[U-Boot] [PATCH 1/4] snow: Expand U-Boot size
Now that we have EFI, etc. enabled, U-Boot is larger than it was. Expand the region allocated for it.
arch/arm/dts/exynos5250-snow.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts index 29c13c1257e..e99f6e72bf6 100644 --- a/arch/arm/dts/exynos5250-snow.dts +++ b/arch/arm/dts/exynos5250-snow.dts @@ -88,7 +88,7 @@
ro-boot { label = "u-boot"; - reg = <0x6000 0x9a000>; + reg = <0x6000 0xb0000>; read-only; type = "blob boot,dtb"; required;
This converts the following to Kconfig: CONFIG_BOARD_TYPES
arch/arm/mach-exynos/Kconfig | 8 ++++++++ configs/odroid-xu3_defconfig | 2 +- configs/odroid_defconfig | 2 +- include/configs/axs10x.h | 1 - include/configs/hsdk.h | 1 - include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 1 - scripts/config_whitelist.txt | 1 - 8 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index ed04369cfae..33323d17f4b 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -166,4 +166,12 @@ source "board/samsung/espresso7420/Kconfig" config SPL_LDSCRIPT default "board/samsung/common/exynos-uboot-spl.lds" if ARCH_EXYNOS5 || ARCH_EXYNOS4
+config BOARD_TYPES + bool "Call get_board_type() to get and display the board type" + help + If this option is enabled, checkboard() will call get_board_type() + to get a string containing the board type and this will be + displayed immediately after the model is shown on the console + early in boot. + endif diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index d5c7cc7129d..f6f05b29483 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_ARCH_EXYNOS5=y +CONFIG_BOARD_TYPES=y CONFIG_IDENT_STRING=" for ODROID-XU3/XU4/HC1/HC2" CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=8 @@ -47,7 +48,6 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GADGET=y CONFIG_USB_DWC3_PHY_SAMSUNG=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 594800fc50c..184bb62c1c1 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_SYS_TEXT_BASE=0x43e00000 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ODROID=y +CONFIG_BOARD_TYPES=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=8 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set @@ -47,7 +48,6 @@ CONFIG_DM_REGULATOR_MAX77686=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 1b2966fd612..a1b9e7b21d9 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -34,7 +34,6 @@ /* * This board might be of different versions so handle it */ -#define CONFIG_BOARD_TYPES
/* * NAND Flash configuration diff --git a/include/configs/hsdk.h b/include/configs/hsdk.h index cdf4fddd940..b1af1271777 100644 --- a/include/configs/hsdk.h +++ b/include/configs/hsdk.h @@ -35,7 +35,6 @@ /* * This board might be of different versions so handle it */ -#define CONFIG_BOARD_TYPES
/* * UART configuration diff --git a/include/configs/odroid.h b/include/configs/odroid.h index ad77242e380..bc044e069e0 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -186,7 +186,6 @@ * TODO: Add Odroid X support */ #define CONFIG_MISC_COMMON -#define CONFIG_BOARD_TYPES
#undef CONFIG_REVISION_TAG
diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index f683ee46e39..c2363dd1eef 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -86,7 +86,6 @@ /* Set soc_rev, soc_id, board_rev, boardname, fdtfile */ #define CONFIG_ODROID_REV_AIN 9 #define CONFIG_REVISION_TAG -#define CONFIG_BOARD_TYPES
#undef CONFIG_SYS_BOARD #define CONFIG_SYS_BOARD "odroid" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b8addeaf693..335977b3038 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -132,7 +132,6 @@ CONFIG_BOARD_POSTCLK_INIT CONFIG_BOARD_REVISION_TAG CONFIG_BOARD_SIZE_LIMIT CONFIG_BOARD_TAURUS -CONFIG_BOARD_TYPES CONFIG_BOOGER CONFIG_BOOTBLOCK CONFIG_BOOTFILE
Hi Simon,
Please note ARC boards have nothing to do with Samsung Exynos. They are based on ARC cores and "arch/arm/mach-exynos/Kconfig" makes no sense for them.
