > > Yes, that's what I am doing. If you look in console.labgrid you can > > see that it is passing U_BOOT_BOARD_IDENTITY as the -r argument. > > Then why do we need this?
- All of the TI platforms that require an Cortex-R and Cortex-A builds.
OK I see. To support that with my integration I would need to provide a way to enable config options in the Labgrid environment. I suppose that is pretty easy.
We have an issue for config fragments [1] but I haven't looked at it, other than proposing a possible option.
[snip]
OK, I pushed it to [2]. There are no changes to the U-Boot side though.
-- Tom
[1] https://source.denx.de/u-boot/custodians/u-boot-dm/-/issues/9 [2] https://github.com/labgrid-project/labgrid/pull/1411
There is quite a bit of code to deal with receiving data from the target so move it into its own receive() function.
test/py/u_boot_spawn.py | 39 +++++++++++++++++++++++++++------------ 1 file changed, 27 insertions(+), 12 deletions(-)
diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index 81a09a9d639..cb0d8f702ba 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -139,6 +139,32 @@ class Spawn:
os.write(self.fd, data.encode(errors='replace'))
+ def receive(self, num_bytes): + """Receive data from the sub-process's stdin. + + Args: + num_bytes (int): Maximum number of bytes to read + + Returns: + str: The data received + + Raises: + ValueError if U-Boot died + """ + try: + c = os.read(self.fd, num_bytes).decode(errors='replace') + except OSError as err: + # With sandbox, try to detect when U-Boot exits when it + # shouldn't and explain why. This is much more friendly than + # just dying with an I/O error + if self.decode_signal and err.errno == 5: # I/O error + alive, _, info = self.checkalive() + if alive: + raise err + raise ValueError('U-Boot exited with %s' % info) + raise + return c + def expect(self, patterns): """Wait for the sub-process to emit specific data.
@@ -195,18 +221,7 @@ class Spawn: events = self.poll.poll(poll_maxwait) if not events: raise Timeout() - try: - c = os.read(self.fd, 1024).decode(errors='replace') - except OSError as err: - # With sandbox, try to detect when U-Boot exits when it - # shouldn't and explain why. This is much more friendly than - # just dying with an I/O error - if self.decode_signal and err.errno == 5: # I/O error - alive, _, info = self.checkalive() - if alive: - raise err - raise ValueError('U-Boot exited with %s' % info) - raise + c = self.receive(1024) if self.logfile_read: self.logfile_read.write(c) self.buf += c
The tests currently catch a very board Exception in each case. This is thrown even in the event of a coding error.
We want to handle exceptions differently depending on their severity, so that we can avoid hour-long delays waiting for a board that is clearly broken.
As a first step, create some new exception types, separating out those which are simply an unexpected result from executed a command, from those which indicate some kind of hardware failure.
test/py/u_boot_console_base.py | 26 ++++++++++++++------------ test/py/u_boot_spawn.py | 11 +++++++++++ 2 files changed, 25 insertions(+), 12 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index 8a9c4a576dc..fa87952694d 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -14,6 +14,7 @@ import pytest import re import sys import u_boot_spawn +from u_boot_spawn import BootFail, Timeout, Unexpected
# Regexes for text we expect U-Boot to send to the console. pattern_u_boot_spl_signon = re.compile('(U-Boot SPL \d{4}\.\d{2}[^\r\n]*\))') @@ -190,13 +191,13 @@ class ConsoleBase(object): m = self.p.expect([pattern_u_boot_spl_signon] + self.bad_patterns) if m != 0: - raise Exception('Bad pattern found on SPL console: ' + + raise BootFail('Bad pattern found on SPL console: ' + self.bad_pattern_ids[m - 1]) env_spl_banner_times -= 1
m = self.p.expect([pattern_u_boot_main_signon] + self.bad_patterns) if m != 0: - raise Exception('Bad pattern found on console: ' + + raise BootFail('Bad pattern found on console: ' + self.bad_pattern_ids[m - 1]) self.u_boot_version_string = self.p.after while True: @@ -207,13 +208,9 @@ class ConsoleBase(object): if m == 2: self.p.send(' ') continue - raise Exception('Bad pattern found on console: ' + + raise BootFail('Bad pattern found on console: ' + self.bad_pattern_ids[m - 3])
