[U-Boot] [PATCH v4 0/3] km/common mainlining remaining parts
This patch serie comprehends the missing parts of the mostly already committed patch serie "v2 km/common mainlining". See: http://lists.denx.de/pipermail/u-boot/2011-May/092323.html
Holger Brunck (2): km/common: simplify default environment km/common: add pnvramsize to default environment
Thomas Herzmann (1): km/common: implement boardId HWkey checks as u-boot cmd
board/keymile/common/common.c | 156 +++++++++++++++++++++++++++ board/keymile/scripts/README | 23 ++++ board/keymile/scripts/debug-arm-env.txt | 2 + board/keymile/scripts/debug-common-env.txt | 9 ++ board/keymile/scripts/debug-ppc-env.txt | 2 + include/configs/km/keymile-common.h | 159 +++------------------------- include/configs/km/km-powerpc.h | 12 +-- include/configs/km/km_arm.h | 5 +- 8 files changed, 213 insertions(+), 155 deletions(-) create mode 100644 board/keymile/scripts/README create mode 100644 board/keymile/scripts/debug-arm-env.txt create mode 100644 board/keymile/scripts/debug-common-env.txt create mode 100644 board/keymile/scripts/debug-ppc-env.txt
BoardId and HWKey are used to identify the HW class of a given board. The correct values are stored in the inventory eeprom. During creation time of a boot package the boardId and HWkey for the SW is stored in the default environment and burned into the flash. During boottime the values in the inventory and in the environment are compared to avoid starting of a SW which is not authorized for this board.
Some bootpackages are allowed to run on a set of different boardId hwKey. In this case the environment variable boardIdListHex was added to the default environment. In this case the command iterates over the pair values and compares them with the values read from the inventory eeprom.
The syntax of such a boardIdListHex value is e.g.: 158_1 159_1 159_2
Signed-off-by: Thomas Herzmann thomas.herzmann@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com Acked-by: Heiko Schocher hs@denx.de cc: Wolfgang Denk wd@denx.de cc: Detlev Zundel dzu@denx.de
--- Changes for v4: - fix small bug introduced in v3 due to the enhanced error handling, return the return code (rc) and not 1 in any case Changes for v3: - add further error handling - rework the patch with inputs from W.Denk: - introduce emtpy line after varaiable declaration - fix one checkpatch warning - add comment why we use simple_strtoul Changes for v2: - split up first large patch series to three independent smaller patch series - give the cmd a more precise name - rework the patch with inputs from W.Denk: - adapt and enhance commit msg - comment the code - add error handling
board/keymile/common/common.c | 156 +++++++++++++++++++++++++++++++++++ include/configs/km/keymile-common.h | 30 +------- 2 files changed, 157 insertions(+), 29 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 9adfefa..9be4c72 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -32,6 +32,7 @@ #include <net.h> #include <netdev.h> #include <asm/io.h> +#include <linux/ctype.h>
#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_OF_LIBFDT) #include <libfdt.h> @@ -716,3 +717,158 @@ static int do_setboardid(cmd_tbl_t *cmdtp, int flag, int argc,
