[U-Boot] [PATCH] ARM: socfpga: Convert to DM serial
Pull the serial port configuration from DT and use DM serial instead of having the serial configuration in two places, DT and board config.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See chin.liang.see@intel.com Cc: Dinh Nguyen dinguyen@kernel.org --- arch/arm/Kconfig | 3 +++ arch/arm/dts/socfpga.dtsi | 2 ++ arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 1 + include/configs/socfpga_common.h | 8 -------- 4 files changed, 6 insertions(+), 8 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 532aa41a87..2012ac6410 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -737,6 +737,7 @@ config ARCH_SOCFPGA select ARCH_MISC_INIT select CPU_V7A select DM + select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK select OF_CONTROL select SPL_LIBCOMMON_SUPPORT @@ -746,11 +747,13 @@ config ARCH_SOCFPGA select SPL_NAND_SUPPORT if SPL_NAND_DENALI select SPL_OF_CONTROL select SPL_SERIAL_SUPPORT + select SPL_DM_SERIAL select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT select SPL_SPI_SUPPORT if DM_SPI select SPL_WATCHDOG_SUPPORT select SUPPORT_SPL select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE + select SYS_NS16550 select SYS_THUMB_BUILD imply CMD_MTDPARTS imply CRC32_VERIFY diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index e64127fcb2..314449478d 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -737,6 +737,7 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&l4_sp_clk>; + clock-frequency = <100000000>; };
uart1: serial1@ffc03000 { @@ -746,6 +747,7 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&l4_sp_clk>; + clock-frequency = <100000000>; };
rst: rstmgr@ffd05000 { diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts index b573d0e658..06b61cb0af 100644 --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts @@ -24,6 +24,7 @@ };
&uart1 { + clock-frequency = <50000000>; u-boot,dm-pre-reloc; status = "okay"; }; diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 54b9edc97c..a60da85499 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -173,14 +173,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * Serial Driver */ #define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS -#define CONFIG_SYS_NS16550_CLK 100000000 -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS -#define CONFIG_SYS_NS16550_CLK 50000000 -#endif
/* * USB
clock-frequency = <100000000>; }; uart1: serial1@ffc03000 {
clock-frequency = <100000000>; }; rst: rstmgr@ffd05000 {
&uart1 {
- Serial Driver
- USB
Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com
- select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK select OF_CONTROL select SPL_LIBCOMMON_SUPPORT
- select SPL_DM_SERIAL select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT select SPL_SPI_SUPPORT if DM_SPI select SPL_WATCHDOG_SUPPORT select SUPPORT_SPL select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE
- select SYS_NS16550 select SYS_THUMB_BUILD imply CMD_MTDPARTS imply CRC32_VERIFY
&uart1 {
- clock-frequency = <50000000>; u-boot,dm-pre-reloc; status = "okay"; };
- Serial Driver
- USB
Unfortunately I saw this just now, but it seems this breaks GEN5 SPL? At least git-bisect told me that 73172753f4f3351ed1c9d2f6586fc599ce4e728c is the first bad commit.
I tested socfpga_socrates_defconfig on my socrates board.
Any idea what's wrong there?
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 532aa41a87..2012ac6410 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -737,6 +737,7 @@ config ARCH_SOCFPGA select ARCH_MISC_INIT select CPU_V7A select DM + select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK select OF_CONTROL select SPL_LIBCOMMON_SUPPORT @@ -746,11 +747,13 @@ config ARCH_SOCFPGA select SPL_NAND_SUPPORT if SPL_NAND_DENALI select SPL_OF_CONTROL select SPL_SERIAL_SUPPORT + select SPL_DM_SERIAL select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT select SPL_SPI_SUPPORT if DM_SPI select SPL_WATCHDOG_SUPPORT select SUPPORT_SPL select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE + select SYS_NS16550 select SYS_THUMB_BUILD imply CMD_MTDPARTS imply CRC32_VERIFY diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index e64127fcb2..314449478d 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -737,6 +737,7 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&l4_sp_clk>; + clock-frequency = <100000000>; }; uart1: serial1@ffc03000 { @@ -746,6 +747,7 @@ reg-shift = <2>; reg-io-width = <4>; clocks = <&l4_sp_clk>; + clock-frequency = <100000000>; }; rst: rstmgr@ffd05000 { diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts index b573d0e658..06b61cb0af 100644 --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts @@ -24,6 +24,7 @@ }; &uart1 { + clock-frequency = <50000000>; u-boot,dm-pre-reloc; status = "okay"; }; diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 54b9edc97c..a60da85499 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -173,14 +173,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * Serial Driver */ #define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS -#define CONFIG_SYS_NS16550_CLK 100000000 -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS -#define CONFIG_SYS_NS16550_CLK 50000000 -#endif /* * USB
Nope, this should work fine. Can you investigate ?
