[U-Boot] [PATCH 1/8] USB Consolidate descriptor definitions
The header files usb.h and usbdescriptors.h have the same or similarly named structure definitions for
usb_device_descriptor usb_string_descriptor usb_endpoint_descriptor usb_config_descriptor vs usb_configuration_descriptor usb_interface_descriptor
There should only be one definition of these structures. Some of these structures are element-wise duplicates, one has unused elements that can be reduced to a duplicate, and some of the the structures have additional elements.
These are the element-wise duplicates in usb.h
For these, the usb.h definition will be removed.
This definition in usb.h has extra unused elements
unsigned char bRefresh unsigned char bSynchAddress;
The definition of usb_endpoint_descriptor in usb.h will be removed.
These definitions in usb.h have extra elements at the end of the usb 2.0 specified descriptor:
usb_config_descriptor usb_interface_descriptor
These structures will have their name shorted by removing the '_descriptor' suffix.
So
usb_config_descriptor -> usb_config usb_interface_descriptor -> usb_interface
The common descriptor elements are now defined by the macros
USB_CONFIG_DESCRIPTOR_DEFINITION USB_INTERFACE_DESCRIPTOR_DEFINITION
This has been compile tested on MAKEALL arm, ppc and mips.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- common/cmd_usb.c | 12 ++++---- common/usb.c | 8 ++-- common/usb_kbd.c | 4 +- common/usb_storage.c | 2 +- cpu/ppc4xx/usbdev.c | 4 +- drivers/usb/host/ehci-hcd.c | 2 +- drivers/usb/musb/musb_hcd.c | 2 +- include/usb.h | 70 +++++------------------------------------- include/usbdescriptors.h | 40 ++++++++++++++---------- 9 files changed, 49 insertions(+), 95 deletions(-)
diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 7b8ee6b..6f3b095 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -187,14 +187,14 @@ void usb_display_desc(struct usb_device *dev)
-void usb_display_conf_desc(struct usb_config_descriptor *config, +void usb_display_conf_desc(struct usb_config *config, struct usb_device *dev) { printf(" Configuration: %d\n", config->bConfigurationValue); printf(" - Interfaces: %d %s%s%dmA\n", config->bNumInterfaces, (config->bmAttributes & 0x40) ? "Self Powered " : "Bus Powered ", (config->bmAttributes & 0x20) ? "Remote Wakeup " : "", - config->MaxPower*2); + config->bMaxPower*2); if (config->iConfiguration) { printf(" - "); usb_display_string(dev, config->iConfiguration); @@ -202,7 +202,7 @@ void usb_display_conf_desc(struct usb_config_descriptor *config, } }
-void usb_display_if_desc(struct usb_interface_descriptor *ifdesc, +void usb_display_if_desc(struct usb_interface *ifdesc, struct usb_device *dev) { printf(" Interface: %d\n", ifdesc->bInterfaceNumber); @@ -246,8 +246,8 @@ void usb_display_ep_desc(struct usb_endpoint_descriptor *epdesc) /* main routine to diasplay the configs, interfaces and endpoints */ void usb_display_config(struct usb_device *dev) { - struct usb_config_descriptor *config; - struct usb_interface_descriptor *ifdesc; + struct usb_config *config; + struct usb_interface *ifdesc; struct usb_endpoint_descriptor *epdesc; int i, ii;
@@ -321,7 +321,7 @@ void usb_show_tree_graph(struct usb_device *dev, char *pre) printf(" %s (%s, %dmA)\n", usb_get_class_desc( dev->config.if_desc[0].bInterfaceClass), portspeed(dev->speed), - dev->config.MaxPower * 2); + dev->config.bMaxPower * 2); if (strlen(dev->mf) || strlen(dev->prod) || strlen(dev->serial)) printf(" %s %s %s %s\n", pre, dev->mf, dev->prod, dev->serial); printf(" %s\n", pre); diff --git a/common/usb.c b/common/usb.c index 87fca70..6649f8c 100644 --- a/common/usb.c +++ b/common/usb.c @@ -440,10 +440,10 @@ int usb_get_configuration_no(struct usb_device *dev, { int result; unsigned int tmp; - struct usb_config_descriptor *config; + struct usb_config *config;
- config = (struct usb_config_descriptor *)&buffer[0]; + config = (struct usb_config *)&buffer[0]; result = usb_get_descriptor(dev, USB_DT_CONFIG, cfgno, buffer, 9); if (result < 9) { if (result < 0) @@ -489,7 +489,7 @@ int usb_set_address(struct usb_device *dev) */ int usb_set_interface(struct usb_device *dev, int interface, int alternate) { - struct usb_interface_descriptor *if_face = NULL; + struct usb_interface *if_face = NULL; int ret, i;
for (i = 0; i < dev->config.bNumInterfaces; i++) { @@ -1347,7 +1347,7 @@ int usb_hub_configure(struct usb_device *dev)
int usb_hub_probe(struct usb_device *dev, int ifnum) { - struct usb_interface_descriptor *iface; + struct usb_interface *iface; struct usb_endpoint_descriptor *ep; int ret;
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index b458d77..4e584a2 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -229,7 +229,7 @@ int usb_kbd_deregister(void)
static void usb_kbd_setled(struct usb_device *dev) { - struct usb_interface_descriptor *iface; + struct usb_interface *iface; iface = &dev->config.if_desc[0]; leds=0; if(scroll_lock!=0) @@ -348,7 +348,7 @@ static int usb_kbd_irq(struct usb_device *dev) /* probes the USB device dev for keyboard type */ static int usb_kbd_probe(struct usb_device *dev, unsigned int ifnum) { - struct usb_interface_descriptor *iface; + struct usb_interface *iface; struct usb_endpoint_descriptor *ep; int pipe,maxp;
diff --git a/common/usb_storage.c b/common/usb_storage.c index 19613f2..4afc8ff 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -1070,7 +1070,7 @@ retry_it: int usb_storage_probe(struct usb_device *dev, unsigned int ifnum, struct us_data *ss) { - struct usb_interface_descriptor *iface; + struct usb_interface *iface; int i; unsigned int flags = 0;
diff --git a/cpu/ppc4xx/usbdev.c b/cpu/ppc4xx/usbdev.c index faf7f08..1df2b8a 100644 --- a/cpu/ppc4xx/usbdev.c +++ b/cpu/ppc4xx/usbdev.c @@ -21,7 +21,7 @@ void process_endpoints(unsigned short usb2d0_intrin) { /*will hold the packet received */ struct usb_device_descriptor usb_device_packet; - struct usb_config_descriptor usb_config_packet; + struct usb_configuration_descriptor usb_config_packet; struct usb_string_descriptor usb_string_packet; struct devrequest setup_packet; unsigned int *setup_packet_pt; @@ -99,7 +99,7 @@ void process_endpoints(unsigned short usb2d0_intrin) usb_config_packet.bConfigurationValue = 1; usb_config_packet.iConfiguration = 0; usb_config_packet.bmAttributes = 0x40; - usb_config_packet.MaxPower = 0; + usb_config_packet.bMaxPower = 0;
/*put packet in fifo */ packet_pt = (unsigned char *)&usb_config_packet; diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 324c308..ba85991 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -96,7 +96,7 @@ static struct descriptor { * UE_DIR_IN | EHCI_INTR_ENDPT */ 3, /* bmAttributes: UE_INTERRUPT */ - 8, 0, /* wMaxPacketSize */ + 8, /* wMaxPacketSize */ 255 /* bInterval */ }, }; diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index 4ca94cb..555d2dc 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -803,7 +803,7 @@ void usb_event_poll() { struct stdio_dev *dev; struct usb_device *usb_kbd_dev; - struct usb_interface_descriptor *iface; + struct usb_interface *iface; struct usb_endpoint_descriptor *ep; int pipe; int maxp; diff --git a/include/usb.h b/include/usb.h index 7c47098..378a23b 100644 --- a/include/usb.h +++ b/include/usb.h @@ -27,6 +27,7 @@ #define _USB_H_
#include <usb_defs.h> +#include <usbdescriptors.h>
/* Everything is aribtrary */ #define USB_ALTSETTINGALLOC 4 @@ -41,13 +42,6 @@
#define USB_CNTL_TIMEOUT 100 /* 100ms timeout */
-/* String descriptor */ -struct usb_string_descriptor { - unsigned char bLength; - unsigned char bDescriptorType; - unsigned short wData[1]; -} __attribute__ ((packed)); - /* device request (setup) */ struct devrequest { unsigned char requesttype; @@ -63,47 +57,9 @@ struct usb_descriptor_header { unsigned char bDescriptorType; } __attribute__ ((packed));
-/* Device descriptor */ -struct usb_device_descriptor { - unsigned char bLength; - unsigned char bDescriptorType; - unsigned short bcdUSB; - unsigned char bDeviceClass; - unsigned char bDeviceSubClass; - unsigned char bDeviceProtocol; - unsigned char bMaxPacketSize0; - unsigned short idVendor; - unsigned short idProduct; - unsigned short bcdDevice; - unsigned char iManufacturer; - unsigned char iProduct; - unsigned char iSerialNumber; - unsigned char bNumConfigurations; -} __attribute__ ((packed)); - -/* Endpoint descriptor */ -struct usb_endpoint_descriptor { - unsigned char bLength; - unsigned char bDescriptorType; - unsigned char bEndpointAddress; - unsigned char bmAttributes; - unsigned short wMaxPacketSize; - unsigned char bInterval; - unsigned char bRefresh; - unsigned char bSynchAddress; -} __attribute__ ((packed)) __attribute__ ((aligned(2))); - -/* Interface descriptor */ -struct usb_interface_descriptor { - unsigned char bLength; - unsigned char bDescriptorType; - unsigned char bInterfaceNumber; - unsigned char bAlternateSetting; - unsigned char bNumEndpoints; - unsigned char bInterfaceClass; - unsigned char bInterfaceSubClass; - unsigned char bInterfaceProtocol; - unsigned char iInterface; +/* Interface */ +struct usb_interface { + USB_INTERFACE_DESCRIPTOR_DEFINITION;
unsigned char no_of_ep; unsigned char num_altsetting; @@ -112,20 +68,12 @@ struct usb_interface_descriptor { struct usb_endpoint_descriptor ep_desc[USB_MAXENDPOINTS]; } __attribute__ ((packed));
- -/* Configuration descriptor information.. */ -struct usb_config_descriptor { - unsigned char bLength; - unsigned char bDescriptorType; - unsigned short wTotalLength; - unsigned char bNumInterfaces; - unsigned char bConfigurationValue; - unsigned char iConfiguration; - unsigned char bmAttributes; - unsigned char MaxPower; +/* Configuration information.. */ +struct usb_config { + USB_CONFIG_DESCRIPTOR_DEFINITION;
unsigned char no_of_if; /* number of interfaces */ - struct usb_interface_descriptor if_desc[USB_MAXINTERFACES]; + struct usb_interface if_desc[USB_MAXINTERFACES]; } __attribute__ ((packed));
enum { @@ -156,7 +104,7 @@ struct usb_device {
int configno; /* selected config number */ struct usb_device_descriptor descriptor; /* Device Descriptor */ - struct usb_config_descriptor config; /* config descriptor */ + struct usb_config config; /* config descriptor */