U_BOOT_CMD(km_setboardid, 1, 0, do_setboardid, "setboardid", "read out bid and " "hwkey from IVM and set in environment"); + +/* + * command km_checkbidhwk + * if "boardid" and "hwkey" are not already set in the environment, do: + * if a "boardIdListHex" exists in the environment: + * - read ivm data for boardid and hwkey + * - compare each entry of the boardIdListHex with the + * IVM data: + * if match: + * set environment variables boardid, boardId, + * hwkey, hwKey to the found values + * both (boardid and boardId) are set because + * they might be used differently in the + * application and in the init scripts (?) + * return 0 in case of match, 1 if not match or error + */ +int do_checkboardidhwk(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + unsigned long ivmbid = 0, ivmhwkey = 0; + unsigned long envbid = 0, envhwkey = 0; + char *p; + int verbose = argc > 1 && *argv[1] == 'v'; + int rc = 0; + + /* + * first read out the real inventory values, these values are + * already stored in the local hush variables + */ + p = get_local_var("IVM_BoardId"); + if (p == NULL) { + printf("can't get the IVM_Boardid\n"); + return 1; + } + rc = strict_strtoul(p, 16, &ivmbid); + + p = get_local_var("IVM_HWKey"); + if (p == NULL) { + printf("can't get the IVM_HWKey\n"); + return 1; + } + rc = strict_strtoul(p, 16, &ivmhwkey); + + if (!ivmbid || !ivmhwkey) { + printf("Error: IVM_BoardId and/or IVM_HWKey not set!\n"); + return rc; + } + + /* now try to read values from environment if available */ + p = getenv("boardid"); + if (p != NULL) + rc = strict_strtoul(p, 16, &envbid); + p = getenv("hwkey"); + if (p != NULL) + rc = strict_strtoul(p, 16, &envhwkey); + + if (rc != 0) { + printf("strict_strtoul returns error: %d", rc); + return rc; + } + + if (!envbid || !envhwkey) { + /* + * BoardId/HWkey not available in the environment, so try the + * environment variable for BoardId/HWkey list + */ + char *bidhwklist = getenv("boardIdListHex"); + + if (bidhwklist) { + int found = 0; + char *rest = bidhwklist; + char *endp; + + if (verbose) { + printf("IVM_BoardId: %ld, IVM_HWKey=%ld\n", + ivmbid, ivmhwkey); + printf("boardIdHwKeyList: %s\n", + bidhwklist); + } + while (!found) { + /* loop over each bid/hwkey pair in the list */ + unsigned long bid = 0; + unsigned long hwkey = 0; + + while (*rest && !isxdigit(*rest)) + rest++; + /* + * use simple_strtoul because we need &end and + * we know we got non numeric char at the end + */ + bid = simple_strtoul(rest, &endp, 16); + /* BoardId and HWkey are separated with a "_" */ + if (*endp == '_') { + rest = endp + 1; + /* + * use simple_strtoul because we need + * &end + */ + hwkey = simple_strtoul(rest, &endp, 16); + rest = endp; + while (*rest && !isxdigit(*rest)) + rest++; + } + if ((!bid) || (!hwkey)) { + /* end of list */ + break; + } + if (verbose) { + printf("trying bid=0x%lX, hwkey=%ld\n", + bid, hwkey); + } + /* + * Compare the values of the found entry in the + * list with the valid values which are stored + * in the inventory eeprom. If they are equal + * store the values in environment variables + * and save the environment. + * This can only happen once for the lifetime + * of a board, because once saved the function + * will never reach the while loop. + */ + if ((bid == ivmbid) && (hwkey == ivmhwkey)) { + char