[PATCH v2 0/4] rockchip: Fixes for RK3568 and RK3588
This series contains fixes for RK3568 and RK3588.
Patch 1 imply use of ROCKCHIP_TPL for RK3588 to generate bootable firmware image. Patch 2 fixes sdmmc boot on rk3588-rock-5b. Patch 3 fixes boot of rk3568-rock-3a, an issue introduced in v1. Patch 4 add fdtoverlay and compressed kernel addresses to env.
The last patch is not a fix but some parts of it was included in v1, so I kept it in v2.
Please consider these patches for v2023.04.
Changes in v2: - Drop applied patches - Add the pre-req patch from [1] - Add patch to fix an issue introduced in v1 - Collect r-b tags
This series can also be found at [2]
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230228213822.3583989-1-jo... [2] https://github.com/Kwiboo/u-boot-rockchip/commits/rk35xx-fixes-v2
Jonas Karlman (4): rockchip: Use an external TPL binary on RK3588 rockchip: rk3588-rock-5b: Fix sdmmc boot rockchip: rk35xx: Fix boot with a large fdt blob rockchip: rk35xx: Enable fdtoverlay and kernel compression
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 3 ++- arch/arm/mach-rockchip/Kconfig | 6 +++++- configs/neu6a-io-rk3588_defconfig | 1 - configs/rock-3a-rk3568_defconfig | 1 - configs/rock5b-rk3588_defconfig | 2 -- doc/board/rockchip/rockchip.rst | 9 +++++++++ include/configs/rk3568_common.h | 7 ++++++- include/configs/rk3588_common.h | 7 ++++++- 8 files changed, 28 insertions(+), 8 deletions(-)
There is no support to initialize DRAM on RK3588 SoCs using U-Boot TPL and instead an external TPL binary must be used to generate a bootable u-boot-rockchip.bin image.
Enable ROCKCHIP_EXTERNAL_TPL by default for RK3588, add build steps for RK3588 to documentation and clean up CONFIG_BINMAN_FDT options.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Jagan Teki jagan@edgeble.ai --- v2: - Pre-req patch picked from [1] - Collect r-b tag
arch/arm/mach-rockchip/Kconfig | 2 +- configs/neu6a-io-rk3588_defconfig | 1 - configs/rock-3a-rk3568_defconfig | 1 - configs/rock5b-rk3588_defconfig | 1 - doc/board/rockchip/rockchip.rst | 9 +++++++++ 5 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 0390431601f9..e5ac58ae60b5 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -428,7 +428,7 @@ config TPL_ROCKCHIP_COMMON_BOARD
config ROCKCHIP_EXTERNAL_TPL bool "Use external TPL binary" - default y if ROCKCHIP_RK3568 + default y if ROCKCHIP_RK3568 || ROCKCHIP_RK3588 help Some Rockchip SoCs require an external TPL to initialize DRAM. Enable this option and build with ROCKCHIP_TPL=/path/to/ddr.bin to diff --git a/configs/neu6a-io-rk3588_defconfig b/configs/neu6a-io-rk3588_defconfig index fb5a2b7dbceb..33c03b58a16c 100644 --- a/configs/neu6a-io-rk3588_defconfig +++ b/configs/neu6a-io-rk3588_defconfig @@ -63,5 +63,4 @@ CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index 1686c8c1aa5a..e16d98b07af9 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -70,5 +70,4 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550_MEM32=y CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index f3026c7ea166..66199387195a 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -68,5 +68,4 @@ CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYSRESET=y -# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index b5563b8f7f9e..1f88d15aad2a 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -185,6 +185,15 @@ To build rk3568 boards: make evb-rk3568_defconfig make CROSS_COMPILE=aarch64-linux-gnu-
+To build rk3588 boards: + +.. code-block:: bash + + export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.27.elf + export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.08.bin + make rock5b-rk3588_defconfig + make CROSS_COMPILE=aarch64-linux-gnu- + Flashing --------
Running U-Boot from a SD-card on ROCK 5 Model B fails to load atf using DMA and prints debug_uart messages.