int have_langid; /* whether string_langid is valid yet */ int string_langid; /* language ID for strings */ diff --git a/include/usbdescriptors.h b/include/usbdescriptors.h index a752097..ea05672 100644 --- a/include/usbdescriptors.h +++ b/include/usbdescriptors.h @@ -201,27 +201,33 @@ struct usb_endpoint_descriptor { u8 bInterval; } __attribute__ ((packed));
+#define USB_INTERFACE_DESCRIPTOR_DEFINITION \ + u8 bLength; \ + u8 bDescriptorType; /* 0x04 */ \ + u8 bInterfaceNumber; \ + u8 bAlternateSetting; \ + u8 bNumEndpoints; \ + u8 bInterfaceClass; \ + u8 bInterfaceSubClass; \ + u8 bInterfaceProtocol; \ + u8 iInterface + struct usb_interface_descriptor { - u8 bLength; - u8 bDescriptorType; /* 0x04 */ - u8 bInterfaceNumber; - u8 bAlternateSetting; - u8 bNumEndpoints; - u8 bInterfaceClass; - u8 bInterfaceSubClass; - u8 bInterfaceProtocol; - u8 iInterface; + USB_INTERFACE_DESCRIPTOR_DEFINITION; } __attribute__ ((packed));
+#define USB_CONFIG_DESCRIPTOR_DEFINITION \ + u8 bLength; \ + u8 bDescriptorType; /* 0x2 */ \ + u16 wTotalLength; \ + u8 bNumInterfaces; \ + u8 bConfigurationValue; \ + u8 iConfiguration; \ + u8 bmAttributes; \ + u8 bMaxPower + struct usb_configuration_descriptor { - u8 bLength; - u8 bDescriptorType; /* 0x2 */ - u16 wTotalLength; - u8 bNumInterfaces; - u8 bConfigurationValue; - u8 iConfiguration; - u8 bmAttributes; - u8 bMaxPower; + USB_CONFIG_DESCRIPTOR_DEFINITION; } __attribute__ ((packed));
When developing usb device features, it is useful to print out common usb structures.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- include/usbdescriptors.h | 31 +++++++++++++ include/usbdevice.h | 105 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 136 insertions(+), 0 deletions(-)
diff --git a/include/usbdescriptors.h b/include/usbdescriptors.h index ea05672..f4e33b6 100644 --- a/include/usbdescriptors.h +++ b/include/usbdescriptors.h @@ -510,4 +510,35 @@ struct usb_class_descriptor {
+#ifdef DEBUG +#define PRINT_DEVICE_DESCRIPTOR(d) \ +do { \ + serial_printf("usb device descriptor \n"); \ + serial_printf("\tbLength %2.2x\n", (d)->bLength); \ + serial_printf("\tbDescriptorType %2.2x\n", \ + (d)->bDescriptorType); \ + serial_printf("\tbcdUSB %4.4x\n", (d)->bcdUSB); \ + serial_printf("\tbDeviceClass %2.2x\n", (d)->bDeviceClass); \ + serial_printf("\tbDeviceSubClass %2.2x\n", \ + (d)->bDeviceSubClass); \ + serial_printf("\tbDeviceProtocol %2.2x\n", \ + (d)->bDeviceProtocol); \ + serial_printf("\tbMaxPacketSize0 %2.2x\n", \ + (d)->bMaxPacketSize0); \ + serial_printf("\tidVendor %4.4x\n", (d)->idVendor); \ + serial_printf("\tidProduct %4.4x\n", (d)->idProduct); \ + serial_printf("\tbcdDevice %4.4x\n", (d)->bcdDevice); \ + serial_printf("\tiManufacturer %2.2x\n", (d)->iManufacturer); \ + serial_printf("\tiProduct %2.2x\n", (d)->iProduct); \ + serial_printf("\tiSerialNumber %2.2x\n", (d)->iSerialNumber); \ + serial_printf("\tbNumConfigurations %2.2x\n", \ + (d)->bNumConfigurations); \ +} while (0) + +#else + +/* stubs */ +#define PRINT_DEVICE_DESCRIPTOR(d) + +#endif /* DEBUG */ #endif diff --git a/include/usbdevice.h b/include/usbdevice.h index 206dbbc..0b7961f 100644 --- a/include/usbdevice.h +++ b/include/usbdevice.h @@ -663,4 +663,109 @@ int usbd_endpoint_halted (struct usb_device_instance *device, int endpoint); void usbd_rcv_complete(struct usb_endpoint_instance *endpoint, int len, int urb_bad); void usbd_tx_complete (struct usb_endpoint_instance *endpoint);
+/* These are macros used in debugging */ +#ifdef DEBUG +#define PRINT_URB(u) \ +do { \ + serial_printf("urb %p\n", (u)); \ + serial_printf("\tendpoint %p\n", (u)->endpoint); \ + serial_printf("\tdevice %p\n", (u)->device); \ + serial_printf("\tbuffer %p\n", (u)->buffer); \ + serial_printf("\tbuffer_length %d\n", (u)->buffer_length); \ + serial_printf("\tactual_length %d\n", (u)->actual_length); \ + serial_printf("\tstatus %d\n", (u)->status); \ + serial_printf("\tdata %d\n", (u)->data); \ +} while (0) \ + +#define PRINT_USB_DEVICE_REQUEST(r) \ +do { \ + serial_printf("usb request\n"); \ + serial_printf("\tbmRequestType 0x%2.2x\n", (r)->bmRequestType); \ + if (0 == ((r)->bmRequestType & USB_REQ_DIRECTION_MASK)) \ + serial_printf("\t\tDirection : To device\n"); \ + else \ + serial_printf("\t\tDirection : To host\n"); \ + if (USB_TYPE_STANDARD == \ + ((r)->bmRequestType & USB_TYPE_STANDARD)) \ + serial_printf("\t\tType : Standard\n"); \ + if (USB_TYPE_CLASS == ((r)->bmRequestType & USB_TYPE_CLASS)) \ + serial_printf("\t\tType : Standard\n"); \ + if (USB_TYPE_VENDOR == ((r)->bmRequestType & USB_TYPE_VENDOR)) \ + serial_printf("\t\tType : Standard\n"); \ + if (USB_TYPE_RESERVED == \ + ((r)->bmRequestType & USB_TYPE_RESERVED)) \ + serial_printf("\t\tType : Standard\n"); \ + if (USB_REQ_RECIPIENT_DEVICE == \ + ((r)->bmRequestType & USB_REQ_RECIPIENT_MASK)) \ + serial_printf("\t\tRecipient : Device\n"); \ + if (USB_REQ_RECIPIENT_INTERFACE == \ + ((r)->bmRequestType & USB_REQ_RECIPIENT_MASK)) \ + serial_printf("\t\tRecipient : Interface\n"); \ + if (USB_REQ_RECIPIENT_ENDPOINT == \ + ((r)->bmRequestType & USB_REQ_RECIPIENT_MASK)) \ + serial_printf("\t\tRecipient : Endpoint\n"); \ + if (USB_REQ_RECIPIENT_OTHER == \ + ((r)->bmRequestType & USB_REQ_RECIPIENT_MASK)) \ + serial_printf("\t\tRecipient : Other\n"); \ + serial_printf("\tbRequest 0x%2.2x\n", (r)->bRequest); \ + if ((r)->bRequest == USB_REQ_GET_STATUS) \ + serial_printf("\t\tGET_STATUS\n"); \ + else if ((r)->bRequest == USB_REQ_SET_ADDRESS) \ + serial_printf("\t\tSET_ADDRESS\n"); \ + else if ((r)->bRequest == USB_REQ_SET_FEATURE) \ + serial_printf("\t\tSET_FEATURE\n"); \ + else if ((r)->bRequest == USB_REQ_GET_DESCRIPTOR) \ + serial_printf("\t\tGET_DESCRIPTOR\n"); \ + else if ((r)->bRequest == USB_REQ_SET_CONFIGURATION) \ + serial_printf("\t\tSET_CONFIGURATION\n"); \ + else if ((r)->bRequest == USB_REQ_SET_INTERFACE) \ + serial_printf("\t\tUSB_REQ_SET_INTERFACE\n"); \ + else \ + serial_printf("\tUNKNOWN %d\n", (r)->bRequest); \ + serial_printf("\twValue 0x%4.4x\n", (r)->wValue); \ + if ((r)->bRequest == USB_REQ_GET_DESCRIPTOR) { \ + switch ((r)->wValue >> 8) { \ + case USB_DESCRIPTOR_TYPE_DEVICE: \ + serial_printf("\tDEVICE\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_CONFIGURATION: \ + serial_printf("\tCONFIGURATION\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_STRING: \ + serial_printf("\tSTRING\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_INTERFACE: \ + serial_printf("\tINTERFACE\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_ENDPOINT: \ + serial_printf("\tENDPOINT\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_DEVICE_QUALIFIER: \ + serial_printf("\tDEVICE_QUALIFIER\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_OTHER_SPEED_CONFIGURATION: \ + serial_printf("\tOTHER_SPEED_CONFIGURATION\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_INTERFACE_POWER: \ + serial_printf("\tINTERFACE_POWER\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_HID: \ + serial_printf("\tHID\n"); \ + break; \ + case USB_DESCRIPTOR_TYPE_REPORT: \ + serial_printf("\tREPORT\n"); \ + break; \ + default: \ + serial_printf("\tUNKNOWN TYPE\n"); \ + break; \ + } \ + } \ + serial_printf("\twIndex 0x%4.4x\n", (r)->wIndex); \ + serial_printf("\twLength 0x%4.4x\n", (r)->wLength); \ +} while (0) +#else +/* stubs */ +#define PRINT_URB(u) +#define PRINT_USB_DEVICE_REQUEST(r) +#endif /* DEBUG */ #endif
The twl4030 provides a PHY device for connecting a link device, like musb, to physical connection.
This change adds the twl4030 usb registers and functions for initializing the PHY as required by omap3.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- Makefile | 1 + drivers/usb/phy/Makefile | 44 +++++++++++ drivers/usb/phy/twl4030.c | 184 +++++++++++++++++++++++++++++++++++++++++++++ include/twl4030.h | 143 +++++++++++++++++++++++++++++++---- 4 files changed, 357 insertions(+), 15 deletions(-) create mode 100644 drivers/usb/phy/Makefile create mode 100644 drivers/usb/phy/twl4030.c
diff --git a/Makefile b/Makefile index 329e0f5..dcaa1dc 100644 --- a/Makefile +++ b/Makefile @@ -241,6 +241,7 @@ LIBS += drivers/twserial/libtws.a LIBS += drivers/usb/gadget/libusb_gadget.a LIBS += drivers/usb/host/libusb_host.a LIBS += drivers/usb/musb/libusb_musb.a +LIBS += drivers/usb/phy/libusb_phy.a LIBS += drivers/video/libvideo.a LIBS += drivers/watchdog/libwatchdog.a LIBS += common/libcommon.a diff --git a/drivers/usb/phy/Makefile b/drivers/usb/phy/Makefile new file mode 100644 index 0000000..200b907 --- /dev/null +++ b/drivers/usb/phy/Makefile @@ -0,0 +1,44 @@ +# +# Copyright (c) 2009 Wind River Systems, Inc. +# Tom Rix Tom.Rix@windriver.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libusb_phy.a + +COBJS-$(CONFIG_TWL4030_USB) += twl4030.o +COBJS-y := twl4030.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/drivers/usb/phy/twl4030.c b/drivers/usb/phy/twl4030.c new file mode 100644 index 0000000..32f1df3 --- /dev/null +++ b/drivers/usb/phy/twl4030.c @@ -0,0 +1,184 @@ +/* + * Copyright (c) 2009 Wind River Systems, Inc. + * Tom Rix Tom.Rix@windriver.com + * + * This is file is based on + * repository git.gitorious.org/u-boot-omap3/mainline.git, + * branch omap3-dev-usb, file drivers/usb/gadget/twl4030_usb.c + * + * This is the unique part of its copyright : + * + * ------------------------------------------------------------------------ + * + * * (C) Copyright 2009 Atin Malaviya (atin.malaviya@gmail.com) + * + * Based on: twl4030_usb.c in linux 2.6 (drivers/i2c/chips/twl4030_usb.c) + * Copyright (C) 2004-2007 Texas Instruments + * Copyright (C) 2008 Nokia Corporation + * Contact: Felipe Balbi felipe.balbi@nokia.com + * + * Author: Atin Malaviya (atin.malaviya@gmail.com) + * + * ------------------------------------------------------------------------ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <twl4030.h> + +/* Defines for bits in registers */ +#define OPMODE_MASK (3 << 3) +#define XCVRSELECT_MASK (3 << 0) +#define CARKITMODE (1 << 2) +#define OTG_ENAB (1 << 5) +#define PHYPWD (1 << 0) +#define CLOCKGATING_EN (1 << 2) +#define CLK32K_EN (1 << 1) +#define REQ_PHY_DPLL_CLK (1 << 0) +#define PHY_DPLL_CLK (1 << 0) + +static int twl4030_usb_write(u8 address, u8 data) +{ + int ret; + ret = twl4030_i2c_write_u8(TWL4030_CHIP_USB, data, address); + if (ret != 0) + printf("TWL4030:USB:Write[0x%x] Error %d\n", address, ret); + + return ret; +} + +static int twl4030_usb_read(u8 