[U-Boot] [PATCH] drivers: uclass: timer: rename timer_init() to dm_timer_init()
Rename timer_init() to dm_timer_init() and remove dm_timer_init() in lib/time.c as
* timer_init is called from board_f.c or board_r.c on different architectures which may result causes timer devices to be probed twice. * lib/time.c dm_timer_init() does nothing other than calling timer_init().
Also remove reinitializing of ret in timer_init().
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com ---
Tested this patch on dra74x evm. and pushed a branch [2].
[1] - http://pastebin.ubuntu.com/14524076/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git dm-timer-fix
--- drivers/timer/timer-uclass.c | 7 +++++-- include/timer.h | 9 +++++++++ lib/time.c | 8 -------- 3 files changed, 14 insertions(+), 10 deletions(-)
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 053411f..83d1a35 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -68,13 +68,16 @@ u64 timer_conv_64(u32 count) return ((u64)gd->timebase_h << 32) | gd->timebase_l; }
-int timer_init(void) +int notrace dm_timer_init(void) { const void *blob = gd->fdt_blob; struct udevice *dev = NULL; int node; int ret;
+ if (gd->timer) + return 0; + /* Check for a chosen timer to be used for tick */ node = fdtdec_get_chosen_node(blob, "tick-timer"); if (node < 0) { @@ -92,7 +95,7 @@ int timer_init(void) */ if (node > 0 && !lists_bind_fdt(gd->dm_root, blob, node, &dev)) { - int ret = device_probe(dev); + ret = device_probe(dev); if (ret) return ret; } diff --git a/include/timer.h b/include/timer.h index 7fee17e..f14725c 100644 --- a/include/timer.h +++ b/include/timer.h @@ -8,6 +8,15 @@ #define _TIMER_H_
/* + * dm_timer_init - initialize a timer for time keeping. On success + * initializes gd->timer so that lib/timer can use it for future + * referrence. + * + * @return - 0 on success or error number + */ +int dm_timer_init(void); + +/* * timer_conv_64 - convert 32-bit counter value to 64-bit * * @count: 32-bit counter value diff --git a/lib/time.c b/lib/time.c index d4060f1..e9f6861 100644 --- a/lib/time.c +++ b/lib/time.c @@ -41,14 +41,6 @@ extern unsigned long __weak timer_read_counter(void); #endif
#ifdef CONFIG_TIMER -static int notrace dm_timer_init(void) -{ - if (!gd->timer) - return timer_init(); - - return 0; -} - ulong notrace get_tbclk(void) { int ret;
Mugunthan V N
