[PATCH v2 0/9] xilinx: versal-net: Add support for new Versal NET SoC
I am sending support for new Xilinx/AMD SoC called Versal NET. Versal NET is very similar to origin Versal SOC. There is different register layout, some IPs have been upgraded like i3c and some other changes in different location.
Thanks, Michal
Changes in v2: - Move symbols from .h to defconfig, enable i2c mux, dm_eth_phy, squashfs and grepenv - Remove CONFIG_SYS_CBSIZE, CONFIG_BOOTP_BOOTFILESIZE, CONFIG_BOOTP_MAY_FAIL from .h file - Setup HAS_CUSTOM_SYS_INIT_SP_ADDR
Jay Buddhabhatti (4): clk: versal: Enable clock driver for Versal NET firmware: zynqmp: Add Versal NET compatible string mailbox: zynqmp: Enable ipi mailbox driver for Versal NET reset: zynqmp: Enable reset driver for Versal NET
Michal Simek (5): arm64: versal-net: Add support for Versal NET platform spi: cadence_qspi: Add support for Versal NET platform spi: zynqmp_gqspi: Add support for Versal NET arm64: versal-net: Add defconfig for Versal NET arm64: versal-net: Add support for mini configuration
Kconfig | 2 +- MAINTAINERS | 7 + arch/arm/Kconfig | 14 ++ arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 3 + arch/arm/dts/versal-net-mini.dts | 67 +++++++ arch/arm/dts/xilinx-versal-net-virt.dts | 11 ++ arch/arm/mach-versal-net/Kconfig | 43 +++++ arch/arm/mach-versal-net/Makefile | 10 ++ arch/arm/mach-versal-net/clk.c | 35 ++++ arch/arm/mach-versal-net/cpu.c | 89 +++++++++ .../mach-versal-net/include/mach/hardware.h | 31 ++++ .../mach-versal-net/include/mach/sys_proto.h | 16 ++ board/xilinx/Kconfig | 6 +- board/xilinx/versal-net/Kconfig | 9 + board/xilinx/versal-net/MAINTAINERS | 8 + board/xilinx/versal-net/Makefile | 9 + board/xilinx/versal-net/board.c | 170 ++++++++++++++++++ configs/xilinx_versal_net_mini_defconfig | 72 ++++++++ configs/xilinx_versal_net_virt_defconfig | 131 ++++++++++++++ drivers/clk/Kconfig | 2 +- drivers/clk/clk_versal.c | 1 + drivers/firmware/firmware-zynqmp.c | 1 + drivers/mailbox/Kconfig | 2 +- drivers/reset/reset-zynqmp.c | 1 + drivers/spi/Kconfig | 2 +- drivers/spi/cadence_ospi_versal.c | 3 +- drivers/spi/zynqmp_gqspi.c | 3 +- env/Kconfig | 6 +- include/configs/xilinx_versal_net.h | 134 ++++++++++++++ include/configs/xilinx_versal_net_mini.h | 21 +++ 31 files changed, 898 insertions(+), 12 deletions(-) create mode 100644 arch/arm/dts/versal-net-mini.dts create mode 100644 arch/arm/dts/xilinx-versal-net-virt.dts create mode 100644 arch/arm/mach-versal-net/Kconfig create mode 100644 arch/arm/mach-versal-net/Makefile create mode 100644 arch/arm/mach-versal-net/clk.c create mode 100644 arch/arm/mach-versal-net/cpu.c create mode 100644 arch/arm/mach-versal-net/include/mach/hardware.h create mode 100644 arch/arm/mach-versal-net/include/mach/sys_proto.h create mode 100644 board/xilinx/versal-net/Kconfig create mode 100644 board/xilinx/versal-net/MAINTAINERS create mode 100644 board/xilinx/versal-net/Makefile create mode 100644 board/xilinx/versal-net/board.c create mode 100644 configs/xilinx_versal_net_mini_defconfig create mode 100644 configs/xilinx_versal_net_virt_defconfig create mode 100644 include/configs/xilinx_versal_net.h create mode 100644 include/configs/xilinx_versal_net_mini.h
Versal NET platform is based on Versal chip which is reusing a lot of IPs. For more information about new IPs please take a look at DT which describe currently supported devices. The patch is adding architecture and board support with soc detection algorithm. Generic setting should be very similar to Versal but it will likely diverge in longer run.