- except Exception as ex: - self.log.error(str(ex)) - self.cleanup_spawn() - raise finally: self.log.timestamp()
@@ -279,7 +276,7 @@ class ConsoleBase(object): m = self.p.expect([chunk] + self.bad_patterns) if m != 0: self.at_prompt = False - raise Exception('Bad pattern found on console: ' + + raise BootFail('Bad pattern found on console: ' + self.bad_pattern_ids[m - 1]) if not wait_for_prompt: return @@ -289,14 +286,18 @@ class ConsoleBase(object): m = self.p.expect([self.prompt_compiled] + self.bad_patterns) if m != 0: self.at_prompt = False - raise Exception('Bad pattern found on console: ' + + raise BootFail('Missing prompt on console: ' + self.bad_pattern_ids[m - 1]) self.at_prompt = True self.at_prompt_logevt = self.logstream.logfile.cur_evt # Only strip \r\n; space/TAB might be significant if testing # indentation. return self.p.before.strip('\r\n') - except Exception as ex: + except Timeout as exc: + self.log.error(str(exc)) + self.cleanup_spawn() + raise + except BootFail as ex: self.log.error(str(ex)) self.cleanup_spawn() raise @@ -355,8 +356,9 @@ class ConsoleBase(object): text = re.escape(text) m = self.p.expect([text] + self.bad_patterns) if m != 0: - raise Exception('Bad pattern found on console: ' + - self.bad_pattern_ids[m - 1]) + raise Unexpected( + "Unexpected pattern found on console (exp '{text}': " + + self.bad_pattern_ids[m - 1])
def drain_console(self): """Read from and log the U-Boot console for a short time. diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index cb0d8f702ba..57ea845ad4c 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -17,6 +17,17 @@ import traceback class Timeout(Exception): """An exception sub-class that indicates that a timeout occurred."""
+class BootFail(Exception): + """An exception sub-class that indicates that a boot failure occurred. + + This is used when a bad pattern is seen when waiting for the boot prompt. + It is regarded as fatal, to avoid trying to boot the again and again to no + avail. + """ + +class Unexpected(Exception): + """An exception sub-class that indicates that unexpected test was seen.""" + class Spawn: """Represents the stdio of a freshly created sub-process. Commands may be sent to the process, and responses waited for.
When the connection to a board dies, assume it is dead forever until some user action is taken. Skip all remaining tests. This avoids CI runs taking an hour, with hundreds of 30-second timeouts all to no avail.
test/py/conftest.py | 19 +++++++++++++++++-- test/py/u_boot_spawn.py | 38 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 55 insertions(+), 2 deletions(-)
diff --git a/test/py/conftest.py b/test/py/conftest.py index 5de8d7b0e23..42af1abd72e 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -25,6 +25,7 @@ import re from _pytest.runner import runtestprotocol import subprocess import sys +from u_boot_spawn import BootFail, Timeout, Unexpected, handle_exception
# Globals: The HTML log file, and the connection to the U-Boot console. log = None @@ -280,6 +281,7 @@ def pytest_configure(config): ubconfig.gdbserver = gdbserver ubconfig.no_prompt_wait = config.getoption('no_prompt_wait') ubconfig.dtb = build_dir + '/arch/sandbox/dts/test.dtb' + ubconfig.connection_ok = True
env_vars = ( 'board_type', @@ -446,8 +448,21 @@ def u_boot_console(request): Returns: The fixture value. """ - - console.ensure_spawned() + if not ubconfig.connection_ok: + pytest.skip('Cannot get target connection') + return None + try: + console.ensure_spawned() + except OSError as err: + handle_exception(ubconfig, console, log, err, 'Lab failure', True) + except Timeout as err: + handle_exception(ubconfig, console, log, err, 'Lab timeout', True) + except BootFail as err: + handle_exception(ubconfig, console, log, err, 'Boot fail', True, + console.get_spawn_output()) + except Unexpected: + handle_exception(ubconfig, console, log, err, 'Unexpected test output', + False) return console
anchors = {} diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index 57ea845ad4c..62eb4118731 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -8,6 +8,7 @@ Logic to spawn a sub-process and interact with its stdio. import os import re import pty +import pytest import signal import select import sys @@ -28,6 +29,43 @@ class BootFail(Exception): class Unexpected(Exception): """An exception sub-class that indicates that unexpected test was seen."""
+ +def handle_exception(ubconfig, console, log, err, name, fatal, output=''): + """Handle an exception from the console + + Exceptions can occur when there is unexpected output or due to the board + crashing or hanging. Some exceptions are likely fatal, where retrying will + just chew up time to no available. In those cases it is best to cause + further tests be skipped. + + Args: + ubconfig (ArbitraryAttributeContainer): ubconfig object + log (Logfile): Place to log errors + console (ConsoleBase): Console to clean up, if fatal + err (Exception): Exception which was thrown + name (str): Name of problem, to log + fatal (bool): True to abort all tests + output (str): Extra output to report on boot failure. This can show the + target's console output as it tried to boot + """ + msg = f'{name}: ' + if fatal: + msg += 'Marking connection bad - no other tests will run' + else: + msg += 'Assuming that lab is healthy' + print(msg) + log.error(msg) + log.error(f'Error: {err}') + + if output: + msg += f'; output {output}' + + if fatal: + ubconfig.connection_ok = False + console.cleanup_spawn() + pytest.exit(msg) + + class Spawn: """Represents the stdio of a freshly created sub-process. Commands may be sent to the process, and responses waited for.
Use the new handle_exception() function from ConsoleBase also.
test/py/u_boot_console_base.py | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index fa87952694d..9474fa87ec9 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -14,7 +14,7 @@ import pytest import re import sys import u_boot_spawn -from u_boot_spawn import BootFail, Timeout, Unexpected +from u_boot_spawn import BootFail, Timeout, Unexpected, handle_exception
# Regexes for text we expect U-Boot to send to the console. pattern_u_boot_spl_signon = re.compile('(U-Boot SPL \d{4}\.\d{2}[^\r\n]*\))') @@ -294,12 +294,12 @@ class ConsoleBase(object): # indentation. return self.p.before.strip('\r\n') except Timeout as exc: - self.log.error(str(exc)) - self.cleanup_spawn() + handle_exception(self.config, self, self.log, exc, 'Lab failure', + True) raise - except BootFail as ex: - self.log.error(str(ex)) - self.cleanup_spawn() + except BootFail as exc: + handle_exception(self.config, self, self.log, exc, 'Boot fail', + True, self.get_spawn_output()) raise finally: self.log.timestamp()
There is quite a bit of code in pytest to try to start up U-Boot on a board, with timeouts, expects, etc.
This is tedious to maintain and is peripheral to the test system's purpose. It seems better to put this logic in the lab itself, where is can provide such support.
With Labgrid we can use the UbootStrategy class to get the board into a useful state, however it needs to do it. Then it can report to pytest by writing a suitable string along with the U-Boot version it detected.
Add support for detecting 'lab mode' and simply assume that all is well in that case. Collect the version string when Labgrid says it is ready.
test/py/u_boot_console_base.py | 68 ++++++++++++++++++++++++++-------- 1 file changed, 53 insertions(+), 15 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index 9474fa87ec9..bcba68f0aac 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -23,13 +23,21 @@ pattern_stop_autoboot_prompt = re.compile('Hit any key to stop autoboot: ') pattern_unknown_command = re.compile('Unknown command '.*' - try 'help'') pattern_error_notification = re.compile('## Error: ') pattern_error_please_reset = re.compile('### ERROR ### Please RESET the board ###') -pattern_ready_prompt = re.compile('U-Boot is ready') +pattern_ready_prompt = re.compile('{lab ready in (.*)s: (.*)}') +pattern_lab_mode = re.compile('{lab mode.*}')
PAT_ID = 0 PAT_RE = 1
# Timeout before expecting the console to be ready (in milliseconds) -TIMEOUT_MS = 30000 +TIMEOUT_MS = 30000 # Standard timeout + +# Timeout for board preparation in lab mode. This needs to be enough to build +# U-Boot, write it to the board and then boot the board. Since this process is +# under the control of another program (e.g. Labgrid), it will failure sooner +# if something goes way. So use a very long timeout here to cover all possible +# situations. +TIMEOUT_PREPARE_MS = 3 * 60 * 1000
bad_pattern_defs = ( ('spl_signon', pattern_u_boot_spl_signon), @@ -143,6 +151,7 @@ class ConsoleBase(object):
self.at_prompt = False self.at_prompt_logevt = None + self.lab_mode = False
def get_spawn(self): # This is not called, ssubclass must define this. @@ -176,40 +185,69 @@ class ConsoleBase(object): self.p.close() self.logstream.close()
+ def set_lab_mode(self): + """Select lab mode + + This tells us that we will get a 'lab ready' message when the board is + ready for use. We don't need to look for signon messages. + """ + self.log.info(f'test.py: Lab mode is active') + self.p.timeout = TIMEOUT_PREPARE_MS + self.lab_mode = True + def wait_for_boot_prompt(self, loop_num = 1): """Wait for the boot up until command prompt. This is for internal use only. """ try: + self.log.info('Waiting for U-Boot to be ready') bcfg = self.config.buildconfig config_spl_serial = bcfg.get('config_spl_serial', 'n') == 'y' env_spl_skipped = self.config.env.get('env__spl_skipped', False) env_spl_banner_times = self.config.env.get('env__spl_banner_times', 1)
- while loop_num > 0: + while not self.lab_mode and loop_num > 0: loop_num -= 1 while config_spl_serial and not env_spl_skipped and env_spl_banner_times > 0: - m = self.p.expect([pattern_u_boot_spl_signon] + - self.bad_patterns) - if m != 0: + m = self.p.expect([pattern_u_boot_spl_signon, + pattern_lab_mode] + self.bad_patterns) + if m == 1: + self.set_lab_mode() + break + elif m != 0: raise BootFail('Bad pattern found on SPL console: ' + - self.bad_pattern_ids[m - 1]) + self.bad_pattern_ids[m - 1]) env_spl_banner_times -= 1
- m = self.p.expect([pattern_u_boot_main_signon] + self.bad_patterns) - if m != 0: - raise BootFail('Bad pattern found on console: ' + - self.bad_pattern_ids[m - 1]) - self.u_boot_version_string = self.p.after + if not self.lab_mode: + m = self.p.expect([pattern_u_boot_main_signon, + pattern_lab_mode] + self.bad_patterns) + if m == 1: + self.set_lab_mode() + elif m != 0: + raise BootFail('Bad pattern found on console: ' + + self.bad_pattern_ids[m - 1]) + if not self.lab_mode: + self.u_boot_version_string = self.p.after while True: m = self.p.expect([self.prompt_compiled, pattern_ready_prompt, pattern_stop_autoboot_prompt] + self.bad_patterns) - if m == 0 or m == 1: + if m == 0: + self.log.info(f'Found ready prompt {m}') + break + elif m == 1: + m = pattern_ready_prompt.search(self.p.after) + self.u_boot_version_string = m.group(2) + self.log.info(f'Lab: Board is ready') + self.p.timeout = TIMEOUT_MS break if m == 2: + self.log.info(f'Found autoboot prompt {m}') self.p.send(' ') continue - raise BootFail('Bad pattern found on console: ' + - self.bad_pattern_ids[m - 3]) + if not self.lab_mode: + raise BootFail('Missing prompt / ready message on console: ' + + self.bad_pattern_ids[m - 3]) + self.log.info(f'U-Boot is ready')
We expect commands to be echoed and this should happen quite quickly, since U-Boot is sitting at the prompt waiting for a command.
Reduce the timeout for this situation. Try to produce a more useful error message when something goes wrong. Also handle the case where the connection has gone away since the last command was issued.
test/py/u_boot_console_base.py | 35 ++++++++++++++++++++-------------- 1 file changed, 21 insertions(+), 14 deletions(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index bcba68f0aac..e2e78179555 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -31,6 +31,7 @@ PAT_RE = 1
# Timeout before expecting the console to be ready (in milliseconds) TIMEOUT_MS = 30000 # Standard timeout +TIMEOUT_CMD_MS = 10000 # Command-echo timeout
# Timeout for board preparation in lab mode. This needs to be enough to build # U-Boot, write it to the board and then boot the board. Since this process is @@ -300,22 +301,28 @@ class ConsoleBase(object):
try: self.at_prompt = False + if not self.p: + raise BootFail( + f"Lab failure: Connection lost when sending command '{cmd}'") + if send_nl: cmd += '\n' - while cmd: - # Limit max outstanding data, so UART FIFOs don't overflow - chunk = cmd[:self.max_fifo_fill] - cmd = cmd[self.max_fifo_fill:] - self.p.send(chunk) - if not wait_for_echo: - continue - chunk = re.escape(chunk) - chunk = chunk.replace('\\n', '[\r\n]') - m = self.p.expect([chunk] + self.bad_patterns) - if m != 0: - self.at_prompt = False - raise BootFail('Bad pattern found on console: ' + - self.bad_pattern_ids[m - 1]) + rem = cmd # Remaining to be sent + with self.temporary_timeout(TIMEOUT_CMD_MS): + while rem: + # Limit max outstanding data, so UART FIFOs don't overflow + chunk = rem[:self.max_fifo_fill] + rem = rem[self.max_fifo_fill:] + self.p.send(chunk) + if not wait_for_echo: + continue + chunk = re.escape(chunk) + chunk = chunk.replace('\\n', '[\r\n]') + m = self.p.expect([chunk] + self.bad_patterns) + if m != 0: + self.at_prompt = False + raise BootFail(f"Failed to get echo on console (cmd '{cmd}':rem '{rem}'): " + + self.bad_pattern_ids[m - 1]) if not wait_for_prompt: return if wait_for_reboot:
Fix a typo in a comment.
test/py/u_boot_console_base.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index e2e78179555..f610fa9a6f8 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -123,7 +123,7 @@ class ConsoleBase(object): Can only usefully be called by sub-classes.
Args: - log: A mulptiplex_log.Logfile object, to which the U-Boot output + log: A multiplexed_log.Logfile object, to which the U-Boot output will be logged. config: A configuration data structure, as built by conftest.py. max_fifo_fill: The maximum number of characters to send to U-Boot
There is a very annoying bug at present where the terminal echos part of the first command sent to the board. This happens because the terminal is still set to echo for a period until Labgrid starts up and can change this.
Fix this by disabling echo (and other terminal features) as soon as the spawn happens.
(no changes since v2)
Changes in v2: - Only disable echo if a terminal is detected
test/py/u_boot_spawn.py | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index 62eb4118731..c0ff0813554 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -12,6 +12,7 @@ import pytest import signal import select import sys +import termios import time import traceback
@@ -117,11 +118,23 @@ class Spawn: finally: os._exit(255)
+ old = None try: + if os.isatty(sys.stdout.fileno()): + new = termios.tcgetattr(self.fd) + old = new + new[3] = new[3] & ~(termios.ICANON | termios.ISIG) + new[3] = new[3] & ~termios.ECHO + new[6][termios.VMIN] = 0 + new[6][termios.VTIME] = 0 + termios.tcsetattr(self.fd, termios.TCSANOW, new) + self.poll = select.poll() self.poll.register(self.fd, select.POLLIN | select.POLLPRI | select.POLLERR | select.POLLHUP | select.POLLNVAL) except: + if old: + termios.tcsetattr(self.fd, termios.TCSANOW, old) self.close() raise
Send the Labgrid quit characters to ask it to exit gracefully. This typically allows it to power off the board being used.
