[U-Boot] [PATCH v1] rockchip: utilize CONFIG_DEFAULT_FDT_FILE
Currently the fdtfile environment variable is set to CONFIG_DEFAULT_DEVICE_TREE which is іnternally used as U-Boot devicetree source. The OS can use a different filename and Kconfig gives us the ability to select a default devicetree via CONFIG_DEFAULT_FDT_FILE. This also gives user configuring U-Boot via menuconfig the behaviour someone would expect.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com
configs/chromebit_mickey_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/evb-rk3036_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3229_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/geekbox_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/lion-rk3368_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/rock2_defconfig | 1 + configs/rock_defconfig | 1 + configs/sheep-rk3368_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + configs/vyasa-rk3288_defconfig | 1 + include/configs/rk3036_common.h | 1 + include/configs/rk3128_common.h | 1 + include/configs/rk3188_common.h | 1 + include/configs/rk322x_common.h | 1 + include/configs/rk3288_common.h | 2 +- include/configs/rk3328_common.h | 1 + include/configs/rk3368_common.h | 1 + include/configs/rk3399_common.h | 2 +- 34 files changed, 34 insertions(+), 2 deletions(-)
diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index d1728ef639..27b0dcaac4 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-mickey" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-mickey.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 43d93f4637..95fe4bcb26 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-jerry" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-jerry.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 706809ca53..bc3bb292c8 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-veyron-minnie" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-veyron-minnie.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index c03682c927..a75c3e047f 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -7,6 +7,7 @@ CONFIG_TARGET_EVB_PX5=y CONFIG_DEFAULT_DEVICE_TREE="rk3368-px5-evb" CONFIG_DEBUG_UART=y CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-px5-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 33775e8cdd..840c731032 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -11,6 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_DEBUG_UART=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x0 # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_DEFAULT_FDT_FILE="rk3036-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index 796d0ec92e..f4b132faf7 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3128=y CONFIG_DEFAULT_DEVICE_TREE="rk3128-evb" CONFIG_DEBUG_UART=y CONFIG_FIT=y +CONFIG_DEFAULT_FDT_FILE="rk3128-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_FASTBOOT_BUF_ADDR=0x60800800 diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 710b0b4e1a..f6cb5fd897 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_EVB_RK3229=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3229-evb" CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rk3229-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 7695277daf..3d8789cf36 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-evb-rk808.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 78ae24b56b..715ac827e2 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3328-evb" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_FASTBOOT_BUF_ADDR=0x800800 diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 05ad0da336..032aef0cac 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index d72f0d42e8..03ad19e425 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_EVB_RV1108=y CONFIG_DEFAULT_DEVICE_TREE="rv1108-evb" CONFIG_DEBUG_UART=y # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_DEFAULT_FDT_FILE="rv1108-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_FASTBOOT_BUF_ADDR=0x62000000 diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index efdd583cf6..bad5c49dd7 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y +CONFIG_DEFAULT_FDT_FILE="rk3288-fennec.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index b252d27464..1c83513647 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 19c0b11040..661d6e96eb 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/geekbox_defconfig b/configs/geekbox_defconfig index 4644e8dca5..6c2153a6f2 100644 --- a/configs/geekbox_defconfig +++ b/configs/geekbox_defconfig @@ -6,6 +6,7 @@ CONFIG_ROCKCHIP_RK3368=y CONFIG_TARGET_GEEKBOX=y CONFIG_DEFAULT_DEVICE_TREE="rk3368-geekbox" CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-geekbox.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_REGMAP=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index ca53005ecb..59c699c3bc 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_SYS_MALLOC_F_LEN=0x0 # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_DEFAULT_FDT_FILE="rk3036-kylin.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_FRAMEWORK is not set diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index 0a5e5b3df3..2ba29cbbcb 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -25,6 +25,7 @@ CONFIG_BOOTSTAGE=y CONFIG_SPL_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_BOOTSTAGE_FDT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-lion-haikou.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index f44537c88f..bbd7c28d9f 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-miqi" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-miqi.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index d78b6d57b6..663c70f82c 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y +CONFIG_DEFAULT_FDT_FILE="rk3288-phycore-rdk.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 2670b4b75a..495bcbb983 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y +CONFIG_DEFAULT_FDT_FILE="rk3288-popmetal.