Signed-off-by: Michal Simek michal.simek@amd.com ---
(no changes since v1)
Kconfig | 2 +- MAINTAINERS | 7 + arch/arm/Kconfig | 14 ++ arch/arm/Makefile | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/xilinx-versal-net-virt.dts | 11 ++ arch/arm/mach-versal-net/Kconfig | 43 +++++ arch/arm/mach-versal-net/Makefile | 10 ++ arch/arm/mach-versal-net/clk.c | 35 ++++ arch/arm/mach-versal-net/cpu.c | 89 +++++++++ .../mach-versal-net/include/mach/hardware.h | 27 +++ .../mach-versal-net/include/mach/sys_proto.h | 16 ++ board/xilinx/Kconfig | 6 +- board/xilinx/versal-net/Kconfig | 9 + board/xilinx/versal-net/MAINTAINERS | 8 + board/xilinx/versal-net/Makefile | 9 + board/xilinx/versal-net/board.c | 170 ++++++++++++++++++ env/Kconfig | 6 +- include/configs/xilinx_versal_net.h | 156 ++++++++++++++++ 19 files changed, 614 insertions(+), 7 deletions(-) create mode 100644 arch/arm/dts/xilinx-versal-net-virt.dts create mode 100644 arch/arm/mach-versal-net/Kconfig create mode 100644 arch/arm/mach-versal-net/Makefile create mode 100644 arch/arm/mach-versal-net/clk.c create mode 100644 arch/arm/mach-versal-net/cpu.c create mode 100644 arch/arm/mach-versal-net/include/mach/hardware.h create mode 100644 arch/arm/mach-versal-net/include/mach/sys_proto.h create mode 100644 board/xilinx/versal-net/Kconfig create mode 100644 board/xilinx/versal-net/MAINTAINERS create mode 100644 board/xilinx/versal-net/Makefile create mode 100644 board/xilinx/versal-net/board.c create mode 100644 include/configs/xilinx_versal_net.h
diff --git a/Kconfig b/Kconfig index 991b260182e8..4542ed7333d1 100644 --- a/Kconfig +++ b/Kconfig @@ -539,7 +539,7 @@ config PLATFORM_ELFENTRY
config STACK_SIZE hex "Define max stack size that can be used by U-Boot" - default 0x4000000 if ARCH_VERSAL || ARCH_ZYNQMP + default 0x4000000 if ARCH_VERSAL_NET || ARCH_VERSAL || ARCH_ZYNQMP default 0x200000 if MICROBLAZE default 0x1000000 help diff --git a/MAINTAINERS b/MAINTAINERS index 1a7a56335f6f..82b5e9edc29c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -628,6 +628,13 @@ F: arch/arm/mach-uniphier/ F: configs/uniphier_*_defconfig N: uniphier
+ARM VERSAL NET +M: Michal Simek michal.simek@amd.com +S: Maintained +T: git https://source.denx.de/u-boot/custodians/u-boot-microblaze.git +F: arch/arm/mach-versal-net/ +N: (?<!uni)versal-net + ARM VERSAL M: Michal Simek michal.simek@amd.com S: Maintained diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 03169eba8dd9..1829b836623b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1247,6 +1247,18 @@ config ARCH_VERSAL imply BOARD_LATE_INIT imply ENV_VARS_UBOOT_RUNTIME_CONFIG
+config ARCH_VERSAL_NET + bool "Support Xilinx Keystone Platform" + select ARM64 + select CLK + select DM + select DM_ETH if NET + select DM_MMC if MMC + select DM_SERIAL + select OF_CONTROL + imply BOARD_LATE_INIT + imply ENV_VARS_UBOOT_RUNTIME_CONFIG + config ARCH_VF610 bool "Freescale Vybrid" select CPU_V7A @@ -2296,6 +2308,8 @@ source "arch/arm/mach-zynqmp/Kconfig"
source "arch/arm/mach-versal/Kconfig"
+source "arch/arm/mach-versal-net/Kconfig" + source "arch/arm/mach-zynqmp-r5/Kconfig"
source "arch/arm/cpu/armv7/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 1f4a1d57883b..ac602aed9c9a 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -88,6 +88,7 @@ machine-$(CONFIG_ARCH_OCTEONTX) += octeontx machine-$(CONFIG_ARCH_OCTEONTX2) += octeontx2 machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_VERSAL) += versal +machine-$(CONFIG_ARCH_VERSAL_NET) += versal-net machine-$(CONFIG_ARCH_ZYNQ) += zynq machine-$(CONFIG_ARCH_ZYNQMP) += zynqmp machine-$(CONFIG_ARCH_ZYNQMP_R5) += zynqmp-r5 diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5bff2e65b76f..a141d0de0c20 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -379,6 +379,8 @@ dtb-$(CONFIG_ARCH_VERSAL) += \ versal-mini-emmc0.dtb \ versal-mini-emmc1.dtb \ xilinx-versal-virt.dtb +dtb-$(CONFIG_ARCH_VERSAL_NET) += \ + xilinx-versal-net-virt.dtb dtb-$(CONFIG_ARCH_ZYNQMP_R5) += \ zynqmp-r5.dtb dtb-$(CONFIG_AM33XX) += \ diff --git a/arch/arm/dts/xilinx-versal-net-virt.dts b/arch/arm/dts/xilinx-versal-net-virt.dts new file mode 100644 index 000000000000..c99257cb0834 --- /dev/null +++ b/arch/arm/dts/xilinx-versal-net-virt.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Empty device tree for versal-net-virt board + * + * Copyright (C) 2022, Advanced Micro Devices, Inc. + */ + +/dts-v1/; + +/ { +}; diff --git a/arch/arm/mach-versal-net/Kconfig b/arch/arm/mach-versal-net/Kconfig new file mode 100644 index 000000000000..62825e189fe6 --- /dev/null +++ b/arch/arm/mach-versal-net/Kconfig @@ -0,0 +1,43 @@ +# SPDX-License-Identifier: GPL-2.0 + +if ARCH_VERSAL_NET + +config SYS_BOARD + string "Board name" + default "versal-net" + +config SYS_VENDOR + string "Vendor name" + default "xilinx" + +config SYS_SOC + default "versal-net" + +config SYS_CONFIG_NAME + string "Board configuration name" + default "xilinx_versal_net" + help + This option contains information about board configuration name. + Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header + will be used for board configuration. + +config SYS_MEM_RSVD_FOR_MMU + bool "Reserve memory for MMU Table" + help + If defined this option is used to setup different space for + MMU table than the one which will be allocated during + relocation. + +config GICV3 + def_bool y + +config SYS_MALLOC_LEN + default 0x2000000 + +config ZYNQ_SDHCI_MAX_FREQ + default 200000000 + +source "board/xilinx/Kconfig" +source "board/xilinx/versal-net/Kconfig" + +endif diff --git a/arch/arm/mach-versal-net/Makefile b/arch/arm/mach-versal-net/Makefile new file mode 100644 index 000000000000..e12c4c0e6739 --- /dev/null +++ b/arch/arm/mach-versal-net/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (C) 2021 - 2022, Xilinx, Inc. +# Copyright (C) 2022, Advanced Micro Devices, Inc. +# +# Michal Simek michal.simek@amd.com +# + +obj-y += clk.o +obj-y += cpu.o diff --git a/arch/arm/mach-versal-net/clk.c b/arch/arm/mach-versal-net/clk.c new file mode 100644 index 000000000000..d097de7afa63 --- /dev/null +++ b/arch/arm/mach-versal-net/clk.