[U-Boot] [PATCH 1/2] post/post.c: CodingStyle cleanup
Make checkpatch-clean..
Signed-off-by: Wolfgang Denk wd@denx.de --- post/post.c | 59 +++++++++++++++++++++++++++-------------------------------- 1 files changed, 27 insertions(+), 32 deletions(-)
diff --git a/post/post.c b/post/post.c index dc9c0f2..ab8e959 100644 --- a/post/post.c +++ b/post/post.c @@ -48,9 +48,8 @@ int post_init_f(void) for (i = 0; i < post_list_size; i++) { struct post_test *test = post_list + i;
- if (test->init_f && test->init_f()) { + if (test->init_f && test->init_f()) res = -1; - } }
gd->post_init_f_time = post_time_ms(0); @@ -106,7 +105,7 @@ void post_bootmode_init(void) newword = BOOTMODE_MAGIC | POST_NORMAL; else /* Use old value */ - newword = post_word_load () & ~POST_COLDBOOT; + newword = post_word_load() & ~POST_COLDBOOT;
if (bootmode == 0) /* We are booting after power-on */ @@ -153,9 +152,9 @@ void post_output_backlog(void)
for (j = 0; j < post_list_size; j++) { if (gd->post_log_word & (post_list[j].testid)) { - post_log ("POST %s ", post_list[j].cmd); + post_log("POST %s ", post_list[j].cmd); if (gd->post_log_res & post_list[j].testid) - post_log ("PASSED\n"); + post_log("PASSED\n"); else { post_log("FAILED\n"); show_boot_progress(-31); @@ -199,12 +198,11 @@ static void post_get_env_flags(int *test_flags) int i, j;
for (i = 0; i < varnum; i++) { - if (getenv_f(var[i], list, sizeof (list)) <= 0) + if (getenv_f(var[i], list, sizeof(list)) <= 0) continue;
- for (j = 0; j < post_list_size; j++) { + for (j = 0; j < post_list_size; j++) test_flags[j] &= ~flag[i]; - }
last = 0; name = list; @@ -222,14 +220,14 @@ static void post_get_env_flags(int *test_flags) *s = 0;
for (j = 0; j < post_list_size; j++) { - if (strcmp (post_list[j].cmd, name) == 0) { + if (strcmp(post_list[j].cmd, name) == 0) { test_flags[j] |= flag[i]; break; } }
if (j == post_list_size) - printf ("No such test: %s\n", name); + printf("No such test: %s\n", name);
name = s + 1; } @@ -264,7 +262,7 @@ static int post_run_single(struct post_test *test, { if ((flags & test_flags & POST_ALWAYS) && (flags & test_flags & POST_MEM)) { - WATCHDOG_RESET (); + WATCHDOG_RESET();
if (!(flags & POST_REBOOT)) { if ((test_flags & POST_REBOOT) && @@ -283,11 +281,10 @@ static int post_run_single(struct post_test *test, show_post_progress(i, POST_BEFORE, POST_FAILED);
if (test_flags & POST_PREREL) { - if ((*test->test) (flags) == 0) { + if ((*test->test)(flags) == 0) { post_log_mark_succ(test->testid); show_post_progress(i, POST_AFTER, POST_PASSED); - } - else { + } else { show_post_progress(i, POST_AFTER, POST_FAILED); if (test_flags & POST_CRITICAL) gd->flags |= GD_FLG_POSTFAIL; @@ -309,9 +306,8 @@ static int post_run_single(struct post_test *test, } }
- if ((test_flags & POST_REBOOT) && !(flags & POST_MANUAL)) { + if ((test_flags & POST_REBOOT) && !(flags & POST_MANUAL)) post_bootmode_test_off(); - }
return 0; } else { @@ -319,7 +315,7 @@ static int post_run_single(struct post_test *test, } }
-int post_run (char *name, int flags) +int post_run(char *name, int flags) { unsigned int i; int test_flags[POST_MAX_NUMBER]; @@ -366,7 +362,7 @@ int post_run (char *name, int flags) return 0; } else { for (i = 0; i < post_list_size; i++) { - if (strcmp (post_list[i].cmd, name) == 0) + if (strcmp(post_list[i].cmd, name) == 0) break; }