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index e6539a7da8..e5753b4f20 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -16,6 +16,7 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_SOURCE="board/theobroma-systems/puma_rk3399/fit_spl_atf.its" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_BOARD_INIT=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index cd9a821974..41934ddfeb 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-rock2-square.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 00ce9c465a..06287eee97 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_ROCK=y CONFIG_SPL_STACK_R_ADDR=0x60080000 CONFIG_DEFAULT_DEVICE_TREE="rk3188-radxarock" CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rk3188-radxarock.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index 8ada6823d0..6a2aff38a0 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -7,6 +7,7 @@ CONFIG_TARGET_SHEEP=y CONFIG_DEFAULT_DEVICE_TREE="rk3368-sheep" CONFIG_DEBUG_UART=y CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3368-sheep.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_CMD_MMC=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index fb6bfa57ad..43b53cbe1b 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -11,6 +11,7 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y +CONFIG_DEFAULT_FDT_FILE="rk3288-tinker.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index 9e4e96a4f2..6d7b127bcf 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-vyasa" CONFIG_DEBUG_UART=y CONFIG_SILENT_CONSOLE=y +CONFIG_DEFAULT_FDT_FILE="rk3288-vyasa.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 2009c2dd29..07c54b596b 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -56,6 +56,7 @@ /* Linux fails to load the fdt if it's loaded above 512M on a evb-rk3036 board, * so limit the fdt reallocation to that */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_high=0x7fffffff\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index cb07466088..94b0ae0d79 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -53,6 +53,7 @@ #include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ BOOTENV
diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index d4ffa041f8..1a0f28d2a7 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -61,6 +61,7 @@ /* Linux fails to load the fdt if it's loaded above 256M on a Rock board, * so limit the fdt reallocation to that */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_high=0x6fffffff\0" \ "initrd_high=0x6fffffff\0" \ "partitions=" PARTS_DEFAULT \ diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index 1bfcda6701..5b9c4082da 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -52,6 +52,7 @@ /* Linux fails to load the fdt if it's loaded above 512M on a evb-rk3036 board, * so limit the fdt reallocation to that */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_high=0x7fffffff\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index f8c793f154..71ae3c2316 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -69,7 +69,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0x0fffffff\0" \ "initrd_high=0x0fffffff\0" \ - "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ ROCKCHIP_DEVICE_SETTINGS \ diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 3bca0f8388..481044dc24 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -46,6 +46,7 @@ #include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ BOOTENV
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 0b07f8dc7a..0e77866b40 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -46,6 +46,7 @@ #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ ENV_MEM_LAYOUT_SETTINGS \ BOOTENV
diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index a61e74bc03..ee38107ea5 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -55,7 +55,7 @@ #include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ ENV_MEM_LAYOUT_SETTINGS \ - "fdtfile=rockchip/" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ BOOTENV
I did wonder, given that many of these boards the value for CONFIG_DEFAULT_DEVICE_TREE and CONFIG_DEFAULT_FDT_FILE is *nearly* identical, if it wouldn't make sense to derive CONFIG_DEFAULT_FDT_FILE From the value of CONFIG_DEFAULT_DEVICE_TREE by default, only overriding it in the unusual cases.
Though there is a lot to be said about being explicit and not mixing the two similar but not identical values.
Tested on puma-rk3399.
Tested-By: Vagrant Cascadian vagrant@debian.org
Was hoping to also test on firefly-rk3399, but having difficulty getting u-boot installed unreleated to this patch. Also having troubles with firefly-rk3288 due to mmc hanging the board: https://bugs.debian.org/898520.
live well, vagrant
configs/puma-rk3399_defconfig | 1 + include/configs/rk3399_common.h | 2 +-
- "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ BOOTENV
-- 2.11.0
Would love to to that, but couldn’t find a proper way to do it. CONFIG_DEFAULT_FDT_FILE is a Kconfig string and therefore always present in the .config. If not set by the user or a defconfig it’s just a empty string (“”). So we can’t do a #ifdef and we can’t do string compares with C macros. An option would be to have DEFAULT_FDT_FILE be hidden behind a Kconfig bool (i.e CONFIG_DEFAULT_FDT_FILE depends on CONFIG_FDT_FILE) But that change looked a bit to invasive for me.
live well, vagrant
-- 2.11.0
Finally was able to test on Firefly-RK3399 applied against u-boot 2018.07-rc2, and it also works correctly.
Are there any outstanding concerns with this patch?
live well, vagrant
There was a similar patch for sunxi[1] and there it was decided to introduce the Kconfig option we talked about. That would make this patch obsolete.
@Jagan, I think Martin is still waiting for an answer from you.
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Tested-By: Vagrant Cascadian vagrant@debian.org
Applied to u-boot-rockchip, thanks!
Klaus Goger
Philipp Tomsich
Vagrant Cascadian
