[U-Boot] [PATCH] fdt_support: add entry for sec3.1 and remove tls_ssl_stream descriptor type capability for sec3.3
Add sec3.1 h/w geometry for fdt node fixups.
Also, technically, whilst SEC v3.3 h/w honours the tls_ssl_stream descriptor type, it lacks the ARC4 algorithm execution unit required to be able to execute anything meaningful with it. Change the node to agree with the documentation that declares that the sec3.3 really doesn't have such a descriptor type.
Reported-by: Haiying Wang Haiying.Wang@freescale.com Signed-off-by: Kim Phillips kim.phillips@freescale.com --- common/fdt_support.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index b6f252a..a8ac617 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -534,7 +534,8 @@ void fdt_fixup_crypto_node(void *blob, int sec_rev) { 0x0202, 1, 24, 0x04c, 0x0122003f }, /* SEC 2.2 */ { 0x0204, 4, 24, 0x07e, 0x012b0ebf }, /* SEC 2.4 */ { 0x0300, 4, 24, 0x9fe, 0x03ab0ebf }, /* SEC 3.0 */ - { 0x0303, 4, 24, 0x97c, 0x03ab0abf }, /* SEC 3.3 */ + { 0x0301, 4, 24, 0xbfe, 0x03ab0ebf }, /* SEC 3.1 */ + { 0x0303, 4, 24, 0x97c, 0x03a30abf }, /* SEC 3.3 */ }; char compat_strlist[ARRAY_SIZE(sec_rev_prop_list) * sizeof("fsl,secX.Y")];
Hi Kim, Haiying,
}; char compat_strlist[ARRAY_SIZE(sec_rev_prop_list) * sizeof("fsl,secX.Y")];{ 0x0303, 4, 24, 0x97c, 0x03a30abf }, /* SEC 3.3 */
Hmmm, we have two pieces of Freescale processor-specific fixups in fdt_support.c:
#ifdef CONFIG_HAS_FSL_DR_USB void fdt_fixup_dr_usb(void *blob, bd_t *bd) : : #endif /* CONFIG_HAS_FSL_DR_USB */
#if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) /* * update crypto node properties to a specified revision of the SEC * called with sec_rev == 0 if not on an mpc8xxxE processor */ void fdt_fixup_crypto_node(void *blob, int sec_rev) : : #endif /* defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) */
While I'm OK with the change and am willing to ack since it appears to be a small and necessary improvement to existing code, it would be better to move the Freescale specific fixups into a Freescale CPU subdirectory, probably cpu/mpc8xxx/fdt.c.
Thanks, gvb
On Sun, 25 Apr 2010 19:55:27 -0400 Jerry Van Baren gvb.uboot@gmail.com wrote:
Hi Kim, Haiying,
Hi Jerry,
thanks.
to do that properly, a merge of 83xx and 8[56]xx families' both cpu and pci code would have to be made - something that I feel is way out of scope for this patch subject.
Kim
Why can't we move fdt_fixup_crypto_node & fdt_fixup_dr_usb into arch/powerpc/cpu/mpc8xxx/fdt.c ?
- k
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- unnecessarily introducing mpc83xx-specific conditions in the mpc8xxx Makefile due to current development logistics is ugly IMHO, but it sounds like this is what the people want anyway.
