Help wanted: Adding OpenSSL in FSL HAB
I would like to compile U-Boot with OpenSSL library and I'm using OpenSSL functions in Freescale's " hab.c ". I do not know how to add the ssl & crypto libraries to U-Boot's makefile (as there are many). I'm quite new to these kind of work, hence I request someone to provide some detailed explanation.
I've also raised my concern in NXP community and I'm linking that here for your reference.
Any help would be much appreciated.
Kind regards,
Daniel Selvan D.
Senior Systems Engineer | Jasmin Infotech
Which architecture ?There is a hab.c in ./arch/arm/mach-imx/hab.c It is added based on the CONFIG_IMX_HAB.
You cab add your configs ( arch/configs) and port it to your custom configuration.
On Monday, July 19, 2021, 7:38:28 AM PDT, Daniel D daniel.selvan@jasmin-infotech.com wrote:
Kind regards,
Daniel Selvan D.
The architecture is arm (i.MX 6UL board) and I've successfully added HAB.
I want to include OpenSSL library into the U-Boot now. Can you comment on this?
Kind regards,
Daniel Selvan D.
You need to enable configs , by running make menuconfig Library routines > Security support and enable the configs needed for the library.
On Monday, July 19, 2021, 10:11:05 PM PDT, Daniel D daniel.selvan@jasmin-infotech.com wrote:
Kind regards,
Daniel Selvan D.
P Please consider the environment before printing this email.
From: "Jojan" jjvazha@yahoo.com To: "u-boot" u-boot@lists.denx.de, "Daniel D" daniel.selvan@jasmin-infotech.com Sent: Monday, 19 July, 2021 23:40:00 Subject: Re: Help wanted: Adding OpenSSL in FSL HAB
Kind regards,
Daniel Selvan D.
Thanks for the update!
I've tried the options as mentioned and cannot find the OpenSSL library in there!
Do you know how to integrate an external library (any) in U-Boot?? Are there any documentation out there?
Thanks in advance.
Kind regards,
Daniel Selvan D.
Daniel D
Jojan
