[U-Boot-Users] usb write command available in u-boot??
Hi all
In u-boot under common/cmd_usb.c there are commands for usb info , usb tree, usb reset,
I can find usb read command also
There is no command for usb write
Is there is possibility to do a usb write command (eg .. writing some data into the flash memory stick) in u-boot level??
Thanks
"mahendra varman" mahendravarman15@gmail.com writes:
In u-boot under common/cmd_usb.c there are commands for usb info , usb tree, usb reset, I can find usb read command also There is no command for usb write
That's right.
No, not with the current implementation, I'm afraid.
Best regards
Markus Klotzbuecher
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Since a bootloader loads things from boot devices as opposed writing things to boot devices, it makes sense that there would be no write command to boot devices.
Absolutely, but it is potentially dangerous to do.
Raw writes of disk images or individual filesystems may be a reasonable thing to do and should require only modest changes to support. Only a block write function would need to be added. This is especially useful if the device is soldered to the board and there is no other way to write the data to the device.
Does anyone have a soldered-on USB storage device?
Crazy data transfer idea:
For simple data transfer, it may be possible to allocate a file on a FAT16 filesystem that uses exactly one cluster and determine the block address of that cluster and instruct U-Boot to write only to that cluster. This would mean that a cluster could be written in raw mode via U-Boot and on another system read as a FAT16 file. The file length would always be a full cluster in size, so the file would need to be copied and truncated to the proper length on the host system. Again, on U-Boot this would require only the addition of a block write function.
Writing files to filesystems via U-Boot:
The filesystem support in U-Boot is designed to function in a read-only mode, but the code is probably based on a read/write Linux driver, so it may not be that difficult to change to support write functions. The filesystems would need to support file creation, data over-write and file append functions, at a minimum.
This would require more work than it would be worth, in my opinion. But a block write function would be useful for some (soldered on) devices, if not USB storage.
Sincerely,
Ken Fuchs
Ken.Fuchs@bench.com
mahendra varman
Markus Klotzbücher