OK, I'll try.
Simon
Ok, so after adding "u-boot,dm-pre-reloc" to uart0 in socfpga_cyclone5_socrates.dts, U-Boot works (combined with an old SPL). SPL still does not work. Any idea? How does SPL get the uart?
Thanks for any pointers.
Simon
Good!
Dig around the NS16550 driver .
Marek Vasut marex@denx.de schrieb am Mi., 1. Aug. 2018, 09:35:
While debugging, a more generic question: which drivers are now remaining non-DM for socfpga?
And am I correct with the assumption that we could get rid of the qts files (other than sdram maybe) by implementing pinctrl and clk drivers as DM drivers? (Not that I would have found documentation about the pin mux hardware cyclone5...)
I'm looking for a way to control pins from a fit image that includes kernel, dts and fpga because the pins may change depending on the fpga config...
Simon (from my private mail)
On 08/01/2018 05:42 PM, Simon Goldschmidt wrote:
Marek Vasut <marex@denx.de mailto:marex@denx.de> schrieb am Mi., 1. Aug. 2018, 09:35:
On 08/01/2018 09:29 AM, Goldschmidt Simon wrote: > > On 30.07.2018 16:04, Marek Vasut wrote: >> On 07/30/2018 04:03 PM, Simon Goldschmidt wrote: >>> >>> On 12.05.2018 22:28, Marek Vasut wrote: >>>> Pull the serial port configuration from DT and use DM serial instead >>>> of having the serial configuration in two places, DT and board config. [..]
Not much I believe, I can't think of anything right now.
Yes. The pinmux docs are probably not public, it has to do with the iocsr ring programming and that's super-secret for whatever reason. What Altera did on Arria10 is pure trash, they encode registers in DT and are done with it. If you can design something saner, that'd be so nice.
I am working on a clock driver for Arria10 now, I might do Gen5 too afterward, since the clock block is similar. The clock DT bindings on the other hand are complete insanity, words fail me. The clock stuff in U-Boot on SoCFPGA right now is a complete disaster too, the way stuff gets added to mach-socfpga is really irritating.
DTOs maybe ?
As I'm not familiar with pinmux DTS, that might be hard for me, but I might try to get it done somehow (or by someone... :)
Could you give me a hint of a platform to take as a good example?
That would be cool. You can count on me testing on cyclone5 as much as I can (as much as I have the hardware, that is).
But you would still use the existing bindings? How does this stuff get added to U-Boot, by first being added to Linux and the DTS being copied here?
DTOs maybe ?
Yeah, I thought of that too. The problem I see is that we would need pinmux and clock support for DTS in Linux but we're kind of stuck to 4.9.y for now due to using an RT configuration.
Simon
Maybe iMX series ?
Pretty much, except on A10 there are the generated handoff files at play too. Basically Altera really screwed it up there, it contains redundant nodes which are both in the base DT and handoff files, but each contain different set of DT properties and have different names, although they represent the same thing. Sigh ...
DTOs maybe ?
Well, implement those drivers ?
Good!
OK, so my DS-5 debugger shows me it's not the driver that fails but "malloc_simple()" returns 0x0 when being called from uclass_get_device_by_seq(). Which is strange because gd->malloc_base is 0xffffe000.
Also, gd->fdt_blob is not initialized at the time serial_init() is called from SPL. Should it be? Because that way, we don't seem to have dts control over which uart is used as console?
Simon
Good!
malloc() returns NULL because it ran out of space ?