buf[10]; + + found = 1; + envbid = bid; + envhwkey = hwkey; + sprintf(buf, "%lx", bid); + setenv("boardid", buf); + sprintf(buf, "%lx", hwkey); + setenv("hwkey", buf); + saveenv(); + } + } /* end while( ! found ) */ + } + } + + /* compare now the values */ + if ((ivmbid == envbid) && (ivmhwkey == envhwkey)) { + printf("boardid=0x%3lX, hwkey=%ld\n", envbid, envhwkey); + rc = 0; /* match */ + } else { + printf("Error: env bId=0x%3lX, hwKey=%ld\n", envbid, envhwkey); + printf(" IVM bId=0x%3lX, hwKey=%ld\n", ivmbid, ivmhwkey); + rc = 1; /* don't match */ + } + return rc; +} + +U_BOOT_CMD(km_checkbidhwk, 2, 0, do_checkboardidhwk, + "check boardid and hwkey", + "[v]\n - check environment parameter "\ + ""boardIdListHex" against stored boardid and hwkey "\ + "from the IVM\n v: verbose output" +); diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index e91f6c7..6a5ecc6 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -238,7 +238,6 @@ "release=" \ "setenv actual_bank ${initial_boot_bank} && " \ "setenv subbootcmds "" \ - "checkboardidlist " \ "checkboardid " \ "ubiattach ubicopy " \ "cramfsloadfdt cramfsloadkernel " \ @@ -389,36 +388,9 @@ "default=" \ "setenv default 'run newenv; reset' && " \ "run release && saveenv; reset\0" \ - "checkboardidlist=" \ - "if test "x${boardIdListHex}" != "x"; then " \ - "IVMbidhwk=${IVM_BoardId}_${IVM_HWKey}; " \ - "found=0; " \ - "for bidhwk in "${boardIdListHex}"; do " \ - "echo trying $bidhwk ...; " \ - "if test "x$bidhwk" = "x$IVMbidhwk"; then " \ - "found=1; " \ - "echo match found for $bidhwk; " \ - "if test "x$bidhwk" != "x${boardId}_${hwKey}";then "\ - "setenv boardid ${IVM_BoardId}; " \ - "setenv boardId ${IVM_BoardId}; " \ - "setenv hwkey ${IVM_HWKey}; " \ - "setenv hwKey ${IVM_HWKey}; " \ - "echo "boardId set to ${boardId}"; " \ - "echo "hwKey set to ${hwKey}"; " \ - "saveenv; " \ - "fi; " \ - "fi; " \ - "done; " \ - "else " \ - "echo "boardIdListHex not set, not checked"; "\ - "found=1; " \ - "fi; " \ - "test "$found" = 1 \0" \ - "checkboardid=" \ - "test "x${boardId}" = "x${IVM_BoardId}" && " \ - "test "x${hwKey}" = "x${IVM_HWKey}"\0" \ "printbootargs=print bootargs\0" \ "rootfsfile="xstr(CONFIG_HOSTNAME) "/rootfsImage\0" \ + "checkboardid=km_checkbidhwk\0" \ ""
#ifndef CONFIG_KM_DEF_ENV
Dear Holger Brunck,
In message 1305266364-8583-2-git-send-email-holger.brunck@keymile.com you wrote:
Changes for v4:
Changes for v3:
Changes for v2:
- comment the code
Applied, thanks.
This is a first step to simplify the default environment. Move all the environment variables which are only needed for debugging purpose to textfiles in the scripts directory. In case of debugging these files can be loaded via tftp into RAM and set via the env import command. Other variables are identified as obsolete and were removed.
--- Changes for v3 and v4: - nothing
Changes for v2: - split up first large patch serie to three independent smaller patch series - no change in the content of this patch