address) +{ + u8 data; + int ret; + ret = twl4030_i2c_read_u8(TWL4030_CHIP_USB, &data, address); + if (ret == 0) + ret = data; + else + printf("TWL4030:USB:Read[0x%x] Error %d\n", address, ret); + + return ret; +} + +static void twl4030_usb_ldo_init(void) +{ + /* Enable writing to power configuration registers */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_MASTER, 0xC0, + TWL4030_PM_MASTER_PROTECT_KEY); + twl4030_i2c_write_u8(TWL4030_CHIP_PM_MASTER, 0x0C, + TWL4030_PM_MASTER_PROTECT_KEY); + + /* put VUSB3V1 LDO in active state */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x00, + TWL4030_PM_RECEIVER_VUSB_DEDICATED2); + + /* input to VUSB3V1 LDO is from VBAT, not VBUS */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x14, + TWL4030_PM_RECEIVER_VUSB_DEDICATED1); + + /* turn on 3.1V regulator */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x20, + TWL4030_PM_RECEIVER_VUSB3V1_DEV_GRP); + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x00, + TWL4030_PM_RECEIVER_VUSB3V1_TYPE); + + /* turn on 1.5V regulator */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x20, + TWL4030_PM_RECEIVER_VUSB1V5_DEV_GRP); + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x00, + TWL4030_PM_RECEIVER_VUSB1V5_TYPE); + + /* turn on 1.8V regulator */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x20, + TWL4030_PM_RECEIVER_VUSB1V8_DEV_GRP); + twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, 0x00, + TWL4030_PM_RECEIVER_VUSB1V8_TYPE); + + /* disable access to power configuration registers */ + twl4030_i2c_write_u8(TWL4030_CHIP_PM_MASTER, 0x00, + TWL4030_PM_MASTER_PROTECT_KEY); +} + +static void twl4030_phy_power(void) +{ + u8 pwr, clk; + /* Power the PHY */ + pwr = twl4030_usb_read(TWL4030_USB_PHY_PWR_CTRL); + pwr &= ~PHYPWD; + twl4030_usb_write(TWL4030_USB_PHY_PWR_CTRL, pwr); + /* Enable clocks */ + clk = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL); + clk |= CLOCKGATING_EN | CLK32K_EN; + twl4030_usb_write(TWL4030_USB_PHY_CLK_CTRL, clk); +} + +/* + * Initiaze the ULPI interface + * ULPI : Universal Transceiver Macrocell Low Pin Interface + * An interface between the USB link controller like musb and the + * the PHY or transceiver that drives the actual bus. + */ +int twl4030_usb_ulpi_init(void) +{ + long timeout = 1000 * 1000; /* 1 sec */; + u8 clk, sts, pwr; + + /* twl4030 ldo init */ + twl4030_usb_ldo_init(); + + /* Enable the twl4030 phy */ + twl4030_phy_power(); + + /* Enable DPLL to access PHY registers over I2C */ + clk = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL); + clk |= REQ_PHY_DPLL_CLK; + twl4030_usb_write(TWL4030_USB_PHY_CLK_CTRL, clk); + + /* Check if the PHY DPLL is locked */ + sts = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL_STS); + while (!(sts & PHY_DPLL_CLK) && 0 < timeout) { + udelay(10); + sts = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL_STS); + timeout -= 10; + } + + /* Final check */ + sts = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL_STS); + if (!(sts & PHY_DPLL_CLK)) { + printf("Error:TWL4030:USB Timeout setting PHY DPLL clock\n"); + return -1; + } + + /* + * There are two circuit blocks attached to the PHY, + * Carkit and USB OTG. Disable Carkit and enable USB OTG + */ + twl4030_usb_write(TWL4030_USB_IFC_CTRL_CLR, CARKITMODE); + pwr = twl4030_usb_read(TWL4030_USB_POWER_CTRL); + pwr |= OTG_ENAB; + twl4030_usb_write(TWL4030_USB_POWER_CTRL_SET, pwr); + /* Clear the opmode bits to ensure normal encode */ + twl4030_usb_write(TWL4030_USB_FUNC_CTRL_CLR, OPMODE_MASK); + /* Clear the xcvrselect bits to enable the high speed transeiver */ + twl4030_usb_write(TWL4030_USB_FUNC_CTRL_CLR, XCVRSELECT_MASK); + + /* Let ULPI control the DPLL clock */ + clk = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL); + clk &= ~REQ_PHY_DPLL_CLK; + twl4030_usb_write(TWL4030_USB_PHY_CLK_CTRL, clk); + + return 0; +} diff --git a/include/twl4030.h b/include/twl4030.h index f260ecb..feaec47 100644 --- a/include/twl4030.h +++ b/include/twl4030.h @@ -342,21 +342,129 @@ #define TWL4030_KEYPAD_CTRL_SOFT_NRST (1 << 0)
/* USB */ -#define TWL4030_USB_FUNC_CTRL (0x04) -#define TWL4030_USB_OPMODE_MASK (3 << 3) -#define TWL4030_USB_XCVRSELECT_MASK (3 << 0) -#define TWL4030_USB_IFC_CTRL (0x07) -#define TWL4030_USB_CARKITMODE (1 << 2) -#define TWL4030_USB_POWER_CTRL (0xAC) -#define TWL4030_USB_OTG_ENAB (1 << 5) -#define TWL4030_USB_PHY_PWR_CTRL (0xFD) -#define TWL4030_USB_PHYPWD (1 << 0) -#define TWL4030_USB_PHY_CLK_CTRL (0xFE) -#define TWL4030_USB_CLOCKGATING_EN (1 << 2) -#define TWL4030_USB_CLK32K_EN (1 << 1) -#define TWL4030_USB_REQ_PHY_DPLL_CLK (1 << 0) -#define TWL4030_USB_PHY_CLK_CTRL_STS (0xFF) -#define TWL4030_USB_PHY_DPLL_CLK (1 << 0) +#define TWL4030_USB_VENDOR_ID_LO 0x00 +#define TWL4030_USB_VENDOR_ID_HI 0x01 +#define TWL4030_USB_PRODUCT_ID_LO 0x02 +#define TWL4030_USB_PRODUCT_ID_HI 0x03 +#define TWL4030_USB_FUNC_CTRL 0x04 +#define TWL4030_USB_FUNC_CTRL_SET 0x05 +#define TWL4030_USB_FUNC_CTRL_CLR 0x06 +#define TWL4030_USB_IFC_CTRL 0x07 +#define TWL4030_USB_IFC_CTRL_SET 0x08 +#define TWL4030_USB_IFC_CTRL_CLR 0x09 +#define TWL4030_USB_OTG_CTRL 0x0A +#define TWL4030_USB_OTG_CTRL_SET 0x0B +#define TWL4030_USB_OTG_CTRL_CLR 0x0C +#define TWL4030_USB_USB_INT_EN_RISE 0x0D +#define TWL4030_USB_USB_INT_EN_RISE_SET 0x0E +#define TWL4030_USB_USB_INT_EN_RISE_CLR 0x0F +#define TWL4030_USB_USB_INT_EN_FALL 0x10 +#define TWL4030_USB_USB_INT_EN_FALL_SET 0x11 +#define TWL4030_USB_USB_INT_EN_FALL_CLR 0x12 +#define TWL4030_USB_USB_INT_STS 0x13 +#define TWL4030_USB_USB_INT_LATCH 0x14 +#define TWL4030_USB_DEBUG 0x15 +#define TWL4030_USB_SCRATCH_REG 0x16 +#define TWL4030_USB_SCRATCH_REG_SET 0x17 +#define TWL4030_USB_SCRATCH_REG_CLR 0x18 +#define TWL4030_USB_CARKIT_CTRL 0x19 +#define TWL4030_USB_CARKIT_CTRL_SET 0x1A +#define TWL4030_USB_CARKIT_CTRL_CLR 0x1B +#define TWL4030_USB_CARKIT_INT_DELAY 0x1C +#define TWL4030_USB_CARKIT_INT_EN 0x1D +#define TWL4030_USB_CARKIT_INT_EN_SET 0x1E +#define TWL4030_USB_CARKIT_INT_EN_CLR 0x1F +#define TWL4030_USB_CARKIT_INT_STS 0x20 +#define TWL4030_USB_CARKIT_INT_LATCH 0x21 +#define TWL4030_USB_CARKIT_PLS_CTRL 0x22 +#define TWL4030_USB_CARKIT_PLS_CTRL_SET 0x23 +#define TWL4030_USB_CARKIT_PLS_CTRL_CLR 0x24 +#define TWL4030_USB_TRANS_POS_WIDTH 0x25 +#define TWL4030_USB_TRANS_NEG_WIDTH 0x26 +#define TWL4030_USB_RCV_PLTY_RECOVERY 0x27 +#define TWL4030_USB_MCPC_CTRL 0x30 +#define TWL4030_USB_MCPC_CTRL_SET 0x31 +#define TWL4030_USB_MCPC_CTRL_CLR 0x32 +#define TWL4030_USB_MCPC_IO_CTRL 0x33 +#define TWL4030_USB_MCPC_IO_CTRL_SET 0x34 +#define TWL4030_USB_MCPC_IO_CTRL_CLR 0x35 +#define TWL4030_USB_MCPC_CTRL2 0x36 +#define TWL4030_USB_MCPC_CTRL2_SET 0x37 +#define TWL4030_USB_MCPC_CTRL2_CLR 0x38 +#define TWL4030_USB_OTHER_FUNC_CTRL 0x80 +#define TWL4030_USB_OTHER_FUNC_CTRL_SET 0x81 +#define TWL4030_USB_OTHER_FUNC_CTRL_CLR 0x82 +#define TWL4030_USB_OTHER_IFC_CTRL 0x83 +#define TWL4030_USB_OTHER_IFC_CTRL_SET 0x84 +#define TWL4030_USB_OTHER_IFC_CTRL_CLR 0x85 +#define TWL4030_USB_OTHER_INT_EN_RISE_SET 0x87 +#define TWL4030_USB_OTHER_INT_EN_RISE_CLR 0x88 +#define TWL4030_USB_OTHER_INT_EN_FALL 0x89 +#define TWL4030_USB_OTHER_INT_EN_FALL_SET 0x8A +#define TWL4030_USB_OTHER_INT_EN_FALL_CLR 0x8B +#define TWL4030_USB_OTHER_INT_STS 0x8C +#define TWL4030_USB_OTHER_INT_LATCH 0x8D +#define TWL4030_USB_ID_STATUS 0x96 +#define TWL4030_USB_CARKIT_SM_1_INT_EN 0x97 +#define TWL4030_USB_CARKIT_SM_1_INT_EN_SET 0x98 +#define TWL4030_USB_CARKIT_SM_1_INT_EN_CLR 0x99 +#define TWL4030_USB_CARKIT_SM_1_INT_STS 0x9A +#define TWL4030_USB_CARKIT_SM_1_INT_LATCH 0x9B +#define TWL4030_USB_CARKIT_SM_2_INT_EN 0x9C +#define TWL4030_USB_CARKIT_SM_2_INT_EN_SET 0x9D +#define TWL4030_USB_CARKIT_SM_2_INT_EN_CLR 0x9E +#define TWL4030_USB_CARKIT_SM_2_INT_STS 0x9F +#define TWL4030_USB_CARKIT_SM_2_INT_LATCH 0xA0 +#define TWL4030_USB_CARKIT_SM_CTRL 0xA1 +#define TWL4030_USB_CARKIT_SM_CTRL_SET 0xA2 +#define TWL4030_USB_CARKIT_SM_CTRL_CLR 0xA3 +#define TWL4030_USB_CARKIT_SM_CMD 0xA4 +#define TWL4030_USB_CARKIT_SM_CMD_SET 0xA5 +#define TWL4030_USB_CARKIT_SM_CMD_CLR 0xA6 +#define TWL4030_USB_CARKIT_SM_CMD_STS 0xA7 +#define TWL4030_USB_CARKIT_SM_STATUS 0xA8 +#define TWL4030_USB_CARKIT_SM_ERR_STATUS 0xAA +#define TWL4030_USB_CARKIT_SM_CTRL_STATE 0xAB +#define TWL4030_USB_POWER_CTRL 0xAC +#define TWL4030_USB_POWER_CTRL_SET 0xAD +#define TWL4030_USB_POWER_CTRL_CLR 0xAE +#define TWL4030_USB_OTHER_IFC_CTRL2 0xAF +#define TWL4030_USB_OTHER_IFC_CTRL2_SET 0xB0 +#define TWL4030_USB_OTHER_IFC_CTRL2_CLR 0xB1 +#define TWL4030_USB_REG_CTRL_EN 0xB2 +#define TWL4030_USB_REG_CTRL_EN_SET 0xB3 +#define TWL4030_USB_REG_CTRL_EN_CLR 0xB4 +#define TWL4030_USB_REG_CTRL_ERROR 0xB5 +#define TWL4030_USB_OTHER_FUNC_CTRL2 0xB8 +#define TWL4030_USB_OTHER_FUNC_CTRL2_SET 0xB9 +#define TWL4030_USB_OTHER_FUNC_CTRL2_CLR 0xBA +#define TWL4030_USB_CARKIT_ANA_CTRL 0xBB +#define TWL4030_USB_CARKIT_ANA_CTRL_SET 0xBC +#define TWL4030_USB_CARKIT_ANA_CTRL_CLR 0xBD +#define TWL4030_USB_VBUS_DEBOUNCE 0xC0 +#define TWL4030_USB_ID_DEBOUNCE 0xC1 +#define TWL4030_USB_TPH_DP_CON_MIN 0xC2 +#define TWL4030_USB_TPH_DP_CON_MAX 0xC3 +#define TWL4030_USB_TCR_DP_CON_MIN 0xC4 +#define TWL4030_USB_TCR_DP_CON_MAX 0xC5 +#define TWL4030_USB_TPH_DP_PD_SHORT 0xC6 +#define TWL4030_USB_TPH_CMD_DLY 0xC7 +#define TWL4030_USB_TPH_DET_RST 0xC8 +#define TWL4030_USB_TPH_AUD_BIAS 0xC9 +#define TWL4030_USB_TCR_UART_DET_MIN 0xCA +#define TWL4030_USB_TCR_UART_DET_MAX 0xCB +#define TWL4030_USB_TPH_ID_INT_PW 0xCD +#define TWL4030_USB_TACC_ID_INT_WAIT 0xCE +#define TWL4030_USB_TACC_ID_INT_PW 0xCF +#define TWL4030_USB_TPH_CMD_WAIT 0xD0 +#define TWL4030_USB_TPH_ACK_WAIT 0xD1 +#define TWL4030_USB_TPH_DP_DISC_DET 0xD2 +#define TWL4030_USB_VBAT_TIMER 0xD3 +#define TWL4030_USB_CARKIT_4W_DEBUG 0xE0 +#define TWL4030_USB_CARKIT_5W_DEBUG 0xE1 +#define TWL4030_USB_PHY_PWR_CTRL 0xFD +#define TWL4030_USB_PHY_CLK_CTRL 0xFE +#define TWL4030_USB_PHY_CLK_CTRL_STS 0xFF
/* * Convience functions to read and write from TWL4030 @@ -398,4 +506,9 @@ void twl4030_power_mmc_init(void); */ void twl4030_led_init(void);
+/* + * USB + */ +int twl4030_usb_ulpi_init(void); + #endif /* TWL4030_H */
This change adds the usb device support for musb.
Omap3 platform support added at the same level as davinci.
The interface for usbtty to use the musb device support was added.