Simon
Marek Vasut marex@denx.de schrieb am Fr., 3. Aug. 2018, 11:00:
On 12.05.2018 22:28, Marek Vasut wrote: > Pull the serial port configuration from DT and use DM serial instead > of having the serial configuration in two places, DT and board > config. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Chin Liang See chin.liang.see@intel.com > Cc: Dinh Nguyen dinguyen@kernel.org > --- > arch/arm/Kconfig | 3 +++ > arch/arm/dts/socfpga.dtsi | 2 ++ > arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 1 + > include/configs/socfpga_common.h | 8 -------- > 4 files changed, 6 insertions(+), 8 deletions(-) > > diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig > index 532aa41a87..2012ac6410 100644 > --- a/arch/arm/Kconfig > +++ b/arch/arm/Kconfig > @@ -737,6 +737,7 @@ config ARCH_SOCFPGA > select ARCH_MISC_INIT > select CPU_V7A > select DM > + select DM_SERIAL > select ENABLE_ARM_SOC_BOOT0_HOOK > select OF_CONTROL > select SPL_LIBCOMMON_SUPPORT > @@ -746,11 +747,13 @@ config ARCH_SOCFPGA > select SPL_NAND_SUPPORT if SPL_NAND_DENALI > select SPL_OF_CONTROL > select SPL_SERIAL_SUPPORT > + select SPL_DM_SERIAL > select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT > select SPL_SPI_SUPPORT if DM_SPI > select SPL_WATCHDOG_SUPPORT > select SUPPORT_SPL > select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE > + select SYS_NS16550 > select SYS_THUMB_BUILD > imply CMD_MTDPARTS > imply CRC32_VERIFY > diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi > index e64127fcb2..314449478d 100644 > --- a/arch/arm/dts/socfpga.dtsi > +++ b/arch/arm/dts/socfpga.dtsi > @@ -737,6 +737,7 @@ > reg-shift = <2>; > reg-io-width = <4>; > clocks = <&l4_sp_clk>; > + clock-frequency = <100000000>; > }; > uart1: serial1@ffc03000 { > @@ -746,6 +747,7 @@ > reg-shift = <2>; > reg-io-width = <4>; > clocks = <&l4_sp_clk>; > + clock-frequency = <100000000>; > }; > rst: rstmgr@ffd05000 { > diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > index b573d0e658..06b61cb0af 100644 > --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > @@ -24,6 +24,7 @@ > }; > &uart1 { > + clock-frequency = <50000000>; > u-boot,dm-pre-reloc; > status = "okay"; > }; > diff --git a/include/configs/socfpga_common.h > b/include/configs/socfpga_common.h > index 54b9edc97c..a60da85499 100644 > --- a/include/configs/socfpga_common.h > +++ b/include/configs/socfpga_common.h > @@ -173,14 +173,6 @@ unsigned int > cm_get_qspi_controller_clk_hz(void); > * Serial Driver > */ > #define CONFIG_SYS_NS16550_SERIAL > -#define CONFIG_SYS_NS16550_REG_SIZE -4 > -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) > -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS > -#define CONFIG_SYS_NS16550_CLK 100000000 > -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) > -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS > -#define CONFIG_SYS_NS16550_CLK 50000000 > -#endif > /* > * USB > Unfortunately I saw this just now, but it seems this breaks GEN5 SPL? At least git-bisect told me that
Good!
No, the malloc limit is not even set in gd. It just somehow fails to add malloc_base. I don't get why, as it should do so given the disassembly.
The next step is then zeroing the memory from calloc() and it doesn't return from there.
I guess next I could check if malloc_simple is called at all without serial DM. That would at least explain how this error is connected to your commit...
Can someone shed some light on this? Should the device tree be available when allocating the SPL console? Because if not, it would just use the first driver available, or am I wrong?
