[U-Boot] preloader_console_init()
Hi Aneesh,
I'am nearly done with OMAP3 - I think I can release the patch today.
I have just one problem left: You implemented preloader_console_init() in omap-common to call setup_clocks_for_console(). This is a OMAP4 specific call - OMAP3 only has per_clocks_init() - which inits a bunch of clocks.
Can you change the preloader_console_init()-function that it requires that the UART already has a clock and move your setup_clocks_for_console() out of the function?
Regards & Thanks Simon
Hi Simon,
On Mon, Jul 25, 2011 at 8:36 PM, Simon Schwarz simonschwarzcor@googlemail.com wrote:
Hi Aneesh,
Sorry. I was on a short travel and didn't have mail access for a couple of days.
The idea was to enable the console at the earliest, even before prcm_init(). If OMAP3 doesn't need this I would suggest moving setup_clocks_for_console() call to s_init() in omap4/board.c
BTW, how did you fix this in your patches fianlly?
br, Aneesh
Hi Aneesh,
On 07/27/2011 04:39 PM, V, Aneesh wrote:
Hi Simon,
Hi Aneesh,
No problem, hope it was great!
So I think it is best to move it to s_init like you said.
For now I don't plan to add this to OMAP3. If we move it to s_init the dev can decide to do early clock init or not.
#ifndef CONFIG_OMAP34XX setup_clocks_for_console(); #endif
To be able to post the patch.
br, Aneesh
Regards Simon
Simon Schwarz
V, Aneesh