Makefile | 1 + arch/powerpc/cpu/mpc8xxx/Makefile | 7 ++- arch/powerpc/cpu/mpc8xxx/fdt.c | 133 ++++++++++++++++++++++++++++++++++++- common/fdt_support.c | 129 ----------------------------------- 4 files changed, 138 insertions(+), 132 deletions(-)
diff --git a/Makefile b/Makefile index 34f10ce..50a403d 100644 --- a/Makefile +++ b/Makefile @@ -220,6 +220,7 @@ LIBS += drivers/power/libpower.a LIBS += drivers/spi/libspi.a ifeq ($(CPU),mpc83xx) LIBS += drivers/qe/qe.a +LIBS += arch/powerpc/cpu/mpc8xxx/lib8xxx.a endif ifeq ($(CPU),mpc85xx) LIBS += drivers/qe/qe.a diff --git a/arch/powerpc/cpu/mpc8xxx/Makefile b/arch/powerpc/cpu/mpc8xxx/Makefile index 481f9e5..67bb5cf 100644 --- a/arch/powerpc/cpu/mpc8xxx/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/Makefile @@ -1,5 +1,5 @@ # -# Copyright 2009 Freescale Semiconductor, Inc. +# Copyright 2009-2010 Freescale Semiconductor, Inc. # # This program is free software; you can redistribute it and/or # modify it under the terms of the GNU General Public License @@ -10,9 +10,12 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib8xxx.a
+ifneq ($(CPU),mpc83xx) COBJS-y += cpu.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o COBJS-$(CONFIG_PCI) += pci_cfg.o +endif + +COBJS-$(CONFIG_OF_LIBFDT) += fdt.o
SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index ccefaf5..79d3cdf 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -1,5 +1,5 @@ /* - * Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2009-2010 Freescale Semiconductor, Inc. * * This file is derived from arch/powerpc/cpu/mpc85xx/cpu.c and * arch/powerpc/cpu/mpc86xx/cpu.c. Basically this file contains @@ -27,6 +27,7 @@ #include <libfdt.h> #include <fdt_support.h>
+#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) void ft_fixup_num_cores(void *blob) { int off, num_cores, del_cores;
@@ -53,3 +54,133 @@ void ft_fixup_num_cores(void *blob) { debug ("deleted %d extra core entry entries from device tree\n", del_cores); } +#endif /* defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) */ + +#ifdef CONFIG_HAS_FSL_DR_USB +void fdt_fixup_dr_usb(void *blob, bd_t *bd) +{ + char *mode; + char *type; + const char *compat = "fsl-usb2-dr"; + const char *prop_mode = "dr_mode"; + const char *prop_type = "phy_type"; + int node_offset; + int err; + + mode = getenv("usb_dr_mode"); + type = getenv("usb_phy_type"); + if (!mode && !type) + return; + + node_offset = fdt_node_offset_by_compatible(blob, 0, compat); + if (node_offset < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + compat, fdt_strerror(node_offset)); + return; + } + + if (mode) { + err = fdt_setprop(blob, node_offset, prop_mode, mode, + strlen(mode) + 1); + if (err < 0) + printf("WARNING: could not set %s for %s: %s.\n", + prop_mode, compat, fdt_strerror(err)); + } + + if (type) { + err = fdt_setprop(blob, node_offset, prop_type, type, + strlen(type) + 1); + if (err < 0) + printf("WARNING: could not set %s for %s: %s.