Simon
On 08/03/2018 11:10 AM, Simon Goldschmidt wrote:
Marek Vasut <marex@denx.de mailto:marex@denx.de> schrieb am Fr., 3. Aug. 2018, 11:00:
On 08/03/2018 10:40 AM, Simon Goldschmidt wrote: > > > On 01.08.2018 09:34, Marek Vasut wrote: >> On 08/01/2018 09:29 AM, Goldschmidt Simon wrote: >>> >>> On 30.07.2018 16:04, Marek Vasut wrote: >>>> On 07/30/2018 04:03 PM, Simon Goldschmidt wrote: >>>>> >>>>> On 12.05.2018 22:28, Marek Vasut wrote: >>>>>> Pull the serial port configuration from DT and use DM serial instead >>>>>> of having the serial configuration in two places, DT and board >>>>>> config. >>>>>> >>>>>> Signed-off-by: Marek Vasut <marex@denx.de <mailto:marex@denx.de>> >>>>>> Cc: Chin Liang See <chin.liang.see@intel.com <mailto:chin.liang.see@intel.com>> >>>>>> Cc: Dinh Nguyen <dinguyen@kernel.org <mailto:dinguyen@kernel.org>> >>>>>> --- >>>>>> arch/arm/Kconfig | 3 +++ >>>>>> arch/arm/dts/socfpga.dtsi | 2 ++ >>>>>> arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 1 + >>>>>> include/configs/socfpga_common.h | 8 -------- >>>>>> 4 files changed, 6 insertions(+), 8 deletions(-) >>>>>> >>>>>> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig >>>>>> index 532aa41a87..2012ac6410 100644 >>>>>> --- a/arch/arm/Kconfig >>>>>> +++ b/arch/arm/Kconfig >>>>>> @@ -737,6 +737,7 @@ config ARCH_SOCFPGA >>>>>> select ARCH_MISC_INIT >>>>>> select CPU_V7A >>>>>> select DM >>>>>> + select DM_SERIAL >>>>>> select ENABLE_ARM_SOC_BOOT0_HOOK >>>>>> select OF_CONTROL >>>>>> select SPL_LIBCOMMON_SUPPORT >>>>>> @@ -746,11 +747,13 @@ config ARCH_SOCFPGA >>>>>> select SPL_NAND_SUPPORT if SPL_NAND_DENALI >>>>>> select SPL_OF_CONTROL >>>>>> select SPL_SERIAL_SUPPORT >>>>>> + select SPL_DM_SERIAL >>>>>> select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT >>>>>> select SPL_SPI_SUPPORT if DM_SPI >>>>>> select SPL_WATCHDOG_SUPPORT >>>>>> select SUPPORT_SPL >>>>>> select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE >>>>>> + select SYS_NS16550 >>>>>> select SYS_THUMB_BUILD >>>>>> imply CMD_MTDPARTS >>>>>> imply CRC32_VERIFY >>>>>> diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi >>>>>> index e64127fcb2..314449478d 100644 >>>>>> --- a/arch/arm/dts/socfpga.dtsi >>>>>> +++ b/arch/arm/dts/socfpga.dtsi >>>>>> @@ -737,6 +737,7 @@ >>>>>> reg-shift = <2>; >>>>>> reg-io-width = <4>; >>>>>> clocks = <&l4_sp_clk>; >>>>>> + clock-frequency = <100000000>; >>>>>> }; >>>>>> uart1: serial1@ffc03000 { >>>>>> @@ -746,6 +747,7 @@ >>>>>> reg-shift = <2>; >>>>>> reg-io-width = <4>; >>>>>> clocks = <&l4_sp_clk>; >>>>>> + clock-frequency = <100000000>; >>>>>> }; >>>>>> rst: rstmgr@ffd05000 { >>>>>> diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts >>>>>> b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts >>>>>> index b573d0e658..06b61cb0af 100644 >>>>>> --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts >>>>>> +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts >>>>>> @@ -24,6 +24,7 @@ >>>>>> }; >>>>>> &uart1 { >>>>>> + clock-frequency = <50000000>; >>>>>> u-boot,dm-pre-reloc; >>>>>> status = "okay"; >>>>>> }; >>>>>> diff --git a/include/configs/socfpga_common.h >>>>>> b/include/configs/socfpga_common.h >>>>>> index 54b9edc97c..a60da85499 100644 >>>>>> --- a/include/configs/socfpga_common.h >>>>>> +++ b/include/configs/socfpga_common.h >>>>>> @@ -173,14 +173,6 @@ unsigned int >>>>>> cm_get_qspi_controller_clk_hz(void); >>>>>> * Serial Driver >>>>>> */ >>>>>> #define CONFIG_SYS_NS16550_SERIAL >>>>>> -#define CONFIG_SYS_NS16550_REG_SIZE -4 >>>>>> -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) >>>>>> -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS >>>>>> -#define CONFIG_SYS_NS16550_CLK 100000000 >>>>>> -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) >>>>>> -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS >>>>>> -#define CONFIG_SYS_NS16550_CLK 50000000 >>>>>> -#endif >>>>>> /* >>>>>> * USB >>>>>> >>>>> Unfortunately I saw this just now, but it seems this breaks GEN5 >>>>> SPL? At >>>>> least git-bisect told me that 73172753f4f3351ed1c9d2f6586fc599ce4e728c >>>>> is the first bad commit. >>>>> >>>>> I tested socfpga_socrates_defconfig on my socrates board. >>>>> >>>>> Any idea what's wrong there? >>>> Nope, this should work fine. Can you investigate ? >>> >>> Ok, so after adding "u-boot,dm-pre-reloc" to uart0 in >>> socfpga_cyclone5_socrates.dts, U-Boot works (combined with an old SPL). >> >> Good! >> >>> SPL still does not work. Any idea? How does SPL get the uart? >>> >>> Thanks for any pointers. >> >> Dig around the NS16550 driver . > OK, so my DS-5 debugger shows me it's not the driver that fails but > "malloc_simple()" returns 0x0 when being called from > uclass_get_device_by_seq(). Which is strange because gd->malloc_base is > 0xffffe000. malloc() returns NULL because it ran out of space ?
