[PATCH 1/3] kconfig: mark SPL/TPL options for DM_KEYBOARD
All three options had the same description.
Signed-off-by: Marcin Juszkiewicz marcin@juszkiewicz.com.pl --- drivers/input/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git drivers/input/Kconfig drivers/input/Kconfig index a3bdd9fa34..a17e55e997 100644 --- drivers/input/Kconfig +++ drivers/input/Kconfig @@ -21,7 +21,7 @@ config DM_KEYBOARD input and update LEDs if the keyboard has them.
config SPL_DM_KEYBOARD - bool "Enable driver model keyboard support" + bool "Enable driver model keyboard support for SPL" depends on SPL_DM help This adds a uclass for keyboards and implements keyboard support @@ -30,7 +30,7 @@ config SPL_DM_KEYBOARD input and update LEDs if the keyboard has them.
config TPL_DM_KEYBOARD - bool "Enable driver model keyboard support" + bool "Enable driver model keyboard support for TPL" depends on TPL_DM help This adds a uclass for keyboards and implements keyboard support
Signed-off-by: Marcin Juszkiewicz marcin@juszkiewicz.com.pl --- lib/Kconfig | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git lib/Kconfig lib/Kconfig index f18bf3778b..af5c38afd9 100644 --- lib/Kconfig +++ lib/Kconfig @@ -162,7 +162,7 @@ config LIB_RAND bool "Pseudo-random library support"
config LIB_HW_RAND - bool "HW Engine for random libray support" + bool "HW Engine for random library support"
endchoice
@@ -448,7 +448,7 @@ config ZSTD config SPL_LZ4 bool "Enable LZ4 decompression support in SPL" help - This enables support for tge LZ4 decompression algorithm in SPL. LZ4 + This enables support for the LZ4 decompression algorithm in SPL. LZ4 is a lossless data compression algorithm that is focused on fast compression and decompression speed. It belongs to the LZ77 family of byte-oriented compression schemes. @@ -456,7 +456,7 @@ config SPL_LZ4 config SPL_LZMA bool "Enable LZMA decompression support for SPL build" help - This enables support for LZMA compression altorithm for SPL boot. + This enables support for LZMA compression algorithm for SPL boot.
config SPL_LZO bool "Enable LZO decompression support in SPL"
Description said that OHCI is not supported for driver model while it was converted too.
Signed-off-by: Marcin Juszkiewicz marcin@juszkiewicz.com.pl --- drivers/usb/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git drivers/usb/Kconfig drivers/usb/Kconfig index 928a89133c..756a4ec402 100644 --- drivers/usb/Kconfig +++ drivers/usb/Kconfig @@ -39,8 +39,8 @@ config DM_USB help Enable driver model for USB. The USB interface is then implemented by the USB uclass. Multiple USB controllers of different types - (XHCI, EHCI) can be attached and used. The 'usb' command works as - normal. OCHI is not supported at present. + (XHCI, EHCI, OHCI) can be attached and used. The 'usb' command works + as normal.
Much of the code is shared but with this option enabled the USB uclass takes care of device enumeration. USB devices can be
Marcin Juszkiewicz