Verified on omap3 beagle, zoom1 and zoom2.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- drivers/serial/usbtty.h | 2 + drivers/usb/musb/Makefile | 2 + drivers/usb/musb/musb_core.c | 8 +- drivers/usb/musb/musb_core.h | 40 ++ drivers/usb/musb/musb_debug.h | 240 ++++++++++++ drivers/usb/musb/musb_udc.c | 823 +++++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/omap3.c | 129 +++++++ drivers/usb/musb/omap3.h | 48 +++ include/usb.h | 3 +- include/usb/musb_udc.h | 54 +++ 10 files changed, 1346 insertions(+), 3 deletions(-) create mode 100644 drivers/usb/musb/musb_debug.h create mode 100644 drivers/usb/musb/musb_udc.c create mode 100644 drivers/usb/musb/omap3.c create mode 100644 drivers/usb/musb/omap3.h create mode 100644 include/usb/musb_udc.h
diff --git a/drivers/serial/usbtty.h b/drivers/serial/usbtty.h index f746d63..6b6c4a1 100644 --- a/drivers/serial/usbtty.h +++ b/drivers/serial/usbtty.h @@ -29,6 +29,8 @@ #include <usb/mpc8xx_udc.h> #elif defined(CONFIG_OMAP1510) #include <usb/omap1510_udc.h> +#elif defined(CONFIG_MUSB_UDC) +#include <usb/musb_udc.h> #elif defined(CONFIG_PXA27X) #include <usb/pxa27x_udc.h> #endif diff --git a/drivers/usb/musb/Makefile b/drivers/usb/musb/Makefile index 09e0a5f..f2ccd9f 100644 --- a/drivers/usb/musb/Makefile +++ b/drivers/usb/musb/Makefile @@ -26,7 +26,9 @@ include $(TOPDIR)/config.mk LIB := $(obj)libusb_musb.a
COBJS-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o +COBJS-$(CONFIG_MUSB_UDC) += musb_udc.o musb_core.o COBJS-$(CONFIG_USB_DAVINCI) += davinci.o +COBJS-$(CONFIG_USB_OMAP3) += omap3.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/musb/musb_core.c b/drivers/usb/musb/musb_core.c index ec57fc8..22f3dba 100644 --- a/drivers/usb/musb/musb_core.c +++ b/drivers/usb/musb/musb_core.c @@ -32,7 +32,9 @@ struct musb_regs *musbr; */ void musb_start(void) { +#if defined(CONFIG_MUSB_HCD) u8 devctl; +#endif
/* disable all interrupts */ writew(0, &musbr->intrtxe); @@ -74,9 +76,10 @@ void musb_configure_ep(struct musb_epinfo *epinfo, u8 cnt) /* Configure fifo size and fifo base address */ writeb(idx, &musbr->txfifosz); writew(fifoaddr >> 3, &musbr->txfifoadd); + + csr = readw(&musbr->txcsr); #if defined(CONFIG_MUSB_HCD) /* clear the data toggle bit */ - csr = readw(&musbr->txcsr); writew(csr | MUSB_TXCSR_CLRDATATOG, &musbr->txcsr); #endif /* Flush fifo if required */ @@ -87,9 +90,10 @@ void musb_configure_ep(struct musb_epinfo *epinfo, u8 cnt) /* Configure fifo size and fifo base address */ writeb(idx, &musbr->rxfifosz); writew(fifoaddr >> 3, &musbr->rxfifoadd); + + csr = readw(&musbr->rxcsr); #if defined(CONFIG_MUSB_HCD) /* clear the data toggle bit */ - csr = readw(&musbr->rxcsr); writew(csr | MUSB_RXCSR_CLRDATATOG, &musbr->rxcsr); #endif /* Flush fifo if required */ diff --git a/drivers/usb/musb/musb_core.h b/drivers/usb/musb/musb_core.h index f9da3f0..15c7f49 100644 --- a/drivers/usb/musb/musb_core.h +++ b/drivers/usb/musb/musb_core.h @@ -40,6 +40,36 @@
#define MUSB_EP0_FIFOSIZE 64 /* This is non-configurable */
+/* EP0 */ +struct musb_ep0_regs { + u16 reserved4; + u16 csr0; + u16 reserved5; + u16 reserved6; + u16 count0; + u8 host_type0; + u8 host_naklimit0; + u8 reserved7; + u8 reserved8; + u8 reserved9; + u8 configdata; +}; + +/* EP 1-15 */ +struct musb_epN_regs { + u16 txmaxp; + u16 txcsr; + u16 rxmaxp; + u16 rxcsr; + u16 rxcount; + u8 txtype; + u8 txinterval; + u8 rxtype; + u8 rxinterval; + u8 reserved0; + u8 fifosize; +}; + /* Mentor USB core register overlay structure */ struct musb_regs { /* common registers */ @@ -97,6 +127,16 @@ struct musb_regs { u8 rxhubaddr; u8 rxhubport; } tar[16]; + /* + * end point registers + * ep0 elements are valid when array index is 0 + * otherwise epN is valid + */ + union musb_ep_regs { + struct musb_ep0_regs ep0; + struct musb_epN_regs epN; + } ep[16]; + } __attribute__((aligned(32)));
/* diff --git a/drivers/usb/musb/musb_debug.h b/drivers/usb/musb/musb_debug.h new file mode 100644 index 0000000..cd6c29b --- /dev/null +++ b/drivers/usb/musb/musb_debug.h @@ -0,0 +1,240 @@ +/* + * Copyright (c) 2009 Wind River Systems, Inc. + * Tom Rix Tom.Rix@windriver.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Define MUSB_DEBUG before including this file to get debug macros */ +#ifdef MUSB_DEBUG + +static inline void MUSB_PRINT_PWR(u8 b) +{ + serial_printf("\tpower 0x%2.2x\n", b); + if (b & MUSB_POWER_ISOUPDATE) + serial_printf("\t\tISOUPDATE\n"); + if (b & MUSB_POWER_SOFTCONN) + serial_printf("\t\tSOFTCONN\n"); + if (b & MUSB_POWER_HSENAB) + serial_printf("\t\tHSENAB\n"); + if (b & MUSB_POWER_HSMODE) + serial_printf("\t\tHSMODE\n"); + if (b & MUSB_POWER_RESET) + serial_printf("\t\tRESET\n"); + if (b & MUSB_POWER_RESUME) + serial_printf("\t\tRESUME\n"); + if (b & MUSB_POWER_SUSPENDM) + serial_printf("\t\tSUSPENDM\n"); + if (b & MUSB_POWER_ENSUSPEND) + serial_printf("\t\tENSUSPEND\n"); +} + +static inline void MUSB_PRINT_CSR0(u16 w) +{ + serial_printf("\tcsr0 0x%4.4x\n", w); + if (w & MUSB_CSR0_FLUSHFIFO) + serial_printf("\t\tFLUSHFIFO\n"); + if (w & MUSB_CSR0_P_SVDSETUPEND) + serial_printf("\t\tSERV_SETUPEND\n"); + if (w & MUSB_CSR0_P_SVDRXPKTRDY) + serial_printf("\t\tSERV_RXPKTRDY\n"); + if (w & MUSB_CSR0_P_SENDSTALL) + serial_printf("\t\tSENDSTALL\n"); + if (w & MUSB_CSR0_P_SETUPEND) + serial_printf("\t\tSETUPEND\n"); + if (w & MUSB_CSR0_P_DATAEND) + serial_printf("\t\tDATAEND\n"); + if (w & MUSB_CSR0_P_SENTSTALL) + serial_printf("\t\tSENTSTALL\n"); + if (w & MUSB_CSR0_TXPKTRDY) + serial_printf("\t\tTXPKTRDY\n"); + if (w & MUSB_CSR0_RXPKTRDY) + serial_printf("\t\tRXPKTRDY\n"); +} + +static inline void MUSB_PRINT_INTRUSB(u8 b) +{ + serial_printf("\tintrusb 0x%2.2x\n", b); + if (b & MUSB_INTR_VBUSERROR) + serial_printf("\t\tMUSB_INTR_VBUSERROR\n"); + if (b & MUSB_INTR_SESSREQ) + serial_printf("\t\tMUSB_INTR_SESSREQ\n"); + if (b & MUSB_INTR_DISCONNECT) + serial_printf("\t\tMUSB_INTR_DISCONNECT\n"); + if (b & MUSB_INTR_CONNECT) + serial_printf("\t\tMUSB_INTR_CONNECT\n"); + if (b & MUSB_INTR_SOF) + serial_printf("\t\tMUSB_INTR_SOF\n"); + if (b & MUSB_INTR_BABBLE) + serial_printf("\t\tMUSB_INTR_RESET or MUSB_INTR_BABBLE\n"); + if (b & MUSB_INTR_RESUME) + serial_printf("\t\tMUSB_INTR_RESUME\n"); + if (b & MUSB_INTR_SUSPEND) + serial_printf("\t\tMUSB_INTR_SUSPEND\n"); +} + +static inline void MUSB_PRINT_INTRTX(u16 w) +{ + serial_printf("\tintrtx 0x%4.4x\n", w); +} + +static inline void MUSB_PRINT_INTRRX(u16 w) +{ + serial_printf("\tintrx 0x%4.4x\n", w); +} + +static inline void MUSB_PRINT_DEVCTL(u8 b) +{ + serial_printf("\tdevctl 0x%2.2x\n", b); + if (b & MUSB_DEVCTL_BDEVICE) + serial_printf("\t\tB device\n"); + else + serial_printf("\t\tA device\n"); + if (b & MUSB_DEVCTL_FSDEV) + serial_printf("\t\tFast Device -(host mode)\n"); + if (b & MUSB_DEVCTL_LSDEV) + serial_printf("\t\tSlow Device -(host mode)\n"); + if (b & MUSB_DEVCTL_HM) + serial_printf("\t\tHost mode\n"); + else + serial_printf("\t\tPeripherial mode\n"); + if (b & MUSB_DEVCTL_HR) + serial_printf("\t\tHost request started(B device)\n"); + else + serial_printf("\t\tHost request finished(B device)\n"); + if (b & MUSB_DEVCTL_BDEVICE) { + if (b & MUSB_DEVCTL_SESSION) + serial_printf("\t\tStart of session(B device)\n"); + else + serial_printf("\t\tEnd of session(B device)\n"); + } else { + if (b & MUSB_DEVCTL_SESSION) + serial_printf("\t\tStart of session(A device)\n"); + else + serial_printf("\t\tEnd of session(A device)\n"); + } +} + +static inline void MUSB_PRINT_CONFIG(u8 b) +{ + serial_printf("\tconfig 0x%2.2x\n", b); + if (b & MUSB_CONFIGDATA_MPRXE) + serial_printf("\t\tAuto combine rx bulk packets\n"); + if (b & MUSB_CONFIGDATA_MPTXE) + serial_printf("\t\tAuto split tx bulk packets\n"); + if (b & MUSB_CONFIGDATA_BIGENDIAN) + serial_printf("\t\tBig Endian ordering\n"); + else + serial_printf("\t\tLittle Endian ordering\n"); + if (b & MUSB_CONFIGDATA_HBRXE) + serial_printf("\t\tHigh speed rx iso endpoint\n"); + if (b & MUSB_CONFIGDATA_HBTXE) + serial_printf("\t\tHigh speed tx iso endpoint\n"); + if (b & MUSB_CONFIGDATA_DYNFIFO) + serial_printf("\t\tDynamic fifo sizing\n"); + if (b & MUSB_CONFIGDATA_SOFTCONE) + serial_printf("\t\tSoft Connect\n"); + if (b & MUSB_CONFIGDATA_UTMIDW) + serial_printf("\t\t16 bit data width\n"); + else + serial_printf("\t\t8 bit data width\n"); +} + +static inline void MUSB_PRINT_RXMAXP(u16 w) +{ + serial_printf("\trxmaxp 0x%4.4x\n", w); +} + +static inline void MUSB_PRINT_RXCSR(u16 w) +{ + serial_printf("\trxcsr 0x%4.4x\n", w); + if (w & MUSB_RXCSR_AUTOCLEAR) + serial_printf("\t\tautclear\n"); + if (w & MUSB_RXCSR_DMAENAB) + serial_printf("\t\tdma enable\n"); + if (w & MUSB_RXCSR_DISNYET) + serial_printf("\t\tdisable nyet\n"); + if (w & MUSB_RXCSR_PID_ERR) + serial_printf("\t\tpid error\n"); + if (w & MUSB_RXCSR_DMAMODE) + serial_printf("\t\tdma mode should be 0 \n"); + if (w & MUSB_RXCSR_CLRDATATOG) + serial_printf("\t\tclear data\n"); + if (w & MUSB_RXCSR_FLUSHFIFO) + serial_printf("\t\tflush fifo\n"); + if (w & MUSB_RXCSR_DATAERROR) + serial_printf("\t\tdata error\n"); + if (w & MUSB_RXCSR_FIFOFULL) + serial_printf("\t\tfifo full\n"); + if (w & MUSB_RXCSR_RXPKTRDY) + serial_printf("\t\trx packet ready\n"); + if (w & MUSB_RXCSR_P_ISO) + serial_printf("\t\tiso mode\n"); + else + serial_printf("\t\tbulk mode\n"); + if (w & MUSB_RXCSR_P_SENTSTALL) + serial_printf("\t\tsent stall\n"); + if (w & MUSB_RXCSR_P_SENDSTALL) + serial_printf("\t\tsend stall\n"); + if (w & MUSB_RXCSR_P_OVERRUN) + serial_printf("\t\toverrun\n"); +} + +static inline void MUSB_PRINT_TXMAXP(u16 w) +{ + serial_printf("\ttxmaxp 0x%4.4x\n", w); +} + +static inline void MUSB_PRINT_TXCSR(u16 w) +{ + serial_printf("\ttxcsr 0x%4.4x\n", w); + if (w & MUSB_TXCSR_TXPKTRDY) + serial_printf("\t\ttxpktrdy\n"); + if (w & MUSB_TXCSR_FIFONOTEMPTY) + serial_printf("\t\tfifo not empty\n"); + if (w & MUSB_TXCSR_FLUSHFIFO) + serial_printf("\t\tflush fifo\n"); + if (w & MUSB_TXCSR_CLRDATATOG) + serial_printf("\t\tclear data toggle\n"); + if (w & MUSB_TXCSR_MODE) + serial_printf("\t\tTX mode\n"); + else + serial_printf("\t\tRX mode\n"); + if (w & MUSB_TXCSR_P_UNDERRUN) + serial_printf("\t\tunderrun\n"); + if (w & MUSB_TXCSR_P_SENTSTALL) + serial_printf("\t\tsent stall\n"); + if (w & MUSB_TXCSR_P_SENDSTALL) + serial_printf("\t\tsend stall\n"); +} + +#else + +/* stubs */ + +#define MUSB_PRINT_PWR(b) +#define MUSB_PRINT_CSR0(w) +#define MUSB_PRINT_INTRUSB(b) +#define MUSB_PRINT_INTRTX(w) +#define MUSB_PRINT_INTRRX(w) +#define MUSB_PRINT_DEVCTL(b) +#define MUSB_PRINT_CONFIG(b) +#define MUSB_PRINT_RXMAXP(w) +#define MUSB_PRINT_RXCSR(w) +#define MUSB_PRINT_TXMAXP(w) +#define MUSB_PRINT_TXCSR(w) + +#endif /* MUSB_DEBUG */ diff --git a/drivers/usb/musb/musb_udc.c b/drivers/usb/musb/musb_udc.c new file mode 100644 index 0000000..3be92f1 --- /dev/null +++ b/drivers/usb/musb/musb_udc.c @@ -0,0 +1,823 @@ +/* + * Copyright (c) 2009 Wind River Systems, Inc. + * Tom Rix Tom.Rix@windriver.com + * + * This file is a rewrite of the usb device part of + * repository git.omapzoom.org/repo/u-boot.git, branch master, + * file cpu/omap3/fastboot.c + * + * This is the unique part of its copyright : + * + * ------------------------------------------------------------------------- + * + * (C) Copyright 2008 - 2009 + * Windriver, <www.windriver.com> + * Tom Rix Tom.Rix@windriver.com + * + * ------------------------------------------------------------------------- + * + * The details of connecting the device to the uboot usb device subsystem + * came from the old omap3 repository www.sakoman.net/u-boot-omap3.git, + * branch omap3-dev-usb, file drivers/usb/usbdcore_musb.c + * + * This is the unique part of its copyright : + * + * ------------------------------------------------------------------------- + * + * (C) Copyright 2008 Texas Instruments Incorporated. + * + * Based on + * u-boot OMAP1510 USB drivers (drivers/usbdcore_omap1510.c) + * twl4030 init based on linux (drivers/i2c/chips/twl4030_usb.c) + * + * Author: Diego Dompe (diego.dompe@ridgerun.com) + * Atin Malaviya (atin.malaviya@gmail.com) + * + * ------------------------------------------------------------------------- + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <usb/musb_udc.h> +#include "../gadget/ep0.h" +#include "musb_core.h" +#if defined(CONFIG_USB_OMAP3) +#include "omap3.h" +#elif defined(CONFIG_USB_DAVINCI) +#include "davinci.h" +#endif + +/* Define MUSB_DEBUG for debugging */ +/* #define MUSB_DEBUG */ +#include "musb_debug.h" + +#define MAX_ENDPOINT 15 + +#define GET_ENDPOINT(dev,ep) \ +(((struct usb_device_instance *)(dev))->bus->endpoint_array + ep) + +#define SET_EP0_STATE(s) \ +do { \ + if ((0 <= (s)) && (SET_ADDRESS >= (s))) { \ + if ((s) != ep0_state) { \ + if ((debug_setup) && (debug_level > 1)) \ + serial_printf("INFO : Changing state from %s to %s in %s at line %d\n", ep0_state_strings[ep0_state], ep0_state_strings[s], __PRETTY_FUNCTION__, __LINE__); \ + ep0_state = s; \ + } \ + } else { \ + if (debug_level > 0) \ + serial_printf("Error at %s %d with setting state %d is invalid\n", __PRETTY_FUNCTION__, __LINE__, s); \ + } \ +} while (0) + +/* static implies these initialized to 0 or NULL */ +static int debug_setup; +static int debug_level; +static struct musb_epinfo epinfo[MAX_ENDPOINT * 2]; +static enum ep0_state_enum { IDLE = 0, TX, RX, SET_ADDRESS } ep0_state = IDLE; +static char *ep0_state_strings[4] = { + "IDLE", + "TX", + "RX", + "SET_ADDRESS", +}; + +static struct urb *ep0_urb; +struct usb_endpoint_instance *ep0_endpoint; +static struct usb_device_instance *udc_device; +static int enabled; + +#ifdef MUSB_DEBUG +static void musb_db_regs(void) +{ + u8 b; + u16 w; + + b = readb(&musbr->faddr); + serial_printf("\tfaddr 0x%2.2x\n", b); + + b = readb(&musbr->power); + MUSB_PRINT_PWR(b); + + w = readw(&musbr->ep[0].ep0.csr0); + MUSB_PRINT_CSR0(w); + + b = readb(&musbr->devctl); + MUSB_PRINT_DEVCTL(b); + + b = readb(&musbr->ep[0].ep0.configdata); + MUSB_PRINT_CONFIG(b); + + w = readw(&musbr->frame); + serial_printf("\tframe 0x%4.4x\n", w); + + b = readb(&musbr->index); + serial_printf("\tindex 0x%2.2x\n", b); + + w = readw(&musbr->ep[1].epN.rxmaxp); + MUSB_PRINT_RXMAXP(w); + + w = readw(&musbr->ep[1].epN.rxcsr); + MUSB_PRINT_RXCSR(w); + + w = readw(&musbr->ep[1].epN.txmaxp); + MUSB_PRINT_TXMAXP(w); + + w = readw(&musbr->ep[1].epN.txcsr); + MUSB_PRINT_TXCSR(w); +} +#else +#define musb_db_regs() +#endif /* DEBUG_MUSB */ + +static void musb_peri_softconnect(void) +{ + u8 power, devctl; + u8 intrusb; + u16 intrrx, intrtx; + + /* Power off MUSB */ + power = readb(&musbr->power); + power &= ~MUSB_POWER_SOFTCONN; + writeb(power, &musbr->power); + + /* Read intr to clear */ + intrusb = readb(&musbr->intrusb); + intrrx = readw(&musbr->intrrx); + intrtx = readw(&musbr->intrtx); + + udelay(2 * 500000); /* 1 sec */ + + /* Power on MUSB */ + power = readb(&musbr->power); + power |= MUSB_POWER_SOFTCONN; + /* + * The usb device interface is usb 1.1 + * Disable 2.0 high speed by clearring the hsenable bit. + */ + power &= ~MUSB_POWER_HSENAB; + writeb(power, &musbr->power); + + /* Check if device is in b-peripheral mode */ + devctl = readb(&musbr->devctl); + if (!(devctl & MUSB_DEVCTL_BDEVICE) || + (devctl & MUSB_DEVCTL_HM)) { + serial_printf("ERROR : Unsupport USB mode\n"); + serial_printf("Check that mini-B USB cable is attached to the device\n"); + } + + if (debug_setup && (debug_level > 1)) + musb_db_regs(); +} + +static void musb_peri_reset(void) +{ + if ((debug_setup) && (debug_level > 1)) + serial_printf("INFO : %s reset\n", __PRETTY_FUNCTION__); + + /* the device address is reset by the event */ + usbd_device_event_irq(udc_device, DEVICE_RESET, 0); + SET_EP0_STATE(IDLE); + if (ep0_endpoint) + ep0_endpoint->endpoint_address = 0xff; +} + +static void musb_peri_resume(void) +{ + /* noop */ +} + +static void musb_peri_ep0_stall(void) +{ + u16 csr0; + csr0 = readw(&musbr->ep[0].ep0.csr0); + csr0 |= MUSB_CSR0_P_SENDSTALL; + writew(csr0, &musbr->ep[0].ep0.csr0); + if ((debug_setup) && (debug_level > 1)) + serial_printf("INFO : %s stall\n", __PRETTY_FUNCTION__); +} + +static void musb_peri_ep0_ack_req(void) +{ + u16 csr0; + csr0 = readw(&musbr->ep[0].ep0.csr0); + csr0 |= MUSB_CSR0_P_SVDRXPKTRDY; + writew(csr0, &musbr->ep[0].ep0.csr0); +} + +static void musb_ep0_tx_ready(void) +{ + u16 csr0; + csr0 = readw(&musbr->ep[0].ep0.csr0); + csr0 |= MUSB_CSR0_TXPKTRDY; + writew(csr0, &musbr->ep[0].ep0.csr0); +} + +static void musb_peri_ep0_last(void) +{ + u16 csr0; + csr0 = readw(&musbr->ep[0].ep0.csr0); + csr0 |= MUSB_CSR0_P_DATAEND; + writew(csr0, &musbr->ep[0].ep0.csr0); +} + +static void musb_peri_ep0_set_address(void) +{ + writeb(udc_device->address, &musbr->faddr); + SET_EP0_STATE(IDLE); + usbd_device_event_irq(udc_device, DEVICE_ADDRESS_ASSIGNED, 0); + if ((debug_setup) && (debug_level > 1)) + serial_printf("INFO : %s Address set to %d\n", __PRETTY_FUNCTION__, udc_device->address); +} + +static void musb_peri_rx_ack(unsigned int ep) +{ + u16 peri_rxcsr; + peri_rxcsr = readw(&musbr->ep[ep].epN.rxcsr); + peri_rxcsr &= ~MUSB_RXCSR_RXPKTRDY; + writew(peri_rxcsr, &musbr->ep[ep].epN.rxcsr); +} + +static void musb_peri_tx_ready(unsigned int ep) +{ + u16 peri_txcsr; + peri_txcsr = readw(&musbr->ep[ep].epN.txcsr); + peri_txcsr |= MUSB_TXCSR_TXPKTRDY; + writew(peri_txcsr, &musbr->ep[ep].epN.txcsr); +} + +static void musb_peri_ep0_zero_data_request(int err) +{ + musb_peri_ep0_ack_req(); + + if (err) { + musb_peri_ep0_stall(); + SET_EP0_STATE(IDLE); + } else { + + musb_peri_ep0_last(); + + /* USBD state */ + switch (ep0_urb->device_request.bRequest) { + case USB_REQ_SET_ADDRESS: + if ((debug_setup) && (debug_level > 1)) + serial_printf("INFO : %s received set address\n", __PRETTY_FUNCTION__); + break; + + case USB_REQ_SET_CONFIGURATION: + if ((debug_setup) && (debug_level > 1)) + serial_printf("INFO : %s Configured\n", __PRETTY_FUNCTION__); + usbd_device_event_irq(udc_device, DEVICE_CONFIGURED, 0); + break; + } + + /* EP0 state */ + if (USB_REQ_SET_ADDRESS == ep0_urb->device_request.bRequest) { + SET_EP0_STATE(SET_ADDRESS); + } else { + SET_EP0_STATE(IDLE); + } + } +} + +static void musb_peri_ep0_rx_data_request(void) +{ + /* + * This is the completion of the data OUT / RX + * + * Host is sending data to ep0 that is not + * part of setup. This comes from the cdc_recv_setup + * op that is device specific. + * + */ + musb_peri_ep0_ack_req(); + + ep0_endpoint->rcv_urb = ep0_urb; + ep0_urb->actual_length = 0; + SET_EP0_STATE(RX); +} + +static void musb_peri_ep0_tx_data_request(int err) +{ + if (err) { + musb_peri_ep0_stall(); + SET_EP0_STATE(IDLE); + } else { + musb_peri_ep0_ack_req(); + + ep0_endpoint->tx_urb = ep0_urb; + ep0_endpoint->sent = 0; + SET_EP0_STATE(TX); + } +} + +static void musb_peri_ep0_idle(void) +{ + u16 count0; + int err; + u16 csr0; + + csr0 = readw(&musbr->ep[0].ep0.csr0); + + if (!(MUSB_CSR0_RXPKTRDY & csr0)) + goto end; + + count0 = readw(&musbr->ep[0].ep0.count0); + if (count0 == 0) + goto end; + + if (count0 != 8) { + if ((debug_setup) && (debug_level > 1)) + serial_printf("WARN : %s SETUP incorrect size %d\n", + __PRETTY_FUNCTION__, count0); + musb_peri_ep0_stall(); + goto end; + } + + read_fifo(0, count0, &ep0_urb->device_request); + + if (debug_level > 2) { + PRINT_USB_DEVICE_REQUEST(&ep0_urb->device_request); + } + + if (0 == ep0_urb->device_request.wLength) { + err = ep0_recv_setup(ep0_urb); + + /* Zero data request */ + musb_peri_ep0_zero_data_request(err); + } else { + /* Is data coming or going ? */ + u8 reqType = ep0_urb->device_request.bmRequestType; + if (USB_REQ_DEVICE2HOST == (reqType & USB_REQ_DIRECTION_MASK)) { + err = ep0_recv_setup(ep0_urb); + /* Device to host */ + musb_peri_ep0_tx_data_request(err); + } else { + /* + * Host to device + * + * The RX routine will call ep0_recv_setup + * when the data packet has arrived. + */ + musb_peri_ep0_rx_data_request(); + } + } + +end: + return; +} + +static void musb_peri_ep0_rx(void) +{ + /* + * This is the completion of the data OUT / RX + * + * Host is sending data to ep0 that is not + * part of setup. This comes from the cdc_recv_setup + * op that is device specific. + * + * Pass the data back to driver ep0_recv_setup which + * should give the cdc_recv_setup the chance to handle + * the rx + */ + u16 csr0; + u16 count0; + + if (debug_level > 3) { + if (0 != ep0_urb->actual_length) { + serial_printf("%s finished ? %d of %d\n", + __PRETTY_FUNCTION__, + ep0_urb->actual_length, + ep0_urb->device_request.wLength); + } + } + + if (ep0_urb->device_request.wLength == ep0_urb->actual_length) { + musb_peri_ep0_last(); + SET_EP0_STATE(IDLE); + ep0_recv_setup(ep0_urb); + return; + } + + csr0 = readw(&musbr->ep[0].ep0.csr0); + if (!(MUSB_CSR0_RXPKTRDY & csr0)) + return; + + count0 = readw(&musbr->ep[0].ep0.count0); + + if (count0) { + struct usb_endpoint_instance *endpoint; + u32 length; + u8 *data; + + endpoint = ep0_endpoint; + if (endpoint && endpoint->rcv_urb) { + struct urb *urb = endpoint->rcv_urb; + unsigned int remaining_space = urb->buffer_length - + urb->actual_length; + + if (remaining_space) { + int urb_bad = 0; /* urb is good */ + + if (count0 > remaining_space) + length = remaining_space; + else + length = count0; + + data = (u8 *) urb->buffer_data; + data += urb->actual_length; + + /* The common musb fifo reader */ + read_fifo(0, length, data); + + musb_peri_ep0_ack_req(); + + /* + * urb's actual_length is updated in + * usbd_rcv_complete + */ + usbd_rcv_complete(endpoint, length, urb_bad); + + } else { + if (debug_level > 0) + serial_printf("ERROR : %s no space in rcv buffer\n", __PRETTY_FUNCTION__); + } + } else { + if (debug_level > 0) + serial_printf("ERROR : %s problem with endpoint\n", __PRETTY_FUNCTION__); + } + } else { + if (debug_level > 0) + serial_printf("ERROR : %s with nothing to do\n", __PRETTY_FUNCTION__); + } +} + +static void musb_peri_ep0_tx(void) +{ + u16 csr0; + int transfer_size = 0; + + csr0 = readw(&musbr->ep[0].ep0.csr0); + + /* Check for pending tx */ + if (csr0 & MUSB_CSR0_TXPKTRDY) + return; + + /* Check if this is the last packet sent */ + if (ep0_endpoint->sent >= ep0_urb->actual_length) { + SET_EP0_STATE(IDLE); + return; + } + + transfer_size = ep0_urb->actual_length - ep0_endpoint->sent; + if (transfer_size > ep0_endpoint->tx_packetSize) + transfer_size = ep0_endpoint->tx_packetSize; + + write_fifo(0, transfer_size, &ep0_urb->buffer[ep0_endpoint->sent]); + ep0_endpoint->sent += transfer_size; + + musb_ep0_tx_ready(); + if (ep0_endpoint->sent >= ep0_urb->actual_length) + musb_peri_ep0_last(); +} + +static void musb_peri_ep0(void) +{ + u16 csr0; + + if (SET_ADDRESS == ep0_state) + musb_peri_ep0_set_address(); + + csr0 = readw(&musbr->ep[0].ep0.csr0); + + /* Error conditions */ + if (MUSB_CSR0_P_SENTSTALL & csr0) { + csr0 &= ~MUSB_CSR0_P_SENTSTALL; + writew(csr0, &musbr->ep[0].ep0.csr0); + SET_EP0_STATE(IDLE); + } + if (MUSB_CSR0_P_SETUPEND & csr0) { + csr0 |= MUSB_CSR0_P_SVDSETUPEND; + writew(csr0, &musbr->ep[0].ep0.csr0); + SET_EP0_STATE(IDLE); + if ((debug_setup) && (debug_level > 1)) + serial_printf("WARN: %s SETUPEND\n", __PRETTY_FUNCTION__); + } + + /* Normal states */ + if (IDLE == ep0_state) + musb_peri_ep0_idle(); + + if (TX == ep0_state) + musb_peri_ep0_tx(); + + if (RX == ep0_state) + musb_peri_ep0_rx(); +} + +static void musb_peri_rx_ep(unsigned int ep) +{ + u16 peri_rxcount = readw(&musbr->ep[ep].epN.rxcount); + + if (peri_rxcount) { + struct usb_endpoint_instance *endpoint; + u32 length; + u8 *data; + + endpoint = GET_ENDPOINT(udc_device, ep); + if (endpoint && endpoint->rcv_urb) { + struct urb *urb = endpoint->rcv_urb; + unsigned int remaining_space = urb->buffer_length - + urb->actual_length; + + if (remaining_space) { + int urb_bad = 0; /* urb is good */ + + if (peri_rxcount > remaining_space) + length = remaining_space; + else + length = peri_rxcount; + + data = (u8 *) urb->buffer_data; + data += urb->actual_length; + + /* The common musb fifo reader */ + read_fifo(ep, length, data); + + musb_peri_rx_ack(ep); + + /* + * urb's actual_length is updated in + * usbd_rcv_complete + */ + usbd_rcv_complete(endpoint, length, urb_bad); + + } else { + if (debug_level > 0) + serial_printf("ERROR : %s %d no space in rcv buffer\n", __PRETTY_FUNCTION__, ep); + } + } else { + if (debug_level > 0) + serial_printf("ERROR : %s %d problem with endpoint\n", __PRETTY_FUNCTION__, ep); + } + + } else { + if (debug_level > 0) + serial_printf("ERROR : %s %d with nothing to do\n", __PRETTY_FUNCTION__, ep); + } +} + +static void musb_peri_rx(u16 intr) +{ + unsigned int ep; + + /* Check for EP0 */ + if (0x01 & intr) + musb_peri_ep0(); + + for (ep = 1; ep < 16; ep++) { + if ((1 << ep) & intr) + musb_peri_rx_ep(ep); + } +} + +static void musb_peri_tx(u16 intr) +{ + u8 ep; + /* Check for EP0 */ + if (0x01 & intr) + musb_peri_ep0_tx(); + + for (ep = 1; ep < 16; ep++) { + if ((1 << ep) & intr) { + /* handle tx for this endpoint */ + } + } +} + +void udc_irq(void) +{ + /* This is a high freq called function */ + if (enabled) { + + u8 intrusb; + u16 intrrx, intrtx; + + intrusb = readb(&musbr->intrusb); + intrrx = readw(&musbr->intrrx); + intrtx = readw(&musbr->intrtx); + + /* + * See drivers/usb/gadget/mpc8xx_udc.c for + * state diagram going from detached through + * configuration. + */ + if (MUSB_INTR_RESUME & intrusb) { + usbd_device_event_irq(udc_device, + DEVICE_BUS_ACTIVITY, 0); + musb_peri_resume(); + } + + musb_peri_ep0(); + + if (intrrx) + musb_peri_rx(intrrx); + + if (intrtx) + musb_peri_tx(intrtx); + + if (MUSB_INTR_RESET & intrusb) { + usbd_device_event_irq(udc_device, DEVICE_RESET, 0); + musb_peri_reset(); + } + + if (MUSB_INTR_DISCONNECT & intrusb) { + /* cable unplugged from hub/host */ + usbd_device_event_irq(udc_device, DEVICE_HUB_RESET, 0); + } + + if (MUSB_INTR_SOF & intrusb) { + usbd_device_event_irq(udc_device, + DEVICE_BUS_ACTIVITY, 0); + musb_peri_resume(); + } + + if (MUSB_INTR_SUSPEND & intrusb) { + usbd_device_event_irq(udc_device, + DEVICE_BUS_INACTIVE, 0); + } + } +} + +void udc_set_nak(int ep_num) +{ + /* noop */ +} + +void udc_unset_nak(int ep_num) +{ + /* noop */ +} + +int udc_endpoint_write(struct usb_endpoint_instance *endpoint) +{ + int ret = 0; + + /* Transmit only if the hardware is available */ + if (endpoint->tx_urb && endpoint->state == 0) { + unsigned int ep = endpoint->endpoint_address & + USB_ENDPOINT_NUMBER_MASK; + + u16 peri_txcsr = readw(&musbr->ep[ep].epN.txcsr); + + /* Error conditions */ + if (peri_txcsr & MUSB_TXCSR_P_UNDERRUN) { + peri_txcsr &= ~MUSB_TXCSR_P_UNDERRUN; + writew(peri_txcsr, &musbr->ep[ep].epN.txcsr); + } + + if (debug_level > 1) { + MUSB_PRINT_TXCSR(peri_txcsr); + } + + /* Check if a packet is waiting to be sent */ + if (!(peri_txcsr & MUSB_TXCSR_TXPKTRDY)) { + u32 length; + u8 *data; + struct urb *urb = endpoint->tx_urb; + unsigned int remaining_packet = urb->actual_length - + endpoint->sent; + + if (endpoint->tx_packetSize < remaining_packet) + length = endpoint->tx_packetSize; + else + length = remaining_packet; + + data = (u8 *) urb->buffer; + data += endpoint->sent; + + /* common musb fifo function */ + write_fifo(ep, length, data); + + musb_peri_tx_ready(ep); + + endpoint->last = length; + /* usbd_tx_complete will take care of updating 'sent' */ + usbd_tx_complete(endpoint); + } + } else { + if (debug_level > 0) + serial_printf("ERROR : %s Problem with urb %p or ep state %d\n", + __PRETTY_FUNCTION__, + endpoint->tx_urb, endpoint->state); + } + + return ret; +} + +void udc_setup_ep(struct usb_device_instance *device, unsigned int id, + struct usb_endpoint_instance *endpoint) +{ + if (0 == id) { + /* EP0 */ + ep0_endpoint = endpoint; + ep0_endpoint->endpoint_address = 0xff; + ep0_urb = usbd_alloc_urb(device, endpoint); + } else if (MAX_ENDPOINT >= id) { + int ep_addr; + + /* Check the direction */ + ep_addr = endpoint->endpoint_address; + if (USB_DIR_IN == (ep_addr & USB_ENDPOINT_DIR_MASK)) { + /* IN */ + epinfo[(id * 2) + 1].epsize = endpoint->tx_packetSize; + } else { + /* OUT */ + epinfo[id * 2].epsize = endpoint->rcv_packetSize; + } + + musb_configure_ep(&epinfo[0], + sizeof(epinfo) / sizeof(struct musb_epinfo)); + } else { + if (debug_level > 0) + serial_printf("ERROR : %s endpoint request %d exceeds maximum %d\n", + __PRETTY_FUNCTION__, id, MAX_ENDPOINT); + } +} + +void udc_connect(void) +{ + /* noop */ +} + +void udc_disconnect(void) +{ + /* noop */ +} + +void udc_enable(struct usb_device_instance *device) +{ + /* Save the device structure pointer */ + udc_device = device; + + enabled = 1; +} + +void udc_disable(void) +{ + enabled = 0; +} + +void udc_startup_events(struct usb_device_instance *device) +{ + /* The DEVICE_INIT event puts the USB device in the state STATE_INIT. */ + usbd_device_event_irq(device, DEVICE_INIT, 0); + + /* + * The DEVICE_CREATE event puts the USB device in the state + * STATE_ATTACHED. + */ + usbd_device_event_irq(device, DEVICE_CREATE, 0); + + udc_enable(device); +} + +int udc_init(void) +{ + int ret; + int ep_loop; + + ret = musb_platform_init(); + if (ret < 0) + goto end; + + /* Configure all the endpoint FIFO's and start usb controller */ + musbr = musb_cfg.regs; + + /* Initialize the endpoints */ + for (ep_loop = 0; ep_loop < MAX_ENDPOINT * 2; ep_loop++) { + epinfo[ep_loop].epnum = (ep_loop / 2) + 1; + epinfo[ep_loop].epdir = ep_loop % 2; /* OUT, IN */ + epinfo[ep_loop].epsize = 0; + } + + musb_peri_softconnect(); + + ret = 0; +end: + return ret; +} diff --git a/drivers/usb/musb/omap3.c b/drivers/usb/musb/omap3.c new file mode 100644 index 0000000..3e502e7 --- /dev/null +++ b/drivers/usb/musb/omap3.c @@ -0,0 +1,129 @@ +/* + * Copyright (c) 2009 Wind River Systems, Inc. + * Tom Rix Tom.Rix@windriver.com + * + * This is file is based on + * repository git.gitorious.org/u-boot-omap3/mainline.git, + * branch omap3-dev-usb, file drivers/usb/host/omap3530_usb.c + * + * This is the unique part of its copyright : + * + * ------------------------------------------------------------------------ + * + * Copyright (c) 2009 Texas Instruments + * + * ------------------------------------------------------------------------ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <twl4030.h> +#include "omap3.h" + +static int platform_needs_initialization = 1; + +struct musb_config musb_cfg = { + (struct musb_regs *)MENTOR_USB0_BASE, + OMAP3_USB_TIMEOUT, + 0 +}; + +/* + * OMAP3 USB OTG registers. + */ +struct omap3_otg_regs { + u32 revision; + u32 sysconfig; + u32 sysstatus; + u32 interfsel; + u32 simenable; + u32 forcestdby; +}; + +static struct omap3_otg_regs *otg; + +#define OMAP3_OTG_SYSCONFIG_SMART_STANDBY_MODE 0x2000 +#define OMAP3_OTG_SYSCONFIG_NO_STANDBY_MODE 0x1000 +#define OMAP3_OTG_SYSCONFIG_SMART_IDLE_MODE 0x0010 +#define OMAP3_OTG_SYSCONFIG_NO_IDLE_MODE 0x0008 +#define OMAP3_OTG_SYSCONFIG_ENABLEWAKEUP 0x0004 +#define OMAP3_OTG_SYSCONFIG_SOFTRESET 0x0002 +#define OMAP3_OTG_SYSCONFIG_AUTOIDLE 0x0001 + +#define OMAP3_OTG_SYSSTATUS_RESETDONE 0x0001 + +#define OMAP3_OTG_INTERFSEL_OMAP 0x0001 + +#define OMAP3_OTG_FORCESTDBY_STANDBY 0x0001 + + +#ifdef DEBUG_MUSB_OMAP3 +static void musb_db_otg_regs(void) +{ + u32 l; + l = readl(&otg->revision); + serial_printf("OTG_REVISION 0x%x\n", l); + l = readl(&otg->sysconfig); + serial_printf("OTG_SYSCONFIG 0x%x\n", l); + l = readl(&otg->sysstatus); + serial_printf("OTG_SYSSTATUS 0x%x\n", l); + l = readl(&otg->interfsel); + serial_printf("OTG_INTERFSEL 0x%x\n", l); + l = readl(&otg->forcestdby); + serial_printf("OTG_FORCESTDBY 0x%x\n", l); +} +#endif + +int musb_platform_init(void) +{ + int ret = -1; + + if (platform_needs_initialization) { + u32 stdby; + + if (twl4030_usb_ulpi_init()) { + serial_printf("ERROR: %s Could not initialize PHY\n", + __PRETTY_FUNCTION__); + goto end; + } + + otg = (struct omap3_otg_regs *)OMAP3_OTG_BASE; + + /* Set OTG to always be on */ + writel(OMAP3_OTG_SYSCONFIG_NO_STANDBY_MODE | + OMAP3_OTG_SYSCONFIG_NO_IDLE_MODE, &otg->sysconfig); + + /* Set the interface */ + writel(OMAP3_OTG_INTERFSEL_OMAP, &otg->interfsel); + + /* Clear force standby */ + stdby = readl(&otg->forcestdby); + stdby &= ~OMAP3_OTG_FORCESTDBY_STANDBY; + writel(stdby, &otg->forcestdby); + + platform_needs_initialization = 0; + } + + ret = platform_needs_initialization; +end: + return ret; + +} + +void musb_platform_deinit(void) +{ + /* noop */ +} diff --git a/drivers/usb/musb/omap3.h b/drivers/usb/musb/omap3.h new file mode 100644 index 0000000..20fc9d2 --- /dev/null +++ b/drivers/usb/musb/omap3.h @@ -0,0 +1,48 @@ +/* + * Copyright (c) 2009 Wind River Systems, Inc. + * Tom Rix Tom.Rix@windriver.com + * + * This file is based on the file drivers/usb/musb/davinci.h + * + * This is the unique part of its copyright: + * + * -------------------------------------------------------------------- + * + * Copyright (c) 2008 Texas Instruments + * Author: Thomas Abraham t-abraham@ti.com, Texas Instruments + * + * -------------------------------------------------------------------- + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _MUSB_OMAP3_H_ +#define _MUSB_OMAP3_H_ + +#include "musb_core.h" + +/* Base address of MUSB registers */ +#define MENTOR_USB0_BASE (OMAP34XX_CORE_L4_IO_BASE + 0xAB000) + +/* Base address of OTG registers */ +#define OMAP3_OTG_BASE (MENTOR_USB0_BASE + 0x400) + +/* Timeout for USB module */ +#define OMAP3_USB_TIMEOUT 0x3FFFFFF + +int musb_platform_init(void); + +#endif /* _MUSB_OMAP3_H */ + diff --git a/include/usb.h b/include/usb.h index 378a23b..198d5bb 100644 --- a/include/usb.h +++ b/include/usb.h @@ -131,7 +131,8 @@ struct usb_device { #if defined(CONFIG_USB_UHCI) || defined(CONFIG_USB_OHCI) || \ defined(CONFIG_USB_EHCI) || defined(CONFIG_USB_OHCI_NEW) || \ defined(CONFIG_USB_SL811HS) || defined(CONFIG_USB_ISP116X_HCD) || \ - defined(CONFIG_USB_R8A66597_HCD) || defined(CONFIG_USB_DAVINCI) + defined(CONFIG_USB_R8A66597_HCD) || defined(CONFIG_USB_DAVINCI) || \ + defined(CONFIG_USB_OMAP3)
int usb_lowlevel_init(void); int usb_lowlevel_stop(void); diff --git a/include/usb/musb_udc.h b/include/usb/musb_udc.h new file mode 100644 index 0000000..ef37dbb --- /dev/null +++ b/include/usb/musb_udc.h @@ -0,0 +1,54 @@ +/* + * Copyright (c) 2009 Wind River Systems, Inc. + * Tom Rix Tom.Rix@windriver.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __MUSB_UDC_H__ +#define __MUSB_UDC_H__ + +#include <usbdevice.h> + +/* UDC level routines */ +void udc_irq(void); +void udc_set_nak(int ep_num); +void udc_unset_nak(int ep_num); +int udc_endpoint_write(struct usb_endpoint_instance *endpoint); +void udc_setup_ep(struct usb_device_instance *device, unsigned int id, + struct usb_endpoint_instance *endpoint); +void udc_connect(void); +void udc_disconnect(void); +void udc_enable(struct usb_device_instance *device); +void udc_disable(void); +void udc_startup_events(struct usb_device_instance *device); +int udc_init(void); + +/* usbtty */ +#ifdef CONFIG_USB_TTY + +#define EP0_MAX_PACKET_SIZE 64 /* MUSB_EP0_FIFOSIZE */ +#define UDC_INT_ENDPOINT 1 +#define UDC_INT_PACKET_SIZE 64 +#define UDC_OUT_ENDPOINT 2 +#define UDC_OUT_PACKET_SIZE 64 +#define UDC_IN_ENDPOINT 3 +#define UDC_IN_PACKET_SIZE 64 +#define UDC_BULK_PACKET_SIZE 64 + +#endif /* CONFIG_USB_TTY */ + +#endif /* __MUSB_UDC_H__ */ +
The primary console of zoom1 is the serial out from the jumpers accessed by removing the back panel.
