[U-Boot] [PATCH v3] Enable snooping on transactions from CAAM block
To enable snooping on CAAM transactions following programming is done
1. Enable core snooping (CCI interface, Core is Slave5 on CCI) This setting is also required for making the system coherent
2. CAAM IP lies behind SMMU3 in the system. Configure SMMU3 to do the following: a) Program SCR to bypass transactions with stream ID other than that of CAAM b) Program S2CR to change memroy attributes of transactions with CAAM's stream ID (0x10) to cacheable.
Signed-off-by: Ruchika Gupta ruchika.gupta@nxp.com Signed-off-by: Nitesh Narayan Lal nitesh.lal@nxp.com Signed-off-by: Aneesh Bansal aneesh.bansal@nxp.com --- Changes in v3: Modified the commit message.
Changes in v2: Avoid mixing the use of u32 and uint32_t. Using uint32_t at all places.
arch/arm/include/asm/arch-ls102xa/config.h | 1 + .../include/asm/arch-ls102xa/ls102xa_stream_id.h | 34 ++++++++++++++++++++ board/freescale/common/ls102xa_stream_id.c | 36 +++++++++++++++++++++- board/freescale/ls1021aqds/ls1021aqds.c | 4 +++ board/freescale/ls1021atwr/ls1021atwr.c | 4 +++ 5 files changed, 78 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index f066480..f14ea2f 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -38,6 +38,7 @@ #define CONFIG_SYS_LS102XA_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x02100000) #define CONFIG_SYS_LS102XA_USB1_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_LS102XA_USB1_OFFSET) +#define CONFIG_SYS_SMMU3_ADDR (CONFIG_SYS_IMMR + 0x300000)
#define CONFIG_SYS_FSL_SEC_OFFSET 0x00700000 #define CONFIG_SYS_LS102XA_USB1_OFFSET 0x07600000 diff --git a/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h b/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h index fa571b3..68e4e02 100644 --- a/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h +++ b/arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h @@ -6,6 +6,39 @@
#ifndef __FSL_LS102XA_STREAM_ID_H_ #define __FSL_LS102XA_STREAM_ID_H_ +#define CONFIG_SMMU_NSCR_OFFSET 0x400 +#define CONFIG_SMMU_SMR_OFFSET 0x800 +#define CONFIG_SMMU_S2CR_OFFSET 0xc00 + +#define SMMU_NSCR_CLIENTPD_SHIFT 0 +#define SMMU_NSCR_MTCFG_SHIFT 20 + +#define SMR_SMR_VALID_SHIFT 31 +#define SMR_ID_MASK 0x7fff +#define SMR_MASK_SHIFT 16 + +#define S2CR_WACFG_SHIFT 22 +#define S2CR_WACFG_MASK 0x3 +#define S2CR_WACFG_WRITE_ALLOCATE 0x2 + +#define S2CR_RACFG_SHIFT 20 +#define S2CR_RACFG_MASK 0x3 +#define S2CR_RACFG_READ_ALLOCATE 0x2 + +#define S2CR_TYPE_SHIFT 16 +#define S2CR_TYPE_MASK 0x3 +#define S2CR_TYPE_BYPASS 0x01 + +#define S2CR_MEM_ATTR_SHIFT 12 +#define S2CR_MEM_ATTR_MASK 0xf +#define S2CR_MEM_ATTR_CACHEABLE 0xa + +#define S2CR_MTCFG 0x00000800 + +#define S2CR_SHCFG_SHIFT 8 +#define S2CR_SHCFG_MASK 0x3 +#define S2CR_SHCFG_OUTER_CACHEABLE 0x1 +#define S2CR_SHCFG_INNER_CACHEABLE 0x2
#include <fsl_sec.h>
@@ -71,4 +104,5 @@ struct smmu_stream_id {
void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size); void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num); +void ls1021x_config_smmu3(uint32_t liodn); #endif diff --git a/board/freescale/common/ls102xa_stream_id.c b/board/freescale/common/ls102xa_stream_id.c index f434269..9ae29b8 100644 --- a/board/freescale/common/ls102xa_stream_id.c +++ b/board/freescale/common/ls102xa_stream_id.c @@ -20,7 +20,7 @@ void ls102xa_config_smmu_stream_id(struct smmu_stream_id *id, uint32_t num) void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size) { int i; - u32 liodn; + uint32_t liodn;
for (i = 0; i < size; i++) { if (tbl[i].num_ids == 2) @@ -31,3 +31,37 @@ void ls1021x_config_caam_stream_id(struct liodn_id_table *tbl, int size) out_le32((uint32_t *)(tbl[i].reg_offset), liodn); } } + +void ls1021x_config_smmu3(uint32_t liodn) +{ + uint32_t *addr; + uint32_t smr, s2cr, nscr; + + addr = (uint32_t *)(CONFIG_SYS_SMMU3_ADDR + CONFIG_SMMU_NSCR_OFFSET); + /* SMMU NSCR configuration */ + nscr = in_le32(addr); + + nscr = nscr & ~(1 << SMMU_NSCR_CLIENTPD_SHIFT | + 1 << SMMU_NSCR_MTCFG_SHIFT); + out_le32(addr, nscr); + + /* SMMU SMR configuration */ + addr = (uint32_t *)(CONFIG_SYS_SMMU3_ADDR + CONFIG_SMMU_SMR_OFFSET); + + smr = 0; + smr = smr & (~(SMR_ID_MASK << SMR_MASK_SHIFT)); + smr = smr | (1 << SMR_SMR_VALID_SHIFT) | liodn; + + out_le32(addr, smr); + + /* SMMU