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2016 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + */ + +#include <common.h> +#include <init.h> +#include <time.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_CLOCKS +/** + * set_cpu_clk_info - Initialize clock framework + * + * Return: 0 always. + * + * This function is called from common code after relocation and sets up the + * clock framework. The framework must not be used before this function had been + * called. + */ +int set_cpu_clk_info(void) +{ + gd->cpu_clk = get_tbclk(); + + gd->bd->bi_arm_freq = gd->cpu_clk / 1000000; + gd->bd->bi_dsp_freq = 0; + + return 0; +} +#endif diff --git a/arch/arm/mach-versal-net/cpu.c b/arch/arm/mach-versal-net/cpu.c new file mode 100644 index 000000000000..4c9b15411df2 --- /dev/null +++ b/arch/arm/mach-versal-net/cpu.c @@ -0,0 +1,89 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + */ + +#include <common.h> +#include <init.h> +#include <asm/armv8/mmu.h> +#include <asm/cache.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/cache.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define VERSAL_NET_MEM_MAP_USED 5 + +#define DRAM_BANKS CONFIG_NR_DRAM_BANKS + +/* +1 is end of list which needs to be empty */ +#define VERSAL_NET_MEM_MAP_MAX (VERSAL_NET_MEM_MAP_USED + DRAM_BANKS + 1) + +static struct mm_region versal_mem_map[VERSAL_NET_MEM_MAP_MAX] = { + { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x70000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0xf0000000UL, + .phys = 0xf0000000UL, + .size = 0x0fe00000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x400000000UL, + .phys = 0x400000000UL, + .size = 0x200000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + .virt = 0x600000000UL, + .phys = 0x600000000UL, + .size = 0x800000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0xe00000000UL, + .phys = 0xe00000000UL, + .size = 0xf200000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + } +}; + +void mem_map_fill(void) +{ + int banks = VERSAL_NET_MEM_MAP_USED; + + for (int i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + /* Zero size means no more DDR that's this is end */ + if (!gd->bd->bi_dram[i].size) + break; + + versal_mem_map[banks].virt = gd->bd->bi_dram[i].start; + versal_mem_map[banks].phys = gd->bd->bi_dram[i].start; + versal_mem_map[banks].size = gd->bd->bi_dram[i].size; + versal_mem_map[banks].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE; + banks = banks + 1; + } +} + +struct mm_region *mem_map = versal_mem_map; + +u64 get_page_table_size(void) +{ + return 0x14000; +} diff --git a/arch/arm/mach-versal-net/include/mach/hardware.h b/arch/arm/mach-versal-net/include/mach/hardware.h new file mode 100644 index 000000000000..2eb549849825 --- /dev/null +++ b/arch/arm/mach-versal-net/include/mach/hardware.h @@ -0,0 +1,27 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2016 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + */ + +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#endif + +#define PMC_TAP 0xF11A0000 + +#define PMC_TAP_IDCODE (PMC_TAP + 0) +#define PMC_TAP_VERSION (PMC_TAP + 0x4) +# define PMC_VERSION_MASK GENMASK(7, 0) +# define PS_VERSION_MASK GENMASK(15, 8) +# define RTL_VERSION_MASK GENMASK(23, 16) +# define PLATFORM_MASK GENMASK(27, 24) +# define PLATFORM_VERSION_MASK GENMASK(31, 28) +#define PMC_TAP_USERCODE (PMC_TAP + 0x8) + +enum versal_net_platform { + VERSAL_NET_SILICON = 0, + VERSAL_NET_SPP = 1, + VERSAL_NET_EMU = 2, + VERSAL_NET_QEMU = 3, +}; diff --git a/arch/arm/mach-versal-net/include/mach/sys_proto.h b/arch/arm/mach-versal-net/include/mach/sys_proto.h new file mode 100644 index 000000000000..5bba9030f2dd --- /dev/null +++ b/arch/arm/mach-versal-net/include/mach/sys_proto.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2021 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + */ + +#include <linux/build_bug.h> + +void mem_map_fill(void); + +static inline int zynqmp_mmio_write(const u32 address, const u32 mask, + const u32 value) +{ + BUILD_BUG(); + return -EINVAL; +} diff --git a/board/xilinx/Kconfig b/board/xilinx/Kconfig index 17880661736d..746a2332ad5f 100644 --- a/board/xilinx/Kconfig +++ b/board/xilinx/Kconfig @@ -42,7 +42,7 @@ endif
config XILINX_OF_BOARD_DTB_ADDR hex "Default DTB pickup address" - default 0x1000 if ARCH_VERSAL + default 0x1000 if ARCH_VERSAL || ARCH_VERSAL_NET default 0x8000 if MICROBLAZE default 0x100000 if ARCH_ZYNQ || ARCH_ZYNQMP depends on OF_BOARD || OF_SEPARATE @@ -51,10 +51,10 @@ config XILINX_OF_BOARD_DTB_ADDR
config BOOT_SCRIPT_OFFSET hex "Boot script offset" - depends on ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || MICROBLAZE + depends on ARCH_ZYNQ || ARCH_ZYNQMP || ARCH_VERSAL || ARCH_VERSAL_NET || MICROBLAZE default 0xFC0000 if ARCH_ZYNQ || MICROBLAZE default 0x3E80000 if ARCH_ZYNQMP - default 0x7F80000 if ARCH_VERSAL + default 0x7F80000 if ARCH_VERSAL || ARCH_VERSAL_NET help Specifies distro boot script offset in NAND/QSPI/NOR flash.