\n", + prop_type, compat, fdt_strerror(err)); + } +} +#endif /* CONFIG_HAS_FSL_DR_USB */ + +#if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) +/* + * update crypto node properties to a specified revision of the SEC + * called with sec_rev == 0 if not on an mpc8xxxE processor + */ +void fdt_fixup_crypto_node(void *blob, int sec_rev) +{ + const struct sec_rev_prop { + u32 sec_rev; + u32 num_channels; + u32 channel_fifo_len; + u32 exec_units_mask; + u32 descriptor_types_mask; + } sec_rev_prop_list [] = { + { 0x0200, 4, 24, 0x07e, 0x01010ebf }, /* SEC 2.0 */ + { 0x0201, 4, 24, 0x0fe, 0x012b0ebf }, /* SEC 2.1 */ + { 0x0202, 1, 24, 0x04c, 0x0122003f }, /* SEC 2.2 */ + { 0x0204, 4, 24, 0x07e, 0x012b0ebf }, /* SEC 2.4 */ + { 0x0300, 4, 24, 0x9fe, 0x03ab0ebf }, /* SEC 3.0 */ + { 0x0301, 4, 24, 0xbfe, 0x03ab0ebf }, /* SEC 3.1 */ + { 0x0303, 4, 24, 0x97c, 0x03a30abf }, /* SEC 3.3 */ + }; + char compat_strlist[ARRAY_SIZE(sec_rev_prop_list) * + sizeof("fsl,secX.Y")]; + int crypto_node, sec_idx, err; + char *p; + u32 val; + + /* locate crypto node based on lowest common compatible */ + crypto_node = fdt_node_offset_by_compatible(blob, -1, "fsl,sec2.0"); + if (crypto_node == -FDT_ERR_NOTFOUND) + return; + + /* delete it if not on an E-processor */ + if (crypto_node > 0 && !sec_rev) { + fdt_del_node(blob, crypto_node); + return; + } + + /* else we got called for possible uprev */ + for (sec_idx = 0; sec_idx < ARRAY_SIZE(sec_rev_prop_list); sec_idx++) + if (sec_rev_prop_list[sec_idx].sec_rev == sec_rev) + break; + + if (sec_idx == ARRAY_SIZE(sec_rev_prop_list)) { + puts("warning: unknown SEC revision number\n"); + return; + } + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].num_channels); + err = fdt_setprop(blob, crypto_node, "fsl,num-channels", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].descriptor_types_mask); + err = fdt_setprop(blob, crypto_node, "fsl,descriptor-types-mask", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].exec_units_mask); + err = fdt_setprop(blob, crypto_node, "fsl,exec-units-mask", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].channel_fifo_len); + err = fdt_setprop(blob, crypto_node, "fsl,channel-fifo-len", &val, 4); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); + + val = 0; + while (sec_idx >= 0) { + p = compat_strlist + val; + val += sprintf(p, "fsl,sec%d.%d", + (sec_rev_prop_list[sec_idx].sec_rev & 0xff00) >> 8, + sec_rev_prop_list[sec_idx].sec_rev & 0x00ff) + 1; + sec_idx--; + } + err = fdt_setprop(blob, crypto_node, "compatible", &compat_strlist, val); + if (err < 0) + printf("WARNING: could not set crypto property: %s\n", + fdt_strerror(err)); +} +#endif /* defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) */ diff --git a/common/fdt_support.c b/common/fdt_support.c index a8ac617..4d87135 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -474,135 +474,6 @@ void fdt_fixup_ethernet(void *fdt) } }
-#ifdef CONFIG_HAS_FSL_DR_USB -void fdt_fixup_dr_usb(void *blob, bd_t *bd) -{ - char *mode; - char *type; - const char *compat = "fsl-usb2-dr"; - const char *prop_mode = "dr_mode"; - const char *prop_type = "phy_type"; - int node_offset; - int err; - - mode = getenv("usb_dr_mode"); - type = getenv("usb_phy_type"); - if (!mode && !type) - return; - - node_offset = fdt_node_offset_by_compatible(blob, 0, compat); - if (node_offset < 0) { - printf("WARNING: could not find compatible node %s: %s.\n", - compat, fdt_strerror(node_offset)); - return; - } - - if (mode) { - err = fdt_setprop(blob, node_offset, prop_mode, mode, - strlen(mode) + 1); - if (err < 0) - printf("WARNING: could not set %s for %s: %s.\n", - prop_mode, compat, fdt_strerror(err)); - } - - if (type) { - err = fdt_setprop(blob, node_offset, prop_type, type, - strlen(type) + 1); - if (err < 0) - printf("WARNING: could not set %s for %s: %s.