Maybe it's not, I recall that the SPL sometimes failed when it grew too large and noone explained in a satisfactory way why. Maybe the commit just triggers this.
> Also, gd->fdt_blob is not initialized at the time serial_init() is > called from SPL. Should it be? Because that way, we don't seem to have > dts control over which uart is used as console?
Simon
Marek Vasut marex@denx.de schrieb am Fr., 3. Aug. 2018, 11:22:
marex@denx.de>>
GEN5
I know. That's why I just tested with a smaller config where I disable spi and spi-flash drivers. The SPL binary is now only 40kbyte but the error remains the same.
I wonder if the cause might be that now malloc_simple() is called earlier than before?
have
Simon
-- Best regards, Marek Vasut
On 03.08.2018 13:01, Simon Goldschmidt wrote:
Marek Vasut <marex@denx.de mailto:marex@denx.de> schrieb am Fr., 3. Aug. 2018, 11:22:
On 08/03/2018 11:10 AM, Simon Goldschmidt wrote: > > > Marek Vasut <marex@denx.de <mailto:marex@denx.de> <mailto:marex@denx.de <mailto:marex@denx.de>>> schrieb am Fr., 3. > Aug. 2018, 11:00: > > On 08/03/2018 10:40 AM, Simon Goldschmidt wrote: > > > > > > On 01.08.2018 09:34, Marek Vasut wrote: > >> On 08/01/2018 09:29 AM, Goldschmidt Simon wrote: > >>> > >>> On 30.07.2018 16:04, Marek Vasut wrote: > >>>> On 07/30/2018 04:03 PM, Simon Goldschmidt wrote: > >>>>> > >>>>> On 12.05.2018 22:28, Marek Vasut wrote: > >>>>>> Pull the serial port configuration from DT and use DM serial > instead > >>>>>> of having the serial configuration in two places, DT and board > >>>>>> config. > >>>>>> > >>>>>> Signed-off-by: Marek Vasut <marex@denx.de <mailto:marex@denx.de> <mailto:marex@denx.de <mailto:marex@denx.de>>> > >>>>>> Cc: Chin Liang See <chin.liang.see@intel.com <mailto:chin.liang.see@intel.com> > <mailto:chin.liang.see@intel.com <mailto:chin.liang.see@intel.com>>> > >>>>>> Cc: Dinh Nguyen <dinguyen@kernel.org <mailto:dinguyen@kernel.org> > <mailto:dinguyen@kernel.org <mailto:dinguyen@kernel.org>>> > >>>>>> --- > >>>>>> arch/arm/Kconfig | 3 +++ > >>>>>> arch/arm/dts/socfpga.dtsi | 2 ++ > >>>>>> arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 1 + > >>>>>> include/configs/socfpga_common.h | 8 -------- > >>>>>> 4 files changed, 6 insertions(+), 8 deletions(-) > >>>>>> > >>>>>> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig > >>>>>> index 532aa41a87..2012ac6410 100644 > >>>>>> --- a/arch/arm/Kconfig > >>>>>> +++ b/arch/arm/Kconfig > >>>>>> @@ -737,6 +737,7 @@ config ARCH_SOCFPGA > >>>>>> select ARCH_MISC_INIT > >>>>>> select CPU_V7A > >>>>>> select DM > >>>>>> + select DM_SERIAL > >>>>>> select ENABLE_ARM_SOC_BOOT0_HOOK > >>>>>> select OF_CONTROL > >>>>>> select SPL_LIBCOMMON_SUPPORT > >>>>>> @@ -746,11 +747,13 @@ config ARCH_SOCFPGA > >>>>>> select SPL_NAND_SUPPORT if SPL_NAND_DENALI > >>>>>> select SPL_OF_CONTROL > >>>>>> select SPL_SERIAL_SUPPORT > >>>>>> + select SPL_DM_SERIAL > >>>>>> select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT > >>>>>> select SPL_SPI_SUPPORT if DM_SPI > >>>>>> select SPL_WATCHDOG_SUPPORT > >>>>>> select SUPPORT_SPL > >>>>>> select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE > >>>>>> + select SYS_NS16550 > >>>>>> select SYS_THUMB_BUILD > >>>>>> imply CMD_MTDPARTS > >>>>>> imply CRC32_VERIFY > >>>>>> diff --git a/arch/arm/dts/socfpga.dtsi > b/arch/arm/dts/socfpga.dtsi > >>>>>> index e64127fcb2..314449478d 100644 > >>>>>> --- a/arch/arm/dts/socfpga.dtsi > >>>>>> +++ b/arch/arm/dts/socfpga.dtsi > >>>>>> @@ -737,6 +737,7 @@ > >>>>>> reg-shift = <2>; > >>>>>> reg-io-width = <4>; > >>>>>> clocks = <&l4_sp_clk>; > >>>>>> + clock-frequency = <100000000>; > >>>>>> }; > >>>>>> uart1: serial1@ffc03000 { > >>>>>> @@ -746,6 +747,7 @@ > >>>>>> reg-shift = <2>; > >>>>>> reg-io-width = <4>; > >>>>>> clocks = <&l4_sp_clk>; > >>>>>> + clock-frequency = <100000000>; > >>>>>> }; > >>>>>> rst: rstmgr@ffd05000 { > >>>>>> diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> index b573d0e658..06b61cb0af 100644 > >>>>>> --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> @@ -24,6 +24,7 @@ > >>>>>> }; > >>>>>> &uart1 { > >>>>>> + clock-frequency = <50000000>; > >>>>>> u-boot,dm-pre-reloc; > >>>>>> status = "okay"; > >>>>>> }; > >>>>>> diff --git a/include/configs/socfpga_common.h > >>>>>> b/include/configs/socfpga_common.h > >>>>>> index 54b9edc97c..a60da85499 100644 > >>>>>> --- a/include/configs/socfpga_common.h > >>>>>> +++ b/include/configs/socfpga_common.h > >>>>>> @@ -173,14 +173,6 @@ unsigned int > >>>>>> cm_get_qspi_controller_clk_hz(void); > >>>>>> * Serial Driver > >>>>>> */ > >>>>>> #define CONFIG_SYS_NS16550_SERIAL > >>>>>> -#define CONFIG_SYS_NS16550_REG_SIZE -4 > >>>>>> -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) > >>>>>> -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS > >>>>>> -#define CONFIG_SYS_NS16550_CLK 100000000 > >>>>>> -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) > >>>>>> -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS > >>>>>> -#define CONFIG_SYS_NS16550_CLK 50000000 > >>>>>> -#endif > >>>>>> /* > >>>>>> * USB > >>>>>> > >>>>> Unfortunately I saw this just now, but it seems this breaks GEN5 > >>>>> SPL? At > >>>>> least git-bisect told me that > 73172753f4f3351ed1c9d2f6586fc599ce4e728c > >>>>> is the first bad commit. > >>>>> > >>>>> I tested socfpga_socrates_defconfig on my socrates board. > >>>>> > >>>>> Any idea what's wrong there? > >>>> Nope, this should work fine. Can you investigate ? > >>> > >>> Ok, so after adding "u-boot,dm-pre-reloc" to uart0 in > >>> socfpga_cyclone5_socrates.dts, U-Boot works (combined with an > old SPL). > >> > >> Good! > >> > >>> SPL still does not work. Any idea? How does SPL get the uart? > >>> > >>> Thanks for any pointers. > >> > >> Dig around the NS16550 driver . > > OK, so my DS-5 debugger shows me it's not the driver that fails but > > "malloc_simple()" returns 0x0 when being called from > > uclass_get_device_by_seq(). Which is strange because > gd->malloc_base is > > 0xffffe000. > > malloc() returns NULL because it ran out of space ? > > > No, the malloc limit is not even set in gd. > It just somehow fails to add malloc_base. I don't get why, as it should > do so given the disassembly. > > The next step is then zeroing the memory from calloc() and it doesn't > return from there. > > I guess next I could check if malloc_simple is called at all without > serial DM. That would at least explain how this error is connected to > your commit... Maybe it's not, I recall that the SPL sometimes failed when it grew too large and noone explained in a satisfactory way why. Maybe the commit just triggers this.