If that doesn't work, try the less graceful approach.
test/py/u_boot_spawn.py | 17 +++++++++++++++-- 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/test/py/u_boot_spawn.py b/test/py/u_boot_spawn.py index c0ff0813554..ec1fa465047 100644 --- a/test/py/u_boot_spawn.py +++ b/test/py/u_boot_spawn.py @@ -16,6 +16,9 @@ import termios import time import traceback
+# Character to send (twice) to exit the terminal +EXIT_CHAR = 0x1d # FS (Ctrl + ]) + class Timeout(Exception): """An exception sub-class that indicates that a timeout occurred."""
@@ -304,15 +307,25 @@ class Spawn: None.
Returns: - Nothing. + str: Type of closure completed """ + self.send(chr(EXIT_CHAR) * 2)
+ # Wait about 10 seconds for Labgrid to close and power off the board + for _ in range(100): + if not self.isalive(): + return 'normal' + time.sleep(0.1) + + # That didn't work, so try closing the PTY os.close(self.fd) for _ in range(100): if not self.isalive(): - break + return 'break' time.sleep(0.1)
+ return 'timeout' + def get_expect_output(self): """Return the output read by expect()
This can take a while and involve multiple steps (e.g. turning the board back off). Add a section for it and show the output.
test/py/u_boot_console_base.py | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/test/py/u_boot_console_base.py b/test/py/u_boot_console_base.py index f610fa9a6f8..b279d95dea0 100644 --- a/test/py/u_boot_console_base.py +++ b/test/py/u_boot_console_base.py @@ -183,7 +183,10 @@ class ConsoleBase(object): """
if self.p: - self.p.close() + self.log.start_section('Stopping U-Boot') + close_type = self.p.close() + self.log.info(f'Close type: {close_type}') + self.log.end_section('Stopping U-Boot') self.logstream.close()
Add a way to run tests on a real hardware lab. This is in the very early experimental stages. There are only 23 boards and 3 of those are broken! (bob, ff3399, samus). A fourth fails due to problems with the TPM tests.
To try this, assuming you have gitlab access, set SJG_LAB=1, e.g.:
git push -o ci.variable="SJG_LAB=1" dm HEAD:try
This relies on the two previous series targeted at -next as well as the bugfix series for -master
Changes in v3: - Split out most patches into two new series and update cover letter
Changes in v2: - Avoid running a docker image for skipped lab tests
.gitlab-ci.yml | 153 +++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 153 insertions(+)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 165f765a833..75c18a0f2f7 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -17,6 +17,7 @@ stages: - testsuites - test.py - world build + - sjg-lab
.buildman_and_testpy_template: &buildman_and_testpy_dfn stage: test.py @@ -482,3 +483,155 @@ coreboot test.py: TEST_PY_TEST_SPEC: "not sleep" TEST_PY_ID: "--id qemu" <<: *buildman_and_testpy_dfn + +.lab_template: &lab_dfn + stage: sjg-lab + rules: + - if: $SJG_LAB == "1" + when: always + - when: manual + tags: [ 'lab' ] + script: + - if [[ -z "${SJG_LAB}" ]]; then + exit 0; + fi + # Environment: + # SRC - source tree + # OUT - output directory for builds + - export SRC="$(pwd)" + - export OUT="${SRC}/build/${BOARD}" + - export PATH=$PATH:~/bin + - export PATH=$PATH:/vid/software/devel/ubtest/u-boot-test-hooks/bin + + # Load it on the device + - ret=0 + - echo "role ${ROLE}" + - export strategy="-s uboot -e off" + # export verbose="-v" + - ${SRC}/test/py/test.py --role ${ROLE} --build-dir "${OUT}" + --capture=tee-sys -k "not bootstd"|| ret=$? + - U_BOOT_BOARD_IDENTITY="${ROLE}" u-boot-test-release || true + - if [[ $ret -ne 0 ]]; then + exit $ret; + fi + artifacts: + when: always + paths: + - "build/${BOARD}/test-log.html" + - "build/${BOARD}/multiplexed_log.css" + expire_in: 1 week + +rpi3: + variables: + ROLE: rpi3 + <<: *lab_dfn + +opi_pc: + variables: + ROLE: opi_pc + <<: *lab_dfn + +pcduino3_nano: + variables: + ROLE: pcduino3_nano + <<: *lab_dfn + +samus: + variables: + ROLE: samus + <<: *lab_dfn + +link: + variables: + ROLE: link + <<: *lab_dfn + +jerry: + variables: + ROLE: jerry + <<: *lab_dfn + +minnowmax: + variables: + ROLE: minnowmax + <<: *lab_dfn + +opi_pc2: + variables: + ROLE: opi_pc2 + <<: *lab_dfn + +bpi: + variables: + ROLE: bpi + <<: *lab_dfn + +rpi2: + variables: + ROLE: rpi2 + <<: *lab_dfn + +bob: + variables: + ROLE: bob + <<: *lab_dfn + +ff3399: + variables: + ROLE: ff3399 + <<: *lab_dfn + +coral: + variables: + ROLE: coral + <<: *lab_dfn + +rpi3z: + variables: + ROLE: rpi3z + <<: *lab_dfn + +bbb: + variables: + ROLE: bbb + <<: *lab_dfn + +kevin: + variables: + ROLE: kevin + <<: *lab_dfn + +pine64: + variables: + ROLE: pine64 + <<: *lab_dfn + +c4: + variables: + ROLE: c4 + <<: *lab_dfn + +rpi4: + variables: + ROLE: rpi4 + <<: *lab_dfn + +rpi0: + variables: + ROLE: rpi0 + <<: *lab_dfn + +snow: + variables: + ROLE: snow + <<: *lab_dfn + +pcduino3: + variables: + ROLE: pcduino3 + <<: *lab_dfn + +nyan-big: + variables: + ROLE: nyan-big + <<: *lab_dfn
Reviewed-by: Andrejs Cainikovs andrejs.cainikovs@toradex.com
Changes in v3:
Changes in v2:
- testsuites
- test.py
- world build
- sjg-lab
- stage: sjg-lab
- rules:
when: always
- when: manual
- tags: [ 'lab' ]
- script:
exit 0;
fi
- # Environment:
- # SRC - source tree
- # OUT - output directory for builds
- # Load it on the device
- ret=0
- # export verbose="-v"
exit $ret;
fi
- artifacts:
- when: always
- paths:
- expire_in: 1 week
+rpi3:
- variables:
- ROLE: rpi3
- <<: *lab_dfn
+opi_pc:
- variables:
- ROLE: opi_pc
- <<: *lab_dfn
+pcduino3_nano:
- variables:
- ROLE: pcduino3_nano
- <<: *lab_dfn
+samus:
- variables:
- ROLE: samus
- <<: *lab_dfn
+link:
- variables:
- ROLE: link
- <<: *lab_dfn
+jerry:
- variables:
- ROLE: jerry
- <<: *lab_dfn
+minnowmax:
- variables:
- ROLE: minnowmax
- <<: *lab_dfn
+opi_pc2:
- variables:
- ROLE: opi_pc2
- <<: *lab_dfn
+bpi:
- variables:
- ROLE: bpi
- <<: *lab_dfn
+rpi2:
- variables:
- ROLE: rpi2
- <<: *lab_dfn
+bob:
- variables:
- ROLE: bob
- <<: *lab_dfn
+ff3399:
- variables:
- ROLE: ff3399
- <<: *lab_dfn
+coral:
- variables:
- ROLE: coral
- <<: *lab_dfn
+rpi3z:
- variables:
- ROLE: rpi3z
- <<: *lab_dfn
+bbb:
- variables:
- ROLE: bbb
- <<: *lab_dfn
+kevin:
- variables:
- ROLE: kevin
- <<: *lab_dfn
+pine64:
- variables:
- ROLE: pine64
- <<: *lab_dfn
+c4:
- variables:
- ROLE: c4
- <<: *lab_dfn
+rpi4:
- variables:
- ROLE: rpi4