@@ -396,7 +392,7 @@ static int post_info_single(struct post_test *test, int full) } }
-int post_info (char *name) +int post_info(char *name) { unsigned int i;
@@ -407,15 +403,14 @@ int post_info (char *name) return 0; } else { for (i = 0; i < post_list_size; i++) { - if (strcmp (post_list[i].cmd, name) == 0) + if (strcmp(post_list[i].cmd, name) == 0) break; }
- if (i < post_list_size) { + if (i < post_list_size) return post_info_single(post_list + i, 1); - } else { + else return -1; - } } }
@@ -425,13 +420,13 @@ int post_log(char *format, ...) uint i; char printbuffer[CONFIG_SYS_PBSIZE];
- va_start (args, format); + va_start(args, format);
/* For this to work, printbuffer must be larger than * anything we ever want to print. */ - i = vsprintf (printbuffer, format, args); - va_end (args); + i = vsprintf(printbuffer, format, args); + va_end(args);
#ifdef CONFIG_LOGBUFFER /* Send to the logbuffer */ @@ -457,32 +452,32 @@ void post_reloc(void) struct post_test *test = post_list + i;
if (test->name) { - addr = (ulong) (test->name) + gd->reloc_off; + addr = (ulong)(test->name) + gd->reloc_off; test->name = (char *)addr; }
if (test->cmd) { - addr = (ulong) (test->cmd) + gd->reloc_off; + addr = (ulong)(test->cmd) + gd->reloc_off; test->cmd = (char *)addr; }
if (test->desc) { - addr = (ulong) (test->desc) + gd->reloc_off; + addr = (ulong)(test->desc) + gd->reloc_off; test->desc = (char *)addr; }
if (test->test) { - addr = (ulong) (test->test) + gd->reloc_off; + addr = (ulong)(test->test) + gd->reloc_off; test->test = (int (*)(int flags)) addr; }
if (test->init_f) { - addr = (ulong) (test->init_f) + gd->reloc_off; + addr = (ulong)(test->init_f) + gd->reloc_off; test->init_f = (int (*)(void)) addr; }
if (test->reloc) { - addr = (ulong) (test->reloc) + gd->reloc_off; + addr = (ulong)(test->reloc) + gd->reloc_off; test->reloc = (void (*)(void)) addr;
test->reloc();
Fix: post.c: In function 'post_log': post.c:425:7: warning: variable 'i' set but not used [-Wunused-but-set-variable]
Signed-off-by: Wolfgang Denk wd@denx.de --- post/post.c | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/post/post.c b/post/post.c index ab8e959..0e67ad7 100644 --- a/post/post.c +++ b/post/post.c @@ -417,7 +417,6 @@ int post_info(char *name) int post_log(char *format, ...) { va_list args; - uint i; char printbuffer[CONFIG_SYS_PBSIZE];
va_start(args, format); @@ -425,7 +424,7 @@ int post_log(char *format, ...) /* For this to work, printbuffer must be larger than * anything we ever want to print. */ - i = vsprintf(printbuffer, format, args); + vsprintf(printbuffer, format, args); va_end(args);
Dear Wolfgang Denk,
Applied, thanks.
if (test->cmd) {
if (test->desc) {
if (test->test) {
if (test->init_f) {
if (test->reloc) {
The cast here doesn't seem right maybe ? :-(
Cheers
Dear Marek Vasut,
if (test->cmd) {
if (test->desc) {
if (test->test) {
if (test->init_f) {
if (test->reloc) {
Why not?
BTW: this is only a CodingStyle cleanup without any changes of the logic.
Dear Marek Vasut,
post/post.c | 59
if (test->cmd) {
if (test->desc) {
if (test->test) {
if (test->init_f) {
if (test->reloc) {
Why not?
Ok! Add my:
Acked-by: Marek Vasut marek.vasut@gmail.com
Dear Wolfgang Denk,
Applied, thanks.