Moreover I'm not sure why CONFIG_BOARD_TYPES is an Exynos-specific option. That said why don't we move CONFIG_BOARD_TYPES to the generic Kconfig?
[snip]
- This board might be of different versions so handle it
There's no reason to keep above comment if "#define" below is gone.
- NAND Flash configuration
Ditto. But then it turned out in case of HSDK CONFIG_BOARD_TYPES is just a copy-paste from AXS10x and "gd->board_type" is not used. That said this hunk is applicable but I may do it myself separately.
- UART configuration
-Alexey
Hi Simon,
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index ed04369cfae..33323d17f4b 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -166,4 +166,12 @@ source "board/samsung/espresso7420/Kconfig" config SPL_LDSCRIPT default "board/samsung/common/exynos-uboot-spl.lds" if ARCH_EXYNOS5 || ARCH_EXYNOS4 +config BOARD_TYPES
- bool "Call get_board_type() to get and display the board
type"
- help
get_board_type()
console
early in boot.
This is interesting - we add BOARD_TYPES and then USB_STORAGE is going to be removed.
- TODO: Add Odroid X support
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
At present the model is shown twice, once in the generic code and once in the exynos code. Drop the latter.
board/samsung/common/board.c | 14 ++++++-------- include/samsung/misc.h | 2 -- 2 files changed, 6 insertions(+), 10 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index 6fd26a3a919..3391228522c 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -290,15 +290,13 @@ int board_mmc_init(bd_t *bis) #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard(void) { - const char *board_info; + if (IS_ENABLED(CONFIG_BOARD_TYPES)) { + const char *board_info = get_board_type(); + + if (board_info) + printf("Type: %s\n", board_info); + }
- board_info = fdt_getprop(gd->fdt_blob, 0, "model", NULL); - printf("Board: %s\n", board_info ? board_info : "unknown"); -#ifdef CONFIG_BOARD_TYPES - board_info = get_board_type(); - if (board_info) - printf("Type: %s\n", board_info); -#endif return 0; } #endif diff --git a/include/samsung/misc.h b/include/samsung/misc.h index 0f957dc3675..017560c2566 100644 --- a/include/samsung/misc.h +++ b/include/samsung/misc.h @@ -32,9 +32,7 @@ void draw_logo(void); char *get_dfu_alt_system(char *interface, char *devstr); char *get_dfu_alt_boot(char *interface, char *devstr); #endif -#ifdef CONFIG_BOARD_TYPES void set_board_type(void); const char *get_board_type(void); -#endif
#endif /* __SAMSUNG_MISC_COMMON_H__ */
Move all exynos boards over to use CONFIG_BLK.
arch/arm/mach-exynos/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 33323d17f4b..f3e43434bc3 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -8,6 +8,8 @@ config ARCH_EXYNOS4 bool "Exynos4 SoC family" select BOARD_EARLY_INIT_F select CPU_V7A + select BLK + select DM_MMC help Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU. There are multiple SoCs in this family including Exynos4210, Exynos4412, @@ -24,6 +26,9 @@ config ARCH_EXYNOS5 imply USB_ETHER_ASIX imply USB_ETHER_RTL8152 imply USB_ETHER_SMSC95XX + select BLK + select DM_MMC + help Samsung Exynos5 SoC family are based on ARM Cortex-A15 CPU (and Cortex-A7 CPU in big.LITTLE configuration). There are multiple SoCs @@ -33,6 +38,8 @@ config ARCH_EXYNOS7 bool "Exynos7 SoC family" select ARM64 select BOARD_EARLY_INIT_F + select BLK + select DM_MMC help Samsung Exynos7 SoC family are based on ARM Cortex-A57 CPU or Cortex-A53 CPU (and some in a big.LITTLE configuration). There are
Alexey Brodkin
Lukasz Majewski
