[PATCH] binman: Use unsigned long over typedef ulong
The header binman_sym.h depends on ulong typedef but does not include types.h. This means the header must be included after including types.h or a header that includes it.
We could include types.h but instead let's just switch from ulong to directly using unsigned long. This removes the need for typedef'ing it in some of the tests, so also remove those.
Signed-off-by: Andrew Davis afd@ti.com --- include/binman_sym.h | 8 ++++---- tools/binman/test/blob_syms.c | 2 -- tools/binman/test/u_boot_binman_syms.c | 2 -- tools/binman/test/u_boot_binman_syms_size.c | 2 -- 4 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/include/binman_sym.h b/include/binman_sym.h index 528d7e4e90e..49a95eafade 100644 --- a/include/binman_sym.h +++ b/include/binman_sym.h @@ -71,7 +71,7 @@ * value #defined above. This is used to check at runtime if the * symbol values were filled in and are OK to use. */ -extern ulong _binman_sym_magic; +extern unsigned long _binman_sym_magic;
/** * DECLARE_BINMAN_MAGIC_SYM - Declare the internal magic symbol @@ -81,7 +81,7 @@ extern ulong _binman_sym_magic; * definitions of the symbol. */ #define DECLARE_BINMAN_MAGIC_SYM \ - ulong _binman_sym_magic \ + unsigned long _binman_sym_magic \ __attribute__((aligned(4), section(".binman_sym")))
/** @@ -93,14 +93,14 @@ extern ulong _binman_sym_magic; * Return: 1 if binman symbol values are usable, 0 if not */ #define BINMAN_SYMS_OK \ - (*(ulong *)&_binman_sym_magic == BINMAN_SYM_MAGIC_VALUE) + (*(unsigned long *)&_binman_sym_magic == BINMAN_SYM_MAGIC_VALUE)
/** * binman_sym() - Access a previously declared symbol * * This is used to get the value of a symbol. E.g.: * - * ulong address = binman_sym(ulong, u_boot_spl, pos); + * unsigned long address = binman_sym(unsigned long, u_boot_spl, pos); * * @_type: Type f the symbol (e.g. unsigned long) * @entry_name: Name of the entry to look for (e.g. 'u_boot_spl') diff --git a/tools/binman/test/blob_syms.c b/tools/binman/test/blob_syms.c index d652c79aa98..1df8d64353f 100644 --- a/tools/binman/test/blob_syms.c +++ b/tools/binman/test/blob_syms.c @@ -5,8 +5,6 @@ * Simple program to create some binman symbols. This is used by binman tests. */
-typedef unsigned long ulong; - #include <linux/kconfig.h> #include <binman_sym.h>
diff --git a/tools/binman/test/u_boot_binman_syms.c b/tools/binman/test/u_boot_binman_syms.c index ed761246aec..147c90230f8 100644 --- a/tools/binman/test/u_boot_binman_syms.c +++ b/tools/binman/test/u_boot_binman_syms.c @@ -5,8 +5,6 @@ * Simple program to create some binman symbols. This is used by binman tests. */
diff --git a/tools/binman/test/u_boot_binman_syms_size.c b/tools/binman/test/u_boot_binman_syms_size.c index fa41b3d9a33..f686892a4da 100644 --- a/tools/binman/test/u_boot_binman_syms_size.c +++ b/tools/binman/test/u_boot_binman_syms_size.c @@ -5,8 +5,6 @@ * Simple program to create some binman symbols. This is used by binman tests. */
Applied to u-boot-dm, thanks!
Andrew Davis