S2CR configuration */ + addr = (uint32_t *)(CONFIG_SYS_SMMU3_ADDR + CONFIG_SMMU_S2CR_OFFSET); + s2cr = (S2CR_WACFG_WRITE_ALLOCATE << S2CR_WACFG_SHIFT) | + (S2CR_RACFG_READ_ALLOCATE << S2CR_RACFG_SHIFT) | + (S2CR_TYPE_BYPASS << S2CR_TYPE_SHIFT) | + (S2CR_MEM_ATTR_CACHEABLE << S2CR_MEM_ATTR_SHIFT) | + S2CR_MTCFG | + (S2CR_SHCFG_OUTER_CACHEABLE << S2CR_SHCFG_SHIFT); + + out_le32(addr, s2cr); +} diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index be3358a..ca1ea61 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -481,6 +481,10 @@ int board_init(void) ARRAY_SIZE(sec_liodn_tbl)); ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id)); + /* Configure SMMU3 to make transactions with CAAM stream ID + * as cacheable + */ + ls1021x_config_smmu3(0x10);
#ifdef CONFIG_LAYERSCAPE_NS_ACCESS enable_layerscape_ns_access(); diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 8eaff5f..ae62bca 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -528,6 +528,10 @@ int board_init(void) ARRAY_SIZE(sec_liodn_tbl)); ls102xa_config_smmu_stream_id(dev_stream_id, ARRAY_SIZE(dev_stream_id)); + /* Configure SMMU3 to make transactions with CAAM stream ID + * as cacheable + */ + ls1021x_config_smmu3(0x10);
+Alison to comment on my question at the end of this email
Aneesh,
A few comments to this patch.
First, please prefix the subject with a meaningful tag. In this case, it should be armv7: ls1020a.
- Enable core snooping (CCI interface, Core is Slave5 on CCI)
- CAAM IP lies behind SMMU3 in the system. Configure SMMU3 to do the following:
Second, the commit message should not exceed 72 characters. Third, the commit message should explain why and what this patch is doing. I don't see any change related to enabling snooping on CCI in this patch.
- u32 liodn;
uint32_t liodn;
- uint32_t *addr;
- uint32_t smr, s2cr, nscr;
- addr = (uint32_t *)(CONFIG_SYS_SMMU3_ADDR + CONFIG_SMMU_NSCR_OFFSET);
- nscr = in_le32(addr);
- nscr = nscr & ~(1 << SMMU_NSCR_CLIENTPD_SHIFT |
- out_le32(addr, nscr);
- /* SMMU SMR configuration */
- addr = (uint32_t *)(CONFIG_SYS_SMMU3_ADDR + CONFIG_SMMU_SMR_OFFSET);
- smr = 0;
- smr = smr & (~(SMR_ID_MASK << SMR_MASK_SHIFT));
- smr = smr | (1 << SMR_SMR_VALID_SHIFT) | liodn;
- out_le32(addr, smr);
- /* SMMU S2CR configuration */
- addr = (uint32_t *)(CONFIG_SYS_SMMU3_ADDR + CONFIG_SMMU_S2CR_OFFSET);
- s2cr = (S2CR_WACFG_WRITE_ALLOCATE << S2CR_WACFG_SHIFT) |
S2CR_MTCFG |
- out_le32(addr, s2cr);
- /* Configure SMMU3 to make transactions with CAAM stream ID
* as cacheable
- ls1021x_config_smmu3(0x10);
* as cacheable
Alison,
Is the SMMU specific to these two boards? Shall it be moved to soc file? The same question goes with stream_id as well.
York
Hi, York,
-----Original Message----- From: york sun [mailto:york.sun@nxp.com] Sent: Tuesday, February 02, 2016 1:06 AM To: Aneesh Bansal; u-boot@lists.denx.de; Huan Wang-B18965 Cc: Ruchika Gupta; Prabhakar Kushwaha; Nitesh Lal Subject: Re: [PATCH v3] Enable snooping on transactions from CAAM block
Aneesh,
- Enable core snooping (CCI interface, Core is Slave5 on CCI) This
following:
0x02100000)
0x300000)
- u32 liodn;
uint32_t liodn;
+void ls1021x_config_smmu3(uint32_t liodn) {
- uint32_t *addr;
- smr = 0;
S2CR_MTCFG |
* as cacheable
* as cacheable
Alison,
[Alison Wang] SMMU is not specific to these two boards. It should be moved to soc file with stream_id.
Best Regards, Alison Wang
-----Original Message----- From: Huan Wang Sent: Tuesday, February 02, 2016 12:31 PM To: york sun york.sun@nxp.com; Aneesh Bansal aneesh.bansal@nxp.com; u- boot@lists.denx.de; Huan Wang-B18965 Alison.Wang@freescale.com Cc: Ruchika Gupta ruchika.gupta@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Nitesh Lal nitesh.lal@nxp.com Subject: RE: [PATCH v3] Enable snooping on transactions from CAAM block
Hi, York,
Aneesh,
the
following:
(CONFIG_SYS_IMMR +
0x02100000)
(CONFIG_SYS_IMMR +
0x300000)
- u32 liodn;
uint32_t liodn;
- uint32_t *addr;
- smr = 0;
S2CR_MTCFG |
* as cacheable
* as cacheable
Alison,
I discussed this with Alison. Alison would be sending a patch to move the existing SMMU code to soc specific file. I would be rebasing my changes on top of that patch.
Regards, Aneesh Bansal
Aneesh Bansal
Huan Wang
york sun