diff --git a/board/xilinx/versal-net/Kconfig b/board/xilinx/versal-net/Kconfig new file mode 100644 index 000000000000..8f94d2bb399a --- /dev/null +++ b/board/xilinx/versal-net/Kconfig @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (C) 2020 - 2022, Xilinx, Inc. +# Copyright (C) 2022, Advanced Micro Devices, Inc. +# + +if ARCH_VERSAL_NET + +endif diff --git a/board/xilinx/versal-net/MAINTAINERS b/board/xilinx/versal-net/MAINTAINERS new file mode 100644 index 000000000000..50120a88d6e7 --- /dev/null +++ b/board/xilinx/versal-net/MAINTAINERS @@ -0,0 +1,8 @@ +XILINX_VERSAL_NET BOARDS +M: Michal Simek michal.simek@amd.com +S: Maintained +T: git https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze.git +F: arch/arm/dts/versal-net* +F: board/xilinx/versal-net/ +F: include/configs/xilinx_versal_net* +F: configs/xilinx_versal_net* diff --git a/board/xilinx/versal-net/Makefile b/board/xilinx/versal-net/Makefile new file mode 100644 index 000000000000..2008d4e231c6 --- /dev/null +++ b/board/xilinx/versal-net/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Copyright (C) 2021 - 2022, Xilinx, Inc. +# Copyright (C) 2022, Advanced Micro Devices, Inc. +# +# Michal Simek michal.simek@amd.com +# + +obj-y := board.o diff --git a/board/xilinx/versal-net/board.c b/board/xilinx/versal-net/board.c new file mode 100644 index 000000000000..760031927f7c --- /dev/null +++ b/board/xilinx/versal-net/board.c @@ -0,0 +1,170 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + */ + +#include <common.h> +#include <cpu_func.h> +#include <fdtdec.h> +#include <init.h> +#include <log.h> +#include <malloc.h> +#include <time.h> +#include <asm/cache.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <dm/device.h> +#include <dm/uclass.h> +#include "../common/board.h" + +#include <linux/bitfield.h> +#include <debug_uart.h> +#include <generated/dt.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + printf("EL Level:\tEL%d\n", current_el()); + + return 0; +} + +static u32 platform_id, platform_version; + +char *soc_name_decode(void) +{ + char *name, *platform_name; + + switch (platform_id) { + case VERSAL_NET_SPP: + platform_name = "ipp"; + break; + case VERSAL_NET_EMU: + platform_name = "emu"; + break; + case VERSAL_NET_QEMU: + platform_name = "qemu"; + break; + default: + return NULL; + } + + /* + * --rev. are 6 chars + * max platform name is qemu which is 4 chars + * platform version number are 1+1 + * Plus 1 char for \n + */ + name = calloc(1, strlen(CONFIG_SYS_BOARD) + 13); + if (!name) + return NULL; + + sprintf(name, "%s-%s-rev%d.%d", CONFIG_SYS_BOARD, + platform_name, platform_version / 10, + platform_version % 10); + + return name; +} + +bool soc_detection(void) +{ + u32 version; + + version = readl(PMC_TAP_VERSION); + platform_id = FIELD_GET(PLATFORM_MASK, version); + + debug("idcode %x, version %x, usercode %x\n", + readl(PMC_TAP_IDCODE), version, + readl(PMC_TAP_USERCODE)); + + debug("pmc_ver %lx, ps version %lx, rtl version %lx\n", + FIELD_GET(PMC_VERSION_MASK, version), + FIELD_GET(PS_VERSION_MASK, version), + FIELD_GET(RTL_VERSION_MASK, version)); + + platform_version = FIELD_GET(PLATFORM_VERSION_MASK, version); + + if (platform_id == VERSAL_NET_SPP || + platform_id == VERSAL_NET_EMU) { + /* + * 9 is diff for + * 0 means 0.9 version + * 1 means 1.0 version + * 2 means 1.1 version + * etc, + */ + platform_version += 9; + } + + debug("Platform id: %d version: %d.%d\n", platform_id, + platform_version / 10, platform_version % 10); + + return true; +} + +int board_early_init_f(void) +{ + if (IS_ENABLED(CONFIG_DEBUG_UART)) { + /* Uart debug for sure */ + debug_uart_init(); + puts("Debug uart enabled\n"); /* or printch() */ + } + + return 0; +} + +int board_early_init_r(void) +{ + return 0; +} + +int board_late_init(void) +{ + if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { + debug("Saved variables - Skipping\n"); + return 0; + } + + if (!CONFIG_IS_ENABLED(ENV_VARS_UBOOT_RUNTIME_CONFIG)) + return 0; + + return board_late_init_xilinx(); +} + +int dram_init_banksize(void) +{ + int ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + return ret; + + mem_map_fill(); + + return 0; +} + +int dram_init(void) +{ + int ret; + + if (CONFIG_IS_ENABLED(SYS_MEM_RSVD_FOR_MMU)) + ret = fdtdec_setup_mem_size_base(); + else + ret = fdtdec_setup_mem_size_base_lowest(); + + if (ret) + return -EINVAL; + + return 0; +} + +void reset_cpu(void) +{ +} diff --git a/env/Kconfig b/env/Kconfig index 5329f7585be5..24111dfaf47b 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -558,7 +558,7 @@ config ENV_OFFSET default 0xF0000 if ARCH_SUNXI default 0xE0000 if ARCH_ZYNQ default 0x1E00000 if ARCH_ZYNQMP - default 0x7F40000 if ARCH_VERSAL + default 0x7F40000 if ARCH_VERSAL || ARCH_VERSAL_NET default 0 if ARC default 0x140000 if ARCH_AT91 default 0x260000 if ARCH_OMAP2PLUS @@ -583,7 +583,7 @@ config ENV_SIZE default 0x10000 if ARCH_SUNXI default 0x8000 if ARCH_ROCKCHIP && ENV_IS_IN_MMC default 0x2000 if ARCH_ROCKCHIP && ENV_IS_IN_SPI_FLASH - default 0x8000 if ARCH_ZYNQMP || ARCH_VERSAL + default 0x8000 if ARCH_ZYNQMP || ARCH_VERSAL || ARCH_VERSAL_NET default 0x4000 if ARC default 0x1f000 help @@ -593,7 +593,7 @@ config ENV_SECT_SIZE hex "Environment Sector-Size" depends on ENV_IS_IN_FLASH || ENV_IS_IN_SPI_FLASH default 0x2000 if ARCH_ROCKCHIP - default 0x40000 if ARCH_ZYNQMP || ARCH_VERSAL + default 0x40000 if ARCH_ZYNQMP || ARCH_VERSAL || ARCH_VERSAL_NET default 0x20000 if ARCH_ZYNQ || ARCH_OMAP2PLUS || ARCH_AT91 default 0x20000 if MICROBLAZE && ENV_IS_IN_SPI_FLASH default 0x10000 if ARCH_SUNXI && ENV_IS_IN_SPI_FLASH diff --git a/include/configs/xilinx_versal_net.h b/include/configs/xilinx_versal_net.h new file mode 100644 index 000000000000..d9286e7f5017 --- /dev/null +++ b/include/configs/xilinx_versal_net.h @@ -0,0 +1,156 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Configuration for Xilinx Versal NET + * Copyright (C) 2016 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + * + * Based on Configuration for Xilinx ZynqMP + */ + +#ifndef __XILINX_VERSAL_NET_H +#define __XILINX_VERSAL_NET_H + +#define CONFIG_REMAKE_ELF + +/* FIXME this is causing issue at least on IPP */ +/* #define CONFIG_ARMV8_SWITCH_TO_EL1 */ + +/* Generic Interrupt Controller Definitions */ +#define GICD_BASE 0xF9000000 +#define GICR_BASE 0xF9060000 + +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE + +/* Serial setup */ +#define CONFIG_CPU_ARMV8 + +#define CONFIG_SYS_BAUDRATE_TABLE \ + { 4800, 9600, 19200, 38400, 57600, 115200 } + +/* BOOTP options */ +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_MAY_FAIL + +/* Monitor Command Prompt */ +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_MAXARGS 64 + +#if defined(CONFIG_CMD_DFU) +#define DFU_DEFAULT_POLL_TIMEOUT 300 +#define CONFIG_THOR_RESET_OFF +#define DFU_ALT_INFO_RAM \ + "dfu_ram_info=" \ + "setenv dfu_alt_info " \ + "Image ram 80000 $kernel_size_r\\;" \ + "system.dtb ram $fdt_addr_r $fdt_size_r\0" \ + "dfu_ram=run dfu_ram_info && dfu 0 ram 0\0" \ + "thor_ram=run dfu_ram_info && thordown 0 ram 0\0" + +#define DFU_ALT_INFO \ + DFU_ALT_INFO_RAM +#endif + +#if !defined(DFU_ALT_INFO) +# define DFU_ALT_INFO +#endif + +/* Ethernet driver */ +#if defined(CONFIG_ZYNQ_GEM) +# define CONFIG_NET_MULTI +# define CONFIG_SYS_FAULT_ECHO_LINK_DOWN +# define PHY_ANEG_TIMEOUT 20000 +#endif + +#define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024) + +#define CONFIG_CLOCKS + +#define ENV_MEM_LAYOUT_SETTINGS \ + "fdt_addr_r=0x40000000\0" \ + "fdt_size_r=0x400000\0" \ + "pxefile_addr_r=0x10000000\0" \ + "kernel_addr_r=0x18000000\0" \ + "kernel_size_r=0x10000000\0" \ + "scriptaddr=0x20000000\0" \ + "ramdisk_addr_r=0x02100000\0" \ + "script_size_f=0x80000\0" + +#if defined(CONFIG_MMC_SDHCI_ZYNQ) +# define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) func(MMC, mmc, 1) +#else +# define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#if defined(CONFIG_CMD_PXE) && defined(CONFIG_CMD_DHCP) +# define BOOT_TARGET_DEVICES_PXE(func) func(PXE, pxe, na) +#else +# define BOOT_TARGET_DEVICES_PXE(func) +#endif + +#if defined(CONFIG_CMD_DHCP) +# define BOOT_TARGET_DEVICES_DHCP(func) func(DHCP, dhcp, na) +#else +# define BOOT_TARGET_DEVICES_DHCP(func) +#endif + +#if defined(CONFIG_ZYNQMP_GQSPI) || defined(CONFIG_CADENCE_OSPI_VERSAL_NET) +# define BOOT_TARGET_DEVICES_XSPI(func) func(XSPI, xspi, 0) +#else +# define BOOT_TARGET_DEVICES_XSPI(func) +#endif + +#define BOOTENV_DEV_XSPI(devtypeu, devtypel, instance) \ + "bootcmd_xspi0=sf probe 0 0 0 && " \ + "sf read $scriptaddr $script_offset_f $script_size_f && " \ + "echo XSPI: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; echo XSPI: SCRIPT FAILED: continuing...;\0" + +#define BOOTENV_DEV_NAME_XSPI(devtypeu, devtypel, instance) \ + "xspi0 " + +#define BOOT_TARGET_DEVICES_JTAG(func) func(JTAG, jtag, na) + +#define BOOTENV_DEV_JTAG(devtypeu, devtypel, instance) \ + "bootcmd_jtag=echo JTAG: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; echo JTAG: SCRIPT FAILED: continuing...;\0" + +#define BOOTENV_DEV_NAME_JTAG(devtypeu, devtypel, instance) \ + "jtag " + +#define BOOT_TARGET_DEVICES_DFU_USB(func) func(DFU_USB, dfu_usb, 0) + +#define BOOTENV_DEV_DFU_USB(devtypeu, devtypel, instance) \ + "bootcmd_dfu_usb=setenv dfu_alt_info boot.scr ram $scriptaddr " \ + "$script_size_f; dfu 0 ram 0 && " \ + "echo DFU: Trying to boot script at ${scriptaddr} && " \ + "source ${scriptaddr}; " \ + "echo DFU: SCRIPT FAILED: continuing...;\0" + +#define BOOTENV_DEV_NAME_DFU_USB(devtypeu, devtypel, instance) \ + "" + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_JTAG(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_XSPI(func) \ + BOOT_TARGET_DEVICES_DFU_USB(func) \ + BOOT_TARGET_DEVICES_PXE(func) \ + BOOT_TARGET_DEVICES_DHCP(func) + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#ifndef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV \ + DFU_ALT_INFO +#endif + +#endif /* __XILINX_VERSAL_NET_H */
Trivial changes to support cadence ospi driver for Versal NET platform. Also avoid ospi flash reset for now.
arch/arm/mach-versal-net/include/mach/hardware.h | 4 ++++ drivers/spi/Kconfig | 2 +- drivers/spi/cadence_ospi_versal.c | 3 ++- 3 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-versal-net/include/mach/hardware.h b/arch/arm/mach-versal-net/include/mach/hardware.h index 2eb549849825..808ce48fd148 100644 --- a/arch/arm/mach-versal-net/include/mach/hardware.h +++ b/arch/arm/mach-versal-net/include/mach/hardware.h @@ -25,3 +25,7 @@ enum versal_net_platform { VERSAL_NET_EMU = 2, VERSAL_NET_QEMU = 3, }; + +#define VERSAL_SLCR_BASEADDR 0xF1060000 +#define VERSAL_AXI_MUX_SEL (VERSAL_SLCR_BASEADDR + 0x504) +#define VERSAL_OSPI_LINEAR_MODE BIT(1) diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index ac91d8225821..240ff212a39f 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -148,7 +148,7 @@ config CQSPI_REF_CLK
config CADENCE_OSPI_VERSAL bool "Configure Versal OSPI" - depends on ARCH_VERSAL && CADENCE_QSPI + depends on (ARCH_VERSAL || ARCH_VERSAL_NET) && CADENCE_QSPI imply DM_GPIO help This option is used to enable Versal OSPI DMA operations which diff --git a/drivers/spi/cadence_ospi_versal.c b/drivers/spi/cadence_ospi_versal.c index a25c50bc5081..a9547a820031 100644 --- a/drivers/spi/cadence_ospi_versal.c +++ b/drivers/spi/cadence_ospi_versal.c @@ -130,6 +130,7 @@ int cadence_qspi_apb_wait_for_dma_cmplt(struct cadence_spi_priv *priv) #if defined(CONFIG_DM_GPIO) int cadence_qspi_versal_flash_reset(struct udevice *dev) { +#ifndef CONFIG_ARCH_VERSAL_NET struct gpio_desc gpio; u32 reset_gpio; int ret; @@ -165,7 +166,7 @@ int cadence_qspi_versal_flash_reset(struct udevice *dev) /* Set value 1 to pin */ dm_gpio_set_value(&gpio, 1); udelay(1); - +#endif return 0; } #else
Add support for Versal NET platform.
drivers/spi/zynqmp_gqspi.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/zynqmp_gqspi.c b/drivers/spi/zynqmp_gqspi.c index 4e718c545c64..d3cc8554b8fb 100644 --- a/drivers/spi/zynqmp_gqspi.c +++ b/drivers/spi/zynqmp_gqspi.c @@ -308,7 +308,8 @@ void zynqmp_qspi_set_tapdelay(struct udevice *bus, u32 baudrateval) debug("%s, req_hz:%d, clk_rate:%d, baudrateval:%d\n", __func__, reqhz, clk_rate, baudrateval);
- if (!IS_ENABLED(CONFIG_ARCH_VERSAL)) { + if (!(IS_ENABLED(CONFIG_ARCH_VERSAL) || + IS_ENABLED(CONFIG_ARCH_VERSAL_NET))) { if (reqhz <= GQSPI_FREQ_40MHZ) { tapdlybypass = TAP_DLY_BYPASS_LQSPI_RX_VALUE << TAP_DLY_BYPASS_LQSPI_RX_SHIFT;
Add support for Versal NET compatible string in clock driver.
Signed-off-by: Jay Buddhabhatti jay.buddhabhatti@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
drivers/clk/Kconfig | 2 +- drivers/clk/clk_versal.c | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index fd9e1a80c6aa..09aa97ee8c0e 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -184,7 +184,7 @@ config CLK_VERSACLOCK
config CLK_VERSAL bool "Enable clock driver support for Versal" - depends on ARCH_VERSAL + depends on (ARCH_VERSAL || ARCH_VERSAL_NET) select ZYNQMP_FIRMWARE help This clock driver adds support for clock realted settings for diff --git a/drivers/clk/clk_versal.c b/drivers/clk/clk_versal.c index a9dd57b098fe..b2f62061cea2 100644 --- a/drivers/clk/clk_versal.c +++ b/drivers/clk/clk_versal.c @@ -739,6 +739,7 @@ static struct clk_ops versal_clk_ops = {
static const struct udevice_id versal_clk_ids[] = { { .compatible = "xlnx,versal-clk" }, + { .compatible = "xlnx,versal-net-clk" }, { } };
Add compatible string for Versal NET.
drivers/firmware/firmware-zynqmp.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 76ddc6b4f404..d8e0d79c5744 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -370,6 +370,7 @@ int __maybe_unused xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, static const struct udevice_id zynqmp_firmware_ids[] = { { .compatible = "xlnx,zynqmp-firmware" }, { .compatible = "xlnx,versal-firmware"}, + { .compatible = "xlnx,versal-net-firmware"}, { } };
Enable mailbox configs for Versal NET.
drivers/mailbox/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mailbox/Kconfig b/drivers/mailbox/Kconfig index acbdce11b7c7..47f24e0a02e0 100644 --- a/drivers/mailbox/Kconfig +++ b/drivers/mailbox/Kconfig @@ -54,7 +54,7 @@ config K3_SEC_PROXY
config ZYNQMP_IPI bool "Xilinx ZynqMP IPI controller support" - depends on DM_MAILBOX && (ARCH_ZYNQMP || ARCH_VERSAL) + depends on DM_MAILBOX && (ARCH_ZYNQMP || ARCH_VERSAL || ARCH_VERSAL_NET) help This enables support for the Xilinx ZynqMP Inter Processor Interrupt communication controller.