board/keymile/scripts/README | 23 +++++ board/keymile/scripts/debug-arm-env.txt | 2 + board/keymile/scripts/debug-common-env.txt | 9 ++ board/keymile/scripts/debug-ppc-env.txt | 2 + include/configs/km/keymile-common.h | 128 +++------------------------- include/configs/km/km-powerpc.h | 12 +-- include/configs/km/km_arm.h | 5 +- 7 files changed, 55 insertions(+), 126 deletions(-) create mode 100644 board/keymile/scripts/README create mode 100644 board/keymile/scripts/debug-arm-env.txt create mode 100644 board/keymile/scripts/debug-common-env.txt create mode 100644 board/keymile/scripts/debug-ppc-env.txt
diff --git a/board/keymile/scripts/README b/board/keymile/scripts/README new file mode 100644 index 0000000..86c2b5a --- /dev/null +++ b/board/keymile/scripts/README @@ -0,0 +1,23 @@ +debug-common-env.txt +============================ +This file defines environment variables which are valid for powerpc boards +and for arm boards. + +addramfs: add phram device for the rootfilesysten in ram +develop: for development, laod kernel via tftp and mount rootfs via NFS +nfsargs: default arguments for nfs boot +ramfs: load rootfilesystem in RAM kernel +rootfsfile: loacation of the rootfs file for ramfs +setramfspram: compute PRAM size for ramfs target +setrootfsaddr: compute rootfilesystem address for phram +tftpkernel: load a kernel with tftp into ram +tftpramfs: load rootfs with tftp into ram + +debug-ppc-env.txt +============================ +fdt_file: location of the dtb file on the tftp server +tftpfdt: load dtb file and set fdt address + +debug-arm-env.txt +============================ +tftpfdt: for arm only a dummy variable, because we have no fdt on arm diff --git a/board/keymile/scripts/debug-arm-env.txt b/board/keymile/scripts/debug-arm-env.txt new file mode 100644 index 0000000..84498af --- /dev/null +++ b/board/keymile/scripts/debug-arm-env.txt @@ -0,0 +1,2 @@ +debug_env_common=tftpboot 0x200000 scripts/debug-common-env.txt && env import -t 0x200000 ${filesize} +tftpfdt=true diff --git a/board/keymile/scripts/debug-common-env.txt b/board/keymile/scripts/debug-common-env.txt new file mode 100644 index 0000000..1fd4b0c --- /dev/null +++ b/board/keymile/scripts/debug-common-env.txt @@ -0,0 +1,9 @@ +addramfs=setenv bootargs "${bootargs} phram.phram=rootfs${boot_bank},${rootfsaddr},${rootfssize}" +develop=setenv subbootcmds "tftpfdt tftpkernel nfsargs ${commonargs} boot " && setenv bootcmd 'run bootrunner' && setenv altbootcmd 'run bootcmd' && km_setboardid && saveenv && reset +nfsargs=setenv bootargs ubi.mtd=ubi0 root=/dev/nfs rw nfsroot=${serverip}:${rootpath} +ramfs=setenv actual_bank -1 && setenv subbootcmds "tftpfdt tftpkernel setrootfsaddr tftpramfs flashargs ${commonargs} addpanic addramfs boot " && setenv bootcmd 'run bootrunner' && setenv altbootcmd 'run bootcmd' && run setboardid && run setramfspram && run setpnvramaddr && saveenv && reset +rootfsfile=${hostname}/rootfsImage +setramfspram=setexpr value 0 + ${reservedpram} && setexpr value 0x${value} + ${rootfssize} && setexpr value 0x${value} + ${varsize} && setexpr value 0x${value} + ${pnvramsize} && setexpr value 0x${value} / 0x400 && setenv pram 0x${value} +tftpkernel=tftpboot ${kernel_addr_r} ${hostname}/uImage && setenv actual_kernel_addr ${kernel_addr_r} +tftpramfs=tftpboot ${rootfsaddr} ${hostname}/rootfsImage && setenv loadaddr +setrootfsaddr=setexpr value ${pnvramsize} - ${rootfssize} && setenv rootfsaddr 0x${value} diff --git a/board/keymile/scripts/debug-ppc-env.txt b/board/keymile/scripts/debug-ppc-env.txt new file mode 100644 