A secondary console is to use the usbtty. The user can set this manually by doing
setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty saveenv
usbtty will be usable by accessing the /dev/ttyACM0 on a linux host.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- include/configs/omap3_zoom1.h | 16 ++++++++++++++++ 1 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 61a41e7..c7a963c 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -99,6 +99,21 @@ #define CONFIG_OMAP3_MMC 1 #define CONFIG_DOS_PARTITION 1
+/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1 + +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "Zoom1" + /* commands to include */ #include <config_cmd_default.h>
@@ -160,6 +175,7 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \ + "usbtty=cdc_acm\0" \ "console=ttyS2,115200n8\0" \ "videomode=1024x768@60,vxres=1024,vyres=768\0" \ "videospec=omapfb:vram:2M,vram:4M\0" \
The primary console of beagle is the serial header.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- include/configs/omap3_beagle.h | 16 ++++++++++++++++ 1 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 61629f8..dc07934 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -98,6 +98,21 @@ #define CONFIG_OMAP3_MMC 1 #define CONFIG_DOS_PARTITION 1
+/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1 + +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "Beagle" + /* commands to include */ #include <config_cmd_default.h>
@@ -163,6 +178,7 @@
Zoom2 needs to use these declarations and the include directory is a better place from them than in the middle of the driver directory. It did not make sense to create a new file for just a couple of lines so they were appended to the serial.h
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- include/serial.h | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/include/serial.h b/include/serial.h index 821b583..2c150ff 100644 --- a/include/serial.h +++ b/include/serial.h @@ -59,4 +59,10 @@ extern void serial_stdio_init(void); extern int serial_assign(char * name); extern void serial_reinit_all(void);
+/* For usbtty */ +extern int usbtty_getc(void); +extern void usbtty_putc(const char c); +extern void usbtty_puts(const char *str); +extern int usbtty_tstc(void); + #endif
The preferred serial output comes from the debug board. When the debug board is disconnected, fall back on using usbtty from the usb connector on the Zoom2 board.
This shows up as /dev/ttyACM0 in a linux host.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- board/omap3/zoom2/zoom2_serial.c | 16 ++++++++++++++++ include/configs/omap3_zoom2.h | 17 +++++++++++++++++ 2 files changed, 33 insertions(+), 0 deletions(-)
diff --git a/board/omap3/zoom2/zoom2_serial.c b/board/omap3/zoom2/zoom2_serial.c index a3d777d..434696a 100644 --- a/board/omap3/zoom2/zoom2_serial.c +++ b/board/omap3/zoom2/zoom2_serial.c @@ -87,6 +87,10 @@ void quad_putc_dev (unsigned long base, const char c)
NS16550_putc ((NS16550_t) base, c); } +#ifdef CONFIG_USB_TTY + else + usbtty_putc(c); +#endif }
void quad_puts_dev (unsigned long base, const char *s) @@ -95,6 +99,10 @@ void quad_puts_dev (unsigned long base, const char *s) while ((s != NULL) && (*s != '\0')) quad_putc_dev (base, *s++); } +#ifdef CONFIG_USB_TTY + else + usbtty_puts(s); +#endif }
int quad_getc_dev (unsigned long base) @@ -102,7 +110,11 @@ int quad_getc_dev (unsigned long base) if (zoom2_debug_board_connected ()) return NS16550_getc ((NS16550_t) base); else +#ifdef CONFIG_USB_TTY + return usbtty_getc(); +#else return 0; +#endif }
int quad_tstc_dev (unsigned long base) @@ -110,7 +122,11 @@ int quad_tstc_dev (unsigned long base) if (zoom2_debug_board_connected ()) return NS16550_tstc ((NS16550_t) base); else +#ifdef CONFIG_USB_TTY + return usbtty_tstc(); +#else return 0; +#endif }
void quad_setbrg_dev (unsigned long base) diff --git a/include/configs/omap3_zoom2.h b/include/configs/omap3_zoom2.h index 03f92f5..a87d59f 100644 --- a/include/configs/omap3_zoom2.h +++ b/include/configs/omap3_zoom2.h @@ -123,6 +123,20 @@ #define CONFIG_OMAP3_GPIO_3 /* board revision */ #define CONFIG_OMAP3_GPIO_5 /* debug board detection, ZOOM2_LED_BLUE */
+/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1 + +/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "Zoom2" + /* commands to include */ #include <config_cmd_default.h>
@@ -169,6 +183,9 @@ /* Environment information */ #define CONFIG_BOOTDELAY 10
+#define CONFIG_EXTRA_ENV_SETTINGS \ + "usbtty=cdc_acm\0" \ + /* * Miscellaneous configurable options */
why not do this #ifndef CONFIG_USB_TTY #define usbtty_putc(c) #define usbtty_puts(s) #define usbtty_getc() 0 #define usbtty_tstc() 0 #endif
and then avoid the ifdef
Best Regards, J.
Yes I agree. I will add stubs to the declarations in serial.h Tom
Best Regards, J.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
Best Regards, J.
Best Regards, J.
please be carefull you have a lot's of ligne which exceed 80 chars limit
please lowercase
- serial_printf("\tpower 0x%2.2x\n", b);
maybe a macro will simplify the code #define MUSB_FLAGS_PRINT(x, y) \ if (b & MUSB_##x_##y) \ serial_printf("\t\t"#y"\n");
static inline void musb_print_pwr(u8 b) { serial_printf("\tpower 0x%2.2x\n", b); MUSB_FLAGS_PRINT(POWER, ISOUPDATE); MUSB_FLAGS_PRINT(POWER, SOFTCONN); MUSB_FLAGS_PRINT(POWER, HSENAB); MUSB_FLAGS_PRINT(POWER, HSMODE); MUSB_FLAGS_PRINT(POWER, RESET); MUSB_FLAGS_PRINT(POWER, RESUME); MUSB_FLAGS_PRINT(POWER, SUSPENDM); MUSB_FLAGS_PRINT(POWER, ENSUSPEND); } and so on
please lowercase and so on
- serial_printf("\tcsr0 0x%4.4x\n", w);
- if (w & MUSB_CSR0_FLUSHFIFO)
- if (w & MUSB_CSR0_P_SVDSETUPEND)
- if (w & MUSB_CSR0_P_SVDRXPKTRDY)
- if (w & MUSB_CSR0_P_SENDSTALL)
- if (w & MUSB_CSR0_P_SETUPEND)
- if (w & MUSB_CSR0_P_DATAEND)
- if (w & MUSB_CSR0_P_SENTSTALL)
- if (w & MUSB_CSR0_TXPKTRDY)
- if (w & MUSB_CSR0_RXPKTRDY)
maybe we can put it configurable
- if ((0 <= (s)) && (SET_ADDRESS >= (s))) { \
too long please split
ep0_state = s; \
- } else { \
+} while (0)
this will be better static enum ep0_state_enum { IDLE = 0, TX, RX, SET_ADDRESS } ep0_state = IDLE;
- "IDLE",
- "TX",
- "RX",
- "SET_ADDRESS",
- u8 b;
- u16 w;
- b = readb(&musbr->faddr);
- serial_printf("\tfaddr 0x%2.2x\n", b);
- b = readb(&musbr->power);
- MUSB_PRINT_PWR(b);
- w = readw(&musbr->ep[0].ep0.csr0);
- MUSB_PRINT_CSR0(w);
- b = readb(&musbr->devctl);
- MUSB_PRINT_DEVCTL(b);
- b = readb(&musbr->ep[0].ep0.configdata);
- MUSB_PRINT_CONFIG(b);
- w = readw(&musbr->frame);
- serial_printf("\tframe 0x%4.4x\n", w);
- b = readb(&musbr->index);
- serial_printf("\tindex 0x%2.2x\n", b);
- w = readw(&musbr->ep[1].epN.rxmaxp);
- MUSB_PRINT_RXMAXP(w);
- w = readw(&musbr->ep[1].epN.rxcsr);
- MUSB_PRINT_RXCSR(w);
- w = readw(&musbr->ep[1].epN.txmaxp);
- MUSB_PRINT_TXMAXP(w);
- w = readw(&musbr->ep[1].epN.txcsr);
- MUSB_PRINT_TXCSR(w);
- u8 power, devctl;
- u8 intrusb;
- u16 intrrx, intrtx;
- /* Power off MUSB */
- power = readb(&musbr->power);
- power &= ~MUSB_POWER_SOFTCONN;
- writeb(power, &musbr->power);
- /* Read intr to clear */
- intrusb = readb(&musbr->intrusb);
- intrrx = readw(&musbr->intrrx);
- intrtx = readw(&musbr->intrtx);
- udelay(2 * 500000); /* 1 sec */
why not udelay(1000 * 1000) as other place?
- /* Power on MUSB */
- power |= MUSB_POWER_SOFTCONN;
- power &= ~MUSB_POWER_HSENAB;
- /* Check if device is in b-peripheral mode */
- devctl = readb(&musbr->devctl);
- if (!(devctl & MUSB_DEVCTL_BDEVICE) ||
evenif it's too long it's better for search
- if (debug_setup && (debug_level > 1))
musb_db_regs();
- if ((debug_setup) && (debug_level > 1))
what do you mean y __PRETTY_FUNCTION__?
- /* the device address is reset by the event */
- usbd_device_event_irq(udc_device, DEVICE_RESET, 0);
- SET_EP0_STATE(IDLE);
- if (ep0_endpoint)
- /* noop */
- u16 csr0;
please add an empty line
- csr0 = readw(&musbr->ep[0].ep0.csr0);
- csr0 |= MUSB_CSR0_P_SENDSTALL;
- writew(csr0, &musbr->ep[0].ep0.csr0);
- u16 csr0;
- csr0 |= MUSB_CSR0_P_SVDRXPKTRDY;
- u16 csr0;
- csr0 |= MUSB_CSR0_TXPKTRDY;
- u16 csr0;
- csr0 |= MUSB_CSR0_P_DATAEND;
is it not possible to create a single function which take MUSB_CSR0_P_DATAEND, MUSB_CSR0_TXPKTRDY, MUSB_CSR0_P_SVDRXPKTRDY, MUSB_CSR0_P_SENDSTALL etc... as paramter?
- writeb(udc_device->address, &musbr->faddr);
- usbd_device_event_irq(udc_device, DEVICE_ADDRESS_ASSIGNED, 0);
- u16 peri_rxcsr;
- peri_rxcsr = readw(&musbr->ep[ep].epN.rxcsr);
- peri_rxcsr &= ~MUSB_RXCSR_RXPKTRDY;
- writew(peri_rxcsr, &musbr->ep[ep].epN.rxcsr);
- u16 peri_txcsr;
- peri_txcsr = readw(&musbr->ep[ep].epN.txcsr);
- peri_txcsr |= MUSB_TXCSR_TXPKTRDY;
- writew(peri_txcsr, &musbr->ep[ep].epN.txcsr);
- musb_peri_ep0_ack_req();
- if (err) {
- } else {
/* USBD state */
maybe you can define a debug macro to reduce the code length and avoid the if everywhere
break;
break;
/* EP0 state */
} else {
- ep0_endpoint->rcv_urb = ep0_urb;
- ep0_urb->actual_length = 0;
- SET_EP0_STATE(RX);
- if (err) {
- } else {
SET_EP0_STATE(TX);
- u16 count0;
- int err;
- u16 csr0;
- if (!(MUSB_CSR0_RXPKTRDY & csr0))
goto end;
- count0 = readw(&musbr->ep[0].ep0.count0);
- if (count0 == 0)
goto end;
- if (count0 != 8) {
goto end;
- read_fifo(0, count0, &ep0_urb->device_request);
- if (debug_level > 2) {
- if (0 == ep0_urb->device_request.wLength) {
please invert the test
- } else {
} else {
* Host to device
+end:
- return;
why? will not be usefull to have an error return?
- defined(CONFIG_USB_R8A66597_HCD) || defined(CONFIG_USB_DAVINCI) || \
- defined(CONFIG_USB_OMAP3)
a simple CONFIG will be better
Best Regards, J.
Yes I saw these from check_patch. I will try to reduce these.
please lowercase
OK
Thanks. I will give this a try.
mmmm I will see
ep0_state = s; \
- } else { \
Ok.
+} while (0)
ok
- "IDLE",
- "TX",
- "RX",
- "SET_ADDRESS",
- u8 b;
- u16 w;
- u8 power, devctl;
- u8 intrusb;
cruft begone! ok. i will clean this up.
musb_db_regs();
This a gcc compiler macro for printing out the function of the calling routine. It is useful in the macro's like the state machine changer to show which function did the change instead of the usual __LINE__ + __FILE__ + eyeball time. It is a non-standard cpp macro and would bite us when compiling without gcc. Does u-boot build with non-gcc ?
- if (ep0_endpoint)
- /* noop */
- u16 csr0;
ok
- u16 csr0;
ok,
- u16 csr0;
ok
- u16 csr0;
empty lines for everyone!
- u16 peri_rxcsr;
- u16 peri_txcsr;
- if (err) {
- } else {
/* USBD state */
ok i will look into it.
break;
break;
/* EP0 state */
} else {
- if (err) {
- } else {
SET_EP0_STATE(TX);
- u16 count0;
- int err;
- u16 csr0;
goto end;
- if (count0 == 0)
goto end;
goto end;
ok
- } else {
} else {
* Host to device
+end:
- return;
I am not sure it needs an error. I will check.
