[U-Boot-Users] [PATCH 0/1] ARM: remove useless function board_post_init
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/board/ixdp425/ixdp425.c b/board/ixdp425/ixdp425.c index 2a33d6d..e0d7637 100644 --- a/board/ixdp425/ixdp425.c +++ b/board/ixdp425/ixdp425.c @@ -38,11 +38,6 @@ DECLARE_GLOBAL_DATA_PTR; /* * Miscelaneous platform dependent initialisations */ -int board_post_init (void) -{ - return (0); -} - int board_init (void) { /* arch number of IXDP */ diff --git a/board/prodrive/pdnb3/pdnb3.c b/board/prodrive/pdnb3/pdnb3.c index a1a310a..3445a3a 100644 --- a/board/prodrive/pdnb3/pdnb3.c +++ b/board/prodrive/pdnb3/pdnb3.c @@ -48,11 +48,6 @@ static unsigned long old_val = 0; /* * Miscelaneous platform dependent initialisations */ -int board_post_init(void) -{ - return (0); -} - int board_init(void) { /* arch number of PDNB3 */ diff --git a/board/xm250/xm250.c b/board/xm250/xm250.c index 528d323..56b1cd4 100644 --- a/board/xm250/xm250.c +++ b/board/xm250/xm250.c @@ -52,14 +52,6 @@ sleep (int i)
int /**********************************************************/ -board_post_init (void) -/**********************************************************/ -{ - return (0); -} - -int -/**********************************************************/ board_init (void) /**********************************************************/ {
missing migration from "Cleanup of some init functions" in c837dcb1a316745092567bfe4fb266d0941884ff
diff --git a/board/xsengine/xsengine.c b/board/xsengine/xsengine.c index 23d56c4..65923e9 100644 --- a/board/xsengine/xsengine.c +++ b/board/xsengine/xsengine.c @@ -47,7 +47,7 @@ int board_init (void) return 0; }
-int board_post_init (void) +int board_late_init (void) { setenv ("stdout", "serial"); setenv ("stderr", "serial"); diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index 766617e..d167e01 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -33,7 +33,7 @@ #define CONFIG_XSENGINE 1 #define CONFIG_MMC 1 #define CONFIG_DOS_PARTITION 1 -#define BOARD_POST_INIT 1 +#define OARD_LATE_INIT 1 #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CFG_HZ 3686400 /* incrementer freq: 3.6864 MHz */
On Mon, Jan 14, 2008 at 10:38:55PM +0100, Jean-Christophe PLAGNIOL-VILLARD wrote:
A typo here ^ ?
Best regards, ladis
-int board_post_init (void) +int board_late_init (void) { setenv ("stdout", "serial"); setenv ("stderr", "serial"); diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index 766617e..635ec8b 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -33,7 +33,7 @@ #define CONFIG_XSENGINE 1 #define CONFIG_MMC 1 #define CONFIG_DOS_PARTITION 1 -#define BOARD_POST_INIT 1 +#define BOARD_LATE_INIT 1 #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CFG_HZ 3686400 /* incrementer freq: 3.6864 MHz */
In message 1200346735-23062-2-git-send-email-plagnioj@jcrosoft.com you wrote:
Applied. Thanks.
Dear Wolfgang,
Applied. Thanks.
It seems you applied wrong version of patch (with typo). Correct one was posted by Jean at 15 Jan 2008 00:06:36 +0100 Message-Id: 1200351996-25634-1-git-send-email-plagnioj@jcrosoft.com
diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index d167e01..635ec8b 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -33,7 +33,7 @@ #define CONFIG_XSENGINE 1 #define CONFIG_MMC 1 #define CONFIG_DOS_PARTITION 1 -#define OARD_LATE_INIT 1 +#define BOARD_LATE_INIT 1 #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CFG_HZ 3686400 /* incrementer freq: 3.6864 MHz */
Best regards, ladis
diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index d167e01..4d1bdd7 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -33,7 +33,7 @@ #define CONFIG_XSENGINE 1 #define CONFIG_MMC 1 #define CONFIG_DOS_PARTITION 1 -#define OARD_LATE_INIT 1 +#define BOARD_LATE_INIT 1 #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CFG_HZ 3686400 /* incrementer freq: 3.6864 MHz */
@@ -86,8 +86,8 @@ #define CFG_ENV_SIZE 0x4000 /* 16kB Total Size of Environment Sector */
/* timeout values are in ticks */ -#define CFG_FLASH_ERASE_TOUT (75*CFG_HZ) /* Timeout for Flash Erase */ -#define CFG_FLASH_WRITE_TOUT (50*CFG_HZ) /* Timeout for Flash Write */ +#define CFG_FLASH_ERASE_TOUT (75*CFG_HZ) /* Timeout for Flash Erase */ +#define CFG_FLASH_WRITE_TOUT (50*CFG_HZ) /* Timeout for Flash Write */
/* Size of malloc() pool */ #define CFG_MALLOC_LEN (CFG_ENV_SIZE + 256*1024) @@ -96,7 +96,7 @@ /* Hardware drivers */ #define CONFIG_DRIVER_SMC91111 #define CONFIG_SMC91111_BASE 0x04000300 -#define CONFIG_SMC_USE_32_BIT 1 +#define CONFIG_SMC_USE_32_BIT 1
/* select serial console configuration */ #define CONFIG_FFUART 1 @@ -138,15 +138,15 @@ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "XS-Engine u-boot> " /* Monitor Command Prompt */ #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ -#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ #define CFG_MEMTEST_START 0xA0400000 /* memtest works on */ #define CFG_MEMTEST_END 0xA0800000 /* 4 ... 8 MB in DRAM */ -#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ +#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } /* valid baudrates */ #define CFG_MMC_BASE 0xF0000000 -#define CFG_LOAD_ADDR 0xA0000000 /* load kernel to this address */ +#define CFG_LOAD_ADDR 0xA0000000 /* load kernel to this address */
/* Stack sizes - The stack sizes are set up in start.S using the settings below */ #define CONFIG_STACKSIZE (128*1024) /* regular stack */ @@ -168,7 +168,7 @@ /* GP direction register */ #define CFG_GPDR0_VAL 0x0000A000 /* CS1, PROG(FPGA) */ #define CFG_GPDR1_VAL 0x00022A80 /* nPWE, FFUART + BTUART pins */ -#define CFG_GPDR2_VAL 0x0000C000 /* CS2, CS3 */ +#define CFG_GPDR2_VAL 0x0000C000 /* CS2, CS3 */
/* GP rising edge detect register */ #define CFG_GRER0_VAL 0x00000000 @@ -185,7 +185,7 @@ #define CFG_GAFR0_U_VAL 0x00000010 /* RDY */ #define CFG_GAFR1_L_VAL 0x09988050 /* FFUART + BTUART pins */ #define CFG_GAFR1_U_VAL 0x00000008 /* nPWE */ -#define CFG_GAFR2_L_VAL 0xA0000000 /* CS2, CS3 */ +#define CFG_GAFR2_L_VAL 0xA0000000 /* CS2, CS3 */ #define CFG_GAFR2_U_VAL 0x00000000
#define CFG_PSSR_VAL 0x00000020 /* Power manager sleep status */
In message 1202659520-26861-1-git-send-email-plagnioj@jcrosoft.com you wrote:
Applied, thanks.
Ladislav Michl
