[PATCH] video: meson: dw-hdmi: do not fail probe if HDMI regulator is already enabled
If the regulator is already enabled, this happens if the regulator is set in regulator-always-on, regulator_set_enable() return -EALREADY.
Ignore the -EALREADY return since it's not an error.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/video/meson/meson_dw_hdmi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/meson/meson_dw_hdmi.c b/drivers/video/meson/meson_dw_hdmi.c index 587df7beb9b..ee219ce6ec4 100644 --- a/drivers/video/meson/meson_dw_hdmi.c +++ b/drivers/video/meson/meson_dw_hdmi.c @@ -419,7 +419,7 @@ static int meson_dw_hdmi_probe(struct udevice *dev)
if (!ret) { ret = regulator_set_enable(supply, true); - if (ret) + if (ret && ret != -EALREADY) return ret; } #endif
--- base-commit: 28dc47038edc4e93f32d75a357131bcf01a18d85 change-id: 20241008-u-boot-video-fix-hdmi-supply-already-on-e6a9af27b1eb
Hi Neil,
if (ret)
You could possible relax this further using something like:
ret = regulator_set_enable_if_allowed(supply, true); if (ret && ret != -ENOSYS)
That way you only reach the error state when there is an error with supply, for other states e.g. when supply is not found, DM_REGULATOR=n or the regulator is already enabled will be treated as success (ret=0).
Regards, Jonas
return ret;
} #endif
On 08/10/2024 16:36, Jonas Karlman wrote:
Hi Neil,
if (ret)
Nice, thanks for the suggestion :-)
Neil
Regards, Jonas
return ret;
} #endif
Jonas Karlman
Neil Armstrong