\n", - prop_type, compat, fdt_strerror(err)); - } -} -#endif /* CONFIG_HAS_FSL_DR_USB */ - -#if defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) -/* - * update crypto node properties to a specified revision of the SEC - * called with sec_rev == 0 if not on an mpc8xxxE processor - */ -void fdt_fixup_crypto_node(void *blob, int sec_rev) -{ - const struct sec_rev_prop { - u32 sec_rev; - u32 num_channels; - u32 channel_fifo_len; - u32 exec_units_mask; - u32 descriptor_types_mask; - } sec_rev_prop_list [] = { - { 0x0200, 4, 24, 0x07e, 0x01010ebf }, /* SEC 2.0 */ - { 0x0201, 4, 24, 0x0fe, 0x012b0ebf }, /* SEC 2.1 */ - { 0x0202, 1, 24, 0x04c, 0x0122003f }, /* SEC 2.2 */ - { 0x0204, 4, 24, 0x07e, 0x012b0ebf }, /* SEC 2.4 */ - { 0x0300, 4, 24, 0x9fe, 0x03ab0ebf }, /* SEC 3.0 */ - { 0x0301, 4, 24, 0xbfe, 0x03ab0ebf }, /* SEC 3.1 */ - { 0x0303, 4, 24, 0x97c, 0x03a30abf }, /* SEC 3.3 */ - }; - char compat_strlist[ARRAY_SIZE(sec_rev_prop_list) * - sizeof("fsl,secX.Y")]; - int crypto_node, sec_idx, err; - char *p; - u32 val; - - /* locate crypto node based on lowest common compatible */ - crypto_node = fdt_node_offset_by_compatible(blob, -1, "fsl,sec2.0"); - if (crypto_node == -FDT_ERR_NOTFOUND) - return; - - /* delete it if not on an E-processor */ - if (crypto_node > 0 && !sec_rev) { - fdt_del_node(blob, crypto_node); - return; - } - - /* else we got called for possible uprev */ - for (sec_idx = 0; sec_idx < ARRAY_SIZE(sec_rev_prop_list); sec_idx++) - if (sec_rev_prop_list[sec_idx].sec_rev == sec_rev) - break; - - if (sec_idx == ARRAY_SIZE(sec_rev_prop_list)) { - puts("warning: unknown SEC revision number\n"); - return; - } - - val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].num_channels); - err = fdt_setprop(blob, crypto_node, "fsl,num-channels", &val, 4); - if (err < 0) - printf("WARNING: could not set crypto property: %s\n", - fdt_strerror(err)); - - val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].descriptor_types_mask); - err = fdt_setprop(blob, crypto_node, "fsl,descriptor-types-mask", &val, 4); - if (err < 0) - printf("WARNING: could not set crypto property: %s\n", - fdt_strerror(err)); - - val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].exec_units_mask); - err = fdt_setprop(blob, crypto_node, "fsl,exec-units-mask", &val, 4); - if (err < 0) - printf("WARNING: could not set crypto property: %s\n", - fdt_strerror(err)); - - val = cpu_to_fdt32(sec_rev_prop_list[sec_idx].channel_fifo_len); - err = fdt_setprop(blob, crypto_node, "fsl,channel-fifo-len", &val, 4); - if (err < 0) - printf("WARNING: could not set crypto property: %s\n", - fdt_strerror(err)); - - val = 0; - while (sec_idx >= 0) { - p = compat_strlist + val; - val += sprintf(p, "fsl,sec%d.%d", - (sec_rev_prop_list[sec_idx].sec_rev & 0xff00) >> 8, - sec_rev_prop_list[sec_idx].sec_rev & 0x00ff) + 1; - sec_idx--; - } - err = fdt_setprop(blob, crypto_node, "compatible", &compat_strlist, val); - if (err < 0) - printf("WARNING: could not set crypto property: %s\n", - fdt_strerror(err)); -} -#endif /* defined(CONFIG_MPC83xx) || defined(CONFIG_MPC85xx) */ - /* Resize the fdt to its actual size + a bit of padding */ int fdt_resize(void *blob) {
applied to 85xx
- k
applied
I've shorten the first line of the commit to be within 80 chars.
- k
Jerry Van Baren
Kim Phillips
Kumar Gala