Enable zynqmp reset driver for Versal NET.
drivers/reset/reset-zynqmp.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/reset/reset-zynqmp.c b/drivers/reset/reset-zynqmp.c index 52c08c4722da..87b4df5bf81a 100644 --- a/drivers/reset/reset-zynqmp.c +++ b/drivers/reset/reset-zynqmp.c @@ -80,6 +80,7 @@ const struct reset_ops zynqmp_reset_ops = { static const struct udevice_id zynqmp_reset_ids[] = { { .compatible = "xlnx,zynqmp-reset" }, { .compatible = "xlnx,versal-reset" }, + { .compatible = "xlnx,versal-net-reset" }, { } };
Use one defconfig for supporting multiple different platforms. DTB reselection is enabled to choose DT based on SOC detection.
configs/xilinx_versal_net_virt_defconfig | 131 +++++++++++++++++++++++ include/configs/xilinx_versal_net.h | 28 +---- 2 files changed, 134 insertions(+), 25 deletions(-) create mode 100644 configs/xilinx_versal_net_virt_defconfig
diff --git a/configs/xilinx_versal_net_virt_defconfig b/configs/xilinx_versal_net_virt_defconfig new file mode 100644 index 000000000000..4a9910b7c4fa --- /dev/null +++ b/configs/xilinx_versal_net_virt_defconfig @@ -0,0 +1,131 @@ +CONFIG_ARM=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_SYS_INIT_SP_BSS_OFFSET=1572864 +CONFIG_ARCH_VERSAL_NET=y +CONFIG_SYS_TEXT_BASE=0x8000000 +CONFIG_SYS_MALLOC_F_LEN=0x100000 +CONFIG_DEFAULT_DEVICE_TREE="xilinx-versal-net-virt" +CONFIG_SYS_PROMPT="Versal NET> " +CONFIG_CMD_FRU=y +CONFIG_SYS_LOAD_ADDR=0x8000000 +CONFIG_SYS_MEMTEST_START=0x00000000 +CONFIG_SYS_MEMTEST_END=0x00001000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_BOOTDELAY=5 +CONFIG_USE_PREBOOT=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_CLOCKS=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_PBSIZE=2073 +CONFIG_SYS_BOOTM_LEN=0x6400000 +CONFIG_CMD_BOOTMENU=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_DM=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_USB=y +CONFIG_BOOTP_MAY_FAIL=y +CONFIG_BOOTP_BOOTFILESIZE=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_SQUASHFS=y +CONFIG_CMD_MTDPARTS=y +CONFIG_CMD_UBI=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_BOARD=y +CONFIG_DTB_RESELECT=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_IP_DEFRAG=y +CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y +CONFIG_TFTP_BLOCKSIZE=4096 +CONFIG_CLK_VERSAL=y +CONFIG_DFU_RAM=y +CONFIG_ZYNQ_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_CADENCE=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_DM_MAILBOX=y +CONFIG_ZYNQMP_IPI=y +CONFIG_MISC=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x0 +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_ZYNQ_SDHCI_MIN_FREQ=100000 +CONFIG_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHY_MARVELL=y +CONFIG_PHY_NATSEMI=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_VITESSE=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH_PHY=y +CONFIG_PHY_GIGE=y +CONFIG_XILINX_AXIEMAC=y +CONFIG_ZYNQ_GEM=y +CONFIG_POWER_DOMAIN=y +CONFIG_ZYNQMP_POWER_DOMAIN=y +CONFIG_DM_RESET=y +CONFIG_RESET_ZYNQMP=y +CONFIG_ARM_DCC=y +CONFIG_PL01X_SERIAL=y +CONFIG_XILINX_UARTLITE=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_CADENCE_OSPI_VERSAL=y +CONFIG_ZYNQ_SPI=y +CONFIG_ZYNQMP_GQSPI=y +CONFIG_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_THOR=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/include/configs/xilinx_versal_net.h b/include/configs/xilinx_versal_net.h index d9286e7f5017..0ccd38b7e692 100644 --- a/include/configs/xilinx_versal_net.h +++ b/include/configs/xilinx_versal_net.h @@ -12,8 +12,6 @@ #ifndef __XILINX_VERSAL_NET_H #define __XILINX_VERSAL_NET_H
-#define CONFIG_REMAKE_ELF - /* FIXME this is causing issue at least on IPP */ /* #define CONFIG_ARMV8_SWITCH_TO_EL1 */
@@ -21,26 +19,10 @@ #define GICD_BASE 0xF9000000 #define GICR_BASE 0xF9060000
-#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE - /* Serial setup */ -#define CONFIG_CPU_ARMV8 - #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
-/* BOOTP options */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_MAY_FAIL - -/* Monitor Command Prompt */ -/* Console I/O Buffer Size */ -#define CONFIG_SYS_CBSIZE 2048 -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -#define CONFIG_SYS_MAXARGS 64 - #if defined(CONFIG_CMD_DFU) #define DFU_DEFAULT_POLL_TIMEOUT 300 #define CONFIG_THOR_RESET_OFF @@ -62,21 +44,17 @@
/* Ethernet driver */ #if defined(CONFIG_ZYNQ_GEM) -# define CONFIG_NET_MULTI -# define CONFIG_SYS_FAULT_ECHO_LINK_DOWN -# define PHY_ANEG_TIMEOUT 20000 +# define PHY_ANEG_TIMEOUT 20000 #endif
-#define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024) - -#define CONFIG_CLOCKS - #define ENV_MEM_LAYOUT_SETTINGS \ "fdt_addr_r=0x40000000\0" \ "fdt_size_r=0x400000\0" \ "pxefile_addr_r=0x10000000\0" \ "kernel_addr_r=0x18000000\0" \ "kernel_size_r=0x10000000\0" \ + "kernel_comp_addr_r=0x30000000\0" \ + "kernel_comp_size=0x3C00000\0" \ "scriptaddr=0x20000000\0" \ "ramdisk_addr_r=0x02100000\0" \ "script_size_f=0x80000\0"
Versal NET mini configuration is designed for running memory test. Current output is on DCC but changing serial0 alias to pl011 will move console to serial port.