index 0000000..3c06ff1 --- /dev/null +++ b/board/keymile/scripts/debug-ppc-env.txt @@ -0,0 +1,2 @@ +debug_env_common=tftpboot 0x200000 scripts/debug-common-env.txt && env import -t 0x200000 ${filesize} +tftpfdt=tftpboot ${fdt_addr_r} ${hostname}/${hostname}.dtb && setenv actual_fdt_addr ${fdt_addr_r} diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 6a5ecc6..9ad2e5b 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -169,13 +169,8 @@ "break=0; " \ "for subbootcmd in ${subbootcmds}; do " \ "if test ${break} -eq 0; then; " \ - "echo "[INFO] running \c"; " \ "print ${subbootcmd}; " \ "run ${subbootcmd} || break=1; " \ - "if test ${break} -eq 1; then; " \ - "echo "[ERR] failed \c"; " \ - "print ${subbootcmd}; " \ - "fi; " \ "fi; " \ "done\0" \ "" @@ -186,8 +181,6 @@ * - set 'bootcmd' and 'altbootcmd' * available targets: * - 'release': for a standalone system kernel/rootfs from flash - * - 'develop': for development kernel(tftp)/rootfs(NFS) - * - 'ramfs': rootfilesystem in RAM kernel(tftp)/rootfs(RAM) * * - 'commonargs': bootargs common to all targets */ @@ -201,40 +194,6 @@ "addmtdparts " \ "addbootcount " \ "\0" \ - "develop=" \ - "setenv subbootcmds "" \ - "tftpfdt tftpkernel " \ - "nfsargs ${commonargs} " \ - "printbootargs boot " \ - "" && " \ - "setenv bootcmd '" \ - "run bootrunner" \ - "' && " \ - "setenv altbootcmd '" \ - "run bootcmd" \ - "' && " \ - "run setboardid && " \ - "saveenv && " \ - "reset\0" \ - "ramfs=" \ - "setenv actual_bank -1 && " \ - "setenv subbootcmds "" \ - "tftpfdt tftpkernel " \ - "setrootfsaddr tftpramfs " \ - "flashargs ${commonargs} " \ - "addpanic addramfs " \ - "printbootargs boot " \ - "" && " \ - "setenv bootcmd '" \ - "run bootrunner" \ - "' && " \ - "setenv altbootcmd '" \ - "run bootcmd" \ - "' && " \ - "run setboardid && " \ - "run setramfspram && " \ - "saveenv && " \ - "reset\0" \ "release=" \ "setenv actual_bank ${initial_boot_bank} && " \ "setenv subbootcmds "" \ @@ -242,8 +201,7 @@ "ubiattach ubicopy " \ "cramfsloadfdt cramfsloadkernel " \ "flashargs ${commonargs} " \ - "addpanic " \ - "printbootargs boot " \ + "addpanic boot " \ "" && " \ "setenv bootcmd '" \ "run actual bootrunner; reset" \ @@ -251,8 +209,12 @@ "setenv altbootcmd '" \ "run backup bootrunner; reset" \ "' && " \ - "saveenv && " \ + "saveenv && saveenv && " \ "reset\0" \ + "debug_env=" \ + "tftp 200000 " CONFIG_KM_ARCH_DBG_FILE " && " \ + "env import -t 200000 ${filesize} && " \ + "run debug_env_common\0" \ ""
/* @@ -262,10 +224,8 @@ * - 'addip': add ip configuration * - 'addmem': limit kernel memory mem= * - 'addpanic': add kernel panic options - * - 'addramfs': add phram device for the rootfilesysten in ram * - 'addtty': add console=... * - 'addvar': add phram device for /var - * - 'nfsargs': default arguments for nfs boot * - 'flashargs': defaults arguments for flash base boot * * processor specific settings @@ -280,25 +240,15 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off\0" \ "addmem=" \ - "setenv bootargs ${bootargs} mem=0x${pnvramaddr}\0" \ + "setenv bootargs ${bootargs} mem=${pnvramaddr}\0" \ "addpanic=" \ - "setenv bootargs ${bootargs} " \ - "panic=1 panic_on_oops=1\0" \ - "addramfs=" \ - "setenv bootargs "" \ - "${bootargs} phram.phram=" \ - "rootfs${boot_bank},${rootfsaddr},${rootfssize}"\0" \ + "setenv bootargs ${bootargs} panic=1 panic_on_oops=1\0" \ "addtty=" \ "setenv bootargs ${bootargs}" \ " console=" CONFIG_KM_CONSOLE_TTY ",${baudrate}\0" \ "addvar=" \ "setenv bootargs ${bootargs} phram.phram=phvar," \ - "${varaddr},0x" xstr(CONFIG_KM_PHRAM) "\0" \ - "nfsargs=" \ - "setenv bootargs " \ - "ubi.mtd=" CONFIG_KM_UBI_LINUX_MTD_NAME " " \ - "root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ + "${varaddr}," xstr(CONFIG_KM_PHRAM) "\0" \ "flashargs=" \ "setenv bootargs " \ "ubi.mtd=" CONFIG_KM_UBI_LINUX_MTD_NAME " " \ @@ -307,71 +257,25 @@ ""
/* - * compute_addr - * - compute addresses and sizes - * - addresses are calculated form the end of memory 'memsize' - * - * - 'setramfspram': compute PRAM size for ramfs target - * - 'setrootfsaddr': compute rootfilesystem address for phram - */ -#define CONFIG_KM_DEF_ENV_COMPUTE_ADDR \ - "setboardid=" \ - "if test "x${boardId}" = "x"; then; " \ - "setenv boardId ${IVM_BoardId} && " \ - "setenv hwKey ${IVM_HWKey}; " \ - "else; " \ - "echo \\c; " \ - "fi\0" \ - "setramfspram=" \ - "setexpr value ${rootfssize} / 0x400 && " \ - "setexpr value 0x${value} + ${pram} && " \ - "setenv pram 0x${value}\0" \ - "setrootfsaddr=" \ - "setexpr value ${pnvramaddr} - ${rootfssize} && " \ - "setenv rootfsaddr 0x${value}\0" \ - "" - -/* * flash_boot * - commands for booting from flash * - * - 'cramfsaddr': address to the cramfs (in ram) * - 'cramfsloadkernel': copy kernel from a cramfs to ram * - 'ubiattach': attach ubi partition * - 'ubicopy': copy ubi volume to ram * - volume names: bootfs0, bootfs1, bootfs2, ... - * - 'ubiparition': mtd parition name for ubi * * processor specific settings * - 'cramfsloadfdt': copy fdt from a cramfs to ram */ #define CONFIG_KM_DEF_ENV_FLASH_BOOT \ - "cramfsaddr="xstr(CONFIG_KM_CRAMFS_ADDR) "\0" \ + "cramfsaddr=" xstr(CONFIG_KM_CRAMFS_ADDR) "\0" \ "cramfsloadkernel=" \ "cramfsload ${kernel_addr_r} uImage && " \ "setenv actual_kernel_addr ${kernel_addr_r}\0" \ - "ubiattach=ubi part ${ubipartition}\0" \ - "ubicopy=ubi read ${cramfsaddr} bootfs${boot_bank}\0" \ - "ubipartition=" CONFIG_KM_UBI_PARTITION_NAME "\0" \ - "" - -/* - * net_boot - * - commands for booting over the network - * - * - 'tftpkernel': load a kernel with tftp into ram - * - 'tftpramfs': load rootfs with tftp into ram - * - * processor specific settings - * - 'tftpfdt': load fdt with tftp into ram - */ -#define CONFIG_KM_DEF_ENV_NET_BOOT \ - "tftpkernel=" \ - "tftpboot ${kernel_addr_r} ${kernel_file} && " \ - "setenv actual_kernel_addr ${kernel_addr_r}\0" \ - "tftpramfs=" \ - "tftpboot ${rootfsaddr} "\"${rootfsfile}\"" && " \ - "setenv loadaddr\0" \ + "ubiattach=ubi part " CONFIG_KM_UBI_PARTITION_NAME "\0" \ + "ubicopy=ubi read "xstr(CONFIG_KM_CRAMFS_ADDR) \ + " bootfs${boot_bank}\0" \ ""
/* @@ -388,8 +292,6 @@ "default=" \ "setenv default 'run newenv; reset' && " \ "run release && saveenv; reset\0" \ - "printbootargs=print bootargs\0" \ - "rootfsfile="xstr(CONFIG_HOSTNAME) "/rootfsImage\0" \ "checkboardid=km_checkbidhwk\0" \ ""
