[PATCH] lib: uuid: fix the test on RNG device presence
Correct the test on RNG device presence,when ret is equal to 0, before to call dm_rng_read function.
Without this patch the RNG device is not used when present (when ret == 0) or a data abort occurs in dm_rng_read when CONFIG_DM_RNG is activated but the RNG device is not present in device tree (ret != 0 and devp = NULL).
Fixes: 92fdad28cfdf ("lib: uuid: use RNG device if present") CC: Matthias Brugger mbrugger@suse.com CC: Torsten Duwe duwe@suse.de Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
lib/uuid.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/uuid.c b/lib/uuid.c index 67267c66a3..e4703dce2b 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -257,7 +257,7 @@ void gen_rand_uuid(unsigned char *uuid_bin)
if (IS_ENABLED(CONFIG_DM_RNG)) { ret = uclass_get_device(UCLASS_RNG, 0, &devp); - if (ret) { + if (!ret) { ret = dm_rng_read(devp, &randv, sizeof(randv)); if (ret < 0) randv = 0;
On Fri, 22 Oct 2021 at 09:05, Patrick Delaunay patrick.delaunay@foss.st.com wrote:
OMG
if (ret) {
-- 2.25.1
Fixes: 92fdad28cfdf ("lib: uuid: use RNG device if present") CC: Matthias Brugger mbrugger@suse.com CC: Torsten Duwe duwe@suse.de Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Simon Glass sjg@chromium.org
Patrick Delaunay