Changes in v2: - Remove CONFIG_SYS_CBSIZE, CONFIG_BOOTP_BOOTFILESIZE, CONFIG_BOOTP_MAY_FAIL from .h file - Setup HAS_CUSTOM_SYS_INIT_SP_ADDR
arch/arm/dts/Makefile | 1 + arch/arm/dts/versal-net-mini.dts | 67 ++++++++++++++++++++++ configs/xilinx_versal_net_mini_defconfig | 72 ++++++++++++++++++++++++ include/configs/xilinx_versal_net_mini.h | 21 +++++++ 4 files changed, 161 insertions(+) create mode 100644 arch/arm/dts/versal-net-mini.dts create mode 100644 configs/xilinx_versal_net_mini_defconfig create mode 100644 include/configs/xilinx_versal_net_mini.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a141d0de0c20..4ad526d565c9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -380,6 +380,7 @@ dtb-$(CONFIG_ARCH_VERSAL) += \ versal-mini-emmc1.dtb \ xilinx-versal-virt.dtb dtb-$(CONFIG_ARCH_VERSAL_NET) += \ + versal-net-mini.dtb \ xilinx-versal-net-virt.dtb dtb-$(CONFIG_ARCH_ZYNQMP_R5) += \ zynqmp-r5.dtb diff --git a/arch/arm/dts/versal-net-mini.dts b/arch/arm/dts/versal-net-mini.dts new file mode 100644 index 000000000000..8c29a6ed6bfe --- /dev/null +++ b/arch/arm/dts/versal-net-mini.dts @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * dts file for Xilinx Versal NET + * + * Copyright (C) 2021 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> + +/ { + compatible = "xlnx,versal-net-mini"; + model = "Xilinx Versal NET MINI"; + #address-cells = <2>; + #size-cells = <2>; + + memory: memory@0 { + reg = <0 0xBBF00000 0 0x100000>, <0 0 0 0x80000000>; + device_type = "memory"; + }; + + aliases { + /* serial0 = &serial0; */ + serial0 = &dcc; + }; + + chosen { + stdout-path = "serial0:115200"; + }; + + clk1: clk1 { + u-boot,dm-pre-reloc; + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <1000000>; + }; + + dcc: dcc { + compatible = "arm,dcc"; + status = "okay"; + u-boot,dm-pre-reloc; + }; + + amba: axi { + compatible = "simple-bus"; + u-boot,dm-pre-reloc; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + serial0: serial@f1920000 { + u-boot,dm-pre-reloc; + compatible = "arm,pl011", "arm,primecell"; + reg = <0 0xf1920000 0 0x1000>; + reg-io-width = <4>; + clock-names = "uartclk", "apb_pclk"; + clocks = <&clk1>, <&clk1>; + clock = <1000000>; + current-speed = <115200>; + skip-init; + }; + }; +}; diff --git a/configs/xilinx_versal_net_mini_defconfig b/configs/xilinx_versal_net_mini_defconfig new file mode 100644 index 000000000000..e8fa08e3ef0d --- /dev/null +++ b/configs/xilinx_versal_net_mini_defconfig @@ -0,0 +1,72 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_versal_net_mini" +CONFIG_SYS_ICACHE_OFF=y +# CONFIG_ARM64_CRC32 is not set +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_VERSAL_NET=y +CONFIG_SYS_TEXT_BASE=0xBBF10000 +CONFIG_SYS_MALLOC_LEN=0x20000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=3 +CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="versal-net-mini" +CONFIG_SYS_PROMPT="Versal NET> " +CONFIG_SYS_MEM_RSVD_FOR_MMU=y +# CONFIG_PSCI_RESET is not set +CONFIG_SYS_LOAD_ADDR=0x8000000 +CONFIG_SYS_MEMTEST_START=0x00000000 +CONFIG_SYS_MEMTEST_END=0x00001000 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xBBF10000 +# CONFIG_EXPERT is not set +# CONFIG_LEGACY_IMAGE_FORMAT is not set +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +# CONFIG_AUTOBOOT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +# CONFIG_CMD_SLEEP is not set +CONFIG_OF_EMBED=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_GPIO is not set +# CONFIG_I2C is not set +# CONFIG_INPUT is not set +# CONFIG_MMC is not set +# CONFIG_POWER is not set +CONFIG_ARM_DCC=y +CONFIG_PL01X_SERIAL=y +# CONFIG_GZIP is not set diff --git a/include/configs/xilinx_versal_net_mini.h b/include/configs/xilinx_versal_net_mini.h new file mode 100644 index 000000000000..1939832a848e --- /dev/null +++ b/include/configs/xilinx_versal_net_mini.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Configuration for Xilinx Versal NET MINI configuration + * + * Copyright (C) 2018 - 2022, Xilinx, Inc. + * Copyright (C) 2022, Advanced Micro Devices, Inc. + * + * Michal Simek michal.simek@amd.com + */ + +#ifndef __CONFIG_VERSAL_NET_MINI_H +#define __CONFIG_VERSAL_NET_MINI_H + +#define CONFIG_EXTRA_ENV_SETTINGS + +#include <configs/xilinx_versal_net.h> + +/* Undef unneeded configs */ +#undef CONFIG_EXTRA_ENV_SETTINGS + +#endif /* __CONFIG_VERSAL_NET_MINI_H */
Thanks, Michal
Changes in v2:
Applied. M
Michal Simek