@@ -401,17 +303,13 @@ CONFIG_KM_DEF_ENV_BOOTRUNNER \ CONFIG_KM_DEF_ENV_BOOTTARGETS \ CONFIG_KM_DEF_ENV_BOOTARGS \ - CONFIG_KM_DEF_ENV_COMPUTE_ADDR \ CONFIG_KM_DEF_ENV_FLASH_BOOT \ - CONFIG_KM_DEF_ENV_NET_BOOT \ CONFIG_KM_DEF_ENV_CONSTANTS \ "altbootcmd=run bootcmd\0" \ "bootcmd=run default\0" \ "bootlimit=2\0" \ "init=/sbin/init-overlay.sh\0" \ "kernel_addr_r="xstr(CONFIG_KM_KERNEL_ADDR) "\0" \ - "kernel_file="xstr(CONFIG_HOSTNAME) "/uImage\0" \ - "kernel_name=uImage\0" \ "load=tftpboot ${u-boot_addr_r} ${u-boot}\0" \ "mtdids=" MTDIDS_DEFAULT "\0" \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ diff --git a/include/configs/km/km-powerpc.h b/include/configs/km/km-powerpc.h index 3351609..d6db8d7 100644 --- a/include/configs/km/km-powerpc.h +++ b/include/configs/km/km-powerpc.h @@ -67,20 +67,14 @@ #define CONFIG_KM_FDT_ADDR 0x7E0000 /* 128Kbytes */
#define CONFIG_KM_DEF_ENV_CPU \ - "addbootcount=echo \\c\0" \ - "addmtdparts=echo \\c\0" \ + "addbootcount=true\0" \ + "addmtdparts=true\0" \ "boot=bootm ${actual_kernel_addr} - ${actual_fdt_addr}\0" \ "cramfsloadfdt=" \ "cramfsload ${fdt_addr_r} " \ "fdt_0x${IVM_BoardId}_0x${IVM_HWKey}.dtb && " \ "setenv actual_fdt_addr ${fdt_addr_r}\0" \ "fdt_addr_r=" xstr(CONFIG_KM_FDT_ADDR) "\0" \ - "fdt_file=" \ - xstr(CONFIG_HOSTNAME) "/" \ - xstr(CONFIG_HOSTNAME) ".dtb\0" \ - "tftpfdt=" \ - "tftpboot ${fdt_addr_r} ${fdt_file} && " \ - "setenv actual_fdt_addr ${fdt_addr_r} \0" \ "update=" \ "protect off " xstr(BOOTFLASH_START) " +${filesize} && "\ "erase " xstr(BOOTFLASH_START) " +${filesize} && " \ @@ -89,4 +83,6 @@ "protect on " xstr(BOOTFLASH_START) " +${filesize}\0" \ ""
+#define CONFIG_KM_ARCH_DBG_FILE "scripts/debug-ppc-env.txt" + #endif /* __CONFIG_KEYMILE_POWERPC_H */ diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index a38a070..aa9f1ae 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -66,12 +66,11 @@ #define CONFIG_KM_DEF_ENV_CPU \ "addmtdparts=setenv bootargs ${bootargs} ${mtdparts}\0" \ "boot=bootm ${actual_kernel_addr} - -\0" \ - "cramfsloadfdt=echo \\c\0" \ - "tftpfdt=echo \\c\0" \ + "cramfsloadfdt=true\0" \ CONFIG_KM_DEF_ENV_UPDATE \ ""
- +#define CONFIG_KM_ARCH_DBG_FILE "scripts/debug-arm-env.txt"
#define CONFIG_MD5 /* get_random_hex on krikwood needs MD5 support */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
Dear Holger Brunck,
In message 1305266364-8583-3-git-send-email-holger.brunck@keymile.com you wrote:
- nothing
Changes for v2:
Applied, thanks.
The pnvram size was used later from start scripts in linux. Therefore it was added to the default environment.
--- changes for v4: - fix small bug introduced in v2, remove "0x" which is already part of the define in the header
Changes for v3: - nothing
Changes for v2: - split up first large patch serie to three independent smaller patch series - rework the patch with inputs from W.Denk: - move variable from c-code to default env to be present in any case when linux starts
include/configs/km/keymile-common.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 9ad2e5b..f89a2ea 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -293,6 +293,7 @@ "setenv default 'run newenv; reset' && " \ "run release && saveenv; reset\0" \ "checkboardid=km_checkbidhwk\0" \ + "pnvramsize=" xstr(CONFIG_KM_PNVRAM) "\0" \ ""
Dear Holger Brunck,
In message 1305266364-8583-4-git-send-email-holger.brunck@keymile.com you wrote:
changes for v4:
Changes for v3:
- nothing
Changes for v2:
Applied, thanks.
Holger Brunck
