[PATCH] ARM: stm32: Set stdio to serial on DH STM32MP15xx DHSOM
In case CONSOLE_MUX and SYS_CONSOLE_IS_IN_ENV are enabled, the console stdin, stdout, stderr must be defined in environment. Define the default settings to fix the following warning on boot:
" In: No input devices available! Out: No output devices available! Err: No error devices available! "
Sort the default environment as well.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: u-boot@dh-electronics.com Cc: uboot-stm32@st-md-mailman.stormreply.com --- include/configs/stm32mp15_dh_dhsom.h | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/include/configs/stm32mp15_dh_dhsom.h b/include/configs/stm32mp15_dh_dhsom.h index 8ff882264f4..de39b19219d 100644 --- a/include/configs/stm32mp15_dh_dhsom.h +++ b/include/configs/stm32mp15_dh_dhsom.h @@ -12,14 +12,13 @@ #define PHY_ANEG_TIMEOUT 20000
#ifdef CONFIG_SPL_BUILD -#define CFG_EXTRA_ENV_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ "dfu_alt_info_ram=u-boot.itb ram " \ __stringify(CONFIG_SPL_LOAD_FIT_ADDRESS) \ " 0x800000\0" #endif
-#define STM32MP_BOARD_EXTRA_ENV \ - "usb_pgood_delay=1000\0" \ +#define STM32MP_BOARD_EXTRA_ENV \ "dh_update_sd_to_emmc=" /* Install U-Boot from SD to eMMC */ \ "setexpr loadaddr1 ${loadaddr} + 0x1000000 && " \ "load mmc 0:4 ${loadaddr1} boot/u-boot-spl.stm32 && " \ @@ -49,7 +48,11 @@ "sf update ${loadaddr1} 0x40000 ${filesize1} && " \ "sf update ${loadaddr} 0x80000 ${filesize} && " \ "env set filesize1 && env set loadaddr1\0" \ - "update_sf=run dh_update_sd_to_sf\0" + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" \ + "update_sf=run dh_update_sd_to_sf\0" \ + "usb_pgood_delay=1000\0"
#include <configs/stm32mp15_common.h>
Hi Marek
- "stdin=serial\0" \
- "stdout=serial\0" \
- "stderr=serial\0" \
- "update_sf=run dh_update_sd_to_sf\0" \
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
On 1/16/24 08:19, Patrice CHOTARD wrote:
Hi Marek
Thanks Patrice
Applied to u-boot-stm32/master
Thanks Patrice
Patrice CHOTARD
