[PATCH 2/8] km/ls102xa: add support for u-boot POST memory test
From production view this is standard test executed during production on
all linux based foxmc cards. On CENT2 HW defined memory region is zero means that some DDR accesses are done by memory_post_dataline and memory_post_addrline but pattern tests are skipped that's why mem_regions is fast there.
On ls102x for the complete DDR region of 1GiB memory_regions_post_test takes approx. 4min and this is too much for production, so this patch defines only 1MiB region as compromise.
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com --- board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c | 34 +++++++++++++++++++++++++ include/configs/km/pg-wcom-ls102xa.h | 4 +++ 2 files changed, 38 insertions(+)
diff --git a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c index 69b5d21..97915f9 100644 --- a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c +++ b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c @@ -141,6 +141,40 @@ int ft_board_setup(void *blob, struct bd_info *bd) return 0; }
+#if defined(CONFIG_POST) +int post_hotkeys_pressed(void) +{ + /* DIC26_SELFTEST: GPRTA0, GPA0 */ + qrio_gpio_direction_input(QRIO_GPIO_A, 0); + return qrio_get_gpio(QRIO_GPIO_A, 0); +} + +ulong post_word_load(void) +{ + /* POST word is located at the beginning of reserved physical RAM */ + void *addr = (void *)(CONFIG_SYS_SDRAM_BASE + + gd->ram_size - CONFIG_KM_RESERVED_PRAM + 8); + return in_le32(addr); +} + +void post_word_store(ulong value) +{ + /* POST word is located at the beginning of reserved physical RAM */ + void *addr = (void *)(CONFIG_SYS_SDRAM_BASE + + gd->ram_size - CONFIG_KM_RESERVED_PRAM + 8); + out_le32(addr, value); +} + +int arch_memory_test_prepare(u32 *vstart, u32 *size, phys_addr_t *phys_offset) +{ + /* Define only 1MiB range for mem_regions at the middle of the RAM */ + /* For 1GiB range mem_regions takes approx. 4min */ + *vstart = CONFIG_SYS_SDRAM_BASE + (gd->ram_size >> 1); + *size = 1 << 20; + return 0; +} +#endif + u8 flash_read8(void *addr) { return __raw_readb(addr + 1); diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 3d7519c..35bfa45 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -43,6 +43,10 @@ #define CONFIG_SYS_SPD_BUS_NUM 0 #define SPD_EEPROM_ADDRESS 0x54
+/* POST memory regions test */ +#define CONFIG_POST (CONFIG_SYS_POST_MEM_REGIONS) +#define CONFIG_POST_EXTERNAL_WORD_FUNCS + /* * IFC Definitions */