Can this be a follow-on ?
Tom
Best Regards, J.
musb_db_regs();
no only gcc but I think it will not be impossible to use an other toolchains but ok
ofcource
Best Regards, J.
The twl4030 provides a PHY device for connecting a link device, like musb, to physical connection.
This change adds the twl4030 usb registers and functions for initializing the PHY as required by omap3.
Makefile | 1 + drivers/usb/phy/Makefile | 44 +++++++++++ drivers/usb/phy/twl4030.c | 184 +++++++++++++++++++++++++++++++++++++++++++++ include/twl4030.h | 143 +++++++++++++++++++++++++++++++---- 4 files changed, 357 insertions(+), 15 deletions(-) create mode 100644 drivers/usb/phy/Makefile create mode 100644 drivers/usb/phy/twl4030.c
diff --git a/Makefile b/Makefile index 329e0f5..dcaa1dc 100644 --- a/Makefile +++ b/Makefile @@ -241,6 +241,7 @@ LIBS += drivers/twserial/libtws.a LIBS += drivers/usb/gadget/libusb_gadget.a LIBS += drivers/usb/host/libusb_host.a LIBS += drivers/usb/musb/libusb_musb.a +LIBS += drivers/usb/phy/libusb_phy.a LIBS += drivers/video/libvideo.a LIBS += drivers/watchdog/libwatchdog.a LIBS += common/libcommon.a diff --git a/drivers/usb/phy/Makefile b/drivers/usb/phy/Makefile new file mode 100644 index 0000000..200b907 --- /dev/null +++ b/drivers/usb/phy/Makefile @@ -0,0 +1,44 @@ +# +# Copyright (c) 2009 Wind River Systems, Inc. +# Tom Rix Tom.Rix@windriver.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB := $(obj)libusb_phy.a
+COBJS-$(CONFIG_TWL4030_USB) += twl4030.o +COBJS-y := twl4030.o
+COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
+all: $(LIB)
+$(LIB): $(obj).depend $(OBJS)
- $(AR) $(ARFLAGS) $@ $(OBJS)
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
+######################################################################### diff --git a/drivers/usb/phy/twl4030.c b/drivers/usb/phy/twl4030.c new file mode 100644 index 0000000..32f1df3 --- /dev/null +++ b/drivers/usb/phy/twl4030.c @@ -0,0 +1,184 @@ +/*
- Copyright (c) 2009 Wind River Systems, Inc.
- Tom Rix Tom.Rix@windriver.com
- This is file is based on
- repository git.gitorious.org/u-boot-omap3/mainline.git,
- branch omap3-dev-usb, file drivers/usb/gadget/twl4030_usb.c
- This is the unique part of its copyright :
- (C) Copyright 2009 Atin Malaviya (atin.malaviya@gmail.com)
- Based on: twl4030_usb.c in linux 2.6 (drivers/i2c/chips/twl4030_usb.c)
- Copyright (C) 2004-2007 Texas Instruments
- Copyright (C) 2008 Nokia Corporation
- Contact: Felipe Balbi felipe.balbi@nokia.com
- Author: Atin Malaviya (atin.malaviya@gmail.com)
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- MA 02111-1307 USA
+/* Defines for bits in registers */ +#define OPMODE_MASK (3 << 3) +#define XCVRSELECT_MASK (3 << 0) +#define CARKITMODE (1 << 2) +#define OTG_ENAB (1 << 5) +#define PHYPWD (1 << 0) +#define CLOCKGATING_EN (1 << 2) +#define CLK32K_EN (1 << 1) +#define REQ_PHY_DPLL_CLK (1 << 0) +#define PHY_DPLL_CLK (1 << 0)
+static int twl4030_usb_write(u8 address, u8 data) +{
- int ret;
- ret = twl4030_i2c_write_u8(TWL4030_CHIP_USB, data, address);
- if (ret != 0)
printf("TWL4030:USB:Write[0x%x] Error %d\n", address, ret);
- return ret;
+static int twl4030_usb_read(u8 address) +{
- u8 data;
- int ret;
- ret = twl4030_i2c_read_u8(TWL4030_CHIP_USB, &data, address);
- if (ret == 0)
ret = data;
- else
printf("TWL4030:USB:Read[0x%x] Error %d\n", address, ret);
- return ret;
why not this and avoid the copy of data if (ret != 0) { printf("TWL4030:USB:Read[0x%x] Error %d\n", address, ret); return ret; }
return data; }
+static void twl4030_phy_power(void) +{
- u8 pwr, clk;
- /* Power the PHY */
- pwr = twl4030_usb_read(TWL4030_USB_PHY_PWR_CTRL);
- pwr &= ~PHYPWD;
- twl4030_usb_write(TWL4030_USB_PHY_PWR_CTRL, pwr);
please add an empty line to make it more readable
- /* Enable clocks */
- clk = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL);
- clk |= CLOCKGATING_EN | CLK32K_EN;
- twl4030_usb_write(TWL4030_USB_PHY_CLK_CTRL, clk);
- Initiaze the ULPI interface
- ULPI : Universal Transceiver Macrocell Low Pin Interface
- An interface between the USB link controller like musb and the
- the PHY or transceiver that drives the actual bus.
+int twl4030_usb_ulpi_init(void) +{
- long timeout = 1000 * 1000; /* 1 sec */;
- u8 clk, sts, pwr;
- /* twl4030 ldo init */
- twl4030_usb_ldo_init();
- /* Enable the twl4030 phy */
- twl4030_phy_power();
- /* Enable DPLL to access PHY registers over I2C */
- clk |= REQ_PHY_DPLL_CLK;
- /* Check if the PHY DPLL is locked */
- sts = twl4030_usb_read(TWL4030_USB_PHY_CLK_CTRL_STS);
- while (!(sts & PHY_DPLL_CLK) && 0 < timeout) {
udelay(10);
timeout -= 10;
why not set time to 100 * 1000 and just decrease by 1
- /* Final check */
- if (!(sts & PHY_DPLL_CLK)) {
printf("Error:TWL4030:USB Timeout setting PHY DPLL clock\n");
return -1;
* There are two circuit blocks attached to the PHY,
* Carkit and USB OTG. Disable Carkit and enable USB OTG
- twl4030_usb_write(TWL4030_USB_IFC_CTRL_CLR, CARKITMODE);
- pwr = twl4030_usb_read(TWL4030_USB_POWER_CTRL);
- pwr |= OTG_ENAB;
- twl4030_usb_write(TWL4030_USB_POWER_CTRL_SET, pwr);
- /* Clear the opmode bits to ensure normal encode */
- twl4030_usb_write(TWL4030_USB_FUNC_CTRL_CLR, OPMODE_MASK);
- /* Clear the xcvrselect bits to enable the high speed transeiver */
- twl4030_usb_write(TWL4030_USB_FUNC_CTRL_CLR, XCVRSELECT_MASK);
- /* Let ULPI control the DPLL clock */
- clk &= ~REQ_PHY_DPLL_CLK;
+} diff --git a/include/twl4030.h b/include/twl4030.h index f260ecb..feaec47 100644 --- a/include/twl4030.h +++ b/include/twl4030.h @@ -342,21 +342,129 @@ #define TWL4030_KEYPAD_CTRL_SOFT_NRST (1 << 0)
/* USB */ -#define TWL4030_USB_FUNC_CTRL (0x04) -#define TWL4030_USB_OPMODE_MASK (3 << 3) -#define TWL4030_USB_XCVRSELECT_MASK (3 << 0) -#define TWL4030_USB_IFC_CTRL (0x07) -#define TWL4030_USB_CARKITMODE (1 << 2) -#define TWL4030_USB_POWER_CTRL (0xAC) -#define TWL4030_USB_OTG_ENAB (1 << 5) -#define TWL4030_USB_PHY_PWR_CTRL (0xFD) -#define TWL4030_USB_PHYPWD (1 << 0) -#define TWL4030_USB_PHY_CLK_CTRL (0xFE) -#define TWL4030_USB_CLOCKGATING_EN (1 << 2) -#define TWL4030_USB_CLK32K_EN (1 << 1) -#define TWL4030_USB_REQ_PHY_DPLL_CLK (1 << 0) -#define TWL4030_USB_PHY_CLK_CTRL_STS (0xFF) -#define TWL4030_USB_PHY_DPLL_CLK (1 << 0)
make some enums by group of function will be better as it simplify the code
+#define TWL4030_USB_VENDOR_ID_LO 0x00 +#define TWL4030_USB_VENDOR_ID_HI 0x01 +#define TWL4030_USB_PRODUCT_ID_LO 0x02 +#define TWL4030_USB_PRODUCT_ID_HI 0x03 +#define TWL4030_USB_FUNC_CTRL 0x04 +#define TWL4030_USB_FUNC_CTRL_SET 0x05 +#define TWL4030_USB_FUNC_CTRL_CLR 0x06 +#define TWL4030_USB_IFC_CTRL 0x07 +#define TWL4030_USB_IFC_CTRL_SET 0x08 +#define TWL4030_USB_IFC_CTRL_CLR 0x09 +#define TWL4030_USB_OTG_CTRL 0x0A +#define TWL4030_USB_OTG_CTRL_SET 0x0B +#define TWL4030_USB_OTG_CTRL_CLR 0x0C +#define TWL4030_USB_USB_INT_EN_RISE 0x0D +#define TWL4030_USB_USB_INT_EN_RISE_SET 0x0E +#define TWL4030_USB_USB_INT_EN_RISE_CLR 0x0F +#define TWL4030_USB_USB_INT_EN_FALL 0x10 +#define TWL4030_USB_USB_INT_EN_FALL_SET 0x11 +#define TWL4030_USB_USB_INT_EN_FALL_CLR 0x12 +#define TWL4030_USB_USB_INT_STS 0x13 +#define TWL4030_USB_USB_INT_LATCH 0x14 +#define TWL4030_USB_DEBUG 0x15 +#define TWL4030_USB_SCRATCH_REG 0x16 +#define TWL4030_USB_SCRATCH_REG_SET 0x17 +#define TWL4030_USB_SCRATCH_REG_CLR 0x18 +#define TWL4030_USB_CARKIT_CTRL 0x19 +#define TWL4030_USB_CARKIT_CTRL_SET 0x1A +#define TWL4030_USB_CARKIT_CTRL_CLR 0x1B +#define TWL4030_USB_CARKIT_INT_DELAY 0x1C +#define TWL4030_USB_CARKIT_INT_EN 0x1D +#define TWL4030_USB_CARKIT_INT_EN_SET 0x1E +#define TWL4030_USB_CARKIT_INT_EN_CLR 0x1F +#define TWL4030_USB_CARKIT_INT_STS 0x20 +#define TWL4030_USB_CARKIT_INT_LATCH 0x21 +#define TWL4030_USB_CARKIT_PLS_CTRL 0x22 +#define TWL4030_USB_CARKIT_PLS_CTRL_SET 0x23 +#define TWL4030_USB_CARKIT_PLS_CTRL_CLR 0x24 +#define TWL4030_USB_TRANS_POS_WIDTH 0x25 +#define TWL4030_USB_TRANS_NEG_WIDTH 0x26 +#define TWL4030_USB_RCV_PLTY_RECOVERY 0x27 +#define TWL4030_USB_MCPC_CTRL 0x30 +#define TWL4030_USB_MCPC_CTRL_SET 0x31 +#define TWL4030_USB_MCPC_CTRL_CLR 0x32 +#define TWL4030_USB_MCPC_IO_CTRL 0x33 +#define TWL4030_USB_MCPC_IO_CTRL_SET 0x34
Best Regards, J.
<snip>
I will take care of all the empty lines.
- if (ret == 0)
ret = data;
- else
- return ret;
return data; }
In general I rather have only one exit point from a function. This makes tracing execution easier.
udelay(10);
timeout -= 10;
Yes.
I see your point, but this is how they are defined in a twl4030 spec. This way makes it easy to look up #define in the spec. Just remove the prefix.
Tom
Best Regards, J.
<snip> >please add an empty line I will take care of all the empty lines.
- if (ret == 0)
ret = data;
- else
- return ret;
return data; }
ok
udelay(10);
timeout -= 10;
Yes.
ok fine
Best Regards, J.
When developing usb device features, it is useful to print out common usb structures.
include/usbdescriptors.h | 31 +++++++++++++ include/usbdevice.h | 105 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 136 insertions(+), 0 deletions(-)
diff --git a/include/usbdescriptors.h b/include/usbdescriptors.h index ea05672..f4e33b6 100644 --- a/include/usbdescriptors.h +++ b/include/usbdescriptors.h @@ -510,4 +510,35 @@ struct usb_class_descriptor {
} __attribute__ ((packed));
+#ifdef DEBUG +#define PRINT_DEVICE_DESCRIPTOR(d) \
inline will be better
+do { \
- serial_printf("usb device descriptor \n"); \
- serial_printf("\tbLength %2.2x\n", (d)->bLength); \
- serial_printf("\tbDescriptorType %2.2x\n", \
(d)->bDescriptorType); \
- serial_printf("\tbcdUSB %4.4x\n", (d)->bcdUSB); \
- serial_printf("\tbDeviceClass %2.2x\n", (d)->bDeviceClass); \
- serial_printf("\tbDeviceSubClass %2.2x\n", \
(d)->bDeviceSubClass); \
- serial_printf("\tbDeviceProtocol %2.2x\n", \
(d)->bDeviceProtocol); \
- serial_printf("\tbMaxPacketSize0 %2.2x\n", \
(d)->bMaxPacketSize0); \
- serial_printf("\tidVendor %4.4x\n", (d)->idVendor); \
- serial_printf("\tidProduct %4.4x\n", (d)->idProduct); \
- serial_printf("\tbcdDevice %4.4x\n", (d)->bcdDevice); \
- serial_printf("\tiManufacturer %2.2x\n", (d)->iManufacturer); \
- serial_printf("\tiProduct %2.2x\n", (d)->iProduct); \
- serial_printf("\tiSerialNumber %2.2x\n", (d)->iSerialNumber); \
- serial_printf("\tbNumConfigurations %2.2x\n", \
(d)->bNumConfigurations); \
+} while (0)
Best Regards, J.
Yes. I agree. Tom
Best Regards, J.
Tom
Tom Rix
