[U-Boot] what is the rationale for 900+ lines duplicated in common/dlmalloc.c and include/malloc.h?
just noticed, in common/dlmalloc.c, the sizable chunk:
#if 0 /* Moved to malloc.h */ /* ---------- To make a malloc.h, start cutting here ------------ */
... several hundred lines ...
#ifdef __cplusplus }; /* end of extern "C" */ #endif
/* ---------- To make a malloc.h, end cutting here ------------ */ #endif /* 0 */ /* Moved to malloc.h */
given that those lines appear to be duplicated in malloc.h, what is the purpose of them still being in dlmalloc.c? i'm just curious.
rday
#if 0 /* Moved to malloc.h */ /* ---------- To make a malloc.h, start cutting here ------------ */ ... several hundred lines ... #ifdef __cplusplus }; /* end of extern "C" */ #endif /* ---------- To make a malloc.h, end cutting here ------------ */ #endif /* 0 */ /* Moved to malloc.h */
Good point. Something that could probably be cleaned up.
i can submit a patch for that ... i can either remove the "if 0" stuff in its entirety, or leave a short comment to the effect that what was here has now been moved, if you think it's worth it. pick one, and i'll put together the patch.
rday
I would remove all of it. If we ever re-sync with upstream on that file it'll still be obvious what we did.
Robert P. J. Day
