[PATCH 1/1] tools: imx8m_image: fix warning message
When a firmware file is missing the warning message doesn't indicate the firmware file name because '$tmp' var doesn't exist. Fix the warning message and while at it reduce the if/else statement.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- tools/imx8m_image.sh | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/tools/imx8m_image.sh b/tools/imx8m_image.sh index 4959f9c835..ba60104443 100755 --- a/tools/imx8m_image.sh +++ b/tools/imx8m_image.sh @@ -14,10 +14,8 @@ for f in $blobs; do continue fi
- if [ -f $f ]; then - continue - else - echo "WARNING '$tmp' not found, resulting binary is not-functional" >&2 + if [ ! -f $f ]; then + echo "WARNING '$f' not found, resulting binary is not-functional" >&2 exit 1 fi done
Thanks for fixing my previous patch.
Fixes: 162c72c80445 ("tools: imx8m_image: Change source path for DDR firmware to build dir")
Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de
continue
- else
- if [ ! -f $f ]; then
exit 1 fi doneecho "WARNING '$f' not found, resulting binary is not-functional" >&2
When a firmware file is missing the warning message doesn't indicate the firmware file name because '$tmp' var doesn't exist. Fix the warning message and while at it reduce the if/else statement. Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de
Best regards, Stefano Babic
sbabic@denx.de
Schrempf Frieder
Sébastien Szymanski