- <<: *lab_dfn
+rpi0:
- variables:
- ROLE: rpi0
- <<: *lab_dfn
+snow:
- variables:
- ROLE: snow
- <<: *lab_dfn
+pcduino3:
- variables:
- ROLE: pcduino3
- <<: *lab_dfn
+nyan-big:
- variables:
- ROLE: nyan-big
- <<: *lab_dfn
-- 2.34.1
Hi Simon
On Mon, Jun 24, 2024 at 2:52 PM Andrejs Cainikovs andrejs.cainikovs@toradex.com wrote:
Do you have documentation on how to set it? We would like to do in our company too
Michael
Changes in v3:
Changes in v2:
- testsuites
- test.py
- world build
- sjg-lab
- stage: sjg-lab
- rules:
when: always
- when: manual
- tags: [ 'lab' ]
- script:
exit 0;
fi
- # Environment:
- ret=0
exit $ret;
fi
- artifacts:
- when: always
- paths:
- expire_in: 1 week
+rpi3:
- variables:
- ROLE: rpi3
- <<: *lab_dfn
+opi_pc:
- variables:
- ROLE: opi_pc
- <<: *lab_dfn
+pcduino3_nano:
- variables:
- <<: *lab_dfn
+samus:
- variables:
- ROLE: samus
- <<: *lab_dfn
+link:
- variables:
- ROLE: link
- <<: *lab_dfn
+jerry:
- variables:
- ROLE: jerry
- <<: *lab_dfn
+minnowmax:
- variables:
- ROLE: minnowmax
- <<: *lab_dfn
+opi_pc2:
- variables:
- ROLE: opi_pc2
- <<: *lab_dfn
+bpi:
- variables:
- ROLE: bpi
- <<: *lab_dfn
+rpi2:
- variables:
- ROLE: rpi2
- <<: *lab_dfn
+bob:
- variables:
- ROLE: bob
- <<: *lab_dfn
+ff3399:
- variables:
- ROLE: ff3399
- <<: *lab_dfn
+coral:
- variables:
- ROLE: coral
- <<: *lab_dfn
+rpi3z:
- variables:
- ROLE: rpi3z
- <<: *lab_dfn
+bbb:
- variables:
- ROLE: bbb
- <<: *lab_dfn
+kevin:
- variables:
- ROLE: kevin
- <<: *lab_dfn
+pine64:
- variables:
- ROLE: pine64
- <<: *lab_dfn
+c4:
- variables:
- ROLE: c4
- <<: *lab_dfn
+rpi4:
- variables:
- ROLE: rpi4
- <<: *lab_dfn
+rpi0:
- variables:
- ROLE: rpi0
- <<: *lab_dfn
+snow:
- variables:
- ROLE: snow
- <<: *lab_dfn
+pcduino3:
- variables:
- ROLE: pcduino3
- <<: *lab_dfn
+nyan-big:
- variables:
- ROLE: nyan-big
- <<: *lab_dfn
-- 2.34.1
On Mon, Jun 24, 2024 at 04:56:02PM +0200, Michael Nazzareno Trimarchi wrote:
Hi Simon
I _think_ from some talking with Simon before the biggest sticking point might be changes needed on the labgrid side of things. However, that might also be most easily remedied if there's a few people showing up in the GitHub issue(s) showing interest in getting changes made/merged and to use the overall feature.
Hi Simon
The documentation is in the PR [1] mostly in the last commit [2].
Yes it would really help for you to try it out and comment on the PR. I may end up splitting it into a few separate PRs, but code review on the project is very limited, from what I have seen so far. You will see an example of my lab (devices and environment file).
I also have a few minor updates to the PR which I just uploaded, to work on top of the grpc branch and to support QEMU.
[1] https://github.com/labgrid-project/labgrid/pull/1411 [2] https://github.com/labgrid-project/labgrid/pull/1411/commits/c4b13af0e616922...
Hi Tom,
Hi Simon
Just to mention that I updated the Labgrid integration to support beagleplay (which as you know combines the U-Boot builds for two boards). It resulted in no changes at all to this series.
So perhaps this series can be reviewed and some of it applied?
Documentation is below.
Andrejs Cainikovs