And this was the right direction: malloc_simple just did not work at that time in the boot. But after fixing this (patches pending) other things (e.g. in dm core) did not work.
The solution was to call 'spl_early_init()' from socfpga's 'boart_init_f()', which not only correctly inits the heap but also inits the dm code.
Now the SPL is working for me, too! :-)
I'll have to prepare patches on top of the current git master though: for now, I have only tested changes on this patch.
I really don't know how this could have worked for other socfpga boards, but I saw the SPL split coming later after this patch, and I must say I don't think it's such a good idea. I'd prefer if all the socfpga platforms could stay with one SPL. That would greatly reduce that chance of old platforms getting broken like this.
Thanks, Simon
On 08/03/2018 11:10 AM, Simon Goldschmidt wrote: > > > Marek Vasut <marex@denx.de mailto:marex@denx.de <mailto:marex@denx.de mailto:marex@denx.de>> schrieb am Fr., 3. > Aug. 2018, 11:00: > > On 08/03/2018 10:40 AM, Simon Goldschmidt wrote: > > > > > > On 01.08.2018 09:34, Marek Vasut wrote: > >> On 08/01/2018 09:29 AM, Goldschmidt Simon wrote: > >>> > >>> On 30.07.2018 16:04, Marek Vasut wrote: > >>>> On 07/30/2018 04:03 PM, Simon Goldschmidt wrote: > >>>>> > >>>>> On 12.05.2018 22:28, Marek Vasut wrote: > >>>>>> Pull the serial port configuration from DT and use DM serial > instead > >>>>>> of having the serial configuration in two places, DT and board > >>>>>> config. > >>>>>> > >>>>>> Signed-off-by: Marek Vasut <marex@denx.de mailto:marex@denx.de <mailto:marex@denx.de mailto:marex@denx.de>> > >>>>>> Cc: Chin Liang See <chin.liang.see@intel.com mailto:chin.liang.see@intel.com > <mailto:chin.liang.see@intel.com mailto:chin.liang.see@intel.com>> > >>>>>> Cc: Dinh Nguyen <dinguyen@kernel.org mailto:dinguyen@kernel.org > <mailto:dinguyen@kernel.org mailto:dinguyen@kernel.org>> > >>>>>> --- > >>>>>> arch/arm/Kconfig | 3 +++ > >>>>>> arch/arm/dts/socfpga.dtsi | 2 ++ > >>>>>> arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 1 + > >>>>>> include/configs/socfpga_common.h | 8 -------- > >>>>>> 4 files changed, 6 insertions(+), 8 deletions(-) > >>>>>> > >>>>>> diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig > >>>>>> index 532aa41a87..2012ac6410 100644 > >>>>>> --- a/arch/arm/Kconfig > >>>>>> +++ b/arch/arm/Kconfig > >>>>>> @@ -737,6 +737,7 @@ config ARCH_SOCFPGA > >>>>>> select ARCH_MISC_INIT > >>>>>> select CPU_V7A > >>>>>> select DM > >>>>>> + select DM_SERIAL > >>>>>> select ENABLE_ARM_SOC_BOOT0_HOOK > >>>>>> select OF_CONTROL > >>>>>> select SPL_LIBCOMMON_SUPPORT > >>>>>> @@ -746,11 +747,13 @@ config ARCH_SOCFPGA > >>>>>> select SPL_NAND_SUPPORT if SPL_NAND_DENALI > >>>>>> select SPL_OF_CONTROL > >>>>>> select SPL_SERIAL_SUPPORT > >>>>>> + select SPL_DM_SERIAL > >>>>>> select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT > >>>>>> select SPL_SPI_SUPPORT if DM_SPI > >>>>>> select SPL_WATCHDOG_SUPPORT > >>>>>> select SUPPORT_SPL > >>>>>> select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE > >>>>>> + select SYS_NS16550 > >>>>>> select SYS_THUMB_BUILD > >>>>>> imply CMD_MTDPARTS > >>>>>> imply CRC32_VERIFY > >>>>>> diff --git a/arch/arm/dts/socfpga.dtsi > b/arch/arm/dts/socfpga.dtsi > >>>>>> index e64127fcb2..314449478d 100644 > >>>>>> --- a/arch/arm/dts/socfpga.dtsi > >>>>>> +++ b/arch/arm/dts/socfpga.dtsi > >>>>>> @@ -737,6 +737,7 @@ > >>>>>> reg-shift = <2>; > >>>>>> reg-io-width = <4>; > >>>>>> clocks = <&l4_sp_clk>; > >>>>>> + clock-frequency = <100000000>; > >>>>>> }; > >>>>>> uart1: serial1@ffc03000 { > >>>>>> @@ -746,6 +747,7 @@ > >>>>>> reg-shift = <2>; > >>>>>> reg-io-width = <4>; > >>>>>> clocks = <&l4_sp_clk>; > >>>>>> + clock-frequency = <100000000>; > >>>>>> }; > >>>>>> rst: rstmgr@ffd05000 { > >>>>>> diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> index b573d0e658..06b61cb0af 100644 > >>>>>> --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts > >>>>>> @@ -24,6 +24,7 @@ > >>>>>> }; > >>>>>> &uart1 { > >>>>>> + clock-frequency = <50000000>; > >>>>>> u-boot,dm-pre-reloc; > >>>>>> status = "okay"; > >>>>>> }; > >>>>>> diff --git a/include/configs/socfpga_common.h > >>>>>> b/include/configs/socfpga_common.h > >>>>>> index 54b9edc97c..a60da85499 100644 > >>>>>> --- a/include/configs/socfpga_common.h > >>>>>> +++ b/include/configs/socfpga_common.h > >>>>>> @@ -173,14 +173,6 @@ unsigned int > >>>>>> cm_get_qspi_controller_clk_hz(void); > >>>>>> * Serial Driver > >>>>>> */ > >>>>>> #define CONFIG_SYS_NS16550_SERIAL > >>>>>> -#define CONFIG_SYS_NS16550_REG_SIZE -4 > >>>>>> -#if defined(CONFIG_TARGET_SOCFPGA_GEN5) > >>>>>> -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART0_ADDRESS > >>>>>> -#define CONFIG_SYS_NS16550_CLK 100000000 > >>>>>> -#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) > >>>>>> -#define CONFIG_SYS_NS16550_COM1 SOCFPGA_UART1_ADDRESS > >>>>>> -#define CONFIG_SYS_NS16550_CLK 50000000 > >>>>>> -#endif > >>>>>> /* > >>>>>> * USB > >>>>>> > >>>>> Unfortunately I saw this just now, but it seems this breaks GEN5 > >>>>> SPL? At > >>>>> least git-bisect told me that > 73172753f4f3351ed1c9d2f6586fc599ce4e728c > >>>>> is the first bad commit. > >>>>> > >>>>> I tested socfpga_socrates_defconfig on my socrates board. > >>>>> > >>>>> Any idea what's wrong there? > >>>> Nope, this should work fine. Can you investigate ? > >>> > >>> Ok, so after adding "u-boot,dm-pre-reloc" to uart0 in > >>> socfpga_cyclone5_socrates.dts, U-Boot works (combined with an > old SPL). > >> > >> Good! > >> > >>> SPL still does not work. Any idea? How does SPL get the uart? > >>> > >>> Thanks for any pointers. > >> > >> Dig around the NS16550 driver . > > OK, so my DS-5 debugger shows me it's not the driver that fails but > > "malloc_simple()" returns 0x0 when being called from > > uclass_get_device_by_seq(). Which is strange because > gd->malloc_base is > > 0xffffe000. > > malloc() returns NULL because it ran out of space ? > > > No, the malloc limit is not even set in gd. > It just somehow fails to add malloc_base. I don't get why, as it should > do so given the disassembly. > > The next step is then zeroing the memory from calloc() and it doesn't > return from there. > > I guess next I could check if malloc_simple is called at all without > serial DM. That would at least explain how this error is connected to > your commit...
I agree, then again the Arria10 has quite different needs in SPL and than the Gen5 . Obviously, if the differences could be somehow pushed into drivers, that'd be nice.
participants (5)
Goldschmidt Simon
Ley Foon Tan
Simon Goldschmidt
Simon Goldschmidt
