[PATCH] arm: Enable cache-pl310 driver build for both SPL and proper U-Boot
Moved CONFIG_SYS_L2_PL310 to the location where the build on the cache-pl310 can be taken in both SPL and proper U-Boot. This driver is required for SoCFPGA when temporarily turning on the cache for better performance in initializing whole DDR to zero.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- arch/arm/lib/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index c603fe61bc..575042e6df 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -43,6 +43,7 @@ ifdef CONFIG_ARM64 obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset-arm64.o obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy-arm64.o else +obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset.o obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o endif
Jit Loon Lim
