[U-Boot] [PATCH 3/3] Create configuration file for da850 EVM
Provides initial support for TI OMAP-L138/DA850 SoC devices on a Logic PD EVM board.
Signed-off-by: Sudhakar Rajashekhara sudhakar.raj@ti.com --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 5 ++ include/configs/da850evm.h | 142 ++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 152 insertions(+), 0 deletions(-) create mode 100644 include/configs/da850evm.h
diff --git a/MAINTAINERS b/MAINTAINERS index 8a61f5b..03d2ede 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -722,6 +722,10 @@ Nick Thompson nick.thompson@gefanuc.com
da830evm ARM926EJS (DA830/OMAP-L137)
+Sudhakar Rajashekhara sudhakar.raj@ti.com + + da850evm ARM926EJS (DA850/OMAP-L138) + Albin Tonnerre albin.tonnerre@free-electrons.com
sbc35_a9g20 ARM926EJS (AT91SAM9G20 SoC) diff --git a/MAKEALL b/MAKEALL index 6ee5c49..74bb85e 100755 --- a/MAKEALL +++ b/MAKEALL @@ -551,6 +551,7 @@ LIST_ARM9=" \ cp946es \ cp966 \ da830evm \ + da850evm \ imx27lite \ lpd7a400 \ mv88f6281gtw_ge \ diff --git a/Makefile b/Makefile index 769bf22..674dd1b 100644 --- a/Makefile +++ b/Makefile @@ -2933,6 +2933,11 @@ cp922_XA10_config \ cp1026_config: unconfig @board/armltd/integrator/split_by_variant.sh cp $@
+da850evm_config: unconfig + @mkdir -p $(obj)include + echo "#define CONFIG_DA850_EVM" >> $(obj)include/config.h + @$(MKCONFIG) -a $(@:_config=) arm arm926ejs da8xxevm davinci davinci + da830evm_config: unconfig @mkdir -p $(obj)include echo "#define CONFIG_DA830_EVM" >> $(obj)include/config.h diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h new file mode 100644 index 0000000..f50ecc5 --- /dev/null +++ b/include/configs/da850evm.h @@ -0,0 +1,142 @@ +/* + * Copyright (C) 2009 Texas Instruments, Inc <www.ti.com> + * + * Based on davinci_dvevm.h. Original Copyrights follow: + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Board + */ + +/* + * SoC Configuration + */ +#define CONFIG_MACH_DAVINCI_DA850_EVM +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) +#define CONFIG_SYS_OSCIN_FREQ 24000000 +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT /* to a proper address, init done */ + +/* + * Memory Info + */ +#define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ +#define PHYS_SDRAM_1_SIZE (64 << 20) /* SDRAM size 64MB */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 /* memtest start addr */ +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) /* 16MB test */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ + +/* + * Serial Driver info + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * I2C Configuration + */ +#define CONFIG_HARD_I2C +#define CONFIG_DRIVER_DAVINCI_I2C +#define CONFIG_SYS_I2C_SPEED 25000 +#define CONFIG_SYS_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */ + +/* + * U-Boot general configuration + */ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#undef CONFIG_MISC_INIT_R +#undef CONFIG_BOOTDELAY +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "DA850-evm > " /* Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_MEMTEST_START + 0x700000) +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE /* Won't work with hush so far, may be later */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* + * Linux Information + */ +#define LINUX_BOOT_PARAM_ADDR (CONFIG_SYS_MEMTEST_START + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS "mem=32M console=ttyS2,115200n8 root=/dev/mtdblock/2 rw noinitrd ip=dhcp" +#define CONFIG_BOOTCOMMAND "" +#define CONFIG_BOOTDELAY 3 + +/* + * U-Boot commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR + +#ifndef CONFIG_DRIVER_TI_EMAC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PING +#endif + +#if !defined(CONFIG_USE_NAND) && \ + !defined(CONFIG_USE_NOR) && \ + !defined(CONFIG_USE_SPIFLASH) +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_SIZE (16 << 10) +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_ENV +#endif + +#endif /* __CONFIG_H */
Dear Sudhakar Rajashekhara,
- @mkdir -p $(obj)include
- echo "#define CONFIG_DA850_EVM" >> $(obj)include/config.h
Please do not add such scripting to the top level Makefile; it is not needed any more.
- U-Boot general configuration
Don't undef what is not defined.
Why does this not work?
- Linux Information
Line too long!
What do you intend here? If you don't need a boot command, then don't define one. Defining an empty one makes no sense.
Don't undef what is not defined. [Fix globally.]
Why would you undefine this command? "imls" is a pretty useful command, and does not require a substantioal amount of memory?
Wolfgang Denk <wd <at> denx.de> writes:
OK. I'll remove it.
OK. Will fix it globally.
Line too long!
I'll correct it.
I'll remove it.
I'll enable support for "imls" once I add in support for SPI/NAND/NOR flashes.
Regards, Sudhakar
