[PATCH] phy: Use dt-bindig definations for npcm usb phy
Use dt-binding definations for the phy switch connection. It declares the target usb controller it is connected to.
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- drivers/phy/phy-npcm-usb.c | 27 ++++++++++----------------- 1 file changed, 10 insertions(+), 17 deletions(-)
diff --git a/drivers/phy/phy-npcm-usb.c b/drivers/phy/phy-npcm-usb.c index 24eba66554..09fb14e26f 100644 --- a/drivers/phy/phy-npcm-usb.c +++ b/drivers/phy/phy-npcm-usb.c @@ -12,6 +12,7 @@ #include <dm/device_compat.h> #include <linux/bitfield.h> #include <linux/delay.h> +#include <dt-bindings/phy/nuvoton,npcm-usbphy.h>
/* GCR Register Offsets */ #define GCR_INTCR3 0x9C @@ -32,14 +33,6 @@ #define USBPHY3SW_HOST2 FIELD_PREP(USBPHY3SW, 1) #define USBPHY3SW_DEV8_PHY3 FIELD_PREP(USBPHY3SW, 3)
-enum controller_id { - UDC0_7, - UDC8, - UDC9, - USBH1, - USBH2, -}; - enum phy_id { PHY1 = 1, PHY2, @@ -47,13 +40,13 @@ enum phy_id { };
/* Phy Switch Settings */ -#define USBDPHY1 ((PHY1 << 8) | UDC0_7) /* Connect UDC0~7 to PHY1 */ -#define USBD8PHY1 ((PHY1 << 8) | UDC8) /* Connect UDC8 to PHY1 */ -#define USBD9PHY1 ((PHY1 << 8) | UDC9) /* Connect UDC9 to PHY1 */ -#define USBD9PHY2 ((PHY2 << 8) | UDC9) /* Connect UDC9 to PHY2 */ -#define USBH1PHY2 ((PHY2 << 8) | USBH1) /* Connect USBH1 to PHY2 */ -#define USBD8PHY3 ((PHY3 << 8) | UDC8) /* Connect UDC8 to PHY3 */ -#define USBH2PHY3 ((PHY3 << 8) | USBH2) /* Connect USBH2 to PHY3 */ +#define USBDPHY1 ((PHY1 << 8) | NPCM_UDC0_7) /* Connect UDC0~7 to PHY1 */ +#define USBD8PHY1 ((PHY1 << 8) | NPCM_UDC8) /* Connect UDC8 to PHY1 */ +#define USBD9PHY1 ((PHY1 << 8) | NPCM_UDC9) /* Connect UDC9 to PHY1 */ +#define USBD9PHY2 ((PHY2 << 8) | NPCM_UDC9) /* Connect UDC9 to PHY2 */ +#define USBH1PHY2 ((PHY2 << 8) | NPCM_USBH1) /* Connect USBH1 to PHY2 */ +#define USBD8PHY3 ((PHY3 << 8) | NPCM_UDC8) /* Connect UDC8 to PHY3 */ +#define USBH2PHY3 ((PHY3 << 8) | NPCM_USBH2) /* Connect USBH2 to PHY3 */
struct npcm_usbphy { struct regmap *syscon; @@ -153,12 +146,12 @@ static int npcm_usb_phy_exit(struct phy *phy) return 0; }
-static int npcm_usb_phy_xlate(struct phy *phy, struct ofnode_phandle_args *args) +static int npcm_usb_phy_xlate(struct phy *phy, struct ofnode_phandle_args *args) { struct npcm_usbphy *priv = dev_get_priv(phy->dev); u16 phy_switch;
- if (args->args_count < 1 || args->args[0] > USBH2) + if (args->args_count < 1 || args->args[0] > NPCM_MAX_USB_CTRL_ID) return -EINVAL;
phy_switch = (priv->id << 8) | args->args[0];
Jim Liu