<debug_uart>
<debug_uart>
U-Boot SPL 2023.04-rc3 (Mar 12 2023 - 00:30:16 +0000) Trying to boot from MMC1 ## Checking hash(es) for config config-1 ... OK ## Checking hash(es) for Image atf-1 ... sha256 error! Bad hash value for 'hash' hash node in 'atf-1' image node mmc_load_image_raw_sector: mmc block read error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
Use fifo-mode to disable DMA in SPL, add same-as-spl to boot-order and remove DEBUG_UART_ANNOUNCE option to fix this.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Kever Yang kever.yang@rock-chips.com --- v2: - Collect r-b tag
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 3 ++- configs/rock5b-rk3588_defconfig | 1 - 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 2386edf90deb..36d557b4934d 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -11,12 +11,13 @@ };
chosen { - u-boot,spl-boot-order = &sdmmc; + u-boot,spl-boot-order = "same-as-spl", &sdmmc; }; };
&sdmmc { bus-width = <4>; u-boot,dm-spl; + u-boot,spl-fifo-mode; status = "okay"; }; diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 66199387195a..3fcc6a26bb51 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -66,6 +66,5 @@ CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 -CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYSRESET=y CONFIG_ERRNO_STR=y
The TF-A blobs used to boot RK3568 and RK3588 boards is based on atf v2.3. Mainline atf v2.3 contains an issue that could lead to a crash when it fails to parse the fdt blob being passed as the platform param. An issue that was fixed in atf v2.4.
The vendor TF-A seem to suffer from a similar issue, and this prevents booting when fdt blob is large enough to trigger this condition.
Fix this by implying SPL_ATF_NO_PLATFORM_PARAM to let u-boot pass a NULL pointer instead of the fdt blob as the platform param.
This fixes booting Radxa ROCK 3A after recent sync of device tree.
Fixes: 073d911ae64a ("rockchip: rk3568-rock-3a: Sync device tree from linux") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- v2: - New patch
arch/arm/mach-rockchip/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index e5ac58ae60b5..d7e3784ba113 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -288,6 +288,7 @@ config ROCKCHIP_RK3568 select BOARD_LATE_INIT select DM_REGULATOR_FIXED select DM_RESET + imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP imply MISC_INIT_R @@ -309,6 +310,7 @@ config ROCKCHIP_RK3588 select REGMAP select SYSCON select BOARD_LATE_INIT + imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP imply MISC_INIT_R
v2:
- New patch
How it related to 3588, couldn't reproduce it from my end at least. I'm using rk3588_bl31_v1.27.elf from rkbin.
Jagan.
Hi Jagan,
v2:
- New patch
I have not been able to reproduce this issue on rk3588, only on rk3568. I added the same imply to rk3588 because we have no insights into what fixes the TF-A blob provided by rockchip have included. Passing 0 works and seem like the more safer default option for a closed-source blob.
See commits [1] and [2] for the commits included in TF-A v2.4 related to the platform param passed from u-boot. The fdt blob loaded into memory may need to exceed 64KiB to trigger the issue observed on a ROCK 3 Model A.
[1] https://github.com/ARM-software/arm-trusted-firmware/commit/8109f738ffa79a63... [2] https://github.com/ARM-software/arm-trusted-firmware/commit/e7b586987c0a4666...
Regards, Jonas
Jagan.
Add fdtoverlay_addr_r, kernel_comp_addr_r and imply use of OF_LIBFDT_OVERLAY on RK3568 and RK3588 to support fdtoverlay and kernel compression.
Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Simon Glass sjg@chromium.org --- v2: - Drop parts that convert to use bootstd - Collect r-b tag
arch/arm/mach-rockchip/Kconfig | 2 ++ include/configs/rk3568_common.h | 7 ++++++- include/configs/rk3588_common.h | 7 ++++++- 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index d7e3784ba113..517326c8c5be 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -290,6 +290,7 @@ config ROCKCHIP_RK3568 select DM_RESET imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD + imply OF_LIBFDT_OVERLAY imply ROCKCHIP_OTP imply MISC_INIT_R help @@ -312,6 +313,7 @@ config ROCKCHIP_RK3588 select BOARD_LATE_INIT imply SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF imply ROCKCHIP_COMMON_BOARD + imply OF_LIBFDT_OVERLAY imply ROCKCHIP_OTP imply MISC_INIT_R help diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index a5e1dde50888..d6b5e7d89022 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -17,10 +17,15 @@
#define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00c00000\0" \ + "script_offset_f=0xffe000\0" \ + "script_size_f=0x2000\0" \ "pxefile_addr_r=0x00e00000\0" \ "fdt_addr_r=0x0a100000\0" \ + "fdtoverlay_addr_r=0x02000000\0" \ "kernel_addr_r=0x02080000\0" \ - "ramdisk_addr_r=0x0a200000\0" + "ramdisk_addr_r=0x0a200000\0" \ + "kernel_comp_addr_r=0x08000000\0" \ + "kernel_comp_size=0x2000000\0"
#include <config_distro_bootcmd.h> #define CFG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/rk3588_common.h b/include/configs/rk3588_common.h index abd20139aaf3..b9f42717b751 100644 --- a/include/configs/rk3588_common.h +++ b/include/configs/rk3588_common.h @@ -16,10 +16,15 @@
Jagan Teki
Jonas Karlman
