[PATCH 0/4] QSPI bugfixes of NXP layerscape platforms
This patch series is an attempt to fix qspi bugs on various NXP layerscape platforms like ls1012a, ls1046a, ls2088a.
Bug fixes involves crashes in flash environment.
Patch series depends on https://patchwork.ozlabs.org/project/uboot/patch/1581413944-7958-3-git-send-...
Patch1: Increase malloc len for more space. Patch2: Reduce ENV_SIZE to successfully store env in ls1012a. Patch3: Enable RELOC_GD config to resolve environment booting crash. Patch4: Unset ENV_ADDR value for ls1012a to resolve crash.
Ashish Kumar (1): configs: ls1012a: Reduce CONFIG_ENV_SIZE to 0x2000
Kuldeep Singh (3): configs: ls1012a: Increase CONFIG_SYS_MALLOC_LEN size configs: nxp: Enable CONFIG_SYS_RELOC_GD_ENV_ADDR configs: ls1012a: Unset ENV_ADDR value
configs/ls1012a2g5rdb_qspi_defconfig | 2 +- configs/ls1012a2g5rdb_tfa_defconfig | 2 +- configs/ls1012afrdm_qspi_defconfig | 2 +- configs/ls1012afrdm_tfa_defconfig | 2 +- configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1012afrwy_qspi_defconfig | 3 ++- configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012afrwy_tfa_defconfig | 4 ++-- configs/ls1012aqds_qspi_defconfig | 2 +- configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012aqds_tfa_defconfig | 2 +- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1012ardb_qspi_defconfig | 2 +- configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012ardb_tfa_defconfig | 3 +-- configs/ls1046afrwy_tfa_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + include/configs/ls1012a_common.h | 2 +- 20 files changed, 22 insertions(+), 18 deletions(-)
CONFIG_SYS_MALLOC_LEN is currently set to low value and leaves very less space to do malloc in flash environmet. Increase the value to get more memory and also make it align with other boards(ls1046a, ls1043a etc.) config values.
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- include/configs/ls1012a_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index e9baa2a..c34faf2 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -34,7 +34,7 @@ #define CONFIG_LAYERSCAPE_NS_ACCESS
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 1024 * 1024)
/*SPI device */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_TFABOOT)
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Kuldeep Singh Sent: Tuesday, May 5, 2020 1:07 PM To: Priyanka Jain priyanka.jain@nxp.com; u-boot@lists.denx.de Cc: Kuldeep Singh kuldeep.singh@nxp.com Subject: [PATCH 1/4] configs: ls1012a: Increase CONFIG_SYS_MALLOC_LEN size
Series applied to u-boot-fsl-qoriq. Awaiting upstream.
Thanks Priyanka
All LS1012A board variants have same CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE values. If both config values are same, flash environment cannot be saved. Since, CONFIG_ENV_SECT_SIZE needs to be same as that of flash sector size, this entry cannot be changed. Reduce CONFIG_ENV_SIZE value to 0x2000. This also helps in making config value aligned with other boards environemt size.
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com Signed-off-by: Ashish Kumar Ashish.kumar@nxp.com --- configs/ls1012a2g5rdb_qspi_defconfig | 2 +- configs/ls1012a2g5rdb_tfa_defconfig | 2 +- configs/ls1012afrdm_qspi_defconfig | 2 +- configs/ls1012afrdm_tfa_defconfig | 2 +- configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1012afrwy_qspi_defconfig | 2 +- configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012afrwy_tfa_defconfig | 2 +- configs/ls1012aqds_qspi_defconfig | 2 +- configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012aqds_tfa_defconfig | 2 +- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 2 +- configs/ls1012ardb_qspi_defconfig | 2 +- configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 2 +- configs/ls1012ardb_tfa_defconfig | 2 +- 15 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig index 9bf5b9c..c539243 100644 --- a/configs/ls1012a2g5rdb_qspi_defconfig +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012A2G5RDB=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012a2g5rdb_tfa_defconfig b/configs/ls1012a2g5rdb_tfa_defconfig index d9d4f82..ac34acd 100644 --- a/configs/ls1012a2g5rdb_tfa_defconfig +++ b/configs/ls1012a2g5rdb_tfa_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012A2G5RDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 02a80b1..5a5b8d9 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRDM=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012afrdm_tfa_defconfig b/configs/ls1012afrdm_tfa_defconfig index ecc4c81..3531aaa 100644 --- a/configs/ls1012afrdm_tfa_defconfig +++ b/configs/ls1012afrdm_tfa_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRDM=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index addb31c..a2e85b2 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_FSL_LS_PPA=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 2156f5e..50e261e 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x1D0000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index a4fdd0c..86d7689 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_NR_DRAM_BANKS=2 diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 280dbd3..5ac2656 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AFRWY=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x1D0000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 7826661..db7d6e1 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AQDS=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 8ab6cbc..5921dbb 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_QSPI_AHB_INIT=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 1b783c5..ebbb968 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012AQDS=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index 4031b9b..2121fe8 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012ARDB=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_FSL_LS_PPA=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 01770b8..086980a 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012ARDB=y CONFIG_SYS_TEXT_BASE=0x40100000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index 57e9dd9..e8286ed 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_QSPI_AHB_INIT=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index 06584ff..85d92cf 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS1012ARDB=y CONFIG_TFABOOT=y CONFIG_SYS_TEXT_BASE=0x82000000 -CONFIG_ENV_SIZE=0x40000 +CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y
Commit 323d3af59fe4 ("configs: ls1012ardb: Enable CONFIG_SYS_RELOC_GD_ENV_ADDR") enables the config only for LS1012ARDB.
Apart from LS1012A-RDB, other platforms such as LS1012A-FRWY, LS2088A and LS1046A-RDB/FRWY also require this config to be enabled. This also helps in resolving booting crash observed in flash environment.
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- configs/ls1012afrwy_qspi_defconfig | 1 + configs/ls1012afrwy_tfa_defconfig | 1 + configs/ls1046afrwy_tfa_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/ls2088aqds_tfa_defconfig | 1 + configs/ls2088ardb_tfa_defconfig | 1 + 6 files changed, 6 insertions(+)
diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 50e261e..9514450 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0x401D0000 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 5ac2656..83c7410 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0x401D0000 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 48dc7ac..68271c3 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -32,6 +32,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0x40500000 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index eab34cd..c20e524 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -33,6 +33,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-rdb" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0x40500000 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 3116a99..7142f86 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -37,6 +37,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0x20500000 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index 4f1c2d6..8e087b8 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -39,6 +39,7 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0x20500000 +CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y
LS1012A-FRWY and LS1012A-RDB crashes in flash environment when CONFIG_ENV_ADDR value is set. Unset the config value in *_tfa_defconfig* to resolve booting crash.
Following crash is observed: Using SERDES1 Protocol: 13576 (0x3508) "Synchronous Abort" handler, esr 0x96000006 elr: 00000000820452c0 lr : 0000000082013f54 (reloc) elr: 00000000b7b932c0 lr : 00000000b7b61f54 x0 : 0000000000000000 x1 : 000000007604e004 x2 : 0000000000000001 x3 : 0000000000000000 ... Code: 54ffff80 9100c000 17fffff7 f9402241 (3860c820) Resetting CPU ...
Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- configs/ls1012afrwy_tfa_defconfig | 1 - configs/ls1012ardb_tfa_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 83c7410..8ecbf7c 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_ADDR=0x401D0000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index 85d92cf..bf89730 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -33,7 +33,6 @@ CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-rdb" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_ADDR=0x40500000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y
Kuldeep Singh
Priyanka Jain (